PDA
View Full Version : Performance & Maintenance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 [64] 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86
  1. Supra 6spd LSD into SC300
  2. IS300 header on a 95 SC300?
  3. Gte Block Swap???
  4. Head gasket kit
  5. Intermittent speedometer/odometer operation
  6. I support illegal downloading
  7. Hot Transmission
  8. Formula to Convert Injector Flows, English to Metric?
  9. Throttle body/pcv clean ?
  10. Fuel filter options
  11. ls400 maf
  12. My Magnaflow Exhaust
  13. car wont shut off! need some guru help
  14. map ecu, stock fuel sc300 question
  15. My New Muffs
  16. broke coil connector plug
  17. 1JZ with RHD motor on ebay
  18. Hi, I'm new here
  19. Which stock Knock Sensor is Best used with Standalone Front or Back one?
  20. my street/drag sc300 fuel setup
  21. where to get an ignitor for the 1J
  22. Looking for a dyno in KS area.
  23. just need help..
  24. Magnaflows...OH MY GOD
  25. My sc caught on fire!
  26. **Soon to be become SC300 1JZ 5speed TT in Canada (pics)**
  27. Cost of 1JZ..trouble finding good info
  28. Where is this wire? MSD 8920
  29. Need help with Tranny swap !
  30. in the process of boosting... O2 sensors??
  31. Whats the best lightwieght flywheel for the GTE
  32. Noob msd 8920 question
  33. Options for SC400??
  34. MAF Sensors?
  35. sc300-->supra 5 speed swap ?'s
  36. Motor Build...
  37. Dedication Time.....
  38. Power Steering Help Please
  39. Strangest problem about battery light coming on
  40. 2jz-ge supercharge question
  41. Need help diagnosing problem
  42. Engine Mounts Help
  43. I need mount traction control
  44. BFI Intake Questions
  45. Q bout cold air
  46. Q about ECM.
  47. bfi questions
  48. what would u say are the best performance mods for smallest amount of money?
  49. 2jzgte swap info needed
  50. Exhaust piping question
  51. New MAGNAFLOW 14829 Mufflers Installed
  52. JDM 2JZGTE Wiring
  53. Which is better?
  54. 94 power steering pump will work in a 93??
  55. My SC isn't being very reliable...
  56. Auto to manual SC300?
  57. apex'i
  58. Help! Car Won't Start!
  59. Finally my turbo is in
  60. turbo in sc 300
  61. sc400 computers
  62. Power Steering Woes
  63. SAFC 2 discusion.
  64. MSD Adaptor but still not working right?
  65. strut tower brace
  66. How to Register my turbo with Intellexual.net?
  67. Gas Tank removal
  68. tach fix 1jz in sc400
  69. Searched but couldnt find an answer...SAFC2
  70. 2jz NA-T 6spd Clutch Engagement Problem
  71. GTE head on GE block
  72. single turbo install
  73. stupid question...
  74. Custom exhaust - rear O2 sensors?
  75. I've taken the Magnaflow plunge...
  76. NJ inspection with AEM??
  77. OBX racing exhaust for the SC
  78. Traction control
  79. help: my gas needle is stuck. what could be the problem?
  80. Drowning plugs: I think I found my problem
  81. FAT supercharger
  82. 1jz power steering pump
  83. 1JZ Fuel managemnt
  84. Supra Swap Into Sc300
  85. 1jz + sc300 auto?
  86. 1jz and 2jz front clips where to buy?
  87. Engine Turns itsself off
  88. stock platinium to ngk3330 and 1jz run bad
  89. Newby in CO/engine has hiccup
  90. Visual Differences (engine)Aristo vs. Supra JDM
  91. JZX100 Tranny
  92. Blown head gasket
  93. I had more fun today than you did.
  94. weird missfiring issues and oil and coolant leaks
  95. Electric Vacume turbo charging?
  96. Motor Mount Replacement Help!!!
  97. SC300 Intercooler pipe and tach problem
  98. catalytic converter where to buy aftermkt?
  99. Timing Belt Install - Question about Cam Gears
  100. coolant issue
  101. power steering pump
  102. bad engine
  103. Electric superchargers?
  104. 3 inch v band clamp not fitting flange wtf
  105. Flywheel bolts
  106. 92' sc400 .. need some help
  107. My baby's in trouble please help!!!
  108. Choice of motor in a SC3
  109. xspower turbos.... anyone have experience?
  110. I have quick question about the 5peed trans.
  111. got my turbo manifold in today ....
  112. SC400 to 1JZ-GTE VVT-I conversion
  113. Need help with DP problem
  114. Sc400 Headers
  115. engine problem
  116. SC 300 Auto 1992/ How to change forward driveshaft bushings
  117. where do i get a union bolt? and the fitting for the return
  118. Borla Exhaust 97 sc300
  119. Your thoughts about building na-t motor...
  120. Swooshing Noise When Throttling?
  121. 1jz Tune with SAFC???
  122. Reversed Polarity / Sc300 5spd
  123. Apexi making exhaust for sc300
  124. Need Help! SC300 Sprayed rubber pieces from transmission I think.
  125. Help...Car keeps giving itself gas w/out me being on the gas pedal
  126. DTC Code help
  127. Check Oil Light
  128. Idle Air Control Valve
  129. 5spd swap question
  130. RPM jumps while driving
  131. Cause of a harsh start?
  132. Street Legal Performance Exhaust
  133. How doI know what I have and need?
  134. CAR still running weird
  135. The car doesn't want to change gears now
  136. replacing stock oem filter with cone on sc400 ???
  137. Exhaust Question. Keeping stock tips?
  138. Turbo Timer
  139. What Down Pipe is used with the Non greddy T78? (TD07-18A) Not 4 bolt Not V-Band
  140. W58 question?
  141. Fuel pressure on the rail in a SC400
  142. JIC Bullet Twin 505S Sus Exhuast YAY!
  143. TPS questions?????
  144. Thinking of buying sc300 to twin turbo..
  145. 7M-GE and 2JZ-GE compatability
  146. Transmission noise when cold + delayed shift
  147. Speed sensor wire?
  148. wiring Harness???
  149. Car Has Issues!!!! Help
  150. ebay intake thats cheap worth it?
  151. New header for SC300, pretty good gains
  152. found a motor
  153. 2jzgte intake manifold on a 2zjge
  154. Need a New Clutch Disc and What else??
  155. Anyone using an electric fan?
  156. Distributor?
  157. Check engine light comes on after trac is turned off
  158. over drive light trouble
  159. 5 speed question and more ?
  160. 1jz vvt-i in a sc300....
  161. Whats the fastest NA-t sc300?
  162. Question for the turbo heads
  163. 1jz speed delimiter
  164. List of Magnaflow products
  165. Fuel cut off
  166. Cam timing belt
  167. SC400 Water pump
  168. MAFs question
  169. Hissssing Gas Cap
  170. Short throw shifters?
  171. It's getting hot in here.
  172. Will this cold air intake work on my sc400?
  173. 2jzgte / 1jzgte help.......
  174. Strange noise at 60-70MPH but no where else.
  175. New Sc Owner! losing coolant
  176. R154 on 1jz automatic (speed sensor q)
  177. Car starts, then dies
  178. Got new motor mounts.. dont think theyre properly installed
  179. Still Stalls In P And N!!!
  180. TH400 people, question on driveshaft/differential
  181. 2000 4.0L VVTi into an SC400?
  182. Electrix Probelem Please Help (ALT?)
  183. TOM"S Soarer compresor kit?!
  184. Blown SC300 93 Head Gasket
  185. installation of bcc and scc
  186. apexi n1 vs magnaflows mufflers
  187. Nightmare Fix Done!!!
  188. DESPERATE NOW! SC400 power steering hose
  189. Check this vid out!! SC400 supercharged
  190. W58 with a 350-400whp goal.
  191. Emissions Problem, Engine Light won't go off
  192. 1JZ Single turbo complete!!!!
  193. anyone do a write up on changing from distributor to coils?
  194. 97 Lexus SC400 Supercharger project
  195. where to order oil pump from
  196. 1jz/w58/auto harness reverse lights?
  197. Transmission for turbo SC300
  198. Limiting factors in turboing the SC400?
  199. SC300 Intake Manifold
  200. Help!!! engine issues
  201. S&S Header on a '99 LS - A tale of woe
  202. SC400 hesitation
  203. Anyone Use This Turbo Kit?
  204. Getrag Swap Support/Mount- What are Sc300 guys using
  205. Power steering compatibility, SC300/400
  206. Install Pics Of Single Turbo
  207. Maintainence Q: bad idle, BAD noises; bad sensor?
  208. SC300/400 power steering compatibility
  209. Strange Starting Behavior
  210. i just ordered the aem standalone unit, who else has it?
  211. 2JZ-GTE swap
  212. sc4 is overheating..plz help
  213. My buddy sprayed off his SC's motor and now its misfiring. Cause?
  214. Help!! SC400 Socal members...
  215. SC clutch pedal question
  216. Project Nearing Completion, pics
  217. hks twin power DLI ignition module
  218. Ticking noise
  219. V160 syncros and bearing kit
  220. 1JZ Fueling
  221. reducing the weight of our cars
  222. JUst wanted to say ( happy 200th post) lmao
  223. rough idle
  224. VSS confusion
  225. where to buy exhaust piping??
  226. what cam options are there?
  227. Which o2 sensor is bank 1 sensor 1
  228. NEWBIE with p.s. fluid filter question
  229. Grounding Kit
  230. Stock Cat's???
  231. Error code 52
  232. egr, trac. control removal
  233. Random auto to 5 speed swap parts question
  234. Did you buy the S&S/JBrady Headers?
  235. 1995 transmission question?
  236. dual walbro setup
  237. Clutch or Trans?
  238. project sc250tt
  239. ijz sc400
  240. 1JZ + Race gas?
  241. Confused/Worried - Airbag Light ON
  242. Confused/Worried - Airbag Light ON
  243. Injector Questions?
  244. Auto to Manual
  245. 1jz to sc400 done and it is easy!!!!
  246. Power Steering Leak
  247. SC400 periodic engine vibration
  248. LSD gearing
  249. Notchy shifting when first starting
  250. what exhaust is this
