PDA
View Full Version : Performance & Maintenance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 [65] 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86
  1. 2jzgte intake manifold on a 2zjge
  2. Need a New Clutch Disc and What else??
  3. Anyone using an electric fan?
  4. Distributor?
  5. Check engine light comes on after trac is turned off
  6. over drive light trouble
  7. 5 speed question and more ?
  8. 1jz vvt-i in a sc300....
  9. Whats the fastest NA-t sc300?
  10. Question for the turbo heads
  11. 1jz speed delimiter
  12. List of Magnaflow products
  13. Fuel cut off
  14. Cam timing belt
  15. SC400 Water pump
  16. MAFs question
  17. Hissssing Gas Cap
  18. Short throw shifters?
  19. It's getting hot in here.
  20. Will this cold air intake work on my sc400?
  21. 2jzgte / 1jzgte help.......
  22. Strange noise at 60-70MPH but no where else.
  23. New Sc Owner! losing coolant
  24. R154 on 1jz automatic (speed sensor q)
  25. Car starts, then dies
  26. Got new motor mounts.. dont think theyre properly installed
  27. Still Stalls In P And N!!!
  28. TH400 people, question on driveshaft/differential
  29. 2000 4.0L VVTi into an SC400?
  30. Electrix Probelem Please Help (ALT?)
  31. TOM"S Soarer compresor kit?!
  32. Blown SC300 93 Head Gasket
  33. installation of bcc and scc
  34. apexi n1 vs magnaflows mufflers
  35. Nightmare Fix Done!!!
  36. DESPERATE NOW! SC400 power steering hose
  37. Check this vid out!! SC400 supercharged
  38. W58 with a 350-400whp goal.
  39. Emissions Problem, Engine Light won't go off
  40. 1JZ Single turbo complete!!!!
  41. anyone do a write up on changing from distributor to coils?
  42. 97 Lexus SC400 Supercharger project
  43. where to order oil pump from
  44. 1jz/w58/auto harness reverse lights?
  45. Transmission for turbo SC300
  46. Limiting factors in turboing the SC400?
  47. SC300 Intake Manifold
  48. Help!!! engine issues
  49. S&S Header on a '99 LS - A tale of woe
  50. SC400 hesitation
  51. Anyone Use This Turbo Kit?
  52. Getrag Swap Support/Mount- What are Sc300 guys using
  53. Power steering compatibility, SC300/400
  54. Install Pics Of Single Turbo
  55. Maintainence Q: bad idle, BAD noises; bad sensor?
  56. SC300/400 power steering compatibility
  57. Strange Starting Behavior
  58. i just ordered the aem standalone unit, who else has it?
  59. 2JZ-GTE swap
  60. sc4 is overheating..plz help
  61. My buddy sprayed off his SC's motor and now its misfiring. Cause?
  62. Help!! SC400 Socal members...
  63. SC clutch pedal question
  64. Project Nearing Completion, pics
  65. hks twin power DLI ignition module
  66. Ticking noise
  67. V160 syncros and bearing kit
  68. 1JZ Fueling
  69. reducing the weight of our cars
  70. JUst wanted to say ( happy 200th post) lmao
  71. rough idle
  72. VSS confusion
  73. where to buy exhaust piping??
  74. what cam options are there?
  75. Which o2 sensor is bank 1 sensor 1
  76. NEWBIE with p.s. fluid filter question
  77. Grounding Kit
  78. Stock Cat's???
  79. Error code 52
  80. egr, trac. control removal
  81. Random auto to 5 speed swap parts question
  82. Did you buy the S&S/JBrady Headers?
  83. 1995 transmission question?
  84. dual walbro setup
  85. Clutch or Trans?
  86. project sc250tt
  87. ijz sc400
  88. 1JZ + Race gas?
  89. Confused/Worried - Airbag Light ON
  90. Confused/Worried - Airbag Light ON
  91. Injector Questions?
  92. Auto to Manual
  93. 1jz to sc400 done and it is easy!!!!
  94. Power Steering Leak
  95. SC400 periodic engine vibration
  96. LSD gearing
  97. Notchy shifting when first starting
  98. what exhaust is this
  99. Just bought a turbo SC300
  100. cat-back exhaust
  101. exhaust pipe size?
  102. VVT-i Turbo/ vvt-i and piggyback fuel controller
  103. Post Your 1jz Pics Here!!!
  104. Any good DIY's on A/C Compressor Replacement?
  105. Which Boost COntroller to recommend?
  106. CD-2 anyone ever used this stuff?
  107. twin turbo upgrade
  108. exhaust rattle
  109. EGR Check engine light
  110. Well I'm finnaly going to do it
  111. Any Oklahoma 1jz's Around?
  112. 95 sc400 lunges when dropped into d or r
  113. check engine light code 71 EGR
  114. sc300, gt42 turbo, transmission question
  115. Speed sensor replacement help needed
  116. SC400 MAF help
  117. toyomoto manifold and clears distributor?
  118. K&N air filter
  119. DASH Removal
  120. Starter Problems
  121. Rough auto trani engage from P-D & D-R
  122. 1jz and ob2 emissions?
  123. Question on OBDI code 61
  124. 500 miles on my 1JZ swap... a review, plus dyno and track numbers!
  125. Displacement on Demand? Could this be done in a lexus?
  126. Help on tuneup?????
  127. Help!!!!
  128. Help!!! Cant Remove Ac Compressor!
  129. 1JZ guys - where does the stock 1J downpipe bolt up?
  130. enhanced engine performance
  131. 1jz vs 2jz vs na-t
  132. New here and boosted
  133. Help me trouble shoot my rumbling/stuttering motor
  134. Cold Start Issues???
  135. Duel tips???
  136. You Gotta Love This Sight!!
  137. 95 sc400 shudders at 3-5k rpm
  138. Supercharging the SC400
  139. sc300 weird sound??
  140. easy bolt on power adders for 1jz?
  141. Serpentine Belt Slipping
  142. What is your Idle rpm at?
  143. Coolant Leak Help!!!
  144. Engine Code
  145. Help 1999 SC300 2JZGTE Fuel Return Line
  146. Temp fix after 1jz swap DIY with pics
  147. general forced induction question
  148. project 1jz sc 400
  149. Clicking Noise
  150. Engine Lifter Clicking
  151. Manual SC300s
  152. Short Shifter for Pre-95s
  153. Raditor options
  154. For Those with C's Shifters
  155. questions about 1jz n 2jz
  156. Power steering and power steering fluid question
  157. newb
  158. sc300 motor mount replacement
  159. Running Rich normal? or just me?
  160. Oil pan bolt question
  161. Clutch recommendations?
  162. MA70 1J into SC
  163. Will JDM 2JZGTE clear SC300 chasis?
  164. Fan is off-balance after 1JZ swap
  165. oil leak?
  166. How many SC3s out there with headers?
  167. intercooler piping
  168. Need to buy ground cable.
  169. Started A Thread in BL's New Suggestion forum on SFs
  170. Very interesting...
  171. 1jz tach fix?
  172. 1jz finally done..
  173. put in rps setup and wow... need help on adjusting clutch pedal??
  174. Where is the "FILL" bolt on sc300 auto tranny?
  175. oil everywhere during spark plug change???
  176. custom or aftermarket exhaust system?
  177. Dead SC400, smoke from near valve covers and distributors
  178. Im Smoking what is it?
  179. What tools?
  180. 2JZ NA-T Thief found
  181. delating the hydraulic fan
  182. positrac for SC400
  183. Help! What is this noise? Vid inside, tremendous rattling
  184. Toyota soarer 2.5TT power?
  185. how much BOOST is too much
  186. SC300 engine for sale - 2JZ-GE
  187. SC400 Valve Cover Gasket R&R thread
  188. Positive Traction on 5spd SC300?
  189. Gear Ratio?
  190. engine noise
  191. Valve ticking?
  192. getting an sc400, but want to TT
  193. BFI Intake and 100 oct = A different car
  194. engine tumbles but not starting
  195. OBD for auto to manual swap?
  196. questions about motor swap
  197. Smoke coming from AC compressor
  198. All 1jzers q?
  199. car suddenly dies, rpm lulls...
  200. Need a list of the engine torque specifications for the 1JZ!
  201. Replace A/C Compressor
  202. i need advice
  203. sounds like rod knocking.,.need advice
  204. Exhaust Video
  205. I need some advice...
  206. Good price of 1JZ swap?????? Suggestions
  207. usdm 2jz gte
  208. from whom I can buy soarer translated schematic?
  209. 98-00 Exhaust manifold
  210. question on 5 speed trannys.
  211. where go that cable (1jz )
  212. about to order lextreme torque converter for my 1jz auto
  213. 1jz gte ignition problem
  214. WTB: Intake, but questions abound...
  215. 1jz gte question?
  216. My Sc300 1jz Pics
  217. Changing the radiator. Help?
  218. after 1jz swap
  219. Auto Lexus trannies stink for performance....
  220. 2jz-gte vvt-i swap~ question...
  221. Stock sc400 exhaust diameter?
  222. a/c gets much colder when car is moving
  223. Greddy Exhaust. real nice.
  224. GS400 Rear onto SC300
  225. Newbie Needs Help!!! 1992 Sc300
  226. Oh oh... always something
  227. x-pipe exhaust setup
  228. What does it take for an SC300...
  229. 5SP Shifting Problems (W58) - not bushings, not loose
  230. fuel filter backwards??????
  231. Just in case you thought 1JZ\'s were slow
  232. A/C only blows low speed
  233. Just got my sc300! with a raidiator question
  234. HELP!! Fan belt snapped!
  235. reset ecu on 1jz, car dies every time i stop
  236. Tranny help!
  237. Cost on timing belt/water pump job?
  238. Smog Numbers
  239. SC300 w/ Aristo 2JZGTE
  240. Diff Fluid
  241. Transmission shifts directly from 1st to overdrive??
  242. annoying THONK sound!? + other concerns..
  243. a little bit of an engine prob
  244. question about VVT-i swap~
  245. The good news....... I found a quicker way to the driveshaft bolts.
  246. ac hose repair
  247. Intake Idea...Anyone tried this?
  248. Who sells 1jz flywheels?
  249. New SC400 Owner, Looking for Tips
  250. Engine pics we don't normally get to see
