- Sc 300 NA-T build, with pics!
- Final drive help!
- R154 clutch options?
- Let's see what your intake looks like?!
- Tranny issues HELP!!!
- quick ? for those with aristo swap
- Best Synthetic Oil for 1JZ/2JZ ?
- detroit locker possible ?
- 92sc400 revs from cold start
- Transmission Fluid Black
- 2002 SC430 stopped running!
- Engine purchase!!
- Engine purchase question!
- Squeaky Noise
- Sc300 not starting. Need help!
- Calling all LSx conversion folks
- how many 1uz front and rear cam seals/plugs?
- 1995 SC400 Exhaust
- Iat sensor singal ??
- GTE ecu in na-t sc300
- What is this dash indicator?
- flywheel question
- supra harness, with a aristo motor
- Decided to take a couple photos of the engine nekkid
- 95 Sc400 Manual Swap soon!
- E-Brake Light On
- Helppp
- sluggish
- Any 1jzgte guys here change valve stem seals here?
- Question regarding VVTI.
- GTE block rebuild piston ring gap help.
- VVTI Coil Packs and Dizzy deleting!
- Power Steering (Like Everyone Else)
- difference between soarer auto trans
- R154 housing
- Alternator oil leak
- Manual shifter removal to fill tranny fluid
- Smoking exhaust and leaking powers steering
- Which tranny for 1UZ?
- SC300 Transmission Fluid Woes
- Need help,fuel pump has no power.
- sc300 1jz downpipe
- Engine leak - Can someone identify what this is? (PIC)
- LSD or Faulty diff??
- Are 92-99 sc300 auto drive shafts all the same?
- seafoam sc400
- What kind of car is this 1jz harness from?
- header back removal diy ?
- sc400: intake manifold porting and gasket matching
- sc300 seems like leaking oil
- sc300 and supra rear end
- Coolant Leak @ Back of Engine...Pull Trans or Engine?
- need help with 1jz
- MAP ECU 3 assistance needed
- whats going on w my AC?
- crank pulley off, balancer still on..what next?
- fuel pump
- traction help!
- Estimate my horsepower - win a lunch with me
- gs steering wheel on sc.
- 1jz AC Compressor Question
- Oil in the top end of the park plugs
- Hello fellow Lexus drivers!
- Help
- best place to order parts
- Stock 1992 SC400 dies after starting
- Expert Advice Needed :[ - 95' SC300
- soarer ecu? how to get past the 13psi limit
- Where to buy 1JZ swaps?
- Tranny swap options? For sc400
- SC300/400 LT1 6-speed swap attempted?
- your take on driftmoition turbo kit
- Sealing auto trans tunnel on 5 speed swap
- My POS keeps dying when put into gear, HELP!!!
- Exhaust questions
- prices
- Koyo A2062 Radiator for 1996 SC400
- 94 SC400 VSS Part Question.
- Need help car dont start
- what is the max GM LS engine to fit in SC400
- Odd noise coming from passenger front shortly after startup.
- Check Engine Light 94 SC400
- HELP SC400 wont start
- going w58 on my 1jz swap!!
- tt differential for 99 sc 3
- 1jz or 2jz that is the question...
- car lags and idle gets really low
- Odd Idle: MAF,IACV,TPS, or Vacuum leek????? need heelp
- First Time Lexus owner - SC300 NOOB factory exhaust spec questions
- Odd Rear end diff pop noise. Brake noise
- R154 Trans Issue.Help
- Problems on my cats
- Re-tune results! S362
- would a 99 sc wire harness plug up to a 01 i.s motor???
- MAF ???? Help
- correct me if iam wrong?
- Finally Some Progress (pic heavy)
- ECU-IG fuse keeps blowing.
- Need Help SC turning off
- HKS T04S turbo help
- need help- hg?
- Is my Transmission shop trying to pull one on me ??
- supra mkii W58
- bucking and hesitation in 1999 SC400
- Gte tps help!
- going turbo for cheap
- radiator silicone hose blue
- USDM 2JZGTE going in
- Will an 89 supra rear end fit in a SC300?
- sc300 97 trans into 93
- O/D Off light intermittent flashing?
- Aeromotive 340lph fuel pump wiring - reverse polarity?
- Coolant loss is driving me crazy!
- Can anyone confirm me if this is a R154 or a W58 Tranny?
- Water Seal Plate Leak on 1UZ
- '96 sc 300 misfire, codes po300, 301, 306
- 1UZ ITB's Finally here?
- MAP-ECU vs. SAFC
- 2jz twins on 1jzgte
- SC300/SC400 Pedal Set for 5 Speed Conversion
- Which oil pump is this?
- old r154 shifter for mk3 what to do
- many problems with my sc400 1993 help !
- na-t turbo set up
- pulley puller snapped crank pulley sc3na-t
- 7mgte pistons in a 2jzge?
- TT upper mani Retrofit!?! almost done...
- 92 SC300, Cold Start Chatter
- Latest source for 1jz valve cover gaskets?
- Power steering help
- how to tune up a 1992 sc400
- Rebuild my 2J or put in a 1J?
- Rough idle
- No start when cold problem. help im stomped
- I bet no one here can tell me what shifter this is on a r154!
- Koyo Aluminum Radiator now leaking!?!
- which harness??
- 1992 motor and motor harness in 1995 sc300 now have warning lights
- 1992 SC400 Engine Shuts Down When Moving Shifter into any Gear
- clicki lickilickilick, no start... few mins later vroom
- Car didn't pass inspection because of jumping idle!
- Whats wrong!?!?
- Odd over heating issue...yes I used the search button.
- 97 supra rear
- odd missfire gets better when warm?
- SC400 Will Not Start, Engine Stalls Out
- Just bought my 95 sc300 need help with door indicator killing my battery!
- blue smoke turns to black
- HELP. Throttle chokes when i drive around the block
- Hot Terminals No Start
- Injector fitting issues help needed
- How to get Climate working for DIY 1jz wiring.
- Lextech temp needle fix?
- Engine Hoist Question
- 1jz vs 2jz
- head gasket
- would a 01 i s 300 motor work on a 99 sc??
- Super Single OS Giken Clutch Kit
- 1jzgte sc300 not starting
- ijz newbie swap help
- Motor Swap
- 2jzgte cold start problem
- Sc300 & GS300 A/C compressors interchangeable?
- 1jz swap issues HELP!!!!
- Idle surges when in park
- 2jzgte+R154=what clutch
- 2JZGE valve covers (HELP)
- 7mgte electronics on sc300 2jzna-t any thoughts??
- help troubleshoot for spark 2jz ge
- Heat problems
- How to Change Front Wheel Bearing?
- 94 SC400 check engine light
- Looking for cooling plate? Also polished rad brackets
- Ps pump question
- Do you recommend rebuilding your A/C compressor?
- chinese forged pistons and rod
- aristo tt auto trans code..??
- Help with 1JZ Motor
- Ordering my swap harness Q's
- Need help with JDM 2jzge swap
- NA or Turbo which is cheaper and worth it???
- 2JZGTE VVTi swap help please!
- Problems with flex disc
- New sc400 owner need help!!
- Upgrade 1jzgte...
- 1UZ partial teardown, pic requests?
- knocking sound when i let the clutch out
- Piggyback guys: How clean is your closed loop?
- Help tune AFC-II
- AC Compressor Front Seal
- ECU Main Relay PART NUMBER?
- Does anyone have same transmission issue / fix
- oil light?
- DIY intercooler pipe beading
- Where To Buy SC Performance Parts?
- Anyone running delphi injectors NA-T
- Need mAnual 2jzge ecu pinout nuetral safety switch from 93sc300
- Sc400 Engine Removal 1UZFE
- Want to start drifting, but I have a question...
- JDM 2jzge
- Are these the supra tt motor mounts needed for sc300 stock replacements?00
- Need help auto to w58 not starting
- Intercooler and blowoff valve!!!
- transmission mount replacement
- Sc400 1jz swap help
- Soarer clutch master/slave cylinder same as?
- Who has a Spec Stage 5 clutch?
- catalytic converter issue
- Do you have a noisy fuel pump??
- Pricing for V160 6-Speed V160 Getrag Transmission? Rebuilt or New?
- I came across this turbo
- legit lsd??
- starting problems. will crank but no start
- Where to buy oem spark plug tube seals
- **Coolant Issue** Need help diagnosing an issue
- GS400 Mid pipe on SC?
- Bought a Turbo 5 speed SC400, and its already under the knife...
- SC400 heater: out of commision! Assist.
- Getting tired of this
- Blown headgasket or something else..?!!?
- Window motor repair
- aftermarket foglight issue smoking issue
- Foaming water!!!
- sc300 keeps turning over not starting
- 1jzgte in the works maybe??
- 1jzgte backfiring, wont start
- Anyone replace valve steam seals with oem?
- Man! Now Check Engine and Track Off!!!
- replaced iacv and now the car won't turn over
- turbo quesiton
- 92 SC400 Wont pass Emissions - Possible ECM Failure???
- Rebuilding Engine. Part/Brands?
- Engine dies at 3000 rpm and then kicks back in after head gasket repair
- sc400 with 1jzgte kickdown cable not connected
- Seafoam smoking under the hood?
- na/t fuel management
- Battery keep draining
- Please help, rack & pinion, PS pump
- What intake are you using 4 stock twins?
- Can this issue be cause of a weak motor mount?
- Stage 3 Clutch recommendations?!
- will GS300 diff in sc400
- Please confirm my basic aristo swap checklist
- What are your ideas on this? 400 issue
- Big single SC400 GTE in progress
- questions about my sc400-T build
- Tundra TRD Supercharger In An SC400
- Which fan and shroud for 1jz?
- ls1 engine to sc400 swap?
