- Aftermarket Intake Mani for Boosted GE setups?
- Automatic shifters
- Ticking sound coming from engine - please help
- Where can i get Crank pully tool for a 300?
- Harmonic Balancer Tips
- my version of the bfi... or should i say bfs? (pics)
- Does this sound like a blown fuel pump?
- single or dual?
- GTE- intake manifold.
- i need help !
- 1jz 1.5jz
- 2jzgte turbo kit will work for a na-t set up??
- Auto 1JZ to 5SP SC Done
- Slugish SC.
- sc300 Radiator question
- Clunking Transmission
- To believe, or not to believe?
- Bad idle when A/C is off....
- Changing exhaust piping on 1jz
- Sport Design ECU?
- KAAZ LSD OK? Story Fishy !
- CAI & exhaust for SC400 questions.
- difference between 300&400 other than engine
- Manual Trans $ How much?
- Do I expect too much from Lexus Dealer Mechanics?
- O2 sensor replacement
- everyone with a 2JZ GTE in their sc
- skidplate important?
- no idle?
- Sign that my A/C compressor is going bad?
- Do you have a tranny cooler?
- Pulley Kit for SC400
- which high flow cat?
- PWNED by PSP...
- Are turboe'd SC's quick with stock auto tranny? I mean when they take off from ...
- SC400 started vibrating and shaking
- SC4 fuel pressure question ? Help
- Problems starting in the morning - Cold start injector time switch?
- are 1jz prices going up??
- Vavle seals
- turbo talk................
- Ignition Maintenance Parts
- POWDERCOATED valve covers.....pic!!
- I misshifted.
- gas mileage
- Anyone running the TRD bar with a single turbo setup?
- Might have to bring the SC to the grave yard
- So we've all heard about grounding kits...
- 5-Speed conversion, What parts do i attually need!?
- first time at the 1/4 in my SC
- How can I get more hp?
- Weird lag
- Best sc300 Exhaust
- Check engine light code 26
- Auto to 6speed
- How I fixed my bucking
- weird thing happend on freeway....
- Electric Supercharger?
- The suspense is over!
- SR20DET engine in a SC
- Which ECU are you running with your 1JZ swap?
- FMIC 4 row question.
- NA-T TE44 turbo head gasket advice?
- Zex Kit 4 Fathers Day SC4
- Size of A/C chorcoral cabin air filter?
- Dallas / DFW Auto to manual swap?
- Best HP intake SC4 ?
- Question about after market Exhaust
- supercharged sc400???
- Sporatic overheating and burping of coolent
- Ran a Bit Better at the Track Last Night
- which auto tranny?
- supra lsd in SC
- SC400 Runs Rich
- Sounds like???
- Valve cover gasket leaking
- Code 71 ?
- anyone with pics of mk3 r154 into sc3?
- No Coolant?
- knocking when I start my car
- Torco Gear Oil
- turbo selection?
- Auto Guys...O/D On or Off?
- Car has some issues.
- Club Lexus members ONLY Turbo video thread
- Got my turbo SC3 running, quick video
- Weird A/C Problem
- Oil Pan Removal for Sc400
- opinion on this generic air filter
- 1JZ harness question/help
- where is the iat sensor located?
- dynoed the car last Sat.
- Looking to buy Clutch
- Exhaust vs. S-AFC
- 2jzgte swap parts list needed..
- SC400 Performance Chips
- egr block off
- driveshaft bushings
- New muffler pics
- Yellowtop Fitment
- Fuel Grade (somone please reply quickly)
- Titan Motorsports
- Tach wire on '98 SC300 ?
- New Toys for 1jz(56k read the dictionary)
- 2jzgte swap question
- Crazy looking Lexus powerd kit car?
- need help with safc2
- Centrifugal Supercharger for SC400
- Iridium or IX Iridium spark plugs???
- Engine shudders when starting and reving
- nitrous on my sc300
- is this normal hp for a sc
- what mufflers for SC4?
- Which TRD LSD for 95 SC400 ?
- Anyone In Flordia Know Of Any Junkyards?
- Blitz Turbo Timer harness for SC300 (1JZ)??
- SC400 Shifting Issue
- 1JZ with 4" single-exit exhaust (pics)
- Injector Install or How To guide for SC300?
- 1jz single trubo conversion
- Safc 2
- My unconventional TT conversion ... pics
- 92 sc400 major bucking under light throttle
- Single and Dual Exhaust Performance
- Yet another 1jz question..
- Greddy Mx Or Borla Exhaust?
- what is this
- R154 and 1jz question.
- 2uz-fe
- tranny mounts
- Exhasct (replace my stock muflers take out cat)
- Looking to purchase a SC3 and go NA-T
- Tranmission: What to do? rebuild/replace?
- So my SC4 has a problem... Yes, I searched!
- Does The 2jzgte Head Bolt Up To A Ge Block
- look what ups brought me!
- sc300 idle?
- AEM EMS and SC300 Issues
- Auto trans length
- Soarer auto trans
- Ordering new catalytic converters
- oil pressure @ tight turns
- overheating ??
- TC Stall speed advice please
- is this normal?
- Tell Between Trac and nonTrac
- Summer Is Coming Up (should Work On My Brand New 400?)
- I can't stand the Noise!!! Anyone else?
- New blower
- up graded axles
- Adding Horsepower
- So how do you tighten the crank pulley bolt without the Lexus tool?
- SPEC clutch
- Airconditioning help needed
- Newbie in supercharging a SC400
- kaaz lsd
- 93 SC400 Idle problems (idle rises/drops/rises/drops)
- Idling very high on SC300
- JZA70 Supra 1JZGTE clip work for soarer swap?
- Car Dies
- How long does a 2JZ-GE engine last?
- Just joined the 1JZGTE club
- R154 Tranny swap
- Crank bolt removed with clothesline?
- Help with 5 speed shifting issue
- tensioner bearing?
- v8 turbo
- driveshaft bushing?
- Supra radiator driect bolt-in?
- Oem Ram Air, cost $0
- NA-T question
- sc300 a/t to manual 1jz Q's?
- help! engine shuttering
- How many "cranks" does it take to start the SC400 engine-reluctant starter?
- Anyone here fix their coolant reservior?
- supra TT 6 spd for SC300 AT
- Fuel System
- Where can i find motor mounts?
- 1and2JZGTE guys website
- HELP! SC400 Air Flow / Engine Smell
- Finally got car fixed....
- Tuned the car on pump gas last night...
- Clutch pedal squeeking
- 2jzgte with 5 speed or 6 speed supra tranny?
- ecu issues
- First time at the track in the 1jz SC300 (56k beware)
- Hello. former Honda owner turned Lexus owner here w/ some ?s
- Heater Problem Pleez help
- Where do i put the transmission cooler
- SC300 Auto to 2JZ-GTE Swap
- Raising the rev limit on SC400
- ? about installing a 5 speed
- engine & tranny swap?
- Has anyone every heard of this or have this happen to you
- Tranny Options
- Exhaust Pics
- Trouble starting
- turbonetics dyno?
- radiators
- Question about SC300 shifter knob
- another exhaust thread
- Exhaust, brakes, and car oh my
- throttle respond **PROBLEM**
- So what actually breaks in our 5 spds?
- auto to manual 1jz swap
- My car stalled???
- Brought the car to Dyno - Video
- 1500$ and not an idea
- tranny or clutch? please help!
- 7m gte turbo, intake & exhaust manifolds
- Question about replacement SC300 shifter knob
- Whirring Noise
- Interesting 1jz timing belt info
- Old shifter design on newer SC300?
- car cranks and fires up but the engine doesn't hold idle
- aftermarket pulleys
- another sc300 na/t
- Problem w/ auto gear shifter
- $500 performance gain?
- Magnaflow Exhaust Tips
- Smog Results. Barely Passed???
- Can't get the shifter out of P
- Buzzing sound
- HELP! Need advice on TC for my SC4
- 1jz swap
- 92 sc300 stalling
- head gasket for V8
- Radiator Removal for SC400?
- Clutch Petal Adjustment
- who's running nitrous?
- clutch or flywheel?
- SC300 Automatic Transmission Shifting Hard
- Injectors? what kind are these?
- MSD for SC 400
- Cat or Resonator?
- $4500 for a manual 5speed SC or $2500 and convert it? (doing 1JZ swap, too)
- 2jzgte In Sc3
- Coolant Hose Break
- 1jzgte Wiring Info!!!!!!!!
- Finally I Got My SC300. Opinions?
- GUY NEED HELP w/TC AND LSD SETUP!
- help getting egr pipe out of intake
- step by step clutch replacement?
- Auto Shift Knob Interchable?
- JDM Dual Exhaust Video..
- Buying a cheap 5speed SC... using current tranny for Supra swap? Labor questions...
- MSD Install
- My NA-T In a Video :-D
- Is this a Deafening Almost Dead Differential?
- Swap 1jz Into Sc400
