PDA
View Full Version : Performance & Maintenance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86
  1. Help!! 2jz-gte swap
  2. 6spd Getrag in SC with 2JZ-GTE?
  3. What need to keep from Soarer Clip for 1jz swap??
  4. Boostwerx Complete Turbo Kit for SC300
  5. Max 1uz overbore?
  6. fixing the 1jzgte throttle cable issue for $5 and 20 minutes
  7. Thinking of NA-T
  8. how to remove/replace clutch master cylinder?
  9. 2JZ-GTE in a SC Exhaust??
  10. '97 SC300 engine and tranny swap
  11. Timing belt.
  12. 1997 SC300 5 speed 1JZGTE swap
  13. soarer fuel setup
  14. could somebody teel me about the paper clip to the +b to fb
  15. Car dies.. alot.
  16. Is my Temperature Gauge normal (pics)
  17. No IGT 2 signal from ECU?
  18. Fuel level gauge problem..
  19. Strange Loss of Power When Gears Change
  20. engine swap
  21. I bit off more than I can chew.
  22. how do i get to the fuel pump ecu
  23. Serious issue
  24. Need boost advice
  25. oil light on periodically 15-20 sec., Oil full
  26. Car is being sluggish!
  27. Throttle body bolt
  28. HELP sc 400 running rich no clue!!!!!!!!!!!!!!
  29. Need some help with starter in SC400 ...
  30. Rear End Clunk
  31. 5-speed swap
  32. 5-speed swap
  33. A/c Drier/receiver, 92 SC400
  34. vacum hoses
  35. Rear end very sloppy---What could it be?
  36. Anyone Build a ITB 2jz ge?
  37. Problem with sc 300 Help Guys
  38. SC4 PS Pump Pulley..
  39. 2jzgte question
  40. Preservative advice
  41. 1998 Sc 300
  42. SC300 2JZGE into SC400 - Search Problem
  43. motor mounts
  44. Top Speed
  45. Looking for Exhaust shop: South MA/RI
  46. Just got my SC3...it wont start.
  47. where do you mount your front mount intercooler? Pics please
  48. i am a new owner of a 93 sc300 and im having problems
  49. cheapest place for clutch
  50. short block/long block
  51. Custom SC400 Exhaust on a Budget-- Pics--
  52. need help...1jz intercooler pipe
  53. Ceramic Blades FTL....Single FTW.......
  54. bleeding the clutch cylinder
  55. sc400 A/C Help needed
  56. Getting a sc300
  57. Where to buy a 1jzgte serpentine belt?
  58. power steering relocation for aftermarket manifolds on sc300
  59. Serpentine belt issue
  60. Cooling fan romoval
  61. Dreaded heater core leaking...can I safely bypass?
  62. i have to ask so be nice
  63. ****I ALMOST DIED TODAY!!! Accelerator stuck!***
  64. Vaccum Diagram
  65. No complete write up for a 2JZGTE swap????
  66. MISFIRE After Engine Cleaning
  67. Throttle Sensor Detector problem? Tranny problem?
  68. 1jz or 2jz
  69. 1jz problem Please Help!!!
  70. JDM Supra Injectors w/Resistor Box
  71. A/C System Diagram
  72. Performance ignition coils
  73. Stock exhaust system backpressure
  74. Speedrex Mufflers?
  75. 1J Issue (NO POWER) fresh swap
  76. Hybrid QUestion.
  77. ignition wire..
  78. SC400 Turbo Manifolds that keep the AC and PS?
  79. Vacuum tubing question
  80. My engine is pissing all over the place!
  81. need engine swap info
  82. Weird Problem, Any others?
  83. Injen Intake
  84. my sc wont start
  85. 2jz-ge NA-T motor question?
  86. 2JZGTE 5 speed with twins owners
  87. ECU is bad!!! help!!!
  88. Aem Ems?
  89. has anyone ever had a bad distributor on their car?
  90. BL 2.5mm headgasket question
  91. r154 help
  92. maintnence on sc
  93. What kind of motor is this?
  94. starting problem
  95. *Tanabe USA* R&D for exhaust
  96. Nagasaki JDM engine????? does anyone have experiance???
  97. Hydrogen Boost Fuel Injection System?
  98. huge noise when shifting from Park to Reverse
  99. Supra Fuel Filter work?
  100. 1jz into a stock 5spd
  101. Possible tranny problem- help me with a quick question...
  102. help finding ECT
  103. need more power
  104. swap manual?
  105. 60mm Gauge Pod?
  106. rev to acceleration problem
  107. car dies three times, now wont start!!!!
  108. Pros and cons of Diff / lsd
  109. Apex-i S-AFC NEO
  110. chirping/squeaking sound...HELP!!
  111. whats causing this sound???
  112. clutch pedal
  113. 1jz vs 2jz vs 1uzfe MPG
  114. W58 "whine"?
  115. R154 or W58...
  116. CEL after stepping up boost
  117. 1jz clip , tigerjapanese.com
  118. Thinking about putting a 6 speed in my SC400
  119. 4l60 tranny
  120. Fixing electrical gremlins
  121. Turbo SCers sign in!
  122. How long can a timing belt last?
  123. 2JZGTE ECU Question.
  124. US Spec 2JZ-GTE?
  125. shifting problems with auto
  126. how much for m/t swap in '93 sc300
  127. Stock rear end?
  128. PS pump help! Question after search
  129. Front mount intercooler and hard pipes for a 1997 SC300 with a 2JZGTE
  130. xs power kits?
  131. Cant turn Overdrive On
  132. 1JZ wowes.........
  133. 95 SC 400 A/C help...
  134. 2JZGTE into 1992 SC300 "manual"
  135. street testing 1jz
  136. Speedometer Failure After Clutch Change
  137. Pics of my engine
  138. Haha
  139. need help asap.
  140. compression #'s
  141. Car cutting out!
  142. Cats melted!!?? 92 SC4
  143. clutch/slave problem need help!
  144. Supercharged 97 SC400 Videos
  145. My SC4 stalls after I turned off A/C
  146. running rich. dont know why. help
  147. Straight Pipes on SC400
  148. Auto Transmission
  149. throttle body pulley wont spring back.
  150. Zees exhaust!
  151. exhaust Q's
  152. VVTi head
  153. Turbo Question
  154. sequential 1jz?
  155. Does ANYONE have a 97+ with working tach after motor swap?
  156. FYI Found a Supra TT engine with 6spd tranny
  157. HKS 1JZ Twin Upgrade??!!
  158. SC Exhausts or Exhaust Tips PIC THREAD!
  159. Odd Engine Swaps...
  160. Problems with my 2nd Rear diff..whats wrong?
  161. Poll: Maintenance and/or Modifications
  162. Ebay Swaps?
  163. exhaust system help, where to find best prices
  164. Supercharged 97 SC400 Videos
  165. My traction light started Blinking?
  166. Help Please!
  167. Need An Intake!!
  168. So I Fixed Code 13 RPM Signal
  169. Perfect play toy
  170. SC Exhausts or custom exhaust Tips PIC thread!
  171. Test only
  172. Will an LS400 rear bolt up to an SC?
  173. Mechanical Issue
  174. looking to convert sc400 to 1jz/5spd, is it much harder than a sc300?
  175. na-t manifold toyomoto
  176. Crazy Crank Pulley Issue!!
  177. big single on NA SC
  178. SC300/400 billet fuel pump hanger, finished product pics
  179. Thinking about an SC
  180. Who all has done this and is it a good idea?
  181. (Picture) is this the low side for A/C recharge?>>>
  182. Heat coming from ebrake
  183. Does anyone know?
  184. Help removing my Intake manifold
  185. DSPORT: IM PUBLISHED ... tuning related
  186. Torque Converter Question
  187. A/C quit working, just in time for summer :(
  188. which way to go??? 1j,2jgte,na/t??
  189. possible or not 355-400whp on 5k budget.
  190. weird electrical bug.
  191. IS headers on an SC?
  192. Fuel/Air mix gauge
  193. 1jz help needed
  194. Remove front cats?
  195. Change out freezeout plug-97 sc300?
  196. MKIII Supra LSD?
  197. Coolant and Oil Light?? WTF
  198. having some weird issues... maybe someone can help
  199. SC400 Motor
  200. Help! My 1UZ is making noise... So is my A340E
  201. Man o Man
  202. Water/Alcohol Injection on NA Motor?
  203. So.. How about a Fuel Cooler?
  204. Fan clutch on 94 sc300
  205. Dyno soon, in all honesty what kinda power can the w58 handle?
  206. AEM cal needed for BL Stg2 kit
  207. Quick throw down?
  208. O2 sensor question
  209. 6-spd conversion for SC400?
  210. CODE 24 IAC..need help!
  211. Steering pump
  212. Where do you get parts for your 1JZ swap???
  213. Heatercore coolant pipe problems!
  214. 1jz gte versus 2jz gte
  215. Besat clutch for 5 speed sc300?
  216. for the 1jz swappers
  217. How to remove the ECU?
  218. is there a seperate tranny ECU?
  219. A/C pulley is making squeaking noise...
  220. SC300 2jz-G/t/E project....
  221. National Service History
  222. quick question about removing the EGR system
  223. engine won't start or dies while driving
  224. Best way to flush fuel system?
  225. Crank Bolt Removal
  226. What would we do w/o great mechanics!!!!!!
  227. 5spd swap = check engine light, help?
  228. Removing Traction Control?
  229. Need your help guys
  230. Stock 5 speed question,
  231. Early stages of a Auto to 5 speed swap "How To"
  232. does all sc300 have traction and abs??
  233. radiator question
  234. another auto < 5 speed?
  235. Pricing on swaps?
  236. what all do i need
  237. question on motor mounts.
  238. Crank Shaft Pulley
  239. What model is my motor from?
  240. Sticky Clutch
  241. Got my 5spd Swap today, thanks R&J Distributing
  242. TRAC light prob.. all help welcome!
  243. Need quick advice on transmission...
  244. Sacreligious
  245. 1jz swap questions
  246. Strange rattling sound and whistling....
  247. Just bought a Chip for my sc300 need some q's answered....
  248. NA-T Stalling problem, can't get it right, HELP!
  249. NA-T Stalling problem, can't get it right, HELP!
  250. Hesitation when rev, feels like a 'dragster' lol
