PDA
View Full Version : Performance & Maintenance
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87
  1. 95 Sc300 radiator bubbling issues
  2. Need advice on adjusting clutch
  3. Just got my DM SC300 5 speed pedal package...any assembly guides?
  4. Must sway bar end links be a matched pair?
  5. power steering
  6. Headlight Cleaning and Defogging DIY
  7. '94 SC400 TPS part #?
  8. manifold remove
  9. Replacing shims for aftermarket cams
  10. US spec engine with JDM Mines ecu ??
  11. Driveshaft center support bearing bolt spacers
  12. radiator fluid leaking. need to replace a pipe
  13. What kind of power are you making?
  14. Eaton Detroit locker??
  15. Throttle body relocation on 2JZ-GE
  16. plummeting mpg
  17. 95 SC400 stuck in park, no power windows, roof, or steering Please Help
  18. Oxygen sensor questions
  19. Ordering some 5 speed conversion parts, missing anything?
  20. sc300 wont start anymore!
  21. Fuel pump differences?
  22. helpp (SWAP)
  23. I am so bummed. Tranny frustrations.
  24. will this injector work?
  25. Ignition switch ques.
  26. HELP!!!! My car fins fine untill put in drive or reverse!!!!
  27. Preferred Turbo kit?
  28. 1JZ SC300 swap finally done needs tweaking! Help?
  29. Issues after 5spd swap
  30. 1UZ spark plug torque?
  31. Grounding problem SC300 '92
  32. SC400 new fuel pump, ECU bypass, stranded again
  33. Cracked manifold worth fixing?
  34. what would you call this clip?
  35. are all transmission mounts created equal?
  36. 1992 sc300 with 95 bumper and fogs
  37. Stumped on clutch/trans issue on 2jz/r154
  38. Rear drive shaft
  39. 92 nat bogging issues
  40. SC400 Transmission Dipstick - Do I have the Wrong One?
  41. 1jz harness missing alternator plug and wires??? help asap!
  42. Supra or Aristo trans in my SC300?
  43. SC300 1JZ Starter Problem
  44. Thermostat question
  45. Help with AC compressor and clutch.
  46. Boost leak/ Turbo failure?
  47. Removing resonators on Sc300? Effective for sound as on 400?
  48. Removing resonators on Sc300? Effective for sound as on 400?
  49. 99 sc300 aristo swap driveshaft help needed
  50. Which standalone is for me?
  51. Civic AEM V2
  52. ECU questions
  53. 17mm Bolt Above Thermostat Inner Threads Stripped Help!!!
  54. 1jz
  55. sc300 with 350z straight pipes
  56. Anything wrong with this R154?
  57. Help with 2 things. Starting issue/timing belt & water pump questions
  58. Serpentine Belt Question
  59. A.C. parts replaced after compressor failed but still not fully cold
  60. Code 14 fixes? i need help!
  61. overheating issue
  62. jzx100 (chaser) into 93 sc300
  63. SC400 Trouble
  64. Cluster problem
  65. A/C refrigerant level
  66. where is the DIY for fuel pump relacement
  67. Shaky, loss of power up hill.
  68. IS300 Fans - How to wire them
  69. Mechanical trouble already???
  70. 97 SC4 Engine Idle/Whining Issue Update
  71. 2JZ Dimensions?
  72. Just dropped in a gte
  73. Question on GS400 3.26 rear diff in a gte swapped auto SC...
  74. SC400 no power, burning, rough idle
  75. 97' SC400 Whining/Whirring from under Hood
  76. Ac compressor question about 2jzgte/1uzfe compatibility.
  77. 1jzgte vvti (JZS171) ECU PINOUT
  78. SC570 (LS1 SC300) cammed idle.
  79. Am I forgetting any maintenance items?
  80. Anyone used Driftmotion's 1JZ aftermarket timing parts?
  81. Map ecu 3
  82. R154 Clutch slipping?
  83. Help with Power Steering Pump
  84. 1jz harness has extra body plugs?
  85. 1999 sc300 tune up
  86. titan motorsports cams vs gsc cams?
  87. how do you get door moldings off
  88. help me with 2 things lol
  89. 1jz with 2jz-ge auto tranny?
  90. How to: Fix your door opener actuator rod lower end
  91. '93 sc300 transmission fluid
  92. Removed rear differential, I think it is making noise, is this normal?
  93. 97 fogs on a 93 sc
  94. 2JZGE NOS Direct Port Nitrous setup coming soon! Any input?
  95. SC400 Max Fuel Pressure (help please!)
  96. SC300 Coolant Reservoir Cap
  97. Sputtering & stalling issue... won't stay running!!!
  98. Heater control valve
  99. where to buy 1jz torque converter?
  100. SC400 Transmission Whine in 1st Gear (A340e)
  101. Differential Fluid Change and Trans Fluid Change at the Dealer
  102. Defeating/Bypassing the Coolant Level Sensor?
  103. Code 52 Knock Sensor on 92 SC400
  104. 1JZ custom patch harness, or just splice/solder?
  105. need lsd diff installed
  106. Drag Tire Recommendations
  107. AEM EMS v2 Timing Problem NA-t
  108. LS430 Diff?
  109. Alarm reset not working
  110. SC400 P/S Buzz question
  111. O2 sensor resistance (cold)
  112. Electric Radiator Fan Install simplified?
  113. Tranny Swap
  114. Is this an R154?
  115. Found a few promising turbo engines, help me pick one
  116. 1.5jzge just need a little info
  117. possible blown head gasket not entirely sure
  118. 1jz people I need help!
  119. Isis fuel pump
  120. Gas Tank Pressure needed?!?
  121. Need help, Electronics not working!
  122. Lean @ Idle, Trac light
  123. 1JZGTE Tach Fix 92-94 & 95-96
  124. Complete Diff bushing kits now available. Multi-piece design for the SC
  125. car missing need help please....
  126. Car shuts off when i turn off the A/C
  127. 92 SC300 Pouring white smoke
  128. what radiator do i have?
  129. 1jz wont fire aem gurus needed
  130. So hot in PHX... Need A/C Help!
  131. 1JZGTE VVTI IN SC300 wiring question
  132. Help, about to pay $355 for Vapor Canister!
  133. 1jz auto help
  134. sc300 2jzgte help, grounded alt.
  135. smoking and stalling
  136. SC4 cooling fan behavior
  137. AC Pro kit works! Definitely worth $$ IMO
  138. how to troubleshoot heater control valve?
  139. driveline vibration after 5-spd swap help me diagnose
  140. Na-t or ls/t56 swap?
  141. Help sc400 overheating with a/c ON
  142. from 810 to 560 in one night. bad idle
  143. Sc400 intake measurements please
  144. Help my 1jz auto dies!
  145. DIY LS1 Motor Mounts, LS1/T56 Swap
  146. Anyone tried Duralast VC120 Vapor Canister?
  147. catalytic converter
  148. 2JZGE Bottom Mount Turbo Manifolds?
  149. Idles at 0-100 rpm but No stalling. Help
  150. Electrical issue
  151. timing belt slipped
  152. 1JZ swap start up on AEM V2
  153. I need to rescue my SC - I turn the key to ON, and nothing works.
  154. Greedy Blue/ Ultimate ECU Reviews?
  155. '93 w58 swap into '92 auto
  156. problems in my sc 300
  157. SC 300/400 gte swap AEM Ecu question.....
  158. Starting issue/funky idle....
  159. at 45 mph car quits running, would not start
  160. r154
  161. is the 12v fuel mod good
  162. Where in 2014 can you find the 1UZ-FE Knock Sensor Sub-Harness?
  163. CX Racing Turbo kits chime in
  164. What harness is this? 98 SC400
  165. Fuel pump upgrades, mount corrosion
  166. Brown liquid from intake?
  167. 98 SC400 Knock Sensor HELP
  168. Fuel Problem Help Please!!
  169. Common 1jz problems?
  170. EGR: to delete or not to delete?
  171. Interest in SC400 Vortech supercharger write up
  172. o2 idea for 1jz
  173. 92 300 misfire question
  174. Transparent Timing Belt Cover for 2JZ
  175. Accessories on 2jzgte swap
  176. 95 SC300 Battery not charging, but batt and alt check out
  177. 2jz vvti in to a 93 sc300
  178. 2jzgte, need vsv help!!!
  179. Surging idle in park or neutral
  180. Alternator Replacement write up/w Pic's
  181. is this the TRAC i pulled out?
  182. injector #1
  183. SC400 1JZ running hot
  184. 1uz wasted spark coil on plug conversion
  185. Sc400 Rear Cam Cap Replacement
  186. miss fire
  187. 1uzfe power steering question.
  188. Need timing belt advise from forum
  189. 97 side
  190. What would you do? Swap an engine into a 300 or manual tranny into 400?
  191. MAF sensor outside of resistance specs?
  192. Engine/Tranny Swap
  193. Engine quits no electrical power
  194. 1992 Lexus SC400 smoke coming into cab??
  195. Anyone ever thought of using a p28 honda Ecu for 1uzfe?
  196. TECHNICAL sc400 5speed conv. questions
  197. Please Help, only car
  198. Need Help: 2JZ-GE NA-T w/ 7M CPS, TT coilpacks, AEM V2 (for GTE)
  199. Tampa Bay SC400 needs help - have an hour of time?
  200. Transmission starts in 2nd gear problem
  201. engine rotation direction?
  202. 1JZ Soarer and MKIV TT PS reservoirs the same?
  203. Help! Transmission noise?
  204. Any ideas for an exhaust?
  205. Any ideas for an exhaust?
  206. Engine revs when itís hot.
  207. putting on 97 sides
  208. People who have TT Auto trannys, post your knowledge here
  209. Should I rebuild this free 2JZGE?
  210. All 1jz Holset hx35 experienced please chime in
  211. Weird Idle/Bucking/Stalling Issues
  212. Misfire symptoms, no CEL. OBD1 2JZGE
  213. NA-t head gasket option?
  214. Vortech Supercharger wastegate idea
  215. Need Help with 5ps swap on 98 sc400
  216. radiator options?
  217. over heating
  218. O/D light flashing on 93 SC300
  219. clutch recommendation?
  220. sc300 2jzgte swap
  221. Mishimoto Aluminum Radiator
  222. Car Not Starting Up
  223. more power
  224. Whos done a 5sp swap on 98 sc400 vvti
  225. Injectors ?
  226. 1.5jz
  227. OEM Fuel lines?
  228. Anyone with experience with chaser ecu's and harnesses?
  229. sc400 crank but no start
  230. Fuel Not Turning On
  231. Fuel Pump Not Getting Power
  232. 1jz sc300 bogging with acceleration but idles fine Help please shes my DD!
  233. clutch or trans issue
  234. BFI thoughts
  235. 2jzgte fuel rail compatible with 1jzgte?
  236. bfi or cold air intake for 92 sc300
  237. HELP I broke the oil sending unit in the block!
  238. Need Help picking out an ECU
  239. First check engne light (code 25) then trac light comes on
  240. Typical A/C issues
  241. wastegate flange help
  242. possible harness / ecu compatability problems?
  243. flex fuel sensor and fuel cooler
  244. ECU and Tuning Question
  245. Has anyone had the same overheating problem? 92 SC400
  246. will vvti ignitor work for vvti gte?
  247. 93 sc400 bogging plz helpp
  248. TRAC and ABS delete?
  249. Remanufactured Cardone ECU's
  250. Transmission problem please help.
