PDA
View Full Version : Performance & Maintenance
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86
  1. A/C Recharging Issue, Whats Next?
  2. Fuse, gasket, or radiator issue? Please Help!!
  3. Need help! Code P1127
  4. Exhausts for SC430 feedback
  5. nat bov spring rate?
  6. Possible Fuel Issue
  7. Stick
  8. Door issue
  9. Blown Engine '94 SC300
  10. Rear mount Tubro 1uz
  11. Throttle Body Cleaning
  12. I need some Fuel Pump advice
  13. Power Steering Leak
  14. Auto to manual
  15. My Mechanic seems to be Guessing!!!
  16. sc300 died left me stranded, igniter?
  17. Need help diagnosing 93 SC300 rear speaker noise issue (bad amp or sub?)
  18. Codes 12,13, & 31?
  19. What plug wires to get?
  20. SC400 - Auto Transmission Noise
  21. rough idle.
  22. Car shuts off with a little throttle applied.
  23. borg warner NA-T throttle body fitment?
  24. Help: 1993 SC300 problem, difficulty starting when hot outside, then engine light
  25. SC 300 issues Saint Louis Missouri
  26. 350z transmission on the 2 JZ..Collins Adapter
  27. Sc400 alternator
  28. Newly acquired sc4. Need advice.
  29. sc400 Running very weird...HELP
  30. Need helping finding ground&power wire for aftermarket antenna
  31. This car is driving me insane!!
  32. lexus sc400 windows
  33. Advice on Ac clutch bolt removal
  34. timing advance?
  35. Overheating need help asap
  36. Intermittent hard starting
  37. How to secure rod to the door lock actuator?
  38. windshield washer pump
  39. fuel level sending unit screws
  40. 1992 SC300 hokey steering
  41. Lexus SC400 92 Help OD light Blinking
  42. Transmission will not shift from 2nd to 3rd...
  43. 1jz vvti - timing belt replacment
  44. 1997 SC400 Transmission Issues
  45. power steering leak on line that goes from gear box to rack
  46. 1997 sc400
  47. FYI: Replacement/upgraded gearsets for R154 now available in USA
  48. help (SC400 dies shifting out of park)
  49. P0441
  50. Maintenance: In acknowledgement of E-Day: Catalyst
  51. Your run of the mill newbie,"my car won't frigging start!" inquiry...
  52. What kind of spark plugs does the sc400 use from the factory?
  53. ANyone in the SFV area with 94 sc400 ecu
  54. Help diagnose inconsistent sputtering engine
  55. 1JZ-GTE Misfire, Please Help !
  56. sc400 crank position sensor
  57. Just got back from Discount Tires
  58. 94 sc400 trans issues
  59. blower motor/cig lighter out, tensioner aswel?
  60. Help!!!! Still having problems w/ SC300 starting
  61. Extreme Overfueling & White Exhaust Smoke
  62. Re-Paint???
  63. 2jzge FFIM write up?
  64. 1JZ Swap running really rich fouls plugs
  65. Methodical Plan of Action For Modifications
  66. Engine bay question
  67. Front Cat Replacement Pipe Aftermarket?
  68. Knock Sensor Wire Harness
  69. SC400 Motor Swap
  70. Problems in my ECU
  71. LS400 PS pump on SC400 fittings?
  72. rear drive shaft
  73. Slew Of Problems(92 SC400)
  74. sc400 does not start
  75. SC300 starts then dies
  76. W58 info needed
  77. poor running
  78. Need some first hand experience
  79. Injector Issue / Question
  80. Need HELP with SC300 not starting.
  81. Help!!!!!!!!
  82. battery smoke when started the car
  83. SC300 Headgasket question
  84. sc300 na-t i know already been discussed but so many things please help
  85. Is this one error Code causing the other one(ABS and Trac)
  86. hunting for clutch pedal alternatives
  87. 1991 Lexus SC400 Acceleration issues & other minors
  88. Universal Bosch O2 sensor wiring
  89. Got a Dave H turbo kit today. Any tips as I step into the boosted world?
  90. question
  91. sc300 Na-t build
  92. How do I wire wideband o2 to Aristo ECU..i.e eliminate stock o2
  93. NA-T with JDM TT ECU - MAP Sensor voltage problems?
  94. low oil pressure
  95. ISSUES Someone please help ASAP BAD sc300 misfire
  96. Oil level?
  97. How to properly increase idle from 650 to 700-800
  98. SC300 won't start after head gasket replacement
  99. seafoam my 92 sc300
  100. wiring 2jzgte vvti into non-vvti sc300?
  101. SC400 97 Speedometer/Odo help.
  102. Serpentine Belt Squeaking due to Harmonic Balancer Alignment?
  103. steering wheel telescoping feature finally working
  104. 1992 SC300 Distributor
  105. Crank Position Sensor
  106. Need 1JZ Alternator Upgrade
  107. head differences 2jz vvti USDM vs JDM
  108. What oil to cool the radiator
  109. Gas Gauge not working
  110. Most probably cause of car hesitating under partial throttle?
  111. Jumped Timing what should I order?!
  112. 97 sc3 to 1jz vvti info
  113. basic na-t setup question
  114. W58 clutch.... going, or normal?
  115. Need help with w58 shifter issue
  116. Timing belt change, Special tools?
  117. Weird Clicking noise in Park + Drive
  118. Best timing kit?
  119. Help identifying a Supra diff?
  120. Sc400 Exhaust manifold swap?
  121. 94 SC400 - strange starting issues
  122. 1998 SC300 Transmission Mounts
  123. Code P1349 - 98 SC400
  124. Oill Leak Need Help
  125. na-t treadstone manifold fitment possible with s366?
  126. No Spark, ECU has been rebuilt. Need help.
  127. Props to Darryl Geller in Atlanta
  128. Tapping Noises on start up
  129. 99 SC300 Transmission Code Question
  130. 1992 SC400 Runs Cold with A/C on
  131. Manzo Performance Stainless Axle Back Exhaust System
  132. Think I found a/c problem
  133. intake modification and another question.
  134. No Start No Spark ..Please Help
  135. bay area oakland 92 sc300 5speed e brake
  136. Oem replacement bushing???
  137. question about changing steering wheels
  138. New Differential Bushings: Polyurethane Vs Solid
  139. W58 swap parts list
  140. Need Urgent Help With Anti-Theft System
  141. SC400 differential options?
  142. Something tells me an ECU cap leaked
  143. No Idle...need suggestions!!
  144. Tutorial: DIY Gauge Cluster LED Needle fix
  145. 1994 SC 400 Electrical/Radio Problems
  146. Need help on final decision... 1jz or 1uz?
  147. ok I need help
  148. 1992 SC400 NA Performance upgrade 200whp
  149. Please help! SC300 is running rough.
  150. clutch pedal option
  151. auto tt lsd for sc300
  152. A/C problem
  153. compression test on engine stand
  154. sc300 rearend options. need help
  155. Need Alittle Help on Differential
  156. How to fix a stuck OPEN wastegate??
  157. Pick request -Mishimoto radiator install
  158. 1JZ Harness Questions
  159. Car shakes in Drive -need assistance-
  160. Electrical Guru's, your help is needed!!!
  161. Belt tensioner
  162. High idle after radiator install
  163. head gasket question
  164. 1jz vvti swap, speedo problem
  165. Poll: Built Auto or R154 swap??
  166. Fuel pump problem
  167. New radiator recommendation
  168. bad starter or?
  169. just when I thought I was out. . . . . .they pull me back in.
  170. Going Lean... 2jzgte swapped
  171. gte gasket compatibility
  172. Who has had issues with their idler pulley?
  173. 98 sc300 no brake lights, stuck in park.
  174. A few sc300 maintenance questions, - maf, leak, curb rash
  175. Adjustable Fuel Pressure Regulator plumbing
  176. 1JZGTE hydraulic water pump
  177. Hi have one ask (taillight module question)
  178. Solenoid 4 wire
  179. stuck injector sprays when off?
  180. radiator install help please
  181. 2jz Engine Wiring
  182. Domestic Injectors on GE
  183. Need advice on which radiator
  184. Odd PS issue
  185. 12v fuel mod with AEM and Big pump
  186. r154 rear subframe options
  187. Engine Randomly shutting off. could use some help
  188. Need Help !
  189. SC400 Fan bracket bolts
  190. DIY: SC300 HID Fogs
  191. HELP-1jz wont rev past 3krpm (estimated) 93sc300
  192. Questions about a Big exhaust leak and Little Oil leak. And a box for my Air intake.
  193. Noise under shifter with car in park (P) and brakes pressed
  194. Ever happened to anyone before? Transmission issue?
  195. Clutch Drops RPM's?
  196. Parts to replace when rebuilding differential?
  197. Possible Pre-Ignition Sensor Damage
  198. bracket above the TPS hitting strut bar
  199. Adding coolers? Oil, trans, diff?
  200. Car warms at idle, but temperature drops when driving
  201. 92 sc300 backfiring through air breather
  202. sc300 distributor life expectancy
  203. Starter woes; now broken connectors
  204. Tomei LSDs, any good?
  205. Long Term SAFC Results
  206. Spinning wheels on dyno
  207. Problems with 12 disc changer
  208. Harness plate help
  209. ECU - Climate Control - Needles & Backlighting
  210. SC400. Need help! Crank will not turn over.
  211. ARP Head Studs
  212. sc300 dies after 10 feet wont restart for several hours.
  213. turns over not cranking no fire help
  214. sc400 Transmission slipping after Its warmed up?
  215. LS400 to SC400 swap?
  216. Turbo problem
  217. Power loss - right bank (psgr) no power, has spark and good sparkplugs.
  218. Car vibration issue - need help
  219. cant get timing belt on
  220. LSD 1998 Sc400
  221. 1uz
  222. ffim
  223. 98+up GS400 trans into a 92-93 SC400?
  224. Driver Side Headlight Problem
  225. Code P0171 and P0172 on Boosted NA-T? Help!
  226. Strange ignition issue
  227. window interior trim crack repair
  228. Check Engine Light On. Plz Help!
  229. a little insight for a 2jz vvti swap
  230. Tuning
  231. what differential is this? will it work in an SC400?
  232. Car misfires and bogs when warmed up please help!!
  233. Can I use a ls400 coolant res in my sc400?
  234. 1jz problems.. wtf is wrong with this thing.
  235. Sc400 won't start, New fuel pump
  236. 1JZGTE Leaky Caps
  237. knocking front wheel
  238. 95 sc300 bad fuel pump ecu?
  239. 1997+ cluster in pre 97
  240. Overheating
  241. Knock Sensor 52 - 93sc4
  242. Beware of Water Pump Holes!
  243. Need guidance asap
  244. Will a 95' SC300 wire harness work in a 92 SC300?
  245. First Start of Driving Season
  246. help, won't start.
  247. Sc400 with a strange leak
  248. Door interior trim panel reassembly
  249. What these cables for?
  250. Can someone please help. GS300 Fan in my 95 SC400
