- *Tanabe USA* R&D for exhaust
- Nagasaki JDM engine????? does anyone have experiance???
- Hydrogen Boost Fuel Injection System?
- huge noise when shifting from Park to Reverse
- Supra Fuel Filter work?
- 1jz into a stock 5spd
- Possible tranny problem- help me with a quick question...
- help finding ECT
- need more power
- swap manual?
- 60mm Gauge Pod?
- rev to acceleration problem
- car dies three times, now wont start!!!!
- Pros and cons of Diff / lsd
- Apex-i S-AFC NEO
- chirping/squeaking sound...HELP!!
- whats causing this sound???
- clutch pedal
- 1jz vs 2jz vs 1uzfe MPG
- W58 "whine"?
- R154 or W58...
- CEL after stepping up boost
- 1jz clip , tigerjapanese.com
- Thinking about putting a 6 speed in my SC400
- 4l60 tranny
- Fixing electrical gremlins
- Turbo SCers sign in!
- How long can a timing belt last?
- 2JZGTE ECU Question.
- US Spec 2JZ-GTE?
- shifting problems with auto
- how much for m/t swap in '93 sc300
- Stock rear end?
- PS pump help! Question after search
- Front mount intercooler and hard pipes for a 1997 SC300 with a 2JZGTE
- xs power kits?
- Cant turn Overdrive On
- 1JZ wowes.........
- 95 SC 400 A/C help...
- 2JZGTE into 1992 SC300 "manual"
- street testing 1jz
- Speedometer Failure After Clutch Change
- Pics of my engine
- Haha
- need help asap.
- compression #'s
- Car cutting out!
- Cats melted!!?? 92 SC4
- clutch/slave problem need help!
- Supercharged 97 SC400 Videos
- My SC4 stalls after I turned off A/C
- running rich. dont know why. help
- Straight Pipes on SC400
- Auto Transmission
- throttle body pulley wont spring back.
- Zees exhaust!
- exhaust Q's
- VVTi head
- Turbo Question
- sequential 1jz?
- Does ANYONE have a 97+ with working tach after motor swap?
- FYI Found a Supra TT engine with 6spd tranny
- HKS 1JZ Twin Upgrade??!!
- SC Exhausts or Exhaust Tips PIC THREAD!
- Odd Engine Swaps...
- Problems with my 2nd Rear diff..whats wrong?
- Poll: Maintenance and/or Modifications
- Ebay Swaps?
- exhaust system help, where to find best prices
- My traction light started Blinking?
- Help Please!
- Need An Intake!!
- So I Fixed Code 13 RPM Signal
- Perfect play toy
- SC Exhausts or custom exhaust Tips PIC thread!
- Test only
- Will an LS400 rear bolt up to an SC?
- Mechanical Issue
- looking to convert sc400 to 1jz/5spd, is it much harder than a sc300?
- na-t manifold toyomoto
- Crazy Crank Pulley Issue!!
- big single on NA SC
- SC300/400 billet fuel pump hanger, finished product pics
- Thinking about an SC
- Who all has done this and is it a good idea?
- (Picture) is this the low side for A/C recharge?>>>
- Heat coming from ebrake
- Does anyone know?
- Help removing my Intake manifold
- DSPORT: IM PUBLISHED ... tuning related
- Torque Converter Question
- A/C quit working, just in time for summer :(
- which way to go??? 1j,2jgte,na/t??
- possible or not 355-400whp on 5k budget.
- weird electrical bug.
- IS headers on an SC?
- Fuel/Air mix gauge
- 1jz help needed
- Remove front cats?
- Change out freezeout plug-97 sc300?
- MKIII Supra LSD?
- Coolant and Oil Light?? WTF
- having some weird issues... maybe someone can help
- SC400 Motor
- Help! My 1UZ is making noise... So is my A340E
- Man o Man
- Water/Alcohol Injection on NA Motor?
- So.. How about a Fuel Cooler?
- Fan clutch on 94 sc300
- Dyno soon, in all honesty what kinda power can the w58 handle?
- AEM cal needed for BL Stg2 kit
- Quick throw down?
- O2 sensor question
- 6-spd conversion for SC400?
- CODE 24 IAC..need help!
- Steering pump
- Where do you get parts for your 1JZ swap???
- Heatercore coolant pipe problems!
- 1jz gte versus 2jz gte
- Besat clutch for 5 speed sc300?
- for the 1jz swappers
- How to remove the ECU?
- is there a seperate tranny ECU?
- A/C pulley is making squeaking noise...
- SC300 2jz-G/t/E project....
- National Service History
- quick question about removing the EGR system
- engine won't start or dies while driving
- Best way to flush fuel system?
- Crank Bolt Removal
- What would we do w/o great mechanics!!!!!!
- 5spd swap = check engine light, help?
- Removing Traction Control?
- Need your help guys
- Stock 5 speed question,
- Early stages of a Auto to 5 speed swap "How To"
- does all sc300 have traction and abs??
- radiator question
- another auto < 5 speed?
- Pricing on swaps?
- what all do i need
- question on motor mounts.
- Crank Shaft Pulley
- What model is my motor from?
- Sticky Clutch
- Got my 5spd Swap today, thanks R&J Distributing
- TRAC light prob.. all help welcome!
- Need quick advice on transmission...
- Sacreligious
- 1jz swap questions
- Strange rattling sound and whistling....
- Just bought a Chip for my sc300 need some q's answered....
- NA-T Stalling problem, can't get it right, HELP!
- Hesitation when rev, feels like a 'dragster' lol
- 2jz cam gears in 1jz?
- Removing the EGR bar from the Intake
- ecu stuck on 100% fuel ...wtf?
- Coolant in #5 Cyl.???? Help!!!
- any prob. with 99 sc4 trans.?
- Why CEL after putting in gas?? All the time?
- Worse gas mileage after cahnging O2 Sensor?
- I know I'm a Noob..(noob didn't title thread either -how can I find an exhaust leak?)
- My custom 6 puck setup!!!
- got a little problem introduced today...
- i need a pic
- Stupid Fuel Filter!!! Help
- engine shaking HELP
- Where can i find these Mufflers??
- Noise from engine
- Ridin on my new 2800 stall speed torque converter!
- 2JZGTE w/67mm Turbo, exhaust question...3 Mufflers, or 2 Resonators & 2 Mufflers?
- HELP! Motor issues...
- installing mvp header on supra
- Just Finished 5 Speed Swap
- 1JZ wiring question
- My baby is sick again, HELP!
- EGR blockoff plates
- Best clutch for the buck???
- gs400v8 vs TT2jz
- A/C R134a Gas leak.
- Auto to manual swap.. now the car wont start- Help!
- Anyone have a spec list for testing 1jz engine?
- HELP! overboost problem.. 1jz swap sc300
- IS300 VVT-I engine in a sc300?
- Air Conditioning went crazy
- sc4 sitting for month in winter now problems?
- Help my oil is leeking !!
- Vehicle Speed Sensor Wire on 1998 SC300?
- Alternator or Battery?
- Fuel Tank Pressure...
- SC300 power steering pump
- 2JZ-GTE, question...
- 1j cranks but wont turn over
- complet swap
- OMG help (help = cant pull the crank pulley bolt out)
- better vids after MVP header install...
- 2JZGTE w/4spd Auto - Fuel Economy is great!
- A new spin on engine swaps for the Soarer
- Looking for Nitrous Pics/Input
- OverHeating - Please Help!
- Post pictures of your (boost, oil, temp) Gauge(s)
- 1jz parts cross refrence
- 1jz T-Stat???
- thinking of swapping 1jz/5spd. into sc400. help appreciated
- exhaust rattle?
- need help for 1uzfe
- 2JZ GE VS GTE block for turbo charge
- door lock actuator
- 1992 Sc400 Problems, Think its the alternator!
- just bought a NA-T kit and have a spare auto and W58 tranny? which one ?
- Does anyone know the power steering fluid capacity?SC400
- 1JZ-GTE VVT-I into a 95 sc300?
- anybody with a 97+ 1jz swap care to chime in
- 1JZ Power Steering Pump...
- cam and crank timing. help
- need help
- intake for a sc400
- After diag, dealer says main ECM... wants $1250, input?
- Smog time
- Overheating-HELP
- Knock CEL - What do I do?
- chaser to soarer 1jz pics proly not 56k...
- Help with 1jz harness into manual sc3
- anyone know where to buy a cheap cone filter?
- No Brake Booster Banjo Fitting Spot...1jz
- this is just WRONG
- 92 SC 400 starting problem
- sc400 95 heater puzzle
- sc400 six speed?
- Crank pulley bolt- how do I remove this thing?
- Just washed engine bay, now car wont start
- economical swap
- 1J swap ( throttle cable ? )
- quick question on a 1jz in a sc
- SC400 engine mount replacement
- idle problem on a load
- In the process of BFI
- For all of you with 1jz/2jz, how do you handle your exhausts?
- piggyback SC400 1uz-fe ??? ??? ??? ???
- Centerforce Clutches
- 5spd conversion
- DIY Cold Air Intake
- Engine Running HOT
- Where would i find a 1jz tensioner pulley?
- New TT style intake manifold for your NA-T
- ABS and TRAC lights
- Valve cover gasket Problem
- So if I........(tuning kind of)
