PDA
View Full Version : Performance & Maintenance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 [76] 77 78 79 80 81 82 83 84 85 86 87
  1. stalling on start up
  2. Fixing a warm start problem
  3. A Few Questions for the 1JZ-GTE Owners
  4. Cruise Control
  5. GOD i hope this fixes my stalling problem.
  6. 8 extra injectors-pics-TT sc400
  7. Vid or Sound clip of 1JZGTE??
  8. sc300nat 6-speed
  9. sc300 diff?
  10. funny noises leading to car breaking down
  11. Toyota Motor Ignition Overview
  12. SC400 Exhaust Decision
  13. Power steering replaced
  14. ISC valve maitenance on old V8 motor
  15. expensive repairs
  16. fan shroud
  17. electrical problem.
  18. Help needed w/ cooling lines SC400
  19. CEL after timing change
  20. 1jz-gte SHES ALIVE!!!
  21. ebay brakes and clutch kits?
  22. Where to find USDM/JDM 2JZ-GTE
  23. Where to get an engine
  24. ebay brakes and clutch kits?
  25. CEL is on
  26. torque converter
  27. Max Performance
  28. 3uzfe
  29. Which Forced Induction to Go With
  30. clumping sound
  31. 3s-gte
  32. Greddy exhaust for SC300 and GS300
  33. LOW IDLE, Help
  34. Hi, Everyone!
  35. My auto tranny seems to be dying...couple of Qs..
  36. SC400 unplugged MAF
  37. car wont start after tensioner install
  38. List of necessary items for BFI
  39. New performance cam and pulleys
  40. So, the countdown begins....
  41. Quick Answer needed regarding stock O2 sensor studs
  42. 93 sc300 5speed clutch/gears
  43. Concerning '95-up SC300 intakes
  44. SC 400 Nitrous
  45. When Running Single Exhaust, How Do You Fill in the Other Hole in the Bumper?
  46. squeaky A/C compressor
  47. Max hp from 2jzge motor
  48. something's up with my crank pulley
  49. basic timing
  50. Pumpkins
  51. Ran into problem while cleaning TB and changing spark plugs
  52. Occasional problem starting the car
  53. SC400 supercharger!
  54. 1jz question?
  55. soarer 5-speed
  56. 2JZ-GE/1JZGTE Decision HELP NEEDED.
  57. Anyone Have a Pic of a JIC ONE Exhuast on an SC?
  58. Magnet oil drain plugs
  59. best turbo for a 1jz
  60. PowerSteering and ElectricFan
  61. Timing belt question
  62. WRX 98' Turbo will it work on lexus with a lilo mod?
  63. SC400 electric fans
  64. look, flat torque curve on a 1JZ. What a coinsidence
  65. Changing spark plugs, cap/rotor, wires today
  66. 1jz 2.5 tt how hard is it ?????
  67. air noise (not what you think)
  68. 98 Supra Tranny in a 97 SC300?
  69. wrecked Sc fixing
  70. 2500rpm transmission noise
  71. 1jz w/5speed
  72. 1jz 5-speed
  73. which companies for custom top feed fuel rail?
  74. in need a R154 5-speed
  75. 8 extra injectors setup-pics..
  76. Broke Trans Input Shaft..
  77. diagnostic code 12 - no rpm signal
  78. Coolant Leak - Pics of source of the problem
  79. Some questions on the 2jz-gte/ge and 1jz swaps...
  80. 1JZ-GTE swap almost done
  81. greddy t78 or T60-1
  82. New alternator hot
  83. Help AUTO. stalling out and dieing!!!
  84. Exhaust Choices. (poll)
  85. Differential howling / whining == $3000? (help?)
  86. Good Bang/Buck BOOST GUAGES?
  87. Some type of performance chip on ebay
  88. Noob here with a ? (2jz swap into SC400 and turbo v8)
  89. Battery in the Trunk
  90. Succesful 5Speed Conversion
  91. For all the people that turboed their SC
  92. How will X-Pipe affect exhaust sound???
  93. 1JZ or 2JZ JDM source help near PA
  94. Cam gear timing marks
  95. internals
  96. WHP limits on the stock 5spd?
  97. OD Light?
  98. Rebuild kits?
  99. wHat does a 1.5jz-gte consist of?
  100. Screeching Noise when foot off the pedal (decelerating)
  101. exhaust?
  102. Vibration on low revs
  103. wires and plugs changed, impressions...
  104. 5Speed Conversion
  105. dyno :(
  106. battery light
  107. Blinking A/C light!
  108. sc300 turbo guys, looking for stock injectors
  109. Dave H Kit question
  110. How much for PS / alt. fix?
  111. fmic
  112. my sc400
  113. does anyone run nos?
  114. 93' SC400 - Loss of power?
  115. DAVE HENRY turbos?
  116. sc400 with nos.
  117. 1JZ Clip Question
  118. My new GE-T numbers, 660 rwhp
  119. questions about turbo kits
  120. need spec on non-vvti 1uz-fe
  121. Msd 6al
  122. Another Trac off Check engine light issue..
  123. need code help asap!! code 14
  124. ehaust 300Z & SC ?
  125. Best Clutch w/ turbo uprade
  126. safc question.
  127. Question about Soarer turbo kits
  128. compression or leak down test..
  129. New exhaust!
  130. shop manual prices?
  131. New member & help with codes please.
  132. engine grabs downhill
  133. walbro fuel pump?
  134. what does it take to swap from auto to manual? please i need help..
  135. tranny cooler?
  136. 2jzgte kit ===>2jzge
  137. updated pics of 1JZsoarer (peters) car!!
  138. 97' SC300 timing belt question
  139. dyno?
  140. Do we have any NEW mods for the SC3/400's??
  141. Na-t Guys...
  142. 2jz-gte in 92sc300 auto?
  143. Power Sttering Leak
  144. Stupid Screws!
  145. Headers for the SC400
  146. intake question
  147. how many cats do i have ????
  148. another na-t question....
  149. ? about engine skidplate
  150. Supra radiator
  151. 1JZ heads, fuel question
  152. Anyone have their ECU De-governed? Top Speed?
  153. 1997 Sc300 5-speed clutch noise
  154. my 1992 sc400 doesnt start right
  155. SC 400 Power Loss
  156. Engine skid plate
  157. Phils Book ? He have one anymore ? Is there a 1jz book ?
  158. Reversed Batt Polarity..now Dead DoorKnob
  159. possible '98+ gated shifter upgrade
  160. dyno today
  161. Dual in-tank fuel pump brackets
  162. R154 tranny...soarer and supra mkIII the same?
  163. 2 short questions
  164. style question about exhaust
  165. Iradium Spark plugs
  166. shift kit? must be MV?
  167. Injen Intake fit ?
  168. 92 sc400 went into a limp mode
  169. How much power should i have at the wheel???
  170. Seafoam experts, check in here.
  171. Intake and Exhaust Question
  172. Finally got my cat-back exhaust
  173. HELP! TPS setting on SC400
  174. EGR stuff off (DIY)
  175. need help with possible ECU problem
  176. SC400 supercharger on ebay?
  177. B & M TRANNY COOLER
  178. LEGAL TT swap in CA??
  179. Problem after BFI build
  180. Aristo Front Clip Compared to TT Supra Clip.
  181. BFI diagram
  182. sc300 starter help
  183. HKS intake/filter
  184. Newbie-ish Exhaust Question
  185. C's Supercharged Soarer
  186. sub sensors in v8
  187. Leaks... ouch, they hurt
  188. Soarer R154
  189. 1JZGTE stuff
  190. Couple pics
  191. o2 simulated sensor
  192. SC exhaust on GS???
  193. any of you sc400 guys use EManage ?
  194. 90,000 service if my SC400 is running great?!
  195. Willing to let shops borrow my car
  196. SC400: X-pipe and keep everything else stock?
  197. 300-400 fan/waterpump pulleys??
  198. how dyno?
  199. automatic shift knob
  200. Changing Gearbox Fluid
  201. What is this Tube and Part in the engine bay???
  202. 22.3 psi on Stock Motor
  203. Question about valve cover gasket on SC300
  204. sc400 cruise control not working among other things HELP!
  205. Fluid sounds behind the dash
  206. scan tool?
  207. aem uego wideband 02
  208. 2JZGTE from dealership?
  209. HELP! SC400 trouble.
  210. GTE oil pump in a GE Block??
  211. 2jz-gte sc300 partslist?
  212. Does anyone have Performance Pulleys on their 1UZFE?
  213. Should i Get The 6-speed?
  214. exhaust came in today
  215. Catalytic Converter
  216. Car died today. Need help.
  217. re-introduction of myself, and turbo questions (edited)
  218. turbo parts list
  219. turbo with stock exhaust system?
  220. oil relocation
  221. walbro pump in stock 1UZ?
  222. AEM EMS 30-1100 (Supra TT) on SC300?
  223. Dave H Kit Questions
  224. Cleaned the powerplant ...
  225. SC400-do I need to remove throttle body to pull the valve cover off?
  226. Slipping!
  227. Is there an off the shelf supercharger kit available for the SC400?
  228. I know somebody can help me.
  229. My new SC300 Exhaust Video - 2.25" Piping
  230. New Exhaust Video
  231. code 13
  232. Neutral Seal?
  233. Location of Engine ECU on SC400
  234. headers
  235. hmmm..engine stalled at IDLE today...weird
  236. Whats the check light next to the TRAC OFF on my 92?
  237. test pipe
  238. For your viewing pleasure.....2JZGE in progress
  239. P/S Problem: Need advice / help
  240. P/S and Alternator....rebuild or replace?
  241. 150k Face lift
  242. 440CC injectors..
  243. New STAGE 2 Nitrous Kit For Bigger Engines!!!
  244. Car Wouldnt Start
  245. Catalytic converter size
  246. Sources for MotorMounts?
  247. Distributer clip/ turbo
  248. Decesions
  249. Batt Light?
  250. Serpentine belt snapped last nite!
