PDA
View Full Version : Performance & Maintenance
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86
  1. Sc300 with sc400 radiator problems
  2. What do you guys think about this turbo?
  3. Need Help ! No Power !
  4. 1 JZ starter question
  5. Accl controller question.
  6. how do i get a soarer harness/ecu to work with chaser engine
  7. JZX100 auto ecu gear inputs
  8. 1992 Sc300 Alternator.
  9. r154 Extreme play in shifter
  10. 1JZ-GTE Ticking, Revs and Dies
  11. Aftermarket header problems
  12. Dyno results are in 662hp on 2jzge
  13. Crossmember issues?
  14. Fuel Lines
  15. Exhaust question...
  16. SC400 Plugs Recomendations
  17. 92-97 vs 98+ sc400 differences?
  18. 95 Hydraulic Clutch
  19. Spark Plug stuck
  20. suprasick on my stock 300 bai/exhaust
  21. Why isn't there an NA section?
  22. 1jz starter questions
  23. Need pic to fix code 71 (resistor mod)
  24. 95 Sc400 idle and acceleration problem
  25. replacing fuel injectors, anything else I should do at same time?
  26. Just replaced my knock sensor...
  27. Cxracing turbo manifold
  28. Just order my knock sensor
  29. "Chugging" at 40mph
  30. na-t or 1jzgte automatic
  31. Gated shifter help! Car will not move when in gear
  32. Check Engine Light, Running Great
  33. Aem 1100 box on NA-t stat sync'd OFF help
  34. slippy release bearing SC400 + W58 + T56 bearing
  35. 1JZ - Why does my 1J like plugs gapped less than .020??
  36. Power steering vacuum air control valve issue
  37. Power Steering noise HELP!!!
  38. trd s/c for sale
  39. Master cylinder install question on 5sp swap
  40. Starter help please
  41. Weird EFI Problem
  42. Anyone w/ 98-00 GS300(auto) ring/pinion gear?
  43. New to lexus need help what's te best fitment for A 92 sc300 the supra motor are the
  44. Inner distributor leak?
  45. 95' sc400 serpentine idler pulley question.
  46. tell me why this will not work on a sc400
  47. BMW gearbox + 2jz ; anyone stateside done this yet?
  48. easy fix for squeaky door panels
  49. Does our orig. key affect a new ECU?
  50. 1jz oil pan dented
  51. Loss of power
  52. cel code 52 on a lexus sc 300
  53. Upgrade S366 to 11 blade billet wheel
  54. Weird Issues With SC400
  55. Advice on buying a flodded SC300
  56. 93
  57. Clutch pedal assembly...where do last 2 bushings go?
  58. 98 sc400 cel codes
  59. need some help out here guys.
  60. Replacing SC A/C evaporator, expansion valve and heater core - Am I missing anything?
  61. Key & Tumble / Ignition Switch Same as Supra?
  62. Random AC Light flashing sometimes....?
  63. Why does our EFI relay get hot?
  64. Sc400 poor idle
  65. ECU & Transmission issues
  66. Weird starter issues
  67. Manifold question.
  68. 1JZ Starts, Idles, and Dies
  69. swap questions
  70. SC Transmission Pan
  71. O/D light flashing, Code 42, No 4th gear
  72. highest hp na 2jz
  73. Car died after 30 miles on a full tank
  74. proportioning valve location
  75. Setting TDC with the DM crank pulley
  76. Sc400 starter replacement issue CEL&overheating solved
  77. Ignition Timing on SC400
  78. My '94 baby
  79. DIY Aftermarket Fuel Rail Installation on 1JZ w/ Pics
  80. Rubber Exhaust Hangers
  81. sc300 1jz vvti swap tach not working
  82. Having issues with USDM OBDII TT ECU mod
  83. SC400 VVTi Intake airbox & intake pipe
  84. 95 Sc300 radiator bubbling issues
  85. Need advice on adjusting clutch
  86. Just got my DM SC300 5 speed pedal package...any assembly guides?
  87. Must sway bar end links be a matched pair?
  88. power steering
  89. Headlight Cleaning and Defogging DIY
  90. '94 SC400 TPS part #?
  91. manifold remove
  92. Replacing shims for aftermarket cams
  93. US spec engine with JDM Mines ecu ??
  94. Driveshaft center support bearing bolt spacers
  95. radiator fluid leaking. need to replace a pipe
  96. What kind of power are you making?
  97. Eaton Detroit locker??
  98. Throttle body relocation on 2JZ-GE
  99. plummeting mpg
  100. 95 SC400 stuck in park, no power windows, roof, or steering Please Help
  101. Oxygen sensor questions
  102. Ordering some 5 speed conversion parts, missing anything?
  103. sc300 wont start anymore!
  104. Fuel pump differences?
  105. helpp (SWAP)
  106. I am so bummed. Tranny frustrations.
  107. will this injector work?
  108. Ignition switch ques.
  109. HELP!!!! My car fins fine untill put in drive or reverse!!!!
  110. Preferred Turbo kit?
  111. 1JZ SC300 swap finally done needs tweaking! Help?
  112. Issues after 5spd swap
  113. 1UZ spark plug torque?
  114. Grounding problem SC300 '92
  115. SC400 new fuel pump, ECU bypass, stranded again
  116. Cracked manifold worth fixing?
  117. what would you call this clip?
  118. are all transmission mounts created equal?
  119. 1992 sc300 with 95 bumper and fogs
  120. Stumped on clutch/trans issue on 2jz/r154
  121. Rear drive shaft
  122. 92 nat bogging issues
  123. SC400 Transmission Dipstick - Do I have the Wrong One?
  124. 1jz harness missing alternator plug and wires??? help asap!
  125. Supra or Aristo trans in my SC300?
  126. SC300 1JZ Starter Problem
  127. Thermostat question
  128. Help with AC compressor and clutch.
  129. Boost leak/ Turbo failure?
  130. Removing resonators on Sc300? Effective for sound as on 400?
  131. Removing resonators on Sc300? Effective for sound as on 400?
  132. 99 sc300 aristo swap driveshaft help needed
  133. Which standalone is for me?
  134. Civic AEM V2
  135. ECU questions
  136. 17mm Bolt Above Thermostat Inner Threads Stripped Help!!!
  137. 1jz
  138. sc300 with 350z straight pipes
  139. Anything wrong with this R154?
  140. Help with 2 things. Starting issue/timing belt & water pump questions
  141. Serpentine Belt Question
  142. A.C. parts replaced after compressor failed but still not fully cold
  143. Code 14 fixes? i need help!
  144. overheating issue
  145. jzx100 (chaser) into 93 sc300
  146. SC400 Trouble
  147. Cluster problem
  148. A/C refrigerant level
  149. where is the DIY for fuel pump relacement
  150. Shaky, loss of power up hill.
  151. IS300 Fans - How to wire them
  152. Mechanical trouble already???
  153. 97 SC4 Engine Idle/Whining Issue Update
  154. 2JZ Dimensions?
  155. Just dropped in a gte
  156. Question on GS400 3.26 rear diff in a gte swapped auto SC...
  157. SC400 no power, burning, rough idle
  158. 97' SC400 Whining/Whirring from under Hood
  159. Ac compressor question about 2jzgte/1uzfe compatibility.
  160. 1jzgte vvti (JZS171) ECU PINOUT
  161. SC570 (LS1 SC300) cammed idle.
  162. Am I forgetting any maintenance items?
  163. Anyone used Driftmotion's 1JZ aftermarket timing parts?
  164. Map ecu 3
  165. R154 Clutch slipping?
  166. Help with Power Steering Pump
  167. 1jz harness has extra body plugs?
  168. 1999 sc300 tune up
  169. titan motorsports cams vs gsc cams?
  170. how do you get door moldings off
  171. help me with 2 things lol
  172. 1jz with 2jz-ge auto tranny?
  173. How to: Fix your door opener actuator rod lower end
  174. '93 sc300 transmission fluid
  175. Removed rear differential, I think it is making noise, is this normal?
  176. 97 fogs on a 93 sc
  177. 2JZGE NOS Direct Port Nitrous setup coming soon! Any input?
  178. SC400 Max Fuel Pressure (help please!)
  179. SC300 Coolant Reservoir Cap
  180. Sputtering & stalling issue... won't stay running!!!
  181. Heater control valve
  182. where to buy 1jz torque converter?
  183. SC400 Transmission Whine in 1st Gear (A340e)
  184. Differential Fluid Change and Trans Fluid Change at the Dealer
  185. Defeating/Bypassing the Coolant Level Sensor?
  186. Code 52 Knock Sensor on 92 SC400
  187. 1JZ custom patch harness, or just splice/solder?
  188. need lsd diff installed
  189. Drag Tire Recommendations
  190. AEM EMS v2 Timing Problem NA-t
  191. LS430 Diff?
  192. Alarm reset not working
  193. SC400 P/S Buzz question
  194. O2 sensor resistance (cold)
  195. Electric Radiator Fan Install simplified?
  196. Tranny Swap
  197. Is this an R154?
  198. Found a few promising turbo engines, help me pick one
  199. 1.5jzge just need a little info
  200. possible blown head gasket not entirely sure
  201. 1jz people I need help!
  202. Isis fuel pump
  203. Gas Tank Pressure needed?!?
  204. Need help, Electronics not working!
  205. Lean @ Idle, Trac light
  206. 1JZGTE Tach Fix 92-94 & 95-96
  207. Complete Diff bushing kits now available. Multi-piece design for the SC
  208. car missing need help please....
  209. Car shuts off when i turn off the A/C
  210. 92 SC300 Pouring white smoke
  211. what radiator do i have?
  212. 1jz wont fire aem gurus needed
  213. So hot in PHX... Need A/C Help!
  214. 1JZGTE VVTI IN SC300 wiring question
  215. Help, about to pay $355 for Vapor Canister!
  216. 1jz auto help
  217. sc300 2jzgte help, grounded alt.
  218. smoking and stalling
  219. SC4 cooling fan behavior
  220. AC Pro kit works! Definitely worth $$ IMO
  221. how to troubleshoot heater control valve?
  222. driveline vibration after 5-spd swap help me diagnose
  223. Na-t or ls/t56 swap?
  224. Help sc400 overheating with a/c ON
  225. from 810 to 560 in one night. bad idle
  226. Sc400 intake measurements please
  227. Help my 1jz auto dies!
  228. DIY LS1 Motor Mounts, LS1/T56 Swap
  229. Anyone tried Duralast VC120 Vapor Canister?
  230. catalytic converter
  231. 2JZGE Bottom Mount Turbo Manifolds?
  232. Idles at 0-100 rpm but No stalling. Help
  233. Electrical issue
  234. timing belt slipped
  235. 1JZ swap start up on AEM V2
  236. I need to rescue my SC - I turn the key to ON, and nothing works.
  237. Greedy Blue/ Ultimate ECU Reviews?
  238. '93 w58 swap into '92 auto
  239. problems in my sc 300
  240. SC 300/400 gte swap AEM Ecu question.....
  241. Starting issue/funky idle....
  242. at 45 mph car quits running, would not start
  243. r154
  244. is the 12v fuel mod good
  245. Where in 2014 can you find the 1UZ-FE Knock Sensor Sub-Harness?
  246. CX Racing Turbo kits chime in
  247. What harness is this? 98 SC400
  248. Fuel pump upgrades, mount corrosion
  249. Brown liquid from intake?
  250. 98 SC400 Knock Sensor HELP
