PDA
View Full Version : Performance & Maintenance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 [77] 78 79 80 81 82 83 84 85 86
  1. Sc430 (has anyone done GS430 engine swap into SC)
  2. Alternator Issues
  3. Installed the Lextreme TQ and Supra LSD today....
  4. The sound of your SC
  5. Tuner Theory - FI guys weight in
  6. Going distributorless with aem?
  7. 98 sc300 not ready for turbo..
  8. List of members with 1JZ swap
  9. Dyno Results with DaveH kit @ 5psi
  10. Supra TT to SC300 Swap
  11. What does the ECT/PWR button do?
  12. Some pics of the Magnaflow True X pipe
  13. Do i need a 5 speed engine harness for a manual tranny swap?
  14. Serious Rear Main Seal Question, please help guys
  15. ::used search:: Check Engine light, and heavy jerking. 95 SC400 120k Miles
  16. tech question bout 1jz....
  17. At what does your SC300 Idle?
  18. Question for 5spd guys
  19. DIY tranny flush?
  20. Question for the FI guys and Fuel gurus
  21. Exhausts?
  22. Single exhaust on the SC300
  23. FINALLY! The moment I have been waiting for 7months for...TRD motor mounts
  24. anyone running the soarer intercooler / side mount?
  25. Those with turbo timers
  26. 1JZ swap info or guide?
  27. headers from Tundra on 1UZ?
  28. Question to Turbo SC300s on here
  29. Where Is The Clutch Switch?
  30. 6 Bolt Main Pics (V8)
  31. Heater troubleshooting
  32. ecu or alternator?
  33. Anybody Have To Experience This?
  34. Anyone know the link to Dave H...
  35. charging system problems
  36. Some Questions about the 1JZ-GTE
  37. 1995 SC Auto Tranny
  38. interest in custom non turbo intake manifold
  39. Traction Control
  40. MAF sensor cleaning
  41. exhaust cut out?
  42. SC300 ecu pinout ?
  43. Emanage working/sort of
  44. Best car for swap ?
  45. Check Engine light SC300
  46. small problem
  47. Help Me... Im lost! Or just new to the family
  48. sc250 what do i need to make it happen?
  49. positve traction?
  50. turbo kits
  51. Installed my magnaflows 14829's today!
  52. Bypassing Fuel Pump ECU?
  53. Drive belt problems
  54. Coolant Reservoir and Heater Problems
  55. Will a rediator reservoir tank from a 95 work in a 93 SC400?
  56. TCC problems?
  57. SC400 Manual tranny
  58. Are There Any Short Shifters For Sc300?
  59. SCFAQ: Airbag Warning Light Reset
  60. busted switch
  61. HELP!! up & down idleing
  62. Cat delete cause problems?
  63. Car running awful then fine
  64. Ahhh Help No Idle!!!
  65. SC400 starter solenoid location??
  66. 93 sc400 heater help
  67. can someone please help me identify this car part?
  68. Cruise control ECU
  69. Engine Differences?
  70. sc14 supercharger on V8 sc400 lexus
  71. are there any intercoolers?
  72. 4.27 Lsd
  73. What brands are there for short shifters?
  74. looking for "check harness A"
  75. 1jzgtte swap questions
  76. Rebuilding the power steering pump on an SC400
  77. Is My SC400 Dead (engine Blown??)
  78. Toyomoto Turbo Kit VS Turbonetics kit
  79. US based A340F performance shift kits?
  80. New European SC400 owner - Engine Problem?
  81. Question about Hooker Maximum Flow mufflers
  82. How to cure lifter noise?
  83. Anyone around here with the 1.5JZ swap...?
  84. Blitz Realize TT Exhaust
  85. Need help saying goodbye to my 95 SC300 Turbo
  86. Electrical
  87. Timing +- 25 degrees??
  88. my 2JZGTE buildup
  89. rear mount turbo idea
  90. acis..... ?
  91. What?!!! Another NA-T on the road?! PIX of my Na-T install!
  92. Car won't idle + a 97 conversion question
  93. SC300 vs GS300 - Need FACTS!!
  94. Late model SC400 LSD question
  95. 624 rwhp stock 2JZGE
  96. Tt Maf
  97. Opinions on the H.V.S.
  98. 2jzgtte wiring question
  99. car dying???
  100. 1JZ swap (general questions)
  101. newbie question?
  102. Best exhaust for the SC400?
  103. New Dual Exhaust, and other updates....
  104. o2 simulator
  105. starter contact points
  106. Torque converter
  107. Hi Flow Cat or Gutted
  108. I'm thinkin' it's about mod time!!!
  109. Custom Piping...what are the differences?
  110. TT SC400 race results..
  111. i need an oil change
  112. Oil leak
  113. engine running poor
  114. ATTN: 5-speed guys with loose/notchy shifts...
  115. Soarer with RB26!!
  116. sc300 headers
  117. Apexi S-AFC2
  118. JIC Exhaust Questions?
  119. what size pipe for exhaust
  120. FMIC Install Pics
  121. Hate the slowmatic? why not go clutchless shiftronic?
  122. What parts are need auto > 5 speed swap?
  123. Stalling on hot starts - easy troubleshooting (Searched)
  124. Vacums Wiring and oil lines for Na-t? help!
  125. NEED HELP ASAP - Clutch
  126. bolt pattern on 1UZ and R154 bellhousing (SC400 auto to 5speed project)
  127. NEED help to pinpoint problem
  128. heater question for 95SC300
  129. SC300 Engine vibration on idle
  130. SC400- "won't get out of its own way"!
  131. New Here,please Help heater not working thread
  132. e-manage wiring help
  133. fan switch sensor?
  134. power steering leakage
  135. How much power?
  136. 2jzgte question
  137. SC stock dual exhaust.....anyone know the weight???????
  138. How much whp is the 5sp sc300 making?
  139. SC400 Mid pipe. question
  140. update on turboing my sc: need some help
  141. Intake snorkel
  142. If you had 5 grand to spend...
  143. Tranny will not shift until warm? whats going on?
  144. Fan Bearing
  145. BFI underway... need help with decisions
  146. What tool for large lug under center cap?
  147. Car Wont Start !!??
  148. 2 quarts low . . . what's going on?
  149. Frame straightening
  150. supra downpipe and driveshaft on SC?
  151. power steering question (whine, fluid, etc?)
  152. Xerd header finally arrives!!
  153. This is one very clean 1UZFE
  154. Adjusting Transmission Cable
  155. Changed timing belt & water pump - Car won't start!
  156. 98 trnas in 93?
  157. First engine upgrades in CA
  158. ps system... really really bad plz help
  159. $134 supercharger adds 30 hp????
  160. What are obstacles swapping 2JZ-GE VVT-i into a pre VVT-i SC300
  161. lower compression of 1uz?
  162. EGR question and a little smoke...
  163. is300 headers work with sc300?
  164. Help!! Car stalls in this morning!
  165. Would a 5spd Supra Diff work on a SC400?
  166. What are the worst things you guys have heard about JDM motors?
  167. mumumumumumufflers
  168. forced induction?
  169. SC400 engine harshness increase
  170. Got my 96 sc300 Check engine??
  171. Car won't start, loud ticking noise under hood
  172. The Ultimate SC400 Question: Supercharge or Turbocharge
  173. SC300 Single Exhaust?
  174. Check Engine Light due to Intake
  175. Serpentine belt on SC300
  176. HELP: loud wheezing sound under the hood!!!
  177. Car dies when I press in the brake
  178. Heater problem
  179. SC4 Shifting probs
  180. electric fans on for 3 seconds???
  181. Current/future mods
  182. What goes here on the SC300 Engine?
  183. Need Intake Manifold Removal Guide for SC300 - Engine/Spark Problems again!!!
  184. battery problems?
  185. A look inside
  186. hummming noise?
  187. listen to this crap... sc is amazing
  188. stock spark plug gap on 96 SC400?
  189. intake and exhaust valve question
  190. performance chip
  191. SC400 Fan belt?!?!
  192. rear main seal
  193. shift problems
  194. power steering pump...best price oem
  195. Where can I get a Valve Body??
  196. for the second time in a row, I washed my engine
  197. BFI + Weapon R?
  198. Quad Exhaust
  199. power steering reservoir
  200. transmission whinning..did search
  201. bad ass twin turbo V8 crate motor just for some ideas
  202. Twin Turbo V8
  203. BL T61 Pics
  204. QUAIFE Sequential gearboxes
  205. More air = less power? Why
  206. To much transmission fluid
  207. leaking from the car
  208. Who's supercharged SC is this?
  209. low power, lots of noise, AND it's smoking...
  210. revisit to the dyno. 92 SC400 results
  211. car stalls after electric fan conversion??
  212. any advice on clutch wear?
  213. strange vibrations (no jokes please!)
  214. Whistle and idle problem?
  215. Engine Noise
  216. EGR location and Replacement
  217. Help with Valve cover gasket job
  218. newb here considering sc400
  219. Will the Dragon TC and supra lsd work for a 98 sc4?
  220. What's the best intake for SC400?
  221. idle
  222. Installed Torsen diff and 6-puck into SC
  223. One Piece Driveshaft
  224. need advice on mufflers
  225. Fuel Pump Location???
  226. overdrive..help please..sc300
  227. O2 Sensors
  228. Ticking noise from the rear what could it be??
  229. Engine not getting fuel
  230. need some advice...
  231. el chepo exhaust (free)
  232. 5-Speed Trannie Stall
  233. Need help from CL SC members
  234. Another Twin Turbo SC400?
  235. part numbers for certain items?
  236. Charcoal Canister ?
  237. Changing My Clutch, Ever Do Yours?
  238. Where can I get the Tex's Headers?
  239. exhaust
  240. Car starting problem...
  241. I REALLY hate my car right now...
  242. Question on a headlight
  243. Can someone tell me the size of these bolts? (plastic engine covers)
  244. SC300 2jz-ge into a SC400?
  245. I had a sqeaking coming from my belts. What else could it be??
  246. Trouble code 14
  247. Vaf
  248. 92-95 SC300 vs 95-99 Maxima (both 5 speed)
  249. About to order TRD LSD..questions
  250. SC300 5 speed conversion questions?
