PDA
View Full Version : Performance & Maintenance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 [75] 76 77 78 79 80 81 82 83 84 85 86
  1. My NA-T In a Video :-D
  2. Is this a Deafening Almost Dead Differential?
  3. Swap 1jz Into Sc400
  4. 1UZFE Raised Redline? Anyone above OEM?
  5. why tranny so damn hot???
  6. Exhaust video
  7. 1JZGTE swap
  8. Who is using MAP-ECU mapecu?
  9. Running EXTREMELY hot
  10. My NA-T 1/4 Miles
  11. Valve Spring Question
  12. No Pictures Here ;)
  13. Soarer Automatic Transmission
  14. Spark plugs?????
  15. Dreaded Check engine light is on.
  16. Tornado
  17. 1jz single turbo manifold
  18. Calling all NA-T Sc300's!!!
  19. cylinder #6 trouble
  20. Shifter Trouble
  21. transmission question .. need some help
  22. Water and water wetter only.
  23. Head gasket replacement..
  24. Nitrous and the SC300
  25. Ls400 AFM Flange
  26. 1jz gte timing belt and cams
  27. Air Ciondition heater Blower not coming on
  28. Spark Plug Gap
  29. BFI Opinions
  30. Resonator Exhaust Question 97 SC400
  31. 1JZ power
  32. Opinions on this 1JZ intake manifold, and 90mm throttle body
  33. my overdrive doesnt work..
  34. bad pumpkin
  35. Sticky gas peddle fix!
  36. The SC is sounding like a go-kart.
  37. 430 engine/transmission swap any info?
  38. Post your 1jz swap issues
  39. Few Issues With The Engine Maybe Cat?
  40. Question about Dave H kit
  41. Misfiring
  42. mteele's 1JZ swap pics (56K take a nap)
  43. SC getting turbo
  44. Sc300 Lsd?
  45. Thinking About Exhaust
  46. Some pics of my new exhaust
  47. Differences between Soarers
  48. supra auto TT rear is not a direct bolt in!!!!!
  49. Custom DIY
  50. So i got some $$ to spend....
  51. re-use head gasket
  52. Need cheap clutch
  53. Pictures of my exhaust
  54. Finished fabricating my frount mount piping
  55. Injen intake
  56. Idle Surge
  57. Question about snorkel
  58. Blitz Nur-Spec Exhaust
  59. Who has/had a 2JZGTE on the SC 5spd tranny
  60. How to Flush the Transmission
  61. v8 or TT 91-94
  62. Does 95 sc300 stick come with LSD?
  63. Need new radiator for sc4
  64. Building Drift Sc300 With 2jz Need Help
  65. 1JZ auto to 5 speed SC
  66. Problem with speedo and tranny
  67. cat back dual exhaust test
  68. Oil Leak Help
  69. Motor mounts search
  70. O2 Sensor Choice (Already Searched)
  71. Interesting 1jz vs 1jz w/ VVTI question
  72. Turbo 1UZ Dyno result, 389 HP, 509 trq. 12.4 PSI. Wow
  73. My 92 5spd will not start! Help!
  74. Drive Belt Problem
  75. Power steering pipe leak
  76. question involving 2jz-gte swap and TRAC
  77. stalling on start up
  78. Fixing a warm start problem
  79. A Few Questions for the 1JZ-GTE Owners
  80. Cruise Control
  81. GOD i hope this fixes my stalling problem.
  82. 8 extra injectors-pics-TT sc400
  83. Vid or Sound clip of 1JZGTE??
  84. sc300nat 6-speed
  85. sc300 diff?
  86. funny noises leading to car breaking down
  87. Toyota Motor Ignition Overview
  88. SC400 Exhaust Decision
  89. Power steering replaced
  90. ISC valve maitenance on old V8 motor
  91. expensive repairs
  92. fan shroud
  93. electrical problem.
  94. Help needed w/ cooling lines SC400
  95. CEL after timing change
  96. 1jz-gte SHES ALIVE!!!
  97. ebay brakes and clutch kits?
  98. Where to find USDM/JDM 2JZ-GTE
  99. Where to get an engine
  100. ebay brakes and clutch kits?
  101. CEL is on
  102. torque converter
  103. Max Performance
  104. 3uzfe
  105. Which Forced Induction to Go With
  106. clumping sound
  107. 3s-gte
  108. Greddy exhaust for SC300 and GS300
  109. LOW IDLE, Help
  110. Hi, Everyone!
  111. My auto tranny seems to be dying...couple of Qs..
  112. SC400 unplugged MAF
  113. car wont start after tensioner install
  114. List of necessary items for BFI
  115. New performance cam and pulleys
  116. So, the countdown begins....
  117. Quick Answer needed regarding stock O2 sensor studs
  118. 93 sc300 5speed clutch/gears
  119. Concerning '95-up SC300 intakes
  120. SC 400 Nitrous
  121. When Running Single Exhaust, How Do You Fill in the Other Hole in the Bumper?
  122. squeaky A/C compressor
  123. Max hp from 2jzge motor
  124. something's up with my crank pulley
  125. basic timing
  126. Pumpkins
  127. Ran into problem while cleaning TB and changing spark plugs
  128. Occasional problem starting the car
  129. SC400 supercharger!
  130. 1jz question?
  131. soarer 5-speed
  132. 2JZ-GE/1JZGTE Decision HELP NEEDED.
  133. Anyone Have a Pic of a JIC ONE Exhuast on an SC?
  134. Magnet oil drain plugs
  135. best turbo for a 1jz
  136. PowerSteering and ElectricFan
  137. Timing belt question
  138. WRX 98' Turbo will it work on lexus with a lilo mod?
  139. SC400 electric fans
  140. look, flat torque curve on a 1JZ. What a coinsidence
  141. Changing spark plugs, cap/rotor, wires today
  142. 1jz 2.5 tt how hard is it ?????
  143. air noise (not what you think)
  144. 98 Supra Tranny in a 97 SC300?
  145. wrecked Sc fixing
  146. 2500rpm transmission noise
  147. 1jz w/5speed
  148. 1jz 5-speed
  149. which companies for custom top feed fuel rail?
  150. in need a R154 5-speed
  151. 8 extra injectors setup-pics..
  152. Broke Trans Input Shaft..
  153. diagnostic code 12 - no rpm signal
  154. Coolant Leak - Pics of source of the problem
  155. Some questions on the 2jz-gte/ge and 1jz swaps...
  156. 1JZ-GTE swap almost done
  157. greddy t78 or T60-1
  158. New alternator hot
  159. Help AUTO. stalling out and dieing!!!
  160. Exhaust Choices. (poll)
  161. Differential howling / whining == $3000? (help?)
  162. Good Bang/Buck BOOST GUAGES?
  163. Some type of performance chip on ebay
  164. Noob here with a ? (2jz swap into SC400 and turbo v8)
  165. Battery in the Trunk
  166. Succesful 5Speed Conversion
  167. For all the people that turboed their SC
  168. How will X-Pipe affect exhaust sound???
  169. 1JZ or 2JZ JDM source help near PA
  170. Cam gear timing marks
  171. internals
  172. WHP limits on the stock 5spd?
  173. OD Light?
  174. Rebuild kits?
  175. wHat does a 1.5jz-gte consist of?
  176. Screeching Noise when foot off the pedal (decelerating)
  177. exhaust?
  178. Vibration on low revs
  179. wires and plugs changed, impressions...
  180. 5Speed Conversion
  181. dyno :(
  182. battery light
  183. Blinking A/C light!
  184. sc300 turbo guys, looking for stock injectors
  185. Dave H Kit question
  186. How much for PS / alt. fix?
  187. fmic
  188. my sc400
  189. does anyone run nos?
  190. 93' SC400 - Loss of power?
  191. DAVE HENRY turbos?
  192. sc400 with nos.
  193. 1JZ Clip Question
  194. My new GE-T numbers, 660 rwhp
  195. questions about turbo kits
  196. need spec on non-vvti 1uz-fe
  197. Msd 6al
  198. Another Trac off Check engine light issue..
  199. need code help asap!! code 14
  200. ehaust 300Z & SC ?
  201. Best Clutch w/ turbo uprade
  202. safc question.
  203. Question about Soarer turbo kits
  204. compression or leak down test..
  205. New exhaust!
  206. shop manual prices?
  207. New member & help with codes please.
  208. engine grabs downhill
  209. walbro fuel pump?
  210. what does it take to swap from auto to manual? please i need help..
  211. tranny cooler?
  212. 2jzgte kit ===>2jzge
  213. updated pics of 1JZsoarer (peters) car!!
  214. 97' SC300 timing belt question
  215. dyno?
  216. Do we have any NEW mods for the SC3/400's??
  217. Na-t Guys...
  218. 2jz-gte in 92sc300 auto?
  219. Power Sttering Leak
  220. Stupid Screws!
  221. Headers for the SC400
  222. intake question
  223. how many cats do i have ????
  224. another na-t question....
  225. ? about engine skidplate
  226. Supra radiator
  227. 1JZ heads, fuel question
  228. Anyone have their ECU De-governed? Top Speed?
  229. 1997 Sc300 5-speed clutch noise
  230. my 1992 sc400 doesnt start right
  231. SC 400 Power Loss
  232. Engine skid plate
  233. Phils Book ? He have one anymore ? Is there a 1jz book ?
  234. Reversed Batt Polarity..now Dead DoorKnob
  235. possible '98+ gated shifter upgrade
  236. dyno today
  237. Dual in-tank fuel pump brackets
  238. R154 tranny...soarer and supra mkIII the same?
  239. 2 short questions
  240. style question about exhaust
  241. Iradium Spark plugs
  242. shift kit? must be MV?
  243. Injen Intake fit ?
  244. 92 sc400 went into a limp mode
  245. How much power should i have at the wheel???
  246. Seafoam experts, check in here.
  247. Intake and Exhaust Question
  248. Finally got my cat-back exhaust
  249. HELP! TPS setting on SC400
  250. EGR stuff off (DIY)
