- LEGAL TT swap in CA??
- Problem after BFI build
- Aristo Front Clip Compared to TT Supra Clip.
- BFI diagram
- sc300 starter help
- HKS intake/filter
- Newbie-ish Exhaust Question
- C's Supercharged Soarer
- sub sensors in v8
- Leaks... ouch, they hurt
- Soarer R154
- 1JZGTE stuff
- Couple pics
- o2 simulated sensor
- SC exhaust on GS???
- any of you sc400 guys use EManage ?
- 90,000 service if my SC400 is running great?!
- Willing to let shops borrow my car
- SC400: X-pipe and keep everything else stock?
- 300-400 fan/waterpump pulleys??
- how dyno?
- automatic shift knob
- Changing Gearbox Fluid
- What is this Tube and Part in the engine bay???
- 22.3 psi on Stock Motor
- Question about valve cover gasket on SC300
- sc400 cruise control not working among other things HELP!
- Fluid sounds behind the dash
- scan tool?
- aem uego wideband 02
- 2JZGTE from dealership?
- HELP! SC400 trouble.
- GTE oil pump in a GE Block??
- 2jz-gte sc300 partslist?
- Does anyone have Performance Pulleys on their 1UZFE?
- Should i Get The 6-speed?
- exhaust came in today
- Catalytic Converter
- Car died today. Need help.
- re-introduction of myself, and turbo questions (edited)
- turbo parts list
- turbo with stock exhaust system?
- oil relocation
- walbro pump in stock 1UZ?
- AEM EMS 30-1100 (Supra TT) on SC300?
- Dave H Kit Questions
- Cleaned the powerplant ...
- SC400-do I need to remove throttle body to pull the valve cover off?
- Slipping!
- Is there an off the shelf supercharger kit available for the SC400?
- I know somebody can help me.
- My new SC300 Exhaust Video - 2.25" Piping
- New Exhaust Video
- code 13
- Neutral Seal?
- Location of Engine ECU on SC400
- headers
- hmmm..engine stalled at IDLE today...weird
- Whats the check light next to the TRAC OFF on my 92?
- test pipe
- For your viewing pleasure.....2JZGE in progress
- P/S Problem: Need advice / help
- P/S and Alternator....rebuild or replace?
- 150k Face lift
- 440CC injectors..
- New STAGE 2 Nitrous Kit For Bigger Engines!!!
- Car Wouldnt Start
- Catalytic converter size
- Sources for MotorMounts?
- Distributer clip/ turbo
- Decesions
- Batt Light?
- Serpentine belt snapped last nite!
- what exhaust is this
- Turbo Timer install
- yet, another na-t question.....
- Gas Mileage on 92 SC 300 - I get like 13MPG!!! Help!
- Car won't start
- thinking bout a tt swap...
- Check Engine Light
- Help!!! My SC might be damaged!!!
- Can A Sc400 Convert To A Manual 5 Spd Or 6 Spd?
- Malfunction Light
- soarer 1jzgte swap guide
- X pipe
- spark plug change
- Where is the coolant going?? Any ideas?
- need some pointers from the na-t people
- Anyone using a Cometic Headgasket?
- Transmission Wont come out :D
- head work.......has anyone done it?
- Hey , guys I was wondering what else I'll need to get 400rwh out of boostlogic or ..
- intermitent hesitation before boston to cali trip, now constant hesitation
- lexuspros ecu performance for limited time?
- How much should I expect to pay (to have a APexi safc installed and dyno tuned)
- Kaaz LSD - Who has one
- ’96 NAT saga, a long tale
- Blitz Nur Spec Rear Section Dual Exhaust
- cats
- Any 1jzgte videos? I heard 1jz's sound great!
- Quick exhaust vid
- What to do before S-AFC install - other mods?
- SC400 Grounding Kits
- goodies coming very soon....
- Injen Intakes
- to 1j or to 2j that is the question
- rx300 shift knob on sc400?
- head gasket for NA-T
- Air Flow Signal/Sensor
- what ecu do i use
- built 1uzfe?
- another newbie question on na-t.....
- How to measure input shaft
- How fast is a SC400 with bolt-ons?
- exhaust
- Could Really Use Some Help! (spots of coolant in engine bay, heat not hot)
- What leaks oil above the water pump??
- na-t guys, will ls400 afm and walbro pump cut it?
- SC300 radiator in 400
- Need advice -changing v8 dist. cap cover on passenger side, -difficult to remove
- SC300 5 spd swap, almost done but need wiring help! Car wont start.
- How long will teh stock clutch last?
- Anyone know length of neg- battery cable?
- Stupid Stupid Me
- starting up help!!
- idling issues
- Help Guys! Can this be Done?
- replacement for MAF sensor
- From Reverse to Drive gear, safe?
- Leaking Distributor
- What EMS to USE on the New Beast and other Stuff
- RPM Still out of control!!
- add engine oil light??
- new project: 6 speed swap
- battery tray
- Tach conversion unit for TT swap??
- Rebuiding SC400 Transmission Advice
- VVTi swap question
- just a little rant (my bad luck)
- transmission codes
- Installing an S-AFC in a 1UZ
- Button next to shifter, '98 SC300
- SC400 Engine Noise
- Valve Cover Gasket
- clutch question...?
- Question about Swap--- regarding transimssion final drive ratio
- Are 93 & 95 electrical systems the same
- FMIC questions
- Intermittent noise coming from engine bay..belt tensioner?
- Malfunction Hazard Light
- And advice on S-AFC tuning - SC400 (OBDI)
- Cheapest place for Magnaflows right now?
- Tune up time; what do you recommend
- Valve body and springs SC300vsSC400
- hfvs shorty headers
- some extra pics of chrisman work - turbo sc400
- I have Qs about 2jzgte swap from Toyota Aritso will a usdm ecu work with jdm clips?
- 10w30 or 5w30....That is the Question!!
- wiring harness for the 1jz
- Weird electrical problems (what does the battery light mean?)
- SC400 Engine Mounts
- Horrible starting noise in morning--need some help please.
- What is the best part source for the 1JZGTE?
- Anyone have SC300 torque settings sheet? Clutch, flywheel torque specs?
- Oil Pressure Sender Replacement
- stock 1jzgte intercooler piping...can i use fr na-t?
- ECU Issues
- Turbo Recommendations for SC 400
- ECU replacement
- Sc430 (has anyone done GS430 engine swap into SC)
- Alternator Issues
- Installed the Lextreme TQ and Supra LSD today....
- The sound of your SC
- Tuner Theory - FI guys weight in
- Going distributorless with aem?
- 98 sc300 not ready for turbo..
- List of members with 1JZ swap
- Dyno Results with DaveH kit @ 5psi
- Supra TT to SC300 Swap
- What does the ECT/PWR button do?
- Some pics of the Magnaflow True X pipe
- Do i need a 5 speed engine harness for a manual tranny swap?
- Serious Rear Main Seal Question, please help guys
- ::used search:: Check Engine light, and heavy jerking. 95 SC400 120k Miles
- tech question bout 1jz....
- At what does your SC300 Idle?
- Question for 5spd guys
- DIY tranny flush?
- Question for the FI guys and Fuel gurus
- Exhausts?
- Single exhaust on the SC300
- FINALLY! The moment I have been waiting for 7months for...TRD motor mounts
- anyone running the soarer intercooler / side mount?
- Those with turbo timers
- 1JZ swap info or guide?
- headers from Tundra on 1UZ?
- Question to Turbo SC300s on here
- Where Is The Clutch Switch?
- 6 Bolt Main Pics (V8)
- Heater troubleshooting
- ecu or alternator?
- Anybody Have To Experience This?
- Anyone know the link to Dave H...
- charging system problems
- Some Questions about the 1JZ-GTE
- 1995 SC Auto Tranny
- interest in custom non turbo intake manifold
- Traction Control
- MAF sensor cleaning
- exhaust cut out?
- SC300 ecu pinout ?
- Emanage working/sort of
- Best car for swap ?
- Check Engine light SC300
- small problem
- Help Me... Im lost! Or just new to the family
- sc250 what do i need to make it happen?
- positve traction?
- turbo kits
- Installed my magnaflows 14829's today!
- Bypassing Fuel Pump ECU?
- Drive belt problems
- Coolant Reservoir and Heater Problems
- Will a rediator reservoir tank from a 95 work in a 93 SC400?
- TCC problems?
- SC400 Manual tranny
- Are There Any Short Shifters For Sc300?
- SCFAQ: Airbag Warning Light Reset
- DIY: Converting cornering lights into fog lights
- busted switch
- HELP!! up & down idleing
- Cat delete cause problems?
- Car running awful then fine
- Ahhh Help No Idle!!!
- SC400 starter solenoid location??
- 93 sc400 heater help
- can someone please help me identify this car part?
- Cruise control ECU
- Engine Differences?
- sc14 supercharger on V8 sc400 lexus
- are there any intercoolers?
- 4.27 Lsd
- What brands are there for short shifters?
- looking for "check harness A"
- 1jzgtte swap questions
- Rebuilding the power steering pump on an SC400
- Is My SC400 Dead (engine Blown??)
- Toyomoto Turbo Kit VS Turbonetics kit
- US based A340F performance shift kits?
- New European SC400 owner - Engine Problem?
