PDA
View Full Version : Performance & Maintenance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 [53] 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87
  1. SC400 Serpentine belt replace recommendation
  2. SC400 Cooling fan fluid requirements ...
  3. Going low speeds in high gears dangerous?
  4. Finally! The SC300 will again be turbocharged!!!!
  5. My new 300 -- suggestions?
  6. car won't turn over!!!
  7. 15 hour Water Pump job
  8. best chassis to start with for 2j platform
  9. gated shifter help leading to DIY
  10. coolant temp (this normal?) pic
  11. Sc300 Oil Change, Overfill?
  12. stuck starter
  13. SC400 Oil Change ... What a Breeze!
  14. Installed VPC, now cel and weird idle
  15. Coolant Leak
  16. cracked block?
  17. 97-00 SC400 BFI questions???
  18. seat belts
  19. Will the BL built TT auto trans fit in an SC?
  20. Boost Controller & Wideband 02 recommendations
  21. This put a smile on my face/2JZGTE
  22. Crank Pulley Bolt Removal Sc400
  23. 1JZ Single Turbo
  24. Companion flange nut size
  25. R154 mk3 tranny extension?????
  26. SC400 idles issue, check engine light, DIES!!
  27. SC4 guys, help! Changed plugs/wires now rough at idle
  28. The dash battery light came on..
  29. questions about fuel managment..help..
  30. Muffler flange
  31. Power FC
  32. Short Shifter Kit??!!?!?
  33. Anything New For Tuning 1jz in sc3?
  34. Looking for SC4 autotrans upgrades
  35. Check Engine Light....Sometimes
  36. Soleniod valve for the heater
  37. Leaking coolant tank in all sc400s?
  38. 1jz coil wires?
  39. my 96 sc 2jzgone na-t first ever pics
  40. r154 conversion intall will pay cash
  41. PLEASE HELP ME!!! Cant get rid of EGR code 71
  42. Will this injector still work?
  43. methanol injection
  44. 400hp 1jz?
  45. BEWARE of OSAKAJDMMOTORS.com
  46. Rebuild the Water Pump?
  47. SC400 Hydraulic Pump Bolt Size?
  48. 2jzgte 6spd sc300 build...
  49. EGR delete
  50. Worth it or not
  51. Whats the world record top speed for the SC?
  52. electric turbo!:)
  53. power steering question
  54. SC400 Manual conversion ???'s
  55. Power steering line fix..oh so pretty
  56. Part number for exhaust rubber hanger?
  57. HELP PLZ!!! SC300 starting issues
  58. Stopped Dead in my Tracks
  59. Will a 2JZ spark plug cover fit a 1JZ engine?
  60. Which pulley is this?
  61. many ?'s
  62. help asap
  63. sc300 ecu question
  64. 93 sc400 need advice
  65. t-25?
  66. Whats your idle?
  67. Location of EGR probe??
  68. Dual tilted exhaust
  69. Engine Mods & CA emissions ---
  70. Supra differential in SC300
  71. bcc install on a 1j
  72. 91 SC400 Coolant level Rises and Falls FAST???
  73. wont rev pass 2k and stutters + pop
  74. ECU used or rebuilt ???
  75. pretensioner
  76. Injector wiring
  77. Fuel pump
  78. Down Pipe
  79. Torque converter?
  80. wiring harness
  81. SC400 transmission?
  82. Heater VSV not getting enough vacuum
  83. 2Jz Ge Best bang for the Buck?!
  84. Should I install the Gated Shifter?
  85. My exhaust quote...Reasonable?
  86. Trying To Remove A R154
  87. Transmission problem - 1st to 4th gear jump
  88. 2jzgte 6spd swap into sc300....questions
  89. AeroTurbine mufflers on a 99 SC300??
  90. muffler question
  91. Badlandz 3" to 4" electric exhaust dump....
  92. Bad Catalytic Converter?
  93. Building A 2jzge Vs Swaping A 2jzgte
  94. boost controller install
  95. SC400 Over Heating
  96. Documentation of R154 swap w/ pics
  97. Opinions on power loss/ SC300
  98. Single or dual exhaust
  99. Some help for a noob?
  100. Supra Torsen LSD installed
  101. New single kit dyno numbers
  102. Please help before I drive my FI SC400 into a lake and leave it for dead!
  103. Throttle Position Sensor Situation
  104. sc400 transmission cable
  105. Stock SC300 Rear end Question
  106. Anyone using a transmission temp gauge on their SC4?
  107. what is first best mod on sc300 under 1k? plz hlp
  108. Installing traction control in non-TC SC400 ?
  109. If you can read Oscilloscopes, look at this gem GE vs GTE
  110. sc300 turbo 2jz swap questions
  111. Lextreme Torque Converter And Turbo SC400
  112. Shifter Removal Help!!!
  113. Data link connector on 92 SC400 location??
  114. what's the best fluid for Torsen diffs?
  115. Dyno results
  116. Voltage woes, issues with battery
  117. Check out this video ( Have a question)
  118. Need Help with 2jzgte with 5speed
  119. Any Idea's on how to remove ECU?
  120. Power Steering woes. Sound clip inside
  121. Problem with lex!!! Electrical?!1
  122. Trouble Passing Emissions
  123. i need help!
  124. Best All Aluminum Radiator for SC300
  125. problem with HOT starts????
  126. Sc400 Guru's Please Help
  127. FINALLY reason for belt ejecting itself
  128. Compression & Leak Down Test
  129. Cast 1JZ exhaust manifold
  130. Vehicle Speed Sensor?
  131. Rebuilt & resurfaced Cylinder Head Gasket - good as new?
  132. Oil Catch Cans In Na-T Questions
  133. Inexpensive EGR block off
  134. downpipe question...
  135. Advice 2JZ-GTE Auto swap SC300
  136. Does this sound like Head Gasket Failure?
  137. Help! SC400 won't go into Drive
  138. Safc 2
  139. SC400 and LS400 Main ECU the same?
  140. Towing SC300 Question
  141. Crank Pulley Tool
  142. OEM look custom exhaust
  143. How do you swap a 2JZGTE into an SC400?
  144. Question(s) for those w/ Seibon CF Hood
  145. trans swap ?
  146. MAP sensor=No MAF???
  147. Turbo miles?
  148. coolant flush
  149. OBDI vs OBDII
  150. usdm 1jzgte swap
  151. Which Water Pump is this???
  152. another safc 2 question
  153. resetting electronics?
  154. weird electrical noise please help!
  155. How to bleed air out of the cooling system - 92 SC400
  156. Stupid emanage blue!!! Help me out here guys.
  157. Review my build - Questions and Answers with lots of pics
  158. Car died today..
  159. Engine Management?
  160. why is the 4.0 not more powerfull
  161. Post pics of NA-T engine bay
  162. Boosting issues
  163. Differential question
  164. Headlight Relay Part #
  165. sc300 troubles. suggestions?
  166. Engine Brake= Wasting Gas??
  167. Where do these plugs go?
  168. Name this leak!
  169. for those with the koyo supra R1856. is this a knockoff version?
  170. Leak problem....
  171. sc300 shutting off....need help!
  172. I can't believe this...
  173. Running Rich any Ideas?
  174. Stock V8 engine bay pics
  175. Brake Bleeding Problem
  176. 1JZGTE antilag 2 step rush racing
  177. banging into gear on freeway
  178. which blow off valve is this?
  179. 1jz
  180. Sc300 1jz soarer swap
  181. Replacing Coolant Reservoir- What is a switch?
  182. 2jzgte question
  183. 21mpg city... SAFCII and 3.76's....
  184. AC compressor
  185. This is for Scott
  186. tanabe medallion exhaust
  187. Noob here and need some basic questions answered
  188. clutch sticking
  189. couple of Questions...
  190. Will This Work?
  191. Losing Coolant from back of motor.
  192. pics of my NA-t project
  193. Trac Control
  194. Soarer R-154 short throw shifter..
  195. Reliabilty questions, concerns and timing job assistance
  196. can anyone help me out
  197. Pricision Industries converter review
  198. RMR SC400 axle-back exhaust my lordy I'm flummuxed
  199. HELP! Standalone and heating problems.
  200. Troubleshoot my SC400??
  201. OFFICIAL: Tanabe Exhaust Contest
  202. power steering fluid change?
  203. 98-00 Sc400 Bfi???
  204. would this be a symtom of a bad injector?
  205. whats is this part called??
  206. Ouch CEL!!
  207. sep belt keeps coming off!
  208. question for you NA-T guys with 3.76 rear
  209. noob here...
  210. Has anyone ever heard/did a swap with this motor??
  211. My 1jz build update
  212. 1jz vs 2jz which is better
  213. MAF wiring
  214. Automatic Transmission Fluid ATF OEM Recommendations
  215. Muffler suggestion? dual tip or single?
  216. Solenoids
  217. Shifter Upgrades..
  218. fluttering noise coming from engine
  219. is replacing header/cat flange gaskets a killer?
  220. sc400 TAP transmission
  221. sc400 wreckinging yard motor
  222. R154 Shifter extentions
  223. best gearing for turbo 5speed?
  224. W58 tranny...
  225. buy a 1jz
  226. I think my cats are clogged!
  227. where does vaccuum start?
  228. seemed to fix bucking problem
  229. I need some help
  230. Need quick O2 Sensor Replacement Help!
  231. Info needed, LSD Guts swapping.
  232. Tanabe Medalion Touring Exhaust Coming Out In May!
  233. Manual SC400
  234. Crank Pulley Options with 2jz-gte
  235. Where to get a OBD2 TT ECU?
  236. Which wiring harness runs through a 95 SC400 Driver's Side Fenderwell?
  237. my 1992 5spd sc300 has lsd?
  238. Coolant leak
  239. VAFC2 writeup for sc300?
  240. Some Diff options...
  241. New MAF needed for OBD code 31?
  242. Few Q's about R154 swap
  243. 1jz bogs while in boost!
  244. 1JZ Question...
  245. Fuel Pump wiring
  246. Once and for all is the exhaust the same on a 97 and 98 SC400?
  247. Over Heathing SC400
  248. what would causes this..
  249. SC300...Im a little retarted
  250. Starter run on issue 92 sc4
