- Can you say Boost leak???
- 5spd, Will Not Stall, Need Help w/ Transmission
- Help Help Electrical Problem
- What adjustable fuel regulator will bolt in?
- What data logger is the best?
- Lexus Sc400 1995 Help With Replacing Wheel Bearings
- Anyone running dual in-tank fuel pumps?
- buying a sc
- Who has the "Baddest" sc out there???
- Power steering pump overflow
- Auto - Manual Conversion. Shifter Hole Help
- 2JZGTE swap into the SC300
- check engine light question
- codes, codes, and more codes ...
- waterpump pulley?
- Keep a bigger eye out for this SC (sneak preview)
- Intercooler spray kit????
- new clutchmasters clutch is junk it broke already being 3 days new!!!!!
- if u swap a 2jz gte in the sc300 and run the gte wireing harness your guages wont ..
- chassis wiring harness
- turbo vs swap
- the 4500$ question
- What injectors can I go with? (SC400)
- what bov is this??
- HELP! turn signal problem
- Heating System Problem...help
- Wastegate
- 1JZ Starter?? What can replace it?
- Magnaflow's installed but now feels funny
- Engine Problems on 92' Lexus SC 400
- Engine Problems On 92' Lexus SC 400
- belt squeaks after adding some belt conditioner!!! Whats wrong?
- 2jz-ge and 2jz-gte, block and crank?
- 98 auto rear end ratio
- Problem with 1JZ swap
- Listen to this setup!!! A 1UZ like it should be.
- Great... car wont start
- vacum hose question
- Gearing differential change SC400?
- opinion on spec clutches?
- v8 problems
- starting issues
- manual trany diffrences...
- 1jz downpie ?
- Lsd Questions
- swap or no swap???
- 92 SC400...removing just the resonator???
- help my stock sc300
- 3vzfe to 1mzfe conversion / SWAP
- Differential / driveshaft knocking + vibration - need help diagnosing?
- Weird sound
- O2 sensor location?
- Looking for a true Cold intake box?
- red brake light coming on at times?
- Please help me read this code
- oops
- standalones (1uz-fe)
- sc300 question + sc300 w/1jz swap question.
- Say hello to my little friend
- HKS speed limit defencer
- 1uz-fe head studs (ARP)
- Help!!! (bIGjUSTINS 1jz-101 threads (no that is not a new engine designation))
- Plug reading
- NA-T database.
- headers
- Please help identify Part@
- maf or map?
- Power steering anomaly ( yep,researched)
- Exhaust concept...
- Adjusting greddy scc?
- Need to drastically quiet my exhasut..suggestions?
- Boom She Goes
- radiator compatability (300 and 400)
- change to jdm cross member so i dont have to get new oil pan?
- has any one installed a virtual works intake?
- 2jzgte converting rear end
- Seafoam Help
- Burning oil: Power steering Air Control Valve???
- Tuning options for na-t... lets discuss
- Paxton Supercharger for sc400: Would you Reccomend?
- NA-T oil to turbo
- why replace ground cable?
- Transmission Fluid in oil trick
- Does ANYBODY know????What ever happened with the WeaponR ecu??
- Question about a 2-way diff and 6-speed swap
- Need help on CLutch & Flywheel recommendations
- EK Tuning SC400 Headers.
- Anything available
- Emanage in a SC400
- Need help to connect turbo timer
- LS1 ? In a SC400/300 has it been done ?
- TOTAL cost for 6 speed conversion?
- Odd issue with my manual transmission...
- cams suggestions?
- Need a new Radiator
- looking for
- Aftermarket Fuel injectors-Real or Fake??
- PS pump??
- How to wire in scc and bcc?
- Engine Ticking......?????Common ? unno.....
- Manual Trans
- Need to buy a battery...
- quick 1jz question
- Maybe you all can shed a little light on my questions!
- Wanted: Diagnostic procedure for VAF
- Replaced Fuel filter night&day
- Help: Car died on me, starter issues
- Need exhaust system input
- power steering issue
- Transmission Problem
- Distrubutor install HOW TO
- 1JZ In.... car will not start, need help
- Auto - Manual swap with MT ECU
- tunning ?'s vvt-i
- sc300 2jz-gte trany swap?
- my first car.. got some plans for it need ideas =/
- What is the best turbo setup?
- how do you drop a 5speed into the sc400
- Top Dead Center And Distributor Replacment
- removed pre-cats?
- Koyo radiator
- Will 2UZ headers fit on the 1UZ
- Difficulty shifting w/'92 SC300 5spd
- HELP! Is it even worth it?
- will a torsen style LSD and dragon TC on a 98 GS400 work on a 95 SC400?
- Need Help !!! Radiator Question ???
- Auto - Manual Clutch Switch
- My 1.5JZ-GTE T67 build for my 92 SC300
- price of new oil sump?
- trany upgrade ? or replace?
- Does anyone know the resistance range of the OEM fuel sender unit?
- SC300 Custom Exhaust - Who has them, please chime in!!
- 93 SC300 - Need help ASAP - ordering steering rack and water pump (many variants)
- Dear Carson Toyota, thanks :'D My car is about to ride like new
- Thermostat replacement sc300
- heater problem
- 1jz Soarer engine swap into Sc400?
- Shredded the timing belt on Sc400
- smoking engine bay???
- My story of how Toyota blew my Tranny
- Tower Strut bar on single turbo
- lexus transmission solenoid # 2 replacement
- intercooler help
- replacement coilpacks
- 701rwhp @26psi dyno sheet
- VIDEO:First start up of single turbo install
- sc300 1jz swap
- Replacing #2 transmission solenoid
- Thinking bout creating a 1jz
- car driving slowly, pre-cat's are red hot
- S-AFCII question please help
- LSD Advice
- Engine serial number
- Washed my engin then....
- Toyota and Lexus parts.??
- Anyone have any undercar pics of supra exhaust?
- half shaft help!
- 1jz auto problem..
- A/T---->5 speed
- Temps
- 1JZ Auto Trans On 2JZGE
- OMFG, Hesitation STILL here and getting WORSE
- 60-1 turbo kit
- question on w58 tranny
- ebay turbo kit
- 1996 1jz swap
- 1992 sc300 5spd sudden loss of power on highway!
- SC400 Overheating
- "stage one" now complete on my jspec goodness
- where to buy a 1jz???? Need links
- Anyone Have Diagram For Safc
- Anybody interested in a partial kit?
- JDM to USDM 2JZ-GTE.
- V8 MAf or stock SC3 MAF with 440cc?
- Help, car wont start
- why 1jz
- step one complete
- Need help, heater doesn't work
- Water pump blew chunks, need advise (Phoenix)
- Compression test on a 1jz
- Should rear main seal be replaced when trani is overhauled?
- How much hp/tq can stock clutch handle?
- 1JZ Noob Question
- Where is IAT SENSOR
- Quick oil question
- OBD2 1JZ Swap...
- My 1JZ carnage from last night
- Changed Spark Plugs and won't start Please help
- So I finally seafoamed my sc400
- Post dyno graph on your SC400
- Help!! working on 1JZ Swap and 18 wires near starter have no place to plug into?
- Aural Pleasure = Tanabe Medallion Touring Exhaust!!!!
- Think I got myself a good deal
- New plugs, wires, cap 'n' rotor...MPG is shot to hell!!!
- Trans issue at 40 mph
- building a 2jzge block...
- Won't allow me to fill up my tank?
- High-pressure clamps + hard line
- sc300 1jz gt35r dyno done
- OMG somebody help me!! Warning LONG
- sc400 stay stock or 2jzgte
- Question for those with 1JZ swaps in Cali
- My local Toyota dealership is filled with idiots :(
- 1JZ Water Pump
- starting problem
- Acceleration?
- 1jz time
- Question about an issue i had
- Throttle Valve cable
- Toyota put Type III tranny fluid in my SC400
- NA-T build....need help!
- 1jz head on 2jz block easy?
- Lexus dealer doesnt have the tool for a tranny power flush?!
- ProBoostChip?!?
- Engine swap 2jzge to 2jzvvi na
- cheap/free horsepower gains
- Fuel filter-1, stokdd-0
- 7M diff in a SC
- question about idle speed..
- driveshaft question
- NOOB QUESTION ABOUT 2JZ swap...
- Weird Jerking when shifting into Drive.
- Changing Water Pump
- Q: About Muffler
- My GTE engine progress pics :)
- r154 clutch fork removal
- HKS knockoff mufflers...my test trial
- PT63 Project *Sneak Preview*
- Sc400 Timing belt
- Problem with your Diff or driveshaft bushing?
- I dont move in "drive"
- spark plugs in single 1jz? and cam gears
- Suggestions pls ! ! Add a little power on a tight budget need help
- Engine sluggish/non-responsive at start up occasionally.
- sc300 swap question
- whine? where is it coming from (yes i searched)
- Supra 6 Speed trans (value?)
- Need a GTE engine.
- auto to manual
- trac light problems
- mufflers interchangable on SC300 and SC400?
- 1.5 jz? on 92 sc
- Writeup on installing GM TH400 automatic transmission
- Help with ignition coil...
- wastegates questions??
- Need advice: 1JZ DP and Exhaust combo
- problem with gas gauge
- Supra 6spd LSD into SC300
- IS300 header on a 95 SC300?
