View Full Version : Performance & Maintenance
  1. pcm / ecu part number interchange
  2. speedometer subassembly gear
  3. Fluid leak. At a loss...
  4. 93 sc400 smog please help !!!!
  5. Bought the SupraStick; Need paddle shifters?
  6. car finaly gave up maybe?
  7. sc300 w58 vs mk3 w58 tail housing length.
  8. Chaser Auto tranny in SC300?
  9. 1997 sc300 P0171
  10. Better than BFI
  11. Want to know if 2001 m5 motor can fit
  12. precat worries
  13. Sc400 Warm Issues, and no spark (Sometimes)
  14. 1998 sc300 turbo help
  15. Need some Help, Engine Dies
  16. r154 slip yoke
  17. sc400 oil light on
  18. pros vs cons remote oil pan/pump for 1uz turbo
  19. When do we change our water pump?
  20. Tuning a 1jzgte single turbo with E-Manage...?
  21. Does anyone know what this exhaust is?
  22. Help on MSD 8920 Install *searched*
  23. Single turbo guys
  24. Need an estimate
  25. How can I verify That a Transmission is an R154?
  26. Burning up MAFs
  27. check engine & trac off lights on after mild tune up
  28. Exhaust leak help.
  29. Engine randomly shutting off while driving
  30. Brian Crower 1jz 264 camshaft results.
  31. High HC on smog SC300 - changed everything
  32. A new FFIM offering for the 2JZGE?
  33. have somebody experience with this upgrage ct15b
  34. injector and what?
  35. Heart Transplant
  36. some advice please? one of my turbos has an issue
  37. just wanted to share this video
  38. Custom Exhaust Front Pipe?
  39. P1121 code, tried a few things but nothing! Help!
  40. Brass radiator SC400: Prestone or Toyota Red?
  41. P0171- help
  42. SUUUPER frustrating Code 14(Ignition Signal) OBD1 issue.
  43. Overheating
  44. sc300 manual front driveshaft length
  45. HELP! Problem with Car..
  46. Best auto trans for sc300?
  47. 2000 SC300 with 2jzge vvti Timing belt and water pump?
  48. Diff Swap
  49. Alright guys why is it so hard to get a manual swap?
  50. GTE Head swap on GE Bottom or Just go 2jzge NA-T
  51. S2000 AP1 6-speed conversion?
  52. AC unit NEED HELP
  53. Help!!!! Grounds 2jzge
  54. Sc400 w58 Swap
  55. Urgent
  56. SC400 Air Suspension Creaks?
  57. Fuel Rail Question
  58. Wastegate question...tial or precision?
  59. fuel guage does not work
  60. Major mistake during the swap , don't make the same mistake I did !
  61. Vacuum Hose Placement
  62. 92 SC400 200k CEL Code 052
  63. leaking tranny fluid
  64. Slow cranking
  65. SC300 Burning to much gas
  66. Fujitsubo Exhaust Clip
  67. is300 valve covers on sc300?
  68. Fender exit downpipe
  69. Injen intake on a 97 SC300
  70. Bleeding new clutch mc? Special procedure?
  71. This is all I really need to do the gte wiring merge correct?
  72. Widow question!!!
  73. Coolant loss
  74. Exhaust resonator questions
  75. Going rich but only at 2K? SC4
  76. Alternator..rebuild, replace, upgrade?
  77. harmonic balancer help
  78. Fuel pump not working
  79. SC 12V fuel pump mod- 1JZ
  80. Throttle Body Issues?
  81. Where to buy Motor Mounts
  82. Lots of oil from pcv
  83. Where do i find a 1/8th BSPT to -3 AN fitting?
  84. 1JZ Alternator will not carge battery
  85. HKS FCD explination?
  86. Ac light flashes on sc400 with 2jzgte swap
  87. bad starter... how to get car started
  88. 92 sc400 transmission type A340 or A341?
  89. SC400 problems HELP!!!!!PLEASE!!!!!
  90. 1UZFE with manual swap, Vvti or not
  91. 5spd swap shifter/trans problem need help
  92. SC400 Neurosurgery - wiring harness repairs
  93. Clutch swap help
  94. Actual NA-T intercooler plumbing kit foud? legit?
  95. 1jz gte vvti
  96. Starter issues...ignition/electrical cutoff?
  97. SC400 wont start. :|
  98. what's wrong with this picture/video
  99. 680cc top feed Siemens injectors fit on stock 1jzgte fuel rail?
  100. Can old o2 sensors cause bad mpg?
  101. Running Rich
  102. 1JZGTE or a 2JZGTE Swap?
  103. so my 92 sc failed smog
  104. ***92 SC400 only firing on half its cylinders***
  105. Random Steering wheel shakes
  106. Help me instal HID headlights
  107. HKS FCD .VS. Greddy BCC
  108. Different Differential make a Difference?say it x10
  109. SC300 MAF's
  110. Oil Pressure
  111. Manual transmission oil and diff oil?!
  112. High Output Alternator?
  113. motor mounts.
  114. cruse control wont work
  115. Radiator
  116. Gasket Brands for our sc400. Good or bad?
  117. Hks fcd opinions
  118. Need a Creative window fix!!!
  119. Help car wont start :(
  120. Odd Window Problem!!!
  121. Something we all need to READ!
  122. hey just a few tps questions
  123. aftermarket electric fan questions
  124. na-t GTE ecu project wont boost past 4k
  125. 2jzge intake question.
  126. need help with overheating on a 92 sc400
  127. Starter burned up?
  128. ecu
  129. Sc300 idle issue. not iacv
  130. turbo and fuel questions
  131. Gauge 10 wire - E85 friendly
  132. sc300 dual feed fuel rail on a budget
  133. GTE Swap info.
  134. Loud noise when changing into 3rd gear
  135. How to tell if you have Ps Problem or Rack and Pinion
  136. Intake pipes
  137. A/C Unit not powering up.
  138. Thermostat housing Gasket
  139. Automatic tranny from IS300 into SC300???
  140. 1uz swap into sc300
  141. dont know what to do about this
  142. 1uz/r154 with sc300/r154 DS confirmation
  143. Pulling 2JZGE minor problem.
  144. 1995 lexus sc300 02 sensor problem.
  145. Need a little help - my SC won't respond at all :(
  146. SC300 w/ Torched Springs
  147. no heat?
  148. egr - Code 71....HELP
  149. Need urgent help
  150. Blitz boost controller questions/ problems
  151. Fuel pump computers all tested bad SC400
  152. Bubbling noise??
  153. Engine Damper?
  154. so now the car runs, i have cel code 25, low idle when warmed up.
  155. Throttle Position Sensor
  156. Best turbo route simplified
  157. Head work
  158. Underdrive pulleys?
  159. Where does this part go?
  160. Grinding/rubbing sound when starting 1992 SC400
  161. Loss of Compression?
  162. hey whats up ClubLexus
  163. 2jzgte swap...wont crank
  164. lacking power
  165. A/c compressor problems
  166. My own sc4 BFI version, not done though.
  167. BC valve springs
  168. wheres the fuse for the eletrice fan 99 sc300?
  169. exhaust drone, rumble.
  170. exhaust drone..
  171. 2JZ-GE Port & Polish
  172. Head gasket
  173. overheating issues, quite intresting...
  174. 2nd gear grind/bind
  175. a/c problems
  176. Sc300 Na-t TT ecu
  177. Does anyone know
  178. 350z g35 trans on 2jz motor
  179. Bad idle on start up when it sits for a few days.
  180. HELP r154 speedo
  181. 1jzgte swap
  182. Going Na-t Questions!!
  183. Help with part Number:
  184. 1jzgte supra swap wiring harness to a sc300
  185. Sounds from the engine (vid inside)
  186. GTE complete? buy?
  187. Help gated shifter swap on 97 sc300
  188. SC300 w/ 1JZ-GTE swap, need trans and other ideas?
  189. Help! Head Gasket? Radiator? 1992SC300 5 speed
  190. No Vacuum?
  191. 97 SC300 Revving on its own at Start UP.
  192. Higher Gear
  193. SST's Alternatives?
  194. parts/rebuild
  195. R154 Slave bleeding problems
  196. how do i know if i have a sc400 diff? helps please
  197. SC400 no start - please help
  198. SC400 almost total system failure - please advise.
  199. This is what 5000 hp 2J's look like. LOL
  200. Super frustrating issue. Code 47 Sub TP Sensor?
  201. 99 sc400 charcoal canister location
  202. Anbody made cat back exhaust system w/the Tanabe mufflers?
  203. Close range key fob?
  204. Where is the low side AC hook up on 94 SC300
  205. Weird Starting problem, anyone help?
  206. MSD Digital-7 Ignition
  207. HELP 97 sc300 idle air control valve
  208. sc400 ecu pinout
  209. v8 conversion on sc300
  210. Help - Throttle Position Sensor TPS screw-up
  211. 440cc Injectors in a SC300
  212. Power steering, Oil, or ???? leak
  213. R12 to R134 AC Retrofit SC400/300
  214. car starts but cel comes on
  215. Is this a good deal?
  216. Transmission won't go all the way in
  217. 95 sc400 Alternator
  218. ?'s on 1jz (bpu mods, 2jz turbos on 1jz, & single turbo on stock ecu?)
  219. ac problem need help!
  220. 95 sc300 auto tranny
  221. Doing the 2jzgte swap
  222. Cold engine, revs jumping, car almost stalling, check engine light coming on.
  223. Using usdm 2jzgte harness on a jdm motor questions .
  224. Post your oil cooler/filter relocation set ups!
  225. left and right front catalytic converters
  226. Common Q
  227. cranking but not running sc300
  228. Any 1jzgte guys here using an aristo trans or ecu?
  229. SC400 Weird Stall
  230. exhaust question
  231. Fluid in my spark plug valley
  232. 1UZ vs 1UZ Vvti block strength?
  233. need help! going lean
  234. How to wire clutch pedal switch auto to manual?
  235. What size tap to use to tap ge oil pan for turbo drain?
  236. SC400 Stock Fuel Pressure
  237. Idle Problem, but no Vaccum Leak.
  238. SC 400 Excessive Cranking at Start
  239. W58 rebuild ?
  240. Sc300 Rear driveshaft length? Seller sold me wrong part?
  241. Small question
  242. SC300 Chirping Noises
  243. kaaz 2 way diff in 92 sc300?
  244. 92' SC400 | Coolant Sensor, Leaking Coolant
  245. sc400 random major oil leak wtf!!!!!!!!
  246. can a 1jz sound like this?
  247. Tempature coolant problem
  248. SC400 Cooling Hoses
  249. SC300 down...NEED HELP !!
  250. Worst 2jz problem discovered!!!
Content Relevant URLs by vBSEO 3.5.2
