PDA
View Full Version : Performance & Maintenance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 [74] 75 76 77 78 79 80 81 82 83 84 85 86
  1. coolant bypass 96sc3
  2. stupid oil cap Q.
  3. borla turbo muffler with a 2.25 inch piping....how does it sound??
  4. Sc400 Lsd
  5. Magnaflow 14829's Installed
  6. which exhaust is better?
  7. White smoke from exhaust
  8. anyone seen this?
  9. Alternator amps help
  10. Sc400 Lsd
  11. uh turbo time NA-T feed me!
  12. SC400 Nitrous Part I
  13. Oil Problem
  14. Bubbles in my coolant resevoir
  15. Which turbo kit to get?
  16. need help with high presure hose
  17. Exhaust Noise-- Straight pipes vs Dynomax Ultraflows
  18. Got exhaust installed
  19. O2 sensor adapter?
  20. Battery dying!?
  21. Single exhaust on SC300
  22. cold air intake
  23. LS400 MAF on NA car
  24. This guy is going to have a hard time convincing me.........
  25. Magnaflow 14829 question
  26. timing belt replacement on SC300
  27. Starting Problem Need Help!
  28. free flow cat
  29. 92 SC3 stalls after alternator replacement
  30. Burning Smell in Engine after 3-5min 80mph Drive
  31. Single exhaust? Yay or Nay?
  32. sc turbo exhaust the cheap way
  33. What other options besides magnaflow and jic exhaust
  34. DIY: A/C compressor removal and installation
  35. Vid: Exhaust sound with removed resonator and mag. 14829
  36. I need help w/ exhaust....
  37. 1JZGTE Taking over the world!
  38. how to test a resistor
  39. 1JZ swap issues... did I get ripped off? (wiring harness questions)
  40. GTE swap 99 SC - tranny?
  41. complete motor swap
  42. my sc300-2jzgte swap question
  43. hi, i'm new here....
  44. JIC Magic Bullet 505S Twin Spartan Exhaust on an NA-T
  45. midpipe and exhaust selections for turbo app
  46. My new Snail
  47. Nos!?!?!
  48. My Na-t set up...part list and search..so it begins=)
  49. Crank Shaft Pulley Removal (Not bolt, the pulley itself)
  50. Buying Xerd headers..anyone use them?
  51. WTB: 2jzgte map sensor
  52. HKS Hi-Power single exhaust pics
  53. New CATS , X-Fac & Dynomax PIC
  54. Retarded question
  55. Replaced radiator in the SC400 last night
  56. Ordered Exhaust
  57. Which SC4 or 3 guys have removed the stock cats?
  58. Magnaflows 14829 need advise 4 SC4
  59. Exhaust Question
  60. Updated engine pic
  61. (doubt it) Is a mk3 1JZ harness usable?
  62. SC300 Blitz Nur Spec Axle Back Shortage
  63. Occasional Trouble Starting
  64. jhotexport tranny ?'s
  65. For those who have replaced the Catalytic con.. a question for you
  66. alternator question on 1jz
  67. Battery keeps on decreasing...need help asap
  68. # of NA-T's and GTE's
  69. Just bought 98' Sc400. questions about mods.
  70. Will Stock Tranny Holds Power for the 1JZ
  71. oil pump for turbo
  72. Aftermarket Intake Mani for Boosted GE setups?
  73. Automatic shifters
  74. Ticking sound coming from engine - please help
  75. Where can i get Crank pully tool for a 300?
  76. Harmonic Balancer Tips
  77. my version of the bfi... or should i say bfs? (pics)
  78. Does this sound like a blown fuel pump?
  79. single or dual?
  80. GTE- intake manifold.
  81. i need help !
  82. 1jz 1.5jz
  83. 2jzgte turbo kit will work for a na-t set up??
  84. Auto 1JZ to 5SP SC Done
  85. Slugish SC.
  86. sc300 Radiator question
  87. Clunking Transmission
  88. To believe, or not to believe?
  89. Bad idle when A/C is off....
  90. Changing exhaust piping on 1jz
  91. Sport Design ECU?
  92. KAAZ LSD OK? Story Fishy !
  93. CAI & exhaust for SC400 questions.
  94. difference between 300&400 other than engine
  95. Manual Trans $ How much?
  96. Do I expect too much from Lexus Dealer Mechanics?
  97. O2 sensor replacement
  98. everyone with a 2JZ GTE in their sc
  99. skidplate important?
  100. no idle?
  101. Sign that my A/C compressor is going bad?
  102. Do you have a tranny cooler?
  103. Pulley Kit for SC400
  104. which high flow cat?
  105. PWNED by PSP...
  106. Are turboe'd SC's quick with stock auto tranny? I mean when they take off from ...
  107. SC400 started vibrating and shaking
  108. SC4 fuel pressure question ? Help
  109. Problems starting in the morning - Cold start injector time switch?
  110. are 1jz prices going up??
  111. Vavle seals
  112. turbo talk................
  113. Ignition Maintenance Parts
  114. POWDERCOATED valve covers.....pic!!
  115. I misshifted.
  116. gas mileage
  117. Anyone running the TRD bar with a single turbo setup?
  118. Might have to bring the SC to the grave yard
  119. So we've all heard about grounding kits...
  120. 5-Speed conversion, What parts do i attually need!?
  121. first time at the 1/4 in my SC
  122. How can I get more hp?
  123. Weird lag
  124. Best sc300 Exhaust
  125. Check engine light code 26
  126. Auto to 6speed
  127. How I fixed my bucking
  128. weird thing happend on freeway....
  129. Electric Supercharger?
  130. The suspense is over!
  131. SR20DET engine in a SC
  132. Which ECU are you running with your 1JZ swap?
  133. FMIC 4 row question.
  134. NA-T TE44 turbo head gasket advice?
  135. Zex Kit 4 Fathers Day SC4
  136. Size of A/C chorcoral cabin air filter?
  137. Dallas / DFW Auto to manual swap?
  138. Best HP intake SC4 ?
  139. Question about after market Exhaust
  140. supercharged sc400???
  141. Sporatic overheating and burping of coolent
  142. Ran a Bit Better at the Track Last Night
  143. which auto tranny?
  144. supra lsd in SC
  145. SC400 Runs Rich
  146. Sounds like???
  147. Valve cover gasket leaking
  148. Code 71 ?
  149. anyone with pics of mk3 r154 into sc3?
  150. No Coolant?
  151. knocking when I start my car
  152. Torco Gear Oil
  153. turbo selection?
  154. Auto Guys...O/D On or Off?
  155. Car has some issues.
  156. Club Lexus members ONLY Turbo video thread
  157. Got my turbo SC3 running, quick video
  158. Weird A/C Problem
  159. Oil Pan Removal for Sc400
  160. opinion on this generic air filter
  161. 1JZ harness question/help
  162. where is the iat sensor located?
  163. dynoed the car last Sat.
  164. Looking to buy Clutch
  165. Exhaust vs. S-AFC
  166. 2jzgte swap parts list needed..
  167. SC400 Performance Chips
  168. egr block off
  169. driveshaft bushings
  170. New muffler pics
  171. Yellowtop Fitment
  172. Fuel Grade (somone please reply quickly)
  173. Titan Motorsports
  174. Tach wire on '98 SC300 ?
  175. New Toys for 1jz(56k read the dictionary)
  176. 2jzgte swap question
  177. Crazy looking Lexus powerd kit car?
  178. need help with safc2
  179. Centrifugal Supercharger for SC400
  180. Iridium or IX Iridium spark plugs???
  181. Engine shudders when starting and reving
  182. nitrous on my sc300
  183. is this normal hp for a sc
  184. what mufflers for SC4?
  185. Which TRD LSD for 95 SC400 ?
  186. Anyone In Flordia Know Of Any Junkyards?
  187. Blitz Turbo Timer harness for SC300 (1JZ)??
  188. SC400 Shifting Issue
  189. 1JZ with 4" single-exit exhaust (pics)
  190. Injector Install or How To guide for SC300?
  191. 1jz single trubo conversion
  192. Safc 2
  193. My unconventional TT conversion ... pics
  194. 92 sc400 major bucking under light throttle
  195. Single and Dual Exhaust Performance
  196. Yet another 1jz question..
  197. Greddy Mx Or Borla Exhaust?
  198. what is this
  199. R154 and 1jz question.
  200. 2uz-fe
  201. tranny mounts
  202. Exhasct (replace my stock muflers take out cat)
  203. Looking to purchase a SC3 and go NA-T
  204. Tranmission: What to do? rebuild/replace?
  205. So my SC4 has a problem... Yes, I searched!
  206. Does The 2jzgte Head Bolt Up To A Ge Block
  207. look what ups brought me!
  208. sc300 idle?
  209. AEM EMS and SC300 Issues
  210. Auto trans length
  211. Soarer auto trans
  212. Ordering new catalytic converters
  213. oil pressure @ tight turns
  214. overheating ??
  215. TC Stall speed advice please
  216. is this normal?
  217. Tell Between Trac and nonTrac
  218. Summer Is Coming Up (should Work On My Brand New 400?)
  219. I can't stand the Noise!!! Anyone else?
  220. New blower
  221. up graded axles
  222. Adding Horsepower
  223. So how do you tighten the crank pulley bolt without the Lexus tool?
  224. SPEC clutch
  225. Airconditioning help needed
  226. Newbie in supercharging a SC400
  227. kaaz lsd
  228. 93 SC400 Idle problems (idle rises/drops/rises/drops)
  229. Idling very high on SC300
  230. JZA70 Supra 1JZGTE clip work for soarer swap?
  231. Car Dies
  232. How long does a 2JZ-GE engine last?
  233. Just joined the 1JZGTE club
  234. R154 Tranny swap
  235. Crank bolt removed with clothesline?
  236. Help with 5 speed shifting issue
  237. tensioner bearing?
  238. v8 turbo
  239. driveshaft bushing?
  240. Supra radiator driect bolt-in?
  241. Oem Ram Air, cost $0
  242. NA-T question
  243. sc300 a/t to manual 1jz Q's?
  244. help! engine shuttering
  245. How many "cranks" does it take to start the SC400 engine-reluctant starter?
  246. Anyone here fix their coolant reservior?
  247. supra TT 6 spd for SC300 AT
  248. Fuel System
  249. Where can i find motor mounts?
  250. 1and2JZGTE guys website
