PDA
View Full Version : Performance & Maintenance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 [79] 80 81 82 83 84 85 86 87
  1. SAFC Fried?
  2. SC vs Supra Parts
  3. Need Suggestion on Timing Belt Types
  4. Car won't start in the morning
  5. Car died while driving. Please advise.
  6. sc300 exhaust
  7. Punching Cat
  8. Post exhaust install 600 mile trip
  9. Compression in motor -> Vibration = rebuild?
  10. Magnaflow exhaust
  11. NA-T: which one is more reliable?
  12. Does the SC4 have slots for clutch cyl like the SC3? 5 spd
  13. (iat) Intake Air Temperature
  14. LSD Swap Questions
  15. Acquired 94 Auto Supra TT diff, now I have some q's
  16. Need info on 1jz swap
  17. Weird loud FAN noise at idle..what the heck?
  18. those with swaps... do you still have AC?
  19. For those with 1jz's
  20. GTE Swap Progress
  21. car starting weak
  22. toyomoto ?
  23. Optima Yellow Batteries
  24. Ignition mods
  25. why is my car so loud?
  26. Another Head Question
  27. rev limit? speed limiter in our cars?
  28. oh man... more noise...
  29. front pipe
  30. JDM question????????
  31. Spark plugs...Which one would you use??
  32. Doing my exhaust with Magnaflows, and running into problems...
  33. help battery problem!
  34. Cat elim pipes
  35. 98-00 SC300 2jzgte possiblity?
  36. Use of N/A & N/A-T
  37. MKIV and SC300 shift knob fitment?
  38. Intercooler piping question
  39. Are 1jz/2jz harmonic balancers the same?
  40. Oil Pan
  41. injen intake for a 96' sc300 will it fit??
  42. Spark plug wires not lasting
  43. Ultimate Lexus Guide? Legit?
  44. Dragon torque converter
  45. Supra Exhaust
  46. Please help! Bad fuel?! (SC300)
  47. Egr Faq
  48. BFI and Torque converter upgrade on sc300?
  49. How to make a clean factory looking BFI DIY
  50. power steering leakage...common problem
  51. guys, need yr help to find the link..
  52. SC300T Vs. SC400T
  53. Electrical problem!!
  54. strange ticking noise during cooloff
  55. custom exhaust
  56. I Need Help Fast!!!!!!!!!!!!!!!!!!!
  57. Apexi safc-II
  58. guys, need your opinion on this...
  59. advice on an intercooler
  60. How to maintain motor over 60k
  61. computer and TPS questions
  62. dyno results after sound performance
  63. sc300 engine question
  64. Power Adders for SC400?
  65. 1jz or 2jz
  66. Need help pruchasing new radiator for 95 sc4
  67. Got wheel, auto transmssion upgrade, question ^^V
  68. bfi and headlights done! pics up
  69. Check Engine/TRAC off Lights came on...
  70. Can I use the Meziere electric water pump?
  71. Transmission Question
  72. W58 1jz bellhousing
  73. installing fuel air ratio guage
  74. Very new to this 1jzgtte swap to a sc300 need help plz
  75. sea foam brake booster line
  76. PS pump and alternator
  77. motors
  78. Radiator Light , and Battery Light
  79. Engine shut down whenever AC turn off
  80. Vacuum Noise Under Hood
  81. Need help on installing Ground Wire Kit
  82. This Sucks!! Smoke.....
  83. Installation of S-AFC? Need opinions
  84. 5-speed tranny shaking?
  85. Greddy 4 row fit in front of sc300?
  86. I'm very close to getting rid of my SC....
  87. sc300 distributor install
  88. 2 types of Catalytic Converter ???
  89. ...and behind door #3, my next mod! - clutch replacement
  90. squeaky clutch?
  91. Jerky SC 300 Transmission-Automatic
  92. Automatic shifter change
  93. auto tranny drain and refill capacity SC400
  94. sc400 turbo
  95. ssc300 5 speed tranny into a auto sc400
  96. SC300 Morning start problem
  97. Any intrest in BFI templates drawn in AutoCAD?
  98. how knows about the 400 drive shaft in the gte swap and what do i need??????
  99. remote mount turbo
  100. Diagnostic code #12, no RPM signal on 1JZ swap
  101. lost power
  102. Throttle body position sensor voltage output
  103. New NA-T project
  104. Changed plugs yesterday- have a guestion
  105. For those looking to do the BFI with velocity stacks...
  106. sc300 resonator length
  107. sc300 reverse to drive clicking noise help!
  108. catback exhaust questions for the turbo guys
  109. SC400 Supra Tranny Swap
  110. Harmonic Dampener pulley broke off, now what?
  111. Catback Exhausts
  112. Is Your Transmission a Slow Learner?
  113. Turbo thoughts, costs
  114. General SC Questions-Transmission shift knob shaking
  115. Electrical problem?
  116. Really weird engine noise?
  117. TT auto transmission into GTE swapped SC300
  118. V8 Picture
  119. Cheaper to modify stock exhaust or get a Borla?
  120. This may be a stupid questions, but...
  121. Can flowmaster mufflers be put on SC400?
  122. HKS Cams
  123. ECU differences, compatibility
  124. SC400 having stuttering/shaking problems
  125. Manual Mode?
  126. Car hard to start!..Code 78!!!
  127. Bad ECU? not sure... need expert advice from SC guys
  128. I just cannot decide what to do
  129. vvt-i
  130. Engine mount question
  131. Anyone removed ignitions switch? Or have a FSM??
  132. MSD 6A install - Pictures & Info
  133. Could a/c clutch cause loud belt whining sound???
  134. how to change alternator on SC400 ??? please help asap
  135. powersteering death whine?
  136. exhaust system
  137. throttle body, maintenance cleaning
  138. AC clutch throwing sparks. Help.
  139. Ractive exhaust concerns
  140. HKS Pod Filter Q?
  141. Got 97+ Refresh Fog Connectors? You do now!
  142. head swap
  143. Old newbie need answers
  144. Magnaflow HI-flo cats?
  145. 97 sc300
  146. SC300 motor hunting help..
  147. looking for an older model sc (I KNOW NOTHING ABOUT THESE CARS! )
  148. "X" pipe
  149. where to buy GTE head gasket?
  150. sc300/sc400
  151. Battery check light
  152. SC300 and 1jzgte swap
  153. in search of an exhaust system
  154. More LSD questions
  155. Mainfold cracked on turbo engine, help? (thread edited to be a bit more creative)
  156. Shaking
  157. Nos fuel pressure tap for sc400
  158. Will 1JZGTE work with W58
  159. Clutch wont disengage.....
  160. weird thermostat happenings..help!
  161. Anyone ever get the C's short shifter for the SC300 (NA Supra)?
  162. Replace Tensioner on SC400
  163. anybody have info about CAMS?
  164. Clearance Under the Hood
  165. Blown 1UZ - Some talk, Some do....
  166. differential hex bolt size
  167. Hole in exhaust
  168. Weird compression test results.
  169. ijz-gte
  170. got my "jdm" mufflers today.
  171. rmm intake
  172. sc400 2jz-gte swap
  173. What should I do with a 190K old engine?
  174. high idle after tb cleaning
  175. Yes, another power steering problem
  176. 1jz-gte auto to 6-speed swap info
  177. Loose rear drvers side wheel
  178. WILL A 95 SC 400 POWER STEERING PUMP WORK WITH A 92 sc400
  179. LSD installed!
  180. Who has ACTUALLY DONE the 5 speed to auto?
  181. New pump gas dyno results :) :) :)
  182. Sc400 260 Hp -> 290 Hp
  183. 60000 miles and time for a new sc400 engine???
  184. new engine needed already for my sc 400???
  185. Power tuning
  186. Apex'i SAFC vs SAFC-II
  187. front mount intake..
  188. clutch pedal
  189. Shifter Moves - Is This Normal ???
  190. Why set up
  191. Engine losses poer/shuts down "sometime" when braking
  192. 99 sc400
  193. engine code P0420 same as code 25?
  194. Does stock air box filter out water?
  195. Weapon R?
  196. Puzzled over Stock GTE swap Dyno Results!
  197. :":":msd":":
  198. Exhaust question
  199. I will be installing a limited slip... need inputs
  200. Car Won't Shift Out Of Park!
  201. 50-state legal cats...
  202. all motor
  203. Another Alt/Batt/Starter prob.
  204. Lextreme vs Precision Industries
  205. BFI: How many of you have done it?
  206. ":":K&n":"
  207. :horse Power:
  208. SC400 stalls after startup unless gas pedal is massaged..
  209. Oil pan of my 93 SC300
  210. AVCR owners question: NO or NC??
  211. possible alternator problem battery overcharge
  212. Short Shifter...
  213. Question on 95 SC300 water pump
  214. Do SC300's & 400's use the same half-shafts?
  215. A340E transmission Question
  216. Son of a bleep bleepin bleep*!&*%$ injectors
  217. Check engine and trac on, Code 25
  218. Nitrous Colder plug suggestions?
  219. anyone using a vortec fmu/sx regulator combo??
  220. rattle
  221. MSD RPM switch Tap on SC400?
  222. Questions about mods (title edited to be a bit more creative)
  223. No heat at all....PLEASE HELP!!!
  224. my alternator is not charging my battery (title edited to be a bit more creative)
  225. Question
  226. Anybody ever build up a v8?
  227. transmission rattle
  228. Engine Question
  229. Stock engine na-t - 9.71 @ 135
  230. vacuum hoses
  231. transmission
  232. Need some help cross-referencing parts...
  233. What NEEDS to be replaced when installing a LSD??
  234. SC400 gated shifter upgrade.
  235. Looking for some good mild performance upgrades
  236. What's the consensus on V8 exhaust diameter?
  237. SC400 Dual Exhaust Concerns
  238. diy on a 2jz swap(inquiry)
  239. definitive upgrade guide to increasing SC4's HP
  240. tranny gear oil
  241. SC 300/400 Transmission options?
  242. For those who went na-t.
  243. More horsepower...
  244. Getting rid of some cats
  245. where are the sparkplugs in SC400 located?
  246. NA 5sp MKIV crank VS 5sp 92 SC300 crank
  247. just installed safcII
  248. shifting into park
  249. what clutch pedal?
  250. 92-97 Engine vs 98+ Engine
