- AC compressor
- This is for Scott
- tanabe medallion exhaust
- Noob here and need some basic questions answered
- clutch sticking
- couple of Questions...
- Will This Work?
- Losing Coolant from back of motor.
- pics of my NA-t project
- Trac Control
- Soarer R-154 short throw shifter..
- Reliabilty questions, concerns and timing job assistance
- can anyone help me out
- Pricision Industries converter review
- RMR SC400 axle-back exhaust my lordy I'm flummuxed
- HELP! Standalone and heating problems.
- Troubleshoot my SC400??
- OFFICIAL: Tanabe Exhaust Contest
- power steering fluid change?
- 98-00 Sc400 Bfi???
- would this be a symtom of a bad injector?
- whats is this part called??
- Ouch CEL!!
- sep belt keeps coming off!
- question for you NA-T guys with 3.76 rear
- noob here...
- Has anyone ever heard/did a swap with this motor??
- My 1jz build update
- 1jz vs 2jz which is better
- MAF wiring
- Automatic Transmission Fluid ATF OEM Recommendations
- Muffler suggestion? dual tip or single?
- Solenoids
- Shifter Upgrades..
- fluttering noise coming from engine
- is replacing header/cat flange gaskets a killer?
- sc400 TAP transmission
- sc400 wreckinging yard motor
- R154 Shifter extentions
- best gearing for turbo 5speed?
- W58 tranny...
- buy a 1jz
- I think my cats are clogged!
- where does vaccuum start?
- seemed to fix bucking problem
- I need some help
- Need quick O2 Sensor Replacement Help!
- Info needed, LSD Guts swapping.
- Tanabe Medalion Touring Exhaust Coming Out In May!
- Manual SC400
- Crank Pulley Options with 2jz-gte
- Where to get a OBD2 TT ECU?
- Which wiring harness runs through a 95 SC400 Driver's Side Fenderwell?
- my 1992 5spd sc300 has lsd?
- Coolant leak
- VAFC2 writeup for sc300?
- Some Diff options...
- New MAF needed for OBD code 31?
- Few Q's about R154 swap
- 1jz bogs while in boost!
- 1JZ Question...
- Fuel Pump wiring
- Once and for all is the exhaust the same on a 97 and 98 SC400?
- Over Heathing SC400
- what would causes this..
- SC300...Im a little retarted
- Starter run on issue 92 sc4
- RMM Exhaust on 98 SC400 has anyone done this yet??
- more issues
- is this a problem...(pic)
- Tranny Solenoid #2
- '92 Sc300 Repair Update
- those coil wires are a KILLER
- Trust SMIC install.
- quick question, power steering stiffness.
- SC 300 Tranny Question
- need help 93 sc400
- Dyno Results what do you think?
- boost logic tranny conversion
- would there be repricussions if...
- LSD Install.
- New Owner, Problems Starting Car, HELP!
- GTE fuel control options.
- R154 conversion - any tips / suggestions during installation?
- Just got Deliviered!!! :)
- The thick 1uz rods are indeed weak
- New Owner
- 1jz swap with r154 got a few questions.
- Trac light on code 43 and 54 maybe accumulator
- Hmm.. Smoking engine. Need opinions.
- NA-T sc300 questions..
- Newbie with a trans question
- mmm...twin turbos
- Suddenly lost 4 cylinders??
- SC400 1JZ Help!
- R154 vs W58 Gear Ratios
- R154 shifter extension- Possible alternative?
- Max Power on Aristo Injectors?
- Speedo issue
- Rear End Rumble
- Power Steering
- Trac Delete 1995 SC300???
- Transmission and new TC installed, now weird vibration when accell?
- ARP Flywheel Bolts- Which size?
- Rod Millen Motorsports SC400 Exhaust???
- steering wheel off center - sometimes
- engine temp question
- NGK Wire set from sparkplugs.com
- How Should I Upgrade my Sc400
- 97 sc 400 Maf work on a 95?
- What Do I Do????
- E-manage ultimate and map sensor
- O/D off light blinks...but only in diagnosis mode
- LSD Rear Question
- Weird idle issue
- Help on LSD question
- exhaust comp. video?
- Supercharged SC400 Vid
- tranny mount same for sc 300 and 400?
- K&N SC400 Air intake installed with pics!
- New to the club and need help...
- I have a weird problem
- Why is the sc sooooo slow off the line?
- fuel pump ecu
- want to make 300-350hp in a NA SC300
- SC400 Hydraulic Fan problem
- Rear end
- car running wierd
- Rumor about R154 in a isuzu?
- NA-T won't go lean enough! (SAFC II just installed)
- this bucking car is killin me
- where/what am I leaking (pics)
- Trans. Issue?
- Check Engine Light On After Flooring It
- First SC400 yay! Clunk when on and off the gas boo...
- IACV. Is this it?
- highest HP (N/A SC400 or GS400)
- 92 SC400 trans prob
- SC300 delays shift from 1st to 2nd?????
- Compressor wheels interchangeable?
- Piggy back SC400 (AFC, etc)
- Fmic???
- 5spd pedal assembly
- SAFCII knock sensor wiring?
- Has anyone passed smog in CA with XERD headers and an Axle-back exhaust ??
- 5 Spd Swap Discoveries
- sc300, 98 vs 92
- What is the F/R Weight Dist. for a 92 SC400?
- Sc400 NOS
- 1 St High Hp Lexus V-8?.....help
- Exhaust Comparison:
- Help!!! Please Help! My Car Is Dead And I Dont Know Why!
- How to pull codes of aristo ecu??
- RADIATORBARN OR KOYO RADIATOR??? (Help Please)
- Need advice and input about XERD hearders and Blitz Exhaust...
- DIY homemade polyurethane
- How do you like your 1jz or 2jz automatic??
- Exhaust
- How many people are running the 2jz-gte head on a stock ge bottom end
- TC ECU in a non TC SC400
- is my belt coming apart?? PICS INSIDE....
- Serpentine belt snapped...
- SC400 headers....best fit
- t3 manifolds
- Water Pump Holes 10 or 11?
- 7mgte 5sp-- 2jzgte swap possible?
- Hello CL community
- :ugh:drive shaft question
- Idle problem
- stalling 92 SC400
- Function of Power Steering ACV
- Pulstar Pulse spark plugs
- Rough vibration?
- Car won't start
- 1jzgte belt
- 1jzgte exhaust 3" lose 4-6mpg?
- hp gain
- CEL on every other day..
- Any ideas are greatly appreciated...
- Shim kit for valve body on SC400...
- Gas pedal very sensitive from stop
- Questionss about specs
- 147,000 miles - Best oil to use?
- 1jz BPU first stage done...
- 1JZ in SC400?????
- 2jzgte vs 2jzgte vvti
- bat light flickering need help asap
- Diagram or Pics Of Headgasket Change
- ????'s Regarding 2jzgett
- cel code 55 4 knock sensors?
- NA-T conversion. What is this and do I need it?
- How much HP will the stock 95 SC400 trans handle?
- sound clip of apexi ws2 driving?
- AemPro Parameter display on PDA?
- OBX Headers
- Stalling briefly, electrical problem?
- What the heck is that?
- what to use for tuning my sc300?
- new sc
- Found what's squealing [Pic]
- tach adaptor will this work?
- sc300 reverse sensor wire location HELP
- will this throttle cable work ?
- Manual swap gurus, need some advice.. clutch pedal part numbers
- Changing Serpentine Belt?
- Diagnose these problems??
- Engine Swap: Is it smog legal
- Auto to Manual Problem
- My NA-T rebuild
- T-61 installed, Troubleshooting...
- replacing SC400 trans question.
- switching rear pumkin question
- where to get and what would it cost me?
- shifter has play
- Power Steering Pump Question
- Write up on SC300 Clutch 56K=No No!
- Does my Head need a rebuild?
- How to find color of wires from pinout?
- Help from some experienced GTE owners...
- What Belt Do I Need???
- jdm gte downpipe..
- Replacing Engine Harness on SC300
- Rear wheel alignment?
- running intercooler piping?
- The Last Seafoam Thread
- Is Fuel Pump ECU from SC300 and SC400 the same?
- Throwing ecu code 21.
- How hard of a project?
- Climate Control Doesnt work after Aristo Swap
- New custom cat-back is in
- Few Driveline Questions..
- Wet and oily air filter
- Sc300 Hid
- Bypassing Neutral Safety Switch?
- Fan blade pulley
- maf question
- Car issue, need some help diagnosing
- JDM trouble codes
- My car makes popcorn/
- sc300
- 90k Service + getting ready for NA-T
- New Squeeks...
- Heat, Heat, and more Heat
- Is300 and sc300 short shifter???
- Transmission Swap
- Single Turbo SC400 and Running
- plz help!!!! how to remove the intake from a 95 sc400???
- First Mods?
- doing a clutch
- Power limits on stock 2jzgte auto tranny
