PDA
View Full Version : Performance & Maintenance
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86
  1. oil sending unit
  2. 1JZ R154 Bellhousing question
  3. 2jzgte swap not getting spark or fuel
  4. how do I get back seat out of my sc
  5. ST92 300 1jz STRANGE PROBLEM! Car stalling while driving please help!
  6. SC300 2JZGTE VVTI harness question. Help.
  7. Warm weather low idle problem still persists.
  8. rough ride at about 45mph
  9. Strange fuel odor coming from my 92 sc400 while driving
  10. Dieseling
  11. Too much coolant...
  12. turbo coolant lines
  13. NA-T oil filter mount
  14. Who can rebuild an SC400 power steering pump well and inexpensively?
  15. How to choose the right map sensor
  16. Turbo size?!
  17. replaced knock sensors, still throwing knock sensor code (SC400)
  18. Testimony of e-bay throttle body?
  19. loss of power running rough
  20. SC400 Driveshaft Guibo Flex Disc
  21. White smoke coming from middle of car??
  22. 98 SC400 Hydraulic Pump
  23. 92 sc300 code 22 and 14
  24. Need Help !
  25. sc400 diff on an sc300??
  26. Coolant temp sensor replaced NOW IT'S WORSE!!
  27. Coolant temp sensor different on Manual?93 SC300 5spd
  28. Name that hose.... I broke
  29. Battery Relocate Question
  30. 95 sc300 2jzge vvti swap
  31. sc400 manual swap clutch not working
  32. is300 vvti 2jz into sc
  33. dinging noise
  34. Do I need to use RTV wen putting intake manifold on (1uzfe)
  35. issues with 95 sc400
  36. will this downpipe work for nonturbo GE?
  37. Boost & Fuel Cut Defenders - Educate me?
  38. best reman p/s pump!?
  39. r12 vs 134a A/C
  40. Bowl full of spaghetti- I mean unknown vacuum lines.
  41. Flasher relay help!
  42. need help/advice.
  43. Best clutch for street SC300 NA-T 400 lb/ft torque?
  44. SC400 header options...
  45. car stalling
  46. HOW TO: Replace center support bearing and remove driveshaft.
  47. Sc 300/400 headlight de-line??
  48. 1jz replace or rebuild turbos?
  49. Poop. Dropped a nut into the intake manifold.
  50. need help
  51. Has anyone used this turbo kit?
  52. Any body know???
  53. 95 sc400 RPM drops and Engine Trouble
  54. Need help with power steering
  55. Tried to fix my Door Hinge Pop. Got Worse!
  56. Air Box Assembly/Blend Door Motor
  57. Looking at Flyweels
  58. squeeky engine noise when cold??
  59. Power Steering going?
  60. About the Radiator!
  61. Power Steering pump: Is there a reliable alternative to the Lexus part?
  62. CL turbo setup?
  63. Diff ??
  64. ABS and TRAC on, how to check codes
  65. 2jzgte hard start when warm
  66. sc400 neutraI safety switch wireing after sc300 w58 manual swap
  67. JDM Engine Corp
  68. Overheats a idle...chaning fan clutch?
  69. Change Fuel Filter...anyone notice a difference?
  70. 1JZ Refresher Build Help
  71. How to Change the major belts for 1992 Sc400?
  72. 95 sc300 not starting
  73. What part is this for injector
  74. 5000rpm cut off on WOT.
  75. Failed Smog after engine swap to 2JZGE
  76. 2jzge log style manifolds
  77. Seafoam experiences?
  78. ECU repair
  79. GM alternator swap (CS-144)?
  80. Looking for insight - broke down
  81. Getting a 200 Amp Alternator. What is the best safest cabling and fuse to get?
  82. 1jz purchase
  83. UZ - Small lines on top
  84. sc400 issues need some help please!!!
  85. sc400 Transmission swap
  86. EGR Pipe removal
  87. '97 sc400 power steering problem
  88. Help with 1jz timing belt
  89. GTE cams on GE head?
  90. sc300 not charging?
  91. passenger side mirror freely moving
  92. Brand New Turbo Oil In Packaging
  93. lc-1 wideband install help
  94. Differences in aem v2 6100 vs 6101
  95. Sc 400 ITBs
  96. 92 sc400 awkward stalling problem
  97. if only!!! IF ONLY I HAD THE MONEY!!!!
  98. throttle body/intake manifold issue
  99. can some 1 tell a place that I can get soarer logos
  100. help pulling my dash to paint it black
  101. Tranny fluid and lucas tranny fix
  102. i need a braided line fuel kit .
  103. Serpentine belt tension pulley(part number)?
  104. Where should a 1uz idle (sc400)
  105. Oil filter, buying one at Lexus vs Toyota dealer . . . .
  106. Sc300 Work
  107. Sc300 Mods?
  108. is vvti 2jzge motor vs sc 2jzge non-vvti motor (bottom end)
  109. Are turbo timers really that necessary
  110. steering wheel swaps??
  111. 98 sc 400 ECU
  112. Sc400 won't reverse
  113. ati pulley honing question
  114. help with turbo timer
  115. turbo!!!!!
  116. HELP SC400 Starting issue
  117. High or low impendance injectors?
  118. More questions pertaining to possible bad ecu?
  119. DIY: SC300/400 Seafoam Guide! With Pictures
  120. Need help with steering issues.
  121. Help please
  122. Should i get PUMPED, or just keep it the way it is!
  123. help
  124. Aftermarket cam gear thread
  125. Water by-pass gasket
  126. How to sump/plumb fuel system (tank) for sc300?
  127. Throttle cable install
  128. 98 lexus sc 400 won't start!
  129. Did I just pull my IACV, or something else?
  130. broken parts on 2.5TT - need PN
  131. speaker grille cleaning?
  132. SC400 randomly cutting out
  133. Climate Control Fail
  134. How do I reverse this mod ??
  135. SC300 cold start idle
  136. 98 VVTi 1UZ EMS Question
  137. What do I need to get this kind of speed?
  138. I know I know but has any one found the fix?
  139. Boostlogic intercooler piping vs universal
  140. Anyone convert a -GE BLOCK TO -GTE?
  141. Need some help installing either MKIV SMIC or Soarer SMIC (have both)
  142. 92 sc400 codes 14 and 15
  143. Sc400 Bogs under full throttle after oil change
  144. Sc300 97 AC does not blow anything
  145. Will 94 SC4 tranny fit my 92 SC4?...
  146. Sc300 rear axle width
  147. sc300 1j running lean at idle
  148. help picking what to do
  149. BFI thread
  150. Sc400 drops to 11v under high load when stopped, stalls unless I raise idle.
  151. Buying 1jz...warning signs?
  152. Performance chips ?
  153. 92 sc300 gas cuts off at 3500rpm???
  154. Neutral Safety Switch problem with R154 swap in my OBDII SC400
  155. MPG, Not a Question
  156. weird clicking/scratching/squeaking noise
  157. headers & downpipe
  158. Vibration in 1st gear after engine change
  159. Trac light and cel help
  160. Oil pump trick??
  161. Which ECU is best
  162. 92 SC400 Loss of Power, Rough Idle, Not ECU, Any help please
  163. Misfire, failed cam position sensor
  164. DIY-SC400 Serpentine Tensioner replacement
  165. BOdy Work baby
  166. ??? CODE #25 Cleared: Safe to drive?
  167. Which compressor housing on BWS366
  168. Custom Cone Air intake (1UZ)
  169. The Main Foglight Thread
  170. i need opinons on transmission swap
  171. Need a big favor from somebody with a long block laying around
  172. How much is a valve adjustment for sc400
  173. turbo ecu help (ive been searching)
  174. 1UZ-FE Cylinder head water passages?
  175. Borg warner s360 on 1jz
  176. Will an auto out of a 95 sc400 plug and play in a 92 sc400?
  177. na-t questions regarding stock parts
  178. Need help with supercharger kit
  179. TonyN SC400
  180. 1992 SC300 N20 NOS wet fogger setup!
  181. Center Cat Delete
  182. Injector impedance question
  183. Check Engine/trac control lights on
  184. DIY: Replacement of ECU SC400 - With pictures
  185. Throttle body differences between 1992-1997
  186. After Tune-Up Issues
  187. Trans problems, need help.
  188. Name these ports - VWR intake
  189. Squeal in engine bay AFTER new tensioner and belt
  190. SC300 Auto to Manual - Questions
  191. Unknown wire/sensor on new block
  192. wont restart after warmed up HELP
  193. manual transmission question
  194. Any dual exit catback exhausts?
  195. Whats my problem, tensioner, alternator, something else?
  196. wastegate spring question
  197. 97 SC400 Engine and Timing Belt
  198. Noise when steering 1999 sc300
  199. FS Fujitsubo Legallis R Dual Catback
  200. Wanting cams
  201. What causes the Ignition Coil to fail?
  202. Factory harness plug near starter
  203. Engine/electrical problems with a 93 SC400
  204. 1.5JZ ecu issue
  205. newbie with some questions
  206. what ems did you use on your NA-T
  207. Alternative Clutch Pedal Options?
  208. intercooler radiator placement
  209. Need help finding the correct replacement transmission for 98 SC300 Auto..
  210. 2JZGE w/W58 Rattle and Vibration
  211. Sc300 help
  212. cig lighter still not working
  213. Which universal Upstream o2 sensor should i purchase
  214. Performance enclosure for cooler air?
  215. Problems with opening driver door all the way
  216. weird hesitation at 3k
  217. Question about fuel pump, rough idle, hesitation, etc.
  218. ac/heat blower motor problem
  219. Harder to shut door when windows closed.
  220. Generic source for climate control LCD backlight bulbs (radioshack?) or OEM part #
  221. Helppppp
  222. Best ECU to use with JDM Rear Sump 2JZGTE Non-VVTI) moto that didn't come with a ECU?
  223. 99 sc4 millenium silver owner here
  224. Help 1997 Sc400 coolant overflowing
  225. Help me!
  226. 2JZGTE Wiring Harness Made Easy
  227. RPM, Idle and Transmission Question
  228. Misfire on acceleration. Stalls at idle.
  229. 92 SC400 Hydro fan question
  230. I need help!!! plz read help your fellow sc owner out!!!
  231. 1JZ No Start Troubles
  232. Is your SC300 "cold blooded", couple issues on cold starts . . . .
  233. chaser/soarer ecu plug pin insert part number
  234. Garrett gt3571 or Precision 6262
  235. Ram air idea (silly?)
  236. Fuel Injector Differences ?
  237. Sc300 2jzge lower exhaust manifold cat delete?
  238. Turn signal stopped working after installing Nardi steering wheel in sc300.
  239. Subframe/Diff Bushings
  240. Ignition coil on 93 sc400
  241. 1jz swap arrived igniter issue help!!!
  242. sc400 dyno numbers
  243. SC300 EB1 / EB2 equivalent in Toyota Chaser
  244. 1992 sc300 ecu
  245. 2jz Alternator upgrade
  246. Torsen OEM LSD diff swap upgrade
  247. 95-97 SC300 short shifter
  248. 1JZ-GTE injectors in a 2JZ-GE?
  249. soarer 1jz swapped sc300 cranking but no start
  250. s362 vs pte 6266
