PDA
View Full Version : Performance & Maintenance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87
  1. VVTi installation
  2. check engine light
  3. Check your intake
  4. electrical problems, help!
  5. question for jz pro's
  6. Exhaust Tick???
  7. Built Tranny
  8. Windows/trans
  9. battery light
  10. Update SC400 weight, gte single, Bride, and R154 (pics)
  11. Need HELP, R154 driveshaft?
  12. torn engine mounts :(
  13. Simple Q - 1995 SC400 OBD1 or OBD2?
  14. sc300
  15. 96' SC300 auto to 5-speed swap???
  16. A noob have questions.. Difference between supra 2jz and sc300 2jz
  17. Tune-up and slave cyl for $1k?
  18. Tune-up and slave cyl for $1k?
  19. 1uz hot valve covers?
  20. SC 400 MAnual tranny??
  21. differentials? choices?
  22. twin or single?
  23. Power Steering Fluid
  24. Has anyone here ever retrofited an R-12 A/C to R-134a?
  25. Power Steering Question
  26. Kaaz 2-way or Supra TT Rear End
  27. oil change question
  28. Help A.C. not working and its HOT AS HELL!!!!
  29. Trans Swap
  30. Exhaust, 3" or 2.5"
  31. SC400 high pressure hose parts HELP!
  32. Help with AEM EMS 1101 pin 62?
  33. question for 1jz sc owners
  34. Pulsation damper needed?
  35. do mk4 tt injectors fit sc300?
  36. delete mufflers or resanators
  37. 1jz cooling?
  38. pics of wet kit install on sc400
  39. Sensor Glitch???
  40. headgasket swap... Shiny oil... bad?
  41. charging ac
  42. maf to map?
  43. Knocking 2jz-Ge....Any suggestions?
  44. help pls. is300 flywheel same as sc300?
  45. Sorry but i had to... soooo happy! :)
  46. 1992 sc300 1jz & r154 swap
  47. which trans. fluid and fluid filter?
  48. alittle budget help please
  49. Turbo Manufacturers?????
  50. Where does this connector go?
  51. Cant seem to mend heating problem
  52. Electrical Diagram needed
  53. Soarer bible
  54. i need help quick please!...
  55. Speedo Problem?
  56. How I swapped an R154 into my SC400
  57. Electrical Issue - Weak Battery???
  58. All Aluminum Radiators - All the same or what? And does the Egg Trick work?
  59. automatic to manuel transmission help
  60. Ive been looking and looking, no one has the jzz30 swap
  61. Unorthodox cam gears
  62. STS Turbos?
  63. SC400 1JZ-GTE Exhaust Drive by Vid American Outlaw Flowmasters
  64. need advice on an sc300
  65. 1JZ-GE Nitrous questions
  66. Should I buy drag radials?
  67. r154 leaking
  68. Little Q and A
  69. which oil inlet/outlet flange am i supposed to get?
  70. Blinker Fuse Location
  71. what happens when Torque Converter fails?
  72. Slow response off the line
  73. 1jz water pump question
  74. Keep my current exhaust or redo it all?
  75. best clutch for N/A
  76. map ecu wiring
  77. Up down idle and then finally settles down..........
  78. Motor cutting out (video Included)
  79. Supercharger question
  80. Apexi Neo-s install help
  81. NEED HELP!! SC300 manual hydraulic line pics need
  82. 1jzgte Wiring Schematics?
  83. Automatic tranny question
  84. hard find, head bolt torque pattern.
  85. apex neo-s power gains sc300
  86. trans cooler really worth it?
  87. Supercharging a 96+ SC400
  88. NEED an ECM.
  89. How do I not Overfill the Tranny Fluid???
  90. Did an A/C test....
  91. one cam is off by 1 or 2 teeth
  92. Automatic transmission
  93. How to mount a blow off valve BOV
  94. 96' sc300 oil questions???
  95. new with sc's help. manual motor swap
  96. how much does it cost to switch auto.to manual?
  97. gte auto ecu into 5speed
  98. PSP replacement 1992 SC400
  99. 2JZGTE Aristo Swap in SC400 - A/C Problem
  100. does anyone know ?????
  101. vsv for evap?
  102. question about checking engine codes
  103. steering problems
  104. Need trans help
  105. 1jzgte in 96 sc obd2
  106. Need Advice: Noise at low RPM's
  107. Installing boost gauge
  108. gte into 5 speed
  109. na build
  110. SC300 Revving like I was tapping on accel
  111. I Want To Swap My Motor, Seached Forever, Need Help On Wiring A 98 Sc3
  112. 92-95 Sc300/sc400 Obd1 Code Retrieval
  113. 92-95 Sc300/sc400 Obd1 Code Retrieval
  114. sc300 auto to manual 1jzgte
  115. 2jz-ge and nitrous questions...
  116. Two Videos Of My Boosted SC300
  117. Need help. Car is dying..
  118. SC300 hard shift problem after valve cover gasket change
  119. What 1JZ manifold are you using?
  120. Wtf Ac?
  121. I'm at a total loss here...
  122. Head Off, anything recommended
  123. i think my car is possessed ...
  124. wiring schematics (engine harness) for 1992 sc300?
  125. 6speed getrag question
  126. no wheel power?! HELP!
  127. SC400 Auto to Manual Conversion?
  128. A/C Fuse? A/C not working
  129. Car not starting
  130. 1JZ w/ SC stock Auto Trans
  131. My r154 1J project
  132. Clutch Recommendations
  133. O2 Sensors
  134. Passing smog test after mods?
  135. My New 92 SC400 - Pictures & Info - WHAT YOU THINK?
  136. AC question for Las Vegas heads!
  137. stumped, and no engine codes :(
  138. New to the sc300 and 2jgte world.
  139. Poll: Should I keep waiting on the EKT headers?
  140. gte exhaust manifold into ge
  141. heard of nagano japanese.com swaps?
  142. Just hit 100k
  143. Simple Drive Belt/Maintenence Question
  144. Hey New to th Sc forums Need HELP please...Check engine light...
  145. Sc300 Transmission and amsoil
  146. new motor, louder than last.
  147. auto loc wiring question????
  148. New axle back mufflers from Megan
  149. SC300 Clutch torque specs
  150. Bearing
  151. Can anyone tell me what these wires are for?
  152. Car wont start...NEED HELP!
  153. Turbo Manifold, Intercooler, Downpipe outa paint shop!
  154. Pulling cams help
  155. will the SRT mani w/ turbonetics 60-1 hi-fi clear distrubuter?
  156. ABflug single vs Junction Produce dual
  157. Not Another SC300 GTE Transformation
  158. Engine Hoist
  159. Another Bad Idle Issue
  160. GMB replacement water pump --- different from stock
  161. TT Supra engine mounts on a '92 SC300
  162. Can anyone hear fuel pump whine through speakers?
  163. a/c problem
  164. considering motor swap need help/opinions
  165. Your Opinion on this 1JZ motor Please!
  166. Sensor On block
  167. HKS Hi Power Exhuast Question
  168. Parts Needed
  169. Small electronic problem. Please help.
  170. 92SC3 bought two months ago, broke down, time for a tuneup
  171. Any experience with Meagan Racing seats?
  172. Help! Head Bolt Size
  173. Bfi V4?
  174. auto to 5 speed
  175. Want to see pics of Apexi WS2 on SC
  176. Installed new exhaust, now have some hesitation. WTF!
  177. 1JZ flywheel and 7M clutch
  178. Serpentine belt slipped off after wipeout
  179. What wastegate mm are you 1UZ turbo guys using?
  180. My latest Mod...thanks to jdmjzz30
  181. a little scared, need help (Timing Belt 2JZ-GE)
  182. Sc400 Rpm ????
  183. Transmission clinking/bucking occasionally
  184. Clutch Master Cylinder
  185. Interesting. I don't get my fuel economy at all
  186. New exhaust on my 1jz SC 4" hotness (no56k)
  187. Would someone please let me know (Correct Socket Size for Plugs)
  188. Building oil pressure --on a fresh re-build GE
  189. Crashed 1JZ MKIII Now drop into sc300
  190. Increasing power with out turbo
  191. No Oil Pressure!! Na-t Sc300 Build
  192. SC300 Climate Control Issues...
  193. Help! GTE swap w/6spd question...
  194. My new exhuast...HKS Hiper
  195. CEL code P0420...a little perplexed
  196. Forced induction fan? hlp plz
  197. Best places to get a 1JZ Soarer Engine clip ???
  198. pulstar pulse spark plugs
  199. She is almost ready to be unleashed
  200. Very strange problem.... help guys!!!! did search
  201. radiator blew!
  202. NA rebuild-- Copper Spray on OEM HG?
  203. 98 sc400 with dead throttle
  204. Wierd Occurance
  205. Coolant splatter from Fan/Water pump Pulley *PICS*
  206. Super crappy idle, car shuddering?...
  207. 2jzge from a Gs300 to a Sc300
  208. Car won't start.
  209. Tranny tunnel cutout r154 swap
  210. question about a 1jz im thinking about getting help please
  211. Low Coolant Light
  212. Need to replace my clutch
  213. 1998 - 2000 SC400 Differential Ratio
  214. what part is this ?(2jzgte)
  215. Who has the best price for SC300 motor mounts?
  216. intake manifold for a 96 sc300
  217. need help sc 300 (muffler ???)
  218. sc400 stalling
  219. water pump
  220. Need some input on this please.
  221. 2JZGTE oil pan question
  222. Coil Pack Inspection and Turbo Blanket FAQ
  223. Weird thing happened today (infamous electrical ghosts)
  224. best exhaust for sc300
  225. SC300 Na --> TT Swap, INSTALL ANYONE!!!!!!
  226. Map ECU2 vs AEM FIC?
  227. greddy BCC adjustment on a 1jz
  228. BG 44k Complete Fuel System cleaner
  229. 2JZGE crankshaft journals
  230. extending the 1jzgte knock sensor?
  231. Good or bad?
  232. Those with low or erratic idle READ!
  233. Trans flush questions
  234. What is this & can I remove it?
  235. 5spd question
  236. How Would the SC look with these exhausts tips?
  237. Transmission Problem
  238. If my 1uz is blown...
  239. Swaping Motor
  240. 2 quick questions aristo gte swap
  241. aristo WIRING help
  242. Aight, I'm gonna do it: Single.
  243. something is wrong with my car please help.
  244. Another stumper?
  245. Tearing down 2JZGTE and questions with pics
  246. Transmission Advice
  247. DO I have a soarer 1jz?
  248. 94 SC300 A/C & HEATER blow same air temp
  249. I may have killed my car. Help please!
  250. Synthetic Oil Benefits?
