- Need 92' sc electrical diagram!
- CEL code P0500 VSS
- some update pictures
- oh noes! starter woes!
- IACV Location?
- Looking to do a swap.....
- Na-t Injector upgrade info??
- I know, another heat ?, but I have piczorz!
- Noob! HelpME!!!!!
- part question
- Stalling issues at a roll
- how to: removal of tensioner 1uz-fe (sc4)
- Part #'s - Valve Covers & FIPG
- What is this sensor? Pics Inside
- Help removing stock Manifold
- Sc400 auto same as TT supra auto?
- 92 SC400 radiator support removal
- charging issues NEED HELP!
- Oxygen Sensor - 95 SC300
- How far can I go using only the battery?
- Replaced shift solenoids: Now worse :(
- The end to all S-AFC2 installation SC300
- 550 Injectors __ stock fuel rail???
- vehicle speed sensor help.
- Is it my clutch?
- Just Picked Up a 1JZGTE Auto Trans... NOW WHAT ?
- Sumebody Please Help!!!!
- Water pump?
- Blown Head Gasket...Starting a rebuild...
- 93 SC300 Car Turned Off On Freeway
- Stock auto shifter??
- Vibration in Gas pedal
- EGR block offs......?
- Water pump dead?
- 1993 sc400 Lexus repair manuals Vol. 1 and 2
- dumb sc300 question?
- 1jz, 2jz,
- Quick Question
- looking to do a 2jz swap
- soarer clip or engine/trans combo?
- Clickin Noise!!!!
- K-Break exhaust, anybody have experience with these?
- 2JZ auto swapped....chime in
- Quick shifter knob question
- new exhaust
- SC300 Question
- sc400 horrible shifting time
- taking off????
- engine trouble please HELP!!!!!
- '96 SC300 Intakes??? Will a 92-95 work?
- sc300 shift kit?
- sc400 2jz aristo wiring???
- 93 SC300 not running right-rich
- Tranny Question? HELP!!!!!!
- AEM ignition maps
- mystery part...
- Please help with torque specs for spark plugs..
- A few auto tranny questions
- Replacement Engine ?
- New track update w/ t66....not good!
- 1jzgte swap..
- engine harness problem
- Clutch Pedal Losing Pressure
- SC400 Cat Removal Help - Rusted Bolts
- 1j & 2j compatibility question.
- Starter Going?
- Need gated shifter help!! Can't get gears and shifter to match
- What is your general range for shifting on a w58?
- Noob Question??
- AEM EMS + walbro pump = high pitch whine
- v10 in a sc?
- If you dont have a battery tie down........
- 1 Jz Swap Or Turbo????
- Noob Question??
- Need help Asap!!!!!
- LOTS of problems HELP, PLEASE
- Can a 95 SC400 IAC be re-built?
- need urgent help, 1uz
- 1JZ no start...got fuel and spark.
- a little worried..
- if you have a 5spd you better do this now!!!
- Overheating from back of engine? SC300
- newb question on idle...
- Heater Core
- help! sputtering bucking hesitating SC400?
- Wrap or stock heat shield?
- SC300 Clutch
- W58 Speed sensor and my SC400 speed sensor?
- Help!!!!!!
- question about r154 swap
- Coolant burning
- warm air blowing through outside air vents whats going on
- 1J owners, I need a favor
- 1JZGTE 3k rpm hesitation
- Auto harness on 5speed engine and tranny???
- transmission fluid really low, on the road 95' sc400
- Limp mode 92 SC400
- Compressor is LOUD!
- Needed : wiring diagram for 1995 SC300 , doing 2jzgte swap
- engine ticking **annoying**
- TT LSD direct bolt up?
- quick tranny mount question
- fix it ticket for exhaust
- Size of head bolts on the 2JZ
- A list of performance mods that increse hp...
- Picking Up A Tranny Need Some Input
- Differentail plugs stripped :(
- Does this unit even exist??
- 95 sc300 1jzgte mapecu install and map. need help please.
- First Gen. S-AFC Wiring Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!
- Stupid Noise Comming from My Car
- 1JZ cold air intake finally in, pic.
- Car won't start...
- Got my MVP Headers today
- Torquing head bolts problem..need help ASAP!!!
- SC 300-97 – Body assy, Transmission valve - A340E - look forward to your recommendati
- NEED HELP with a Q45 Throttle body
- 92 SC300 coolant smell on startup
- happen to have a copy of this?
- 1jz-gte, do I need brackets if I use supra tt motor mounts?
- Excessive Emission?
- Finally doing "it" this weekend!!!
- 1jz/2jz power steering question
- Tune up Messed up
- Weird CEL problem, Please help...
- BFI project begins soon!
- Knock Sensor Location and Replacing...
- Need a cheap place to get R154 1J bellhousing.
- electrical ghost strikes again
- Could any of this be the ECU?
- here we go again.your info is appreciated.
- Problem with Fuel and with 12 Disc Changer
- clicking sound on p/s
- 1jz no reverse light, airbag light on
- Front Main and Cam Seals Help
- Power Steering????
- Part 2: Aristo Engine Swap.
- No spark condition. Need help TT swap!
- I have to give my car gas to start it!
- MK3 1jzgte/R154
- SC400 fuel line diagram
- Tranny Swap?
- torquing down rear diff bolts
- Auto Shifter
- Spontaneously accelerating cruise control
- Hmm..Could someone help with wires question?
- (NEED HELP) Rebuild
- safc 2 with itc
- Ethanol - E85 for SC300/400
- Snap on scanner adapter and card for Toyota/Lexus?
- Starter issue (amp draw?)
- Started my 1J swap today kinda! haha
- 1jz swapped sc3: A/C Compressor
- Good News on the R154 shifter extension(sort of)
- 92-96 RMM Exhaust for a 97 SC400
- did a compression test on my SC3...
- Gauge recalibration
- Funny noise on cold start
- oem bov replacement
- My shifter idea
- sc300 or sc400 cheaper to fix?
- Some help with an Auto tranny swap
- Fuel pump question
- shaking back end while doing burnout
- Pictures of CF Seibon Hood Fitment
- tricking the safc for big INJ
- Change timing belt?
- sc300 auto to 6spd conversion
- So I dropped my sc300 off at my mechanic and...
- Quick question about the intake.....
- -Idleing Problem w/ My 97 SC4-
- Writeup on dual nozzle meth install w/ pics.
- My 92 1J Pics
- what exaust is this?
- gs400/430 diff questions
- Auto trans question
- JZX147 (GS300) clutch pedal usable on a SC400 ??
- SC300 auto to W58 swap...HELP!!
- Oh so strange.... Fan clutch??
- My car is jerking
- SC300 will not crank???
- 5Zigen Fireball Mega Exhaust :D
- fuel/air controls
- Question on Full exhaust
- V Band Clamp not tighten properly..
- Which do I change?
- Question for those Original 5 speed owners ...
- Help, car will not turn off!
- FFIMs?
- Trufanatic's Official Build thread
- Never Do This....
- 1jz on AEM EMS-Tuned!
- Transmission Maintence Questions
- changing Shift Solenoids
- Motor and trans mounts? I think not..
- sc300 motor and tranny swap to sc400
- 1jz intake manifold with 2jzge runners for 2jzge?
- 4 inch intake
- 2jzge-t how much boost?
- CEL after Oil Change
- 92 SC400 A/C Drier replacement ???
- Interchangeable Transmission Mounts?
- Source for Garrett GT35R turbo
- is something wrong with my car?
- Returned back to stock and car is not running
- 1JZ Fan Clutch Alternative Engine
- Is this the FASTEST
- brake/electric problem
- SC300 + V8 MAF for F/I
- Price check from Auto > Manual swap
- running with AEM, car won't idle when Hot
- New rear end went in
- Cant remove the crank bolt
- CEL and Trac light and more...
- Oil Filter Heat Sink Cover
- Stutter Sound?
- single exhaust 1jz :)
- OEM parts please help..
- Just my luck. :(
- ac question
- SC-300 lower control bushings
- Upgrading Intake To Cone Filter
- Whos is this!!??
- Power limits on stock 2jzge auto tranny
- sc400 and aristo swap questions
- question! to sc300 2jz-ge owners.
- Wtf?
- Part number for Tranny Solenoids
- need your advice on my engine work...
- Bad day at the garage f
- Rear factory lsd most common?
- Aristo 2jzgte vvti ECU Part Number
- 1JZ+Trans+GT35r=?
- Anyone changed their head gasket?
- got my exhaust
- WOT box
- gm synchromesh regular or Friction Modified
- Oil leak
- Clutch "whir" - Throwout bearing?
- tranny ???????
- Steering Rack Replacement Need help. DUI
- Late model soarer R154 short shifter?
- HELP! my battery keeps dying overnight
- Fan Broke...
- Oil change
- Zex on SC3?
- 93 sc400 overheating REALY BAD!!
- Hey I Need The Part Number For The Exhaust
- Newb tuning question
- Want better low end performance, try this! It's free!
