- 92-07 Lexus SC Series Throttle Body Bypass Kit +8hp
- 1jz engine swap
- Air Condition?
- Ok What Would You Do...
- couple of new pictures of centered exhaust
- Crank pulley debate
- No acceleration and burning smell.
- Cold Start Idle
- suggestions for leaky head gasket
- NEED HELP! 93 sc300 wont start, then start, then dont
- SC400 Cooling Fan Pump, Who has replaced it?
- Exhaust for 1999 SC400 w/ VVTi?
- Th400 vs Built Auto
- can anyone positively id this ecu
- sc300 tranny
- 1jzgte harness
- cant find a soarer clip!
- Where do I find a Pillar for my Gauges????
- Nissan Stanza electric fans in a 1992 sc300
- Funny how decisions get made for you
- Jumping FP and +B port. obd2 sc400.
- Turbo Socks
- Would these work for my swap?
- Key communicator issue for a 5spd swap
- want to start working
- ? on map ecu for na-t .
- *New Turbo*Bigger Injectors*LSD
- 1jzgte ecu question
- what year v8 maf works with sc300
- Turn Key Solution.
- Still sqeaking after repair!
- My Temp Gauge smokes crack.
- car died at work CEL 31: airflow meter signal (vacuum sensor signal)
- I need direction
- 99 sc300 6spd +2jzgte
- Clutch, which one is good??
- 1jzgte question regarding afm/mafs
- is300 5spd auto swap into auto supra/sc
- tuning safc2/vpc ?
- Is this a R154???
- '98 SC400 Transmission Pressure adjustment
- Remote mount turbo build
- New Exhuast!
- Can I Use 87 Octane?
- squealing noises - is it power steering?
- DYNO nightmare
- hi there
- Check Engine Light -Code 75,76 78
- Bubblegum? WTF is this?
- Trouble Shooting SC 400 Idle Issue
- Hot vs cold dyno runs
- 1jz sc300 question
- PT61 turbo loud sound
- 1UZ information, specs
- Ignition switched power wire
- 95 sc 400 need help!
- SC400 Cam Kit?
- Help, Swap Soarer Stuck, Help.
- Think before you buy an sc
- computer upgrade
- 1jzgte harness missing speed sensor plug
- na-T problem
- tranny swaps?
- gspeed wants to sell me a chaser clip???
- SC 400 Air Conditioning Service Info Needed
- fuel pump
- Manual Swap Question (Torque Specs)
- 1jzgte swap into sc300 questions?
- That's all well and good..
- 2jz tranny options?
- Air Conditioning
- shocks
- Traction control removal? Questions? Help? Any experts?
- multiple questions???
- Anyone buy the getrag trans. from Carson Toyota?
- is it possible this soarer clip is modded
- CEL Help.
- Maintenance help...
- Exhaust Question
- If im switching the complete powertrain from a 93 sc300 to a 97 sc300 is it ok?
- Just bought a 95
- 92 sc300 short shifter???
- 2jz-ge turbo manifold (NA-T)
- weird shaking coming from transmission I think
- (domestic) V8 in a SC300/400
- does this really work?
- Supra 1J Hydro Fan
- anyone else have this isssue???(water in engine!!!)
- AC problem.
- My turbo timer
- is there a writeup for installing AEM 1101 on sc300?
- Front cross member
- fuel cut or boost cut?
- S&S Headers for SC400
- SC 300 Problem!! Starts but won't crank. Need suggestions.
- SC400 1992, Won't Start Sometimes, Bad Battery?
- Need engine for '93 300
- Can't Find In Search: INTAKE
- Alternator issues
- 2 Blowoff Valves-Pros & Cons
- Shift Knob fitment?
- 1jz A/C wiring and a few other things
- Drive shaft 1jzgte to 94 sc300 & misc
- power steering fix..
- Whats a reasonable time 4 Removal of the oil pan 2 weld a fitting ?
- Post pics of where you mounted your BOV
- 1jz extending wires.
- 1jz swap questions
- Time to choose....v8 or NA-T?
- Racing Seats w/ Heaters?
- R154 and the SC.
- Lexus or Toyota 2JZ-GTE Flywheel Bolts?
- Who does 2jz head work in Seattle/Tacoma area?
- How much do the soarer r154/1jz bellhousings go for?
- Exhaust back pressure equals ? in hp gain
- SC400 Dyno test results are 243.5 crank hp at 5,400rpm
- Need ideas for Machine Work
- 98 VVTi motor. w58 tranny. is it possible?
- A Couple of ?s
- ignition-no start issue
- What is this?
- check engine light
- i need a motor
- Easier Solution to Dreaded Power Steering Leak
- SC300 exhaust ideas, i need your input please
- 1jzgte swap automatic harness manual transmission
- got a question bout the 2jz gte swap
- White smoke after replacing steering pump????
- 1uz xtras
- 2JZGTE (maybe 1jzgte too?) - Tach Fix! For newer model SCs 97+
- 2JZGTE guys, does your A/C work? Parts I. and II.
- Leaky Waterpump
- How do I remove my rusted on exhaust??
- Supra clutch pedal Assembly in a SC?
- Another adapter for manual on sc400
- 1jz-gte supra vs. soarer
- Changed the plugs and may change the timing belt
- another overdrive light thread. please help
- Overdrive not working! Help!
- Question for the 1JZ Guys!!!!!!!
- It's not my tranny!
- SC300 factory exhaust options fighting a ticket
- What simple DIYs if you think the SC burns too much gas?
- Stock Flange on a 1j
- Help Sc300 Vss And Parking Wires!!!
- 97 sc300 engine & tranny swap Help!
- 98 2jz-ge swap
- Burning oil but no smoke?
- 1jz idling problem, please help!!!
- Blitz Nur Spec R Mt3140 Exhaust
- I just Painted some engine pieces and did the BFI
- Removal of 5 speed parts.
- Check Engine Light - What was your Problem?
- AC just blows air, Low freeon?
- battery help
- Help!! 2jz-gte swap
- 6spd Getrag in SC with 2JZ-GTE?
- What need to keep from Soarer Clip for 1jz swap??
- Boostwerx Complete Turbo Kit for SC300
- Max 1uz overbore?
- fixing the 1jzgte throttle cable issue for $5 and 20 minutes
- Thinking of NA-T
- how to remove/replace clutch master cylinder?
- 2JZ-GTE in a SC Exhaust??
- '97 SC300 engine and tranny swap
- Timing belt.
- 1997 SC300 5 speed 1JZGTE swap
- soarer fuel setup
- could somebody teel me about the paper clip to the +b to fb
- Car dies.. alot.
- Is my Temperature Gauge normal (pics)
- No IGT 2 signal from ECU?
- Fuel level gauge problem..
- Strange Loss of Power When Gears Change
- engine swap
- I bit off more than I can chew.
- how do i get to the fuel pump ecu
- Serious issue
- Need boost advice
- oil light on periodically 15-20 sec., Oil full
- Car is being sluggish!
- Throttle body bolt
- HELP sc 400 running rich no clue!!!!!!!!!!!!!!
- Need some help with starter in SC400 ...
- Rear End Clunk
- 5-speed swap
- 5-speed swap
- A/c Drier/receiver, 92 SC400
- vacum hoses
- Rear end very sloppy---What could it be?
- Anyone Build a ITB 2jz ge?
- Problem with sc 300 Help Guys
- SC4 PS Pump Pulley..
- 2jzgte question
- Preservative advice
- 1998 Sc 300
- SC300 2JZGE into SC400 - Search Problem
- motor mounts
- Top Speed
- Looking for Exhaust shop: South MA/RI
- Just got my SC3...it wont start.
- where do you mount your front mount intercooler? Pics please
- i am a new owner of a 93 sc300 and im having problems
- cheapest place for clutch
- short block/long block
- Custom SC400 Exhaust on a Budget-- Pics--
- need help...1jz intercooler pipe
- Ceramic Blades FTL....Single FTW.......
- bleeding the clutch cylinder
- sc400 A/C Help needed
- Getting a sc300
- Where to buy a 1jzgte serpentine belt?
- power steering relocation for aftermarket manifolds on sc300
- Serpentine belt issue
- Cooling fan romoval
- Dreaded heater core leaking...can I safely bypass?
- i have to ask so be nice
- ****I ALMOST DIED TODAY!!! Accelerator stuck!***
- Vaccum Diagram
- No complete write up for a 2JZGTE swap????
- MISFIRE After Engine Cleaning
- Throttle Sensor Detector problem? Tranny problem?
- 1jz or 2jz
- 1jz problem Please Help!!!
- JDM Supra Injectors w/Resistor Box
- A/C System Diagram
- Performance ignition coils
- Stock exhaust system backpressure
- Speedrex Mufflers?
- 1J Issue (NO POWER) fresh swap
- Hybrid QUestion.
- ignition wire..
- SC400 Turbo Manifolds that keep the AC and PS?
- Vacuum tubing question
- My engine is pissing all over the place!
- need engine swap info
- Weird Problem, Any others?
- Injen Intake
- my sc wont start
- 2jz-ge NA-T motor question?
- 2JZGTE 5 speed with twins owners
- ECU is bad!!! help!!!
- Aem Ems?
- has anyone ever had a bad distributor on their car?
- BL 2.5mm headgasket question
- r154 help
- maintnence on sc
- What kind of motor is this?
- starting problem
