PDA
View Full Version : Performance & Maintenance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 [59] 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87
  1. safcii help
  2. 1.5jz swap
  3. A/C not blowing cold when car is not moving
  4. Stock mufflers
  5. Pro Boost Platinum performance module
  6. SC leaking fuel
  7. A hello and a code 71
  8. C.L. mem. has ques. about 90 Supra
  9. Weird things happening
  10. Ball Bearing Coolant lines
  11. I think there is something wrong with my Transmission
  12. Planning some mods
  13. My New SC's engine problem, Should I worry ?
  14. anyone remember the post about univeral toyota SC kits?
  15. Emission test woes...92 SC300
  16. Thermostat Prob.
  17. GE clutch/fan/shroud fit GTE
  18. How strong are the stock rear ends?
  19. R154 & W58 shifters
  20. Whipple Supercharger
  21. 97 SC300 w/USDM 2JZ-GTE and V160 <Speedometer Question?>
  22. Idle Speed Too Low
  23. 2jz-gte w/ a ge auto trans
  24. Valve job?
  25. Resonators?
  26. anyone heard of this turbo kit?...
  27. Radiator Question?
  28. Need LA Based SC300 Knowledge Assistance
  29. stock fuel pump
  30. crazy thoughts (Engine Swap)
  31. Does the SC have an A/C System Diagnostic Check? Come on FSM folks!
  32. 1jz / Greddy Profec B Spec Ii Info
  33. c.d. changer weight
  34. new fans! pics
  35. Short little exhaust video...
  36. my idle?
  37. What is my single 1J setup worth?
  38. sc 400 wont start
  39. Fuel Pump or Fuel Pump ECU?
  40. R154 Transmission question
  41. the big diff 300 vs 400
  42. Th400 in Sc300 1j
  43. Car breaking up!
  44. Is a sc400 97 tranny a direct swap with a 95 sc400 tranny??
  45. Resetting the ECU? Or do I need more fuel?
  46. Worst climate for boost?
  47. 1JZGTE SWAP into SC300
  48. Sc400
  49. Bee*R rev limiter installed pics and vid(it may be ricey, but darnit i love it)
  50. My SC just started bellowing out smoke; smells like gas
  51. AC conversion R12 to 134a
  52. My SC1JZ Project
  53. 2jzgte into sc300
  54. High Idle Speed @ 1000 rpms
  55. 5spd driveshaft Vs. Auto
  56. Engine Cover for 1992 SC4
  57. Battery Relocation Help
  58. who can wire up my harness?
  59. Leaking coolant from back of motor
  60. SC400 and LSD (limited slip differential)
  61. map ecu wiring diagram for odb1?
  62. Searching for a 1jzgte.
  63. oil filter location SC300?
  64. Ordering the motor but need some help...?
  65. What oil should I use?
  66. Pondering my intake setup
  67. Magnaflows
  68. Air Flow Meter
  69. Squealing noise from new clutch
  70. is there a trick to the fuel filter
  71. What's next on my 2jz-gte SC?
  72. MKIII Supra does 701 RWHP on stock 1JZ
  73. Oil Capacity in an sc300?
  74. Differential
  75. Catch Can Setups
  76. Air Conditioning redux
  77. needs help after 1jz swap
  78. 92' SC 300 Performance Help
  79. Driveshaft Guibo / Flex Joints / Bushings / rubber piece with 6 holes in it
  80. Bfi ???
  81. tach fix woot!
  82. My Mechanic Says Car Not Worth Fixing
  83. Filtration
  84. A/C Clutch Engages w/Relay jumped, Freon Level Good, Still not cold?? Ideas?
  85. Where is your idle?
  86. sc400 not starting in morning but easily starts later in day?
  87. Temp Gauge and Coolant
  88. Tranny question?
  89. Personal concern: Are lightened flywheels "loud" ??
  90. Supra Front Mount Intercooler Kit Fmic 1jz
  91. speed wire at cruise ecu
  92. Cooling system maint...
  93. Difffence between 7mge and 2jzge intake manifolds?
  94. Does anyone know if the SC300 and the first gen GS share the same tranny?
  95. Damaged SC400 engine; replacement / rebuilt recommendations
  96. Supra LSD
  97. 1j leaning out not reving well
  98. sc400 idling at 3k rpm
  99. started polishing my oem intake!
  100. What are the possibilities???
  101. Whats Wrong With My Sc400?
  102. Does this Lexus Dealership theory sound logical???
  103. Where is the fuel filter
  104. turbo question
  105. what i did this weekend......
  106. Got a question about 2jzgte
  107. cooling system
  108. which injectors?
  109. Any known problems with swapping in a JDM motor in our cars?
  110. JDM Racing motors
  111. Need Picture Of Soarer Harness Asap!!
  112. SC300 12v Fuel Mod w/ Pictures - FAQ
  113. Possible Blown Head Gasket?
  114. Motor mounts
  115. car studdering
  116. Grounding issue??????
  117. Which is SC4 is best for boosting?
  118. 1uz manifold on EBAY AREADY
  119. just put a 1.3 head gasket on, quick question
  120. motor mount question.
  121. Apexi SAFC2 and PHR radiator fans discontinued?
  122. Rough Idle ... looking for some help
  123. Local Tuning Shops.
  124. Sc400s post your 1/4 times
  125. Hyper Voltage System
  126. 98+ sc's suitable for performance mods?
  127. 300 Pumpkin into 400?
  128. Distibutor O-Ring Part (pic)
  129. What else can you remove from the engine bay?
  130. tranny
  131. The start of some V8 madness
  132. Trasmission Shift Solenoid #1
  133. odd clutch pedal problem!!! some insight please
  134. 95 SC400 hesitation ?
  135. NA-T & Miles
  136. Need Some Help
  137. Japanese harness diagram
  138. Magnaflow mufflers
  139. 2JZ-GTE swap to sc400 questions
  140. what 1jz motorset did I buy??????
  141. help, neutral safety bypass , no crank
  142. Dyno result of my 2JZ-GTE 6 speed SC300
  143. my 2JZ-GTE 6 speed SC300 Dyno result
  144. cleaning iacv
  145. getting engine code read
  146. TPS sensor Zex kit
  147. 1JZ-GTE gasket kits
  148. some vaccum issue during 1jz swap, help
  149. yea....i did it guys.
  150. Pulling as much Power out of the 1UZ-FE as possible
  151. Coolant in Spark Plug valley
  152. Question about fuses/relays
  153. starting problem
  154. Rebuilding a W58
  155. buying my husbands gift
  156. ??? bout thevsafc from MRS. T70 supra
  157. exhaust fitment
  158. Dave H LSD kit??
  159. clearance ?
  160. why wont the mkiii 1jz downpipe work???
  161. So is it a grounding issue or... What do you think?
  162. Catalytic converter replacement issues, in need of advice
  163. help with oil leak
  164. Rear end ?'s
  165. r154 drive shaft issue, mk3 front won't fit
  166. sc400 plug wires ?
  167. Need some help from anyone
  168. 1jzgte downpipe mk3 vs jzz30
  169. transmission starts in second gear need help!
  170. Can't Put It In Gear
  171. im shootin for 1000 hp on the stock ge block, wanna see whats next? (pic)
  172. help please read!! 1jz swap!!
  173. Timing belt replacment...
  174. tapping power for gauges
  175. inspection question
  176. Grinking noise in the tranny?
  177. Bomz Crank Pulley
  178. 92-07 Lexus SC Series Throttle Body Bypass Kit +8hp
  179. 1jz engine swap
  180. Air Condition?
  181. Ok What Would You Do...
  182. couple of new pictures of centered exhaust
  183. Crank pulley debate
  184. No acceleration and burning smell.
  185. Cold Start Idle
  186. suggestions for leaky head gasket
  187. NEED HELP! 93 sc300 wont start, then start, then dont
  188. SC400 Cooling Fan Pump, Who has replaced it?
  189. Exhaust for 1999 SC400 w/ VVTi?
  190. Th400 vs Built Auto
  191. can anyone positively id this ecu
  192. sc300 tranny
  193. 1jzgte harness
  194. cant find a soarer clip!
  195. Where do I find a Pillar for my Gauges????
  196. Nissan Stanza electric fans in a 1992 sc300
  197. Funny how decisions get made for you
  198. Jumping FP and +B port. obd2 sc400.
  199. Turbo Socks
  200. Would these work for my swap?
  201. Key communicator issue for a 5spd swap
  202. want to start working
  203. ? on map ecu for na-t .
  204. *New Turbo*Bigger Injectors*LSD
  205. 1jzgte ecu question
  206. what year v8 maf works with sc300
  207. Turn Key Solution.
  208. Still sqeaking after repair!
  209. My Temp Gauge smokes crack.
  210. car died at work CEL 31: airflow meter signal (vacuum sensor signal)
  211. I need direction
  212. 99 sc300 6spd +2jzgte
  213. Clutch, which one is good??
  214. 1jzgte question regarding afm/mafs
  215. is300 5spd auto swap into auto supra/sc
  216. tuning safc2/vpc ?
  217. Is this a R154???
  218. '98 SC400 Transmission Pressure adjustment
  219. Remote mount turbo build
  220. New Exhuast!
  221. Can I Use 87 Octane?
  222. squealing noises - is it power steering?
  223. DYNO nightmare
  224. hi there
  225. Check Engine Light -Code 75,76 78
  226. Bubblegum? WTF is this?
  227. Trouble Shooting SC 400 Idle Issue
  228. Hot vs cold dyno runs
  229. 1jz sc300 question
  230. PT61 turbo loud sound
  231. 1UZ information, specs
  232. Ignition switched power wire
  233. 95 sc 400 need help!
  234. SC400 Cam Kit?
  235. Help, Swap Soarer Stuck, Help.
  236. Think before you buy an sc
  237. computer upgrade
  238. 1jzgte harness missing speed sensor plug
  239. na-T problem
  240. tranny swaps?
  241. gspeed wants to sell me a chaser clip???
  242. SC 400 Air Conditioning Service Info Needed
  243. fuel pump
  244. Manual Swap Question (Torque Specs)
  245. 1jzgte swap into sc300 questions?
  246. That's all well and good..
  247. 2jz tranny options?
  248. Air Conditioning
  249. shocks
  250. Traction control removal? Questions? Help? Any experts?
