PDA
View Full Version : Performance & Maintenance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87
  1. drive shaft question
  2. Power Steering question please
  3. AEM map sensor install on 1jz
  4. need help with 5 speed swap
  5. SC400 shuts off at startup,and boggs back when driven.?Help.?
  6. 5-speed pedals
  7. Annoying noise I can't track down.
  8. Vacuum hose issues
  9. transmission mount question
  10. E8 standalone
  11. Just got back from the dyno
  12. Help out with looking for a clutch
  13. Squeaking Very LOUD
  14. Rear Output shaft seal r154 HELP
  15. supra 1jz into SC?
  16. Oxygen Sensor Interchange for 1JZ
  17. VACUUM LINES...ugh...and a question.
  18. I made a video! First start up for turbo setup gt3076r *incomplete
  19. Can't read OBDII CEL?
  20. 5Spd Conversion questions. SC400 related.
  21. My Cutout idea
  22. egr valve..how to
  23. smoke from exhaust
  24. Car tugging a lot on the highway
  25. i need help!!! Crank Sensor
  26. A few questions about the 1jz engine sets on ebay
  27. Is the Sc400 Tranny Difficult to remove?
  28. Power steering broken?
  29. Goin 2 the track 2nite...
  30. Would this work? *help*
  31. Power Steering Knowledge Needed.
  32. Fuel system for 700rwhp 2jzge!...
  33. Headgasket change turn around?
  34. quick tranny question...
  35. GTE Auto with SC400 Driveshaft...AM I being slow???
  36. Help please, tps wiring problem
  37. pumpkin install
  38. complicated starting problem, need expert advice please
  39. 400 electric fan conversion 1 or 2 fans?
  40. only right rear looses traction
  41. which rear end do i need
  42. What do you think of this turbo?
  43. WTB: cold air intake/filter SC400
  44. where the f#*$ do i get a midepipe
  45. please help!!!car not starting
  46. A few questions about my tranny and other stuff
  47. What's the best resonator out there?
  48. 93 SC400 Need your help running 3/4 hot
  49. Fuel Pump Installation!
  50. SC300- full tank to dead dry average
  51. Regarding the SC300 computer wiring system
  52. Igniton not working
  53. Runs Better with MAF Disconnected
  54. calling all aristo swaps
  55. Question for the 2jzge; interchangable parts
  56. I want more out of her!
  57. Potential of the 1UZFE when Force Induced
  58. Just Wondering
  59. Educate Me.......Engines
  60. Auto and 5spd ECU difference issue?
  61. 1jz sc300 topspeed only 110mph
  62. ECU Help
  63. Power Window Problem
  64. Does anyone have a spare ECU (SC400) or has anyone else tried this?
  65. where to buy oem pressure plate bolts
  66. V160 Install Question
  67. Screeching clutch.
  68. A few vids of the Mag/Dyn Exhaust
  69. SC400 trans performance Q
  70. can anyone help me idenifly these 2 turbo gaskets?
  71. Can't decide on rods to save my life!
  72. what does this do and where does it go?
  73. Battery always draining car. What if I disconnected a Terminal?
  74. How to tell if it's W58 or R154?
  75. Should I get a 1JZ or a 1JZ VVT-i?
  76. V-Band Downpipe for a single 1jz
  77. Bought a JDM Supra TT motor with Auto tranny for my sc300 what else do i need
  78. Going to track for the first time HELP
  79. Sc300 exhaust compatibility
  80. Clutch suggestions needed
  81. P/S lost at idle
  82. Using foam in the engine bay [BFI]
  83. GE for a GTE short block ?
  84. Alright New Castrol Edge, whats your take anyone use it?
  85. What hose is this?
  86. What i need to turbo?
  87. 2jz sounding like a EJ20
  88. ever had this problem
  89. timing belt...serpentine belt...
  90. Soarer MT clutch engagement help
  91. LSD rear end identification, traction control?
  92. Tach only reads half of real engine rpm?
  93. Help me out Here Guys
  94. Looks like my W58 is toast.....what do you think?
  95. 1992 SC300 TPS Voltage
  96. check engine light came on then off
  97. transmission question
  98. knock sensors
  99. What 1jz's?
  100. Rev dropping?
  101. soarer/chaser ecu Fcon
  102. need help with power steering leak
  103. Can I modify my auto trans (SC400)
  104. My 1jzgte swap thread pic heavy!
  105. Comp stage 3 clutch for your stock clutch
  106. problem engine light is on!!!
  107. What Headers Should I Get For My SC300?
  108. Greddy MX vid clip
  109. questions on torque converter
  110. HOW TO: SC300 High Pressure Power Steering Hose
  111. Ebay Reman'd Compressor or Used Compressor?
  112. Bad Idle/Shaking/Misfire?? Help!
  113. can someone identify this BOV?
  114. My custom cold air intake set up!! Pics!!
  115. Random CEL, bad O2 sensors?
  116. Out of interest....
  117. Is this a good idea when motor swapping?
  118. where to buy a motor????
  119. W58 to 1uz Adapter plate on Fleabay!
  120. FINALLY my exhaust sound clip
  121. Removing Alternator 1992 SC400? HELP!!
  122. anyone have a rear end diagram
  123. Exhuast pin point?
  124. a/c stopped working!!!
  125. Vibrations when gas depressed
  126. transmissions
  127. Planned: Suprastick and Amsoil
  128. How many have the EKT/IMF headers for the SC400 ?
  129. just Bought this gte
  130. sc300 Speed Sensor, Location, which one 5spd
  131. Does SC300 have any engine reset tool? check engine?
  132. Spark plug wire question.
  133. Turbo Opinions NEEDED.
  134. Exhaust sizing
  135. Ignition system wearing out too fast
  136. SC4 Throttle Plate cleaning.
  137. engine broke off valve in 3rd cyclinder
  138. Alterntor ?
  139. Cel light on!!!! Code 25
  140. No power to my passenger side coil on SC400
  141. 1jz time
  142. Location of EGR temp sensor on a 1992 SC400?
  143. PLEASE help!! Where is the fuel pump relay for a 93 sc400?!
  144. sc400 makes rubbing nosies
  145. Driveshaft Loop
  146. what size is the injector tip?
  147. tony performance sc300 1/4 pass
  148. 1jz tensioner Question, Help
  149. Please help meee! 93 sc400 battery light on
  150. Timing Belt
  151. 92 sc300 Running rich/poring smoke HELP????
  152. how many cats and resonators on sc400?
  153. SC 1jz at Dyno on stock boost 280WHP with Video!
  154. virgin 5speed SC300 NEED ADVICE!
  155. SC400 and LS400 transmission difference?
  156. suggestions anyone?
  157. TT HG thickeness?
  158. first video sc300 na-t out for a run
  159. A/C Light Blinking (Used Search)
  160. Problem: RPM bouncing, no throttle response , CEL flashing
  161. 2JZGTE water pump in an SC300
  162. 92 SC400 - Water Pump Problem???
  163. Misfires at WOT
  164. Sc300 Muffler delete
  165. rough idle on 93 5speed sc300
  166. Rich mixture
  167. Tune time
  168. SC400 Auto Driveshaft Pictures?
  169. Fastest 60ft times in an SC.....?
  170. Headers for 2jzge?
  171. grindy gears low rpm?
  172. advantages of forged pistons over stock TT?
  173. Strength of metals after heating and cooling
  174. Looking for Pictures of speed sensor
  175. Alternator upgrades?
  176. Another Speedo Thread (I've Searched) - Wiring Question
  177. Some Engine shots just before I ship my car out of Japan
  178. high end loss
  179. please help me with sc400 slow on take off
  180. Start Me UP
  181. GT30 With 2jzgte ????????????
  182. Supra TT LSD...
  183. ~ 1JZGTE in a SC3 ~
  184. Sc400 2jswap need help!!!!!!!
  185. Sc400 Tranny Conversion
  186. power steering noise
  187. Nitrous Kit Help Please!
  188. My car keeps dying, any advice?
  189. GS exhaust fit in SC?
  190. Can i reuse the IACV gasket when cleaning it?
  191. 1jz or Na-T
  192. PS pump rebuild kit
  193. Bad gas - now the car has intermittent sputtering.
  194. Greddy SP2 exhaust for Supra TT...anyone have it?
  195. R154
  196. Burnt clutch, replacing it, what do i need?
  197. SC300 with a TT Head and TT Auto Questioins???
  198. WTB: Turbo Kit for my Sc300
  199. sc300 ecu same as gs300?
  200. Ignition Control Modules??? Opinions welcomed!!
  201. Mishimoto electric fans.
  202. driving with no maf sensor
  203. 1992 SC400 Car is bucking at 35-50mph!!!
  204. NOOB needs help and opinions!!!
  205. Supra USDM TT Harness Info - Need it
  206. Something bad happened
  207. Quick HKS FCD question
  208. Sluggish
  209. My NA-T project... for all you picture *****s(56k... doubt it)
  210. 1JZ-GTE running hella rich, S-AFC 2 help!!!
  211. battery light coming on after 3k rpms?
  212. my next muffler setup
  213. New 1992 SC400 troubleshooting, won't start... pissing me off!!
  214. Made lots of changes, ignition woes ensue
  215. 1jz swap problem...
  216. I need to make a decission; Best option for my bottom end
  217. tech meter help
  218. What is this plug on the Rack Pinion
  219. Camshaft question
  220. So if I cannot get my Blitz Nur Specs... which mufflers?
  221. LSD DIFF question?
  222. CEL + Cooling Problem
  223. weird clutch pedal operation? help me please.
  224. Engine covers?
  225. A/C Line Repair???
  226. Fuel Problem?
  227. help me choose
  228. Battery jumped backwards!!!Please Help me!
  229. OEM sc motor mounts vs Supra mounts
  230. sc400's....maybe cheaper headers.....
  231. New Help onFan blade.
  232. How to remove AC clutch? (diy request)
  233. not my sc but pics of my set up....
  234. PLEASE help me matchup these last wires
  235. Who has replaced a sc400 radiator???
  236. 1UZFE power loss: What's the real Culprit?
  237. WTB Air Intake For sale?
  238. what drive shaft???
  239. Newb with 1jz question
  240. Can someone identify this part?
  241. My 93 SC400 is dying, please help me diagnost the prob
  242. JZX100 VVTI 1JZ to SC300... Who has done it?
  243. wifes car acting very strange wont start
  244. middle of working:Need help fast
  245. Another 2jz-gte swap thread...
  246. Will a turbo Manifold from a NA 2JZ fit on a NA VVt-i 2JZ
  247. wondering!
  248. Differential flanges for new driveshaft
  249. DIY: Alternator Plug Repair Harness
  250. Driveshaft and Flywheel aluminum vs steel
