- I have a single exhaust, what about the other side?
- What gauge is our Ignition wire?
- Thoughts on the auto shift lever
- sc300 auto to manual swap
- MAF Question?
- Success!!! Finally found a solution
- leaking exhaust manifold - labor rape?
- valve cover gasket replacement ?
- 3 inch Straight pipe Exaust
- Performance Shops in Georgia
- Who here has used the MKIII Supra Clutch Pedal Assembly on a 5spd swap?
- Exhaust work cost ??
- heres a question
- HKS hi power question??
- obd1 and obd2 injector differences?
- OPEN UP WIDE and say AHHHHH!!
- Turbo EXPERTS, please help me order!
- the never ending SC issues...
- Need transmission help
- How Important are Exhaust for Performance?
- Exhaust Clips - N/A Sc300's
- Does your stock exhaust make noises?
- Shops that do 1jz swaps
- Swap
- What wastegate are you running?
- In Here!!! Problem Sc/soarer>????
- high idle and smoke after spark plugs change!?
- GE power steering pump support bracket... orientation?... Need help today!
- Twins on the 2jzge?
- Smoked out my highway - my story of the day.
- 1jz Help....Please Help
- Weird exhaust whistle
- has everyone given up on 40mph vibration?
- sc400 starting problem
- U-joint tear - Need help -
- 92 SC300 (130k) NEED HELP with Problem
- Walk Crank Walk
- intakes anyone ??please
- looking for intake ???Please,anyone??
- check engine light PO 125
- thermostat install - how to prevent trapped air?
- Pictures of my 98 SC400 custom made BFI snorkel--Hope it works!!
- anyone have an extra fuel pump ecu? 92sc4 warm startup sputtering
- driveshaft length for sc300 with 6spd gte?
- tach signal and speedo sensor
- Look what came in today!!
- How about power-mods for a NA SC300?
- exhaust or vaccuum leak
- for turbo sc which way is cheaper & more stable?
- Troy's build
- tc lock up?
- 92 SC300 ECU Question
- Whats Wrong With my SC?
- Engine Cleaning ?
- Engine Cleaning ???
- Wiring Retardation
- Good piggyback system na-t are running
- is this normal?
- My new custom turbo exhaust
- HOLLY mackeral bat-man...lexus people :)
- Check out my fuel sump
- Need to borrow some 370/310 RC Injectors
- SC400 Serpentine belt replace recommendation
- SC400 Cooling fan fluid requirements ...
- Going low speeds in high gears dangerous?
- Finally! The SC300 will again be turbocharged!!!!
- My new 300 -- suggestions?
- car won't turn over!!!
- 15 hour Water Pump job
- best chassis to start with for 2j platform
- gated shifter help leading to DIY
- coolant temp (this normal?) pic
- Sc300 Oil Change, Overfill?
- stuck starter
- SC400 Oil Change ... What a Breeze!
- Installed VPC, now cel and weird idle
- Coolant Leak
- cracked block?
- 97-00 SC400 BFI questions???
- seat belts
- Will the BL built TT auto trans fit in an SC?
- Boost Controller & Wideband 02 recommendations
- This put a smile on my face/2JZGTE
- Crank Pulley Bolt Removal Sc400
- 1JZ Single Turbo
- Companion flange nut size
- R154 mk3 tranny extension?????
- SC400 idles issue, check engine light, DIES!!
- SC4 guys, help! Changed plugs/wires now rough at idle
- The dash battery light came on..
- questions about fuel managment..help..
- Muffler flange
- Power FC
- Short Shifter Kit??!!?!?
- Anything New For Tuning 1jz in sc3?
- Looking for SC4 autotrans upgrades
- Check Engine Light....Sometimes
- Soleniod valve for the heater
- Leaking coolant tank in all sc400s?
- 1jz coil wires?
- my 96 sc 2jzgone na-t first ever pics
- r154 conversion intall will pay cash
- PLEASE HELP ME!!! Cant get rid of EGR code 71
- Will this injector still work?
- methanol injection
- 400hp 1jz?
- BEWARE of OSAKAJDMMOTORS.com
- Rebuild the Water Pump?
- SC400 Hydraulic Pump Bolt Size?
- 2jzgte 6spd sc300 build...
- EGR delete
- Worth it or not
- Whats the world record top speed for the SC?
- electric turbo!:)
- power steering question
- SC400 Manual conversion ???'s
- Power steering line fix..oh so pretty
- Part number for exhaust rubber hanger?
- HELP PLZ!!! SC300 starting issues
- Stopped Dead in my Tracks
- Will a 2JZ spark plug cover fit a 1JZ engine?
- Which pulley is this?
- many ?'s
- help asap
- sc300 ecu question
- 93 sc400 need advice
- t-25?
- Whats your idle?
- Location of EGR probe??
- Dual tilted exhaust
- Engine Mods & CA emissions ---
- Supra differential in SC300
- bcc install on a 1j
- 91 SC400 Coolant level Rises and Falls FAST???
- wont rev pass 2k and stutters + pop
- ECU used or rebuilt ???
- pretensioner
- Injector wiring
- Fuel pump
- Down Pipe
- Torque converter?
- wiring harness
- SC400 transmission?
- Heater VSV not getting enough vacuum
- 2Jz Ge Best bang for the Buck?!
- Should I install the Gated Shifter?
- My exhaust quote...Reasonable?
- Trying To Remove A R154
- Transmission problem - 1st to 4th gear jump
- 2jzgte 6spd swap into sc300....questions
- AeroTurbine mufflers on a 99 SC300??
- muffler question
- Badlandz 3" to 4" electric exhaust dump....
- Bad Catalytic Converter?
- Building A 2jzge Vs Swaping A 2jzgte
- boost controller install
- SC400 Over Heating
- Documentation of R154 swap w/ pics
- Opinions on power loss/ SC300
- Single or dual exhaust
- Some help for a noob?
- Supra Torsen LSD installed
- New single kit dyno numbers
- Please help before I drive my FI SC400 into a lake and leave it for dead!
- Throttle Position Sensor Situation
- sc400 transmission cable
- Stock SC300 Rear end Question
- Anyone using a transmission temp gauge on their SC4?
- what is first best mod on sc300 under 1k? plz hlp
- Installing traction control in non-TC SC400 ?
- If you can read Oscilloscopes, look at this gem GE vs GTE
- sc300 turbo 2jz swap questions
- Lextreme Torque Converter And Turbo SC400
- Shifter Removal Help!!!
- Data link connector on 92 SC400 location??
- what's the best fluid for Torsen diffs?
- Dyno results
- Voltage woes, issues with battery
- Check out this video ( Have a question)
- Need Help with 2jzgte with 5speed
- Any Idea's on how to remove ECU?
- Power Steering woes. Sound clip inside
- Problem with lex!!! Electrical?!1
- Trouble Passing Emissions
- i need help!
- Best All Aluminum Radiator for SC300
- problem with HOT starts????
- Sc400 Guru's Please Help
- FINALLY reason for belt ejecting itself
- Compression & Leak Down Test
- Cast 1JZ exhaust manifold
- Vehicle Speed Sensor?
- Rebuilt & resurfaced Cylinder Head Gasket - good as new?
- Oil Catch Cans In Na-T Questions
- Inexpensive EGR block off
- downpipe question...
- Advice 2JZ-GTE Auto swap SC300
- Does this sound like Head Gasket Failure?
- Help! SC400 won't go into Drive
- Safc 2
- SC400 and LS400 Main ECU the same?
- Towing SC300 Question
- Crank Pulley Tool
- OEM look custom exhaust
- How do you swap a 2JZGTE into an SC400?
- Question(s) for those w/ Seibon CF Hood
- trans swap ?
- MAP sensor=No MAF???
- Turbo miles?
- coolant flush
- OBDI vs OBDII
- usdm 1jzgte swap
- Which Water Pump is this???
- another safc 2 question
- resetting electronics?
- weird electrical noise please help!
- How to bleed air out of the cooling system - 92 SC400
- Stupid emanage blue!!! Help me out here guys.
- Review my build - Questions and Answers with lots of pics
- Car died today..
- Engine Management?
- why is the 4.0 not more powerfull
- Post pics of NA-T engine bay
- Boosting issues
- Differential question
- Headlight Relay Part #
- sc300 troubles. suggestions?
- Engine Brake= Wasting Gas??
- Where do these plugs go?
- Name this leak!
- for those with the koyo supra R1856. is this a knockoff version?
- Leak problem....
- sc300 shutting off....need help!
- I can't believe this...
- Running Rich any Ideas?
- Stock V8 engine bay pics
- Brake Bleeding Problem
- 1JZGTE antilag 2 step rush racing
- banging into gear on freeway
- which blow off valve is this?
- 1jz
- Sc300 1jz soarer swap
- Replacing Coolant Reservoir- What is a switch?
- 2jzgte question
- 21mpg city... SAFCII and 3.76's....
- AC compressor
- This is for Scott
- tanabe medallion exhaust
- Noob here and need some basic questions answered
