- Passing emissions with standalone....
- My SMOG experience...
- Click, click, vrrooom (SC300)
- sc 300 vs. sc 400
- My Dyno Results- T67 turbo NA-T (video included)
- Exhaust options.
- spark plug help...
- 92 SC400 O2 Sensor problem
- Where to buy motor?
- Thinking about buying this Soarer...
- nOOb questions on turbo stuff
- Noise
- Fuel pump
- TRAC ticking, ticking, ticking
- How do I ground my Igniter on the 1JZGTE??
- air ambiant sensor
- camshaft
- Help-a-noob Power Steering Questions
- Oh Boy, It's here!!!
- Extreme Heat
- A/C Repair
- 3things-
- Ball Bearing VS non BB.....
- who has greedy evo2 in the sc400??? will it fit?
- OIL: Synthetic or Conventional?
- Neutral Pull
- A/C Evaporator
- Speedometer accuracy and LSD
- Looky what I got.....R154!
- sc300 vs sc400
- O.L.T. could you PLEASE clarify...
- air intake tube on sc400 ques.
- unknown cold start fuel or ignition
- ClubLexus' Top 20 Fastest SC300's
- Need Pics of Dual Exhaust Setups!!
- Coolent recomendations
- 1jz Supra ecu in soarer?
- T67 DBB turbo.....my new toy
- V8 Maf
- My 1jz is on the way
- replace timing belt after 50k of use?
- 1jz-gte to 2jz-gte. Difficulty rating?
- Custom Cold Air Intake
- exhaust size
- fuel pump? fuel delivery? HELP!!!!
- How much did you pay for custom exhaust?
- ?? about midpipe...
- tranny or engine.
- starting issues...
- ac out??
- Supra LSD
- Help! 1jzgte sc300 driveshalf wont engage
- Tweak tip for auto Sc shifting!
- Weird SC probs...
- Play in shifter
- 400-600 rwhp sc's
- How did HP get boosted on 96 SC4's?
- Does anyone know where to hook up the kickdown switch?
- 2JZ-GE Underhood Vacuum Diagram
- 2jzGE head on a GTE block?
- Does anyone make a 20over stock compression piston?
- Supra wire harness.
- SC400 Transmission Mount Part Number?
- Which gear should I dyno my car in?
- running straight 4in exhaust
- Stalling Problems for my Sc300
- Post Pics Of 1JZ Swaps
- does anyone know about this?? ( Supra exhaust will fit or not? )
- ac out???
- Fuel gauge BELOW the E?
- The Swap Has Begun
- Stock 2jz-ge motor w/ arp studs
- 9 second SC's
- driveshaft question
- Iat ?
- Jumped my diag. and got code 71
- Clutch choices.
- can anyone help with this
- Frankenstein my whip
- what u think about this turbo kit?
- supercharger for a 97 sc400 ??
- supercharger for a '97 V8
- 2JZGTE/V160 into SC300, shifter question.
- How tall is a 1UZ-FE?
- 2jz into sc400
- i am a newbie in this forum. have a couple of questions.
- Flapping / Shuffling Noise... ABS???
- r154 shifter extention.
- Doubt regarding 1jz motorset
- radiator (from supra fit?)
- Best Looking 4" "JDM TIGHT YO" Exhaust Tips?
- LOL, I have a voltage issue.
- My New Exhaust
- Dual Electric Fan Question
- BRAKE Light from low fluid
- My new exhaust!!!
- aristo LSD on sc300???
- 1jz cam seal replacement
- Mysterious 1jz Black Can/Box Identification
- vvti vs non-vvti
- Technition said I had an Oil leak..
- whats the best performing exhaust for sc400?
- another rough idle question
- does anyone have a power steering hose diagram?
- Swap Quote....
- ? about a/c compressor going out
- where is the fuel filter located?
- Karman Vortex Sensor issue
- Disconnecting fuel line under drivers side
- timing belt shaving
- AC Manifold Gauge questions
- 1JZ w/ trd mounts?
- My 2JZ Swap with NAS
- strange crunching noise
- SC300 Firing order.
- turbo>800
- ?? about a/c compressor...
- A/C Randomly Blows Hot Air?!
- The Big Bad 1jz into SC400 thread
- exhaust rattle
- 1jz swap into sc400
- Help, low idle
- Which is easier AT or MT ?
- ARGGGHH! Power Steering Pump
- Water Pump/Timing belt replacement
- Engine Problems. Need Help
- Low throttle settings on SAFC with V8MAF
- swap over parts
- w58 sc400 DS
- Confused about rear diff mount.
- Need more air....
- New Shudder at coast... Help!?
- motor/tranny (th400) swap
- new engine or 5spd swap
- fuel filter
- Air Conditionong Issues
- Need advice, transmissin question
- Wiring Diagrams
- Aftermarket Shift Knob
- Auto To Manual Conversion!!!
- Does powersteering wheel always leak when it hits around 85miles?
- ??Help with oil pan removal on sc300??
- 1jz start up question
- Check Engine Light is on
- Noob Question Help Asap!
- i got an exhaust shop to help me delete my secondary CAT
- Wont start sometimes??
- stock whp on a 5spd sc300???
- sc question
- Waterpump with timing belt?
- SC400 CD Player Help
- BFI intake link
- Catch Can Lines.....How Big (an)
- vibrations while under load over 45mph????
- Question for those w/ MSD Blaster
- please help....which exhaust for 1jz? thx.
- just a simple noob question on the 1jz
- Automatic Transmissions
- engine is dieing
- Question about is300 turbo manifolds.
- New mbc... how much boost can i ran?
- Which is the #1 shift solenoid??(PIC)
- First Motor Teardown..Need some moral support
- Looking for Crankshaft Pulley.
- Dayco timing belt sc400?
- How bad of an idea is this?
- 2jz-gte(Aristo) into sc400
- changed vcg, plugs,wires,cap,rotor,and more(PICS INSIDE).
- Sc300 2jzgte swap
- Harmonic Balancer
- engine woes
- weirdest thing happend to me the other day
- TRD Supercharger
- Fuel line upgrade ?
- AC Redux
- Alternator Woes...
- Toulene Octane Booster?
- Oh Boy!
- 97+ sc300 DIFF ratio
- Need help with AC
- Tranny Swap Questions?
- Need input on Ebay turbo Kit
- Yeah..I searched! Tranny problemas
- semi downshift?
- new turbo engine or rebuild ????
- coolant hose under throttle body
- voltage issues
- new turbo engine swap or rebuild
- Custom Exhaust
- Belt tensioner
- Anyone bought from ******************
- Any1 w/ Lifetime warranty on SC400 alt socal
- auto to manual conversion question?
- Throttle feel of a 92 SC
- manual conversion
- Cruise on the outs
- hks fcon question
- Sc300 ac noise
- How to not kill the ozone with the A/C when pulling 1jz from clip????
- ground kit issue with sc400
- Which oil?
- 1jz to sc300 AC fix
- anyone knows what size??
- Accessory belt size?
- $1500 turbo kit
- Oily valves and pistons
- Weird problem. (fuel delivery problem)
- i lost two engines i 3 hours
- My car is not starting from a swap!!!
- Solid Motor Mounts
- Which Xpipe?
- 1JZ emblem on engine whereabouts??
- Headers and Mid-pipe or No
- Shortblock to Longblock (Parts?)
- starts but dies in gear
- Something is seriously wrong with my car...please HELP!!!
- SC400 135,000 Miles Transmission
- 1j differances
- cold power
- LSD for a 4.27 diff
- problem with battery
- How to change the 120A fuse?
- sc400 single muffler size
- Bobbing Shifter... is this normal?
- Expected times for sc300 5speed w/1Jz swap?
- 2JZGE Throttle Body Gasket/Cannot find
- trany ?
- Overheating, need a water pump writeup
- Conservation Question for a motor sitting.
- Excessive oil consumption???
- 1jz stock turbo upgrades
- Engine Issue...no idea what it is, and service center not open on the long weekend
- 2JZGE with ITBs?
- Noob Looking Into An SC300
- Which Nitours Kit for SC400?
- newbie question??
- How much does it cost?
- Looking for aluminum radiator??
- Metal head gasket
- Has my AC been converted? (pic)
- high tank pressure, fuel evaporating
- JDM CLIP + INSTALL Shops in SOCAL?
- Shifter Bushing Kit
- Fidanza Flywheel
- sc300 power steering pump seal kit part # ??
- 1uz 2uz 3uz Stroker Kits!
- Soarer ingo!
- I splurged.
- i neeed help!!!!!! electrical problems
