PDA
View Full Version : Performance & Maintenance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 [71] 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87
  1. toys came in lol
  2. Where to buy supercharger kit for my sc400?!
  3. Turbo surge
  4. 6 speed torsen in sc400?
  5. SAFC2 Wiring Question
  6. How much did it cost you?
  7. Coolant dissap.=problems..
  8. Anyone solved CE Code 25 ? 92-94 SC4
  9. Over heating
  10. Going rate for a leak down test?
  11. na-t's with stock maf
  12. AC Problems....(yes I searched already)..HELP!
  13. save on gas/extra pep for sc300
  14. Putting on my Magnaflow 14829 mufflers with all new piping.....
  15. Easiest/Best tranny for 2jz-gte swap
  16. Headlights dim when I hit the brakes
  17. what LSD fits SC300 5spd?
  18. JDM 2jz-gte into US spec?
  19. whats this about the sc400 can be 5spd ?
  20. Whats wrong with my baby?
  21. Flywheel install - does it matter how it is installed?
  22. Leaking Oil Pan Gasket
  23. engine mounts - steering rack
  24. quad tip dual muffler setups WANTED!
  25. Master Cylinder and Clutch Pedal Assembly
  26. mods to increase gas mileage
  27. how much do front clip usually run for these days?
  28. need turbo on sc 400
  29. my trac light is on
  30. Hks Vpc ?
  31. Where does this tube from the Charcoal Canister connect to?
  32. Soarer LSD?
  33. Driveshaft Center Support Bearing?
  34. My new toy for my SC
  35. IS250 shift knob fits SC300 5sp?
  36. SC300 Stumbling on Full Throttle or Idle??
  37. Help NEED TRANNY FOR 92 SC400
  38. ABS unit compatability
  39. Which manifolds fit the 2jzge?
  40. 1jz-gte mpg?
  41. Auto to manual near complete, one minor problem
  42. Having boost issues with my 1JZ SC300.
  43. Motor Teardown
  44. manual gear box problem
  45. 400 hp 1jz or 2jz.. cheaper?
  46. 1jz v v t i swap info a 97-2000 sc 300
  47. MK3 1JZ injector compatability
  48. Lights dimm and car seems to turn off and back on?
  49. Motor Mount Upgrade
  50. Injector question
  51. 2jz-Gte into an Sc400... I know it has been covered before...
  52. Spark Plug Heat Range?
  53. 2jz info
  54. Budget Cold Air Intake 2 - Total Spent $53.79
  55. looking for sound clip
  56. Fuel Filter for my sc300
  57. stock flywheel weight VS supra flywheel?
  58. FYI GS400 ECU learns and compensates you may be lean
  59. Motor is out - finally...
  60. Swapping Spark Plugs Tomorrow
  61. so-cal 2jz-gte transplant looking for a shop
  62. If compression test checks out well, is a leakdown necessary?
  63. 2jzgte swap info/pricing
  64. Anyone with bad heater valves and a free 'fix'
  65. CEL for: 02 heater & TPS
  66. TRAC OFF blinks after installing new tires
  67. Remanufactured Starter - OK????
  68. New SC Owner & CEL Problem
  69. The fun begins tomorrow... wish me luck!
  70. sc air filters
  71. BFI Question
  72. Turbo Project...
  73. Turbo Kit Install - Day One
  74. Project V8 enroute
  75. which turbo route?
  76. Help me pick out which mufflers I want.
  77. supra NA ECU same as SC300 5 sp ECU?
  78. how much oil does your engine eat up?
  79. Sc300 and Gs300 engine compatibility?
  80. Replacing stock Cats with new high flow cats?
  81. Replacing Transmission Mount on 92 SC300 - New Mount doesn't Match
  82. power steering help
  83. obd1 code scanner?
  84. sc400 V8 manual transmission conversions?
  85. 3uz-fe swap
  86. Recomendations for my new SC..
  87. Very Important 1JZGTE 1st Gen Recall info!!!
  88. best 1j bang for the buck mod
  89. 100K Tune Up?
  90. trans dont shift until slightly warm??
  91. cel code 25 and 26 ANY INFO PLEASE?
  92. What do i need to do to get rid of my distributor?
  93. Sc300 Mods
  94. is my starter gone?
  95. Changed PS pum and car won't start
  96. serpentine belt idler pulley question SC400
  97. What does this vacuum hose attach to?
  98. GE buildup with GTE parts
  99. help!!!! anyone using this
  100. SC400 low idle
  101. Changing clutch
  102. sc300/supra master cylinder question
  103. Whistling intake
  104. whining / screeching noise when turning engine off
  105. WhereTB OEM crank pulley
  106. Problem with my SC300 staying on
  107. Rising Temperature
  108. How much power can the stock 5spd tranny handle?
  109. auto to r154 swap help
  110. Hesitation, temp problem
  111. 1JZ auto + NA ecu = ??
  112. SC300 MAF Resistor Pin Location?
  113. Does Soarer 5 speed have LSD
  114. started 1JZ swap and damn it!!!
  115. Budget Cold air intake
  116. Anothe power steering question.
  117. My 1JZ swap.
  118. Transmission
  119. charging system diagram
  120. SC300 tranny
  121. First post.. WHAT'S THIS CAR WORTH? - and other imponderables.
  122. TX emissions
  123. TX emissions
  124. Question for those with 1JZ swaps
  125. Heater problem
  126. got_trd's 2nd vid
  127. A/C Compressor question
  128. BLown Transmission
  129. what are the fuses for???
  130. Noob with 2 questions.
  131. car still wont stay on!!!! help me!!!!
  132. JIC Dual Exhaust (SC300)- Where to buy?
  133. sc300 cat and gs300 cat
  134. So I think it's time for an ATC.
  135. Clutch pedal stiffness and doesnt return properly
  136. HK$ Timing belt, worth it? Other related questions...
  137. Power Steering; yet another one
  138. high rpm exhaust smoke?
  139. What does a 4in Exhaust & DP sound like you ask?
  140. HELP NEEDED NOW!!please
  141. Harness question
  142. ECT Sport switch not working
  143. How come the SC430 gets a compressor?
  144. Whats going on??????
  145. what cams can i use for the 2jzge
  146. Which setup for daily driving?
  147. CAI installed
  148. Custon Exhaust system headers 3" pipe cat hks exhaust
  149. SC400 Motor-mount questions
  150. swapped 1jz dudes... can you still get ECU codes with US dash?
  151. Gas smell from enging
  152. Need some turbo advice please....
  153. How to Tune your SAFC I/II Courtesy of NPM
  154. What's missing from this list? (r154 swap)
  155. need a starter!
  156. 5-speed parts interchange
  157. Official SC exhaust thread! post up.
  158. 1992 SC300 5spd runs great at startup, HESITATION once warmed up..
  159. 1uz vs. 3uz weight
  160. sc 400 manual transmission
  161. Heater Problems
  162. Car hesitating. Used Seafoam and compression spikes.
  163. 1jz dyno runs
  164. Other make parts
  165. i got a damn light popping up
  166. catalytic convert hollowing/removal
  167. JDM To USDM Auto GTE into 99 Sc300 Swap Info
  168. Sc300 Jerking at 4000 RPM
  169. Problem installing shifter on a 95 SC300...
  170. ebay turbo?
  171. What is that light?
  172. Good sites for 1JZ/2JZ swappers
  173. driver side muffler
  174. something wrong with my car
  175. Too much engine/transmission noise from console area
  176. Tell me about the SC's traction control system
  177. idle rise and fall
  178. Throttle body question (sc300)
  179. Flashing Lights in console
  180. Wanting to buy SC400 99
  181. Auto>Manual conversion SC300 - What is needed?
  182. will IS300 5 speed trans fit sc300 5 speed?
  183. Supra TT harness
  184. 95 SC400 MAF Problem
  185. Weird problem with the sc...
  186. vvti motor in non-vvti car?
  187. Ever seen this 1uzfe clip?
  188. turbo/distributor clearence issues on ssautochome manifolds?
  189. what should i do??
  190. Immediate Help Please!!!!!!
  191. 1JZ Is In!.... But have some questions..
  192. Vaccuum Leak!
  193. Exhaust Questions on my SC
  194. HKS F-Con Fuel Management with 1JZ swap
  195. RDMS SC400TT-dyno results..
  196. 1jzgte parts....
  197. SC300 Muffler upgrade?
  198. SC300 NA-T Muffler choice?
  199. sneak peak before the big numbers come in
  200. Turbo kit??
  201. what you guys think
  202. Car requires two cranks to start
  203. HELP! possible ECU issue.
  204. Faster
  205. Transmission rebuilding, 98' sc300
  206. VPC resistor location for 93 2jzge
  207. Master/slave cylinder question.
  208. Help! S&S Headers, now no Start!
  209. intercooler piping route?
  210. 500hp civic or Lexus sc300-T
  211. Exhaust and Catalytic Converter questions
  212. all-motor route??
  213. Has anyone supercharge there SC300?
  214. Air In The System Need Help
  215. sc300 na-t
  216. aluminum 1JZ spark cover
  217. How many 1jz SC300/400's on this board?
  218. for the sc400 guys
  219. 2JZ-GTE swap into a SC400
  220. Dyno'd my sc4........
  221. Is this a good 1jz price?
  222. gt35 sc400 project (stuff)
  223. Anyone using SP's na-t kit?
  224. Preppin' for the 1jz swap
  225. Exhaust 4 99SC300
  226. Please Help Me Out WIth A Vibration Problem...
  227. Couple Questions on swaps
  228. So...I got a new starter....
  229. value of soarer R154
  230. Help!!!!!!!!!!!!!!!!!!!!!! (trac and check engine light)
  231. If you're new READ THIS FIRST!! Please Sticky.
  232. K & N intake kits
  233. sc300>400 transmission
  234. Central Jersey Meet 11/26!
  235. bypassing fuel pressure pulsation damper
  236. Help. What did I break?
  237. This is a stupid Question but.....
  238. Updates on my SC300
  239. Intake discussion, and BFI
  240. help with supercharger for sc400
  241. My 1st MOD
  242. important 1JZ swap info learned
  243. Price premium for 5sp SC300
  244. I need the NYC to help me on the come up
  245. So I dropped my girl off at the dealer tonight...
  246. weird start up
  247. convertin trannys between auto nd manual!!
  248. Random 1jz questions
  249. Vibration
  250. how much is this setup worth
