- Ignition issue??
- Fail SMOG!?? WTH...
- driveshaft guru's inside!!
- 1jz idle speed screw - pic help
- 6 Cylinder CNG Natural Gas Conversion Kit?
- 2jzge obd1 auto ecu work with w58??
- floor jack and jack stand
- eBay Turbo kit
- Messed up with trans fluid. Full flush?
- How do I clean valves? Doing valve stem seals
- Of course, trans pan gasket leak..:(
- help!!! snap on/snap off!!!!
- Where do I begin?
- OK, how do I put the valve body back in to the tranny properly?
- 2JZGE non vvti Cam question (distributorless)
- 1JZ wiring guru's, AEM V2...
- BIZARRE tranny issue, please help!
- GS400 manifolds
- 1997 sc400 cel code p0340?? Cam sensor
- SC300 Power Steering Hoses (not the high pressure one)
- Injector Dynamics
- 1997 Sc400 Differential fluid?
- Oh god did I just blow my engine?
- Sc400 Auto trans filter? Autozone vs dealer?
- Main relay (efi relay) getting hot - car wont run properly
- Getting My 1UZ Into The 300+hp Club
- 1jzgte single turbo o2 sensor help
- Transmission jerking on sc400
- would this work?
- Fuel system part identification help
- 5 or 6 speed automatic from newer SC400/430's?
- W58 or R154 transmission?
- ngk in my sc400
- Thinking of getting a Torsen LSD 3.69 ratio from a Supra for the Soarer
- Torn between setups
- Fuel return issues
- radiator light
- overheating problem
- 1jzgte SC400 which motor mounts?
- 5 speed help!!
- my 92 sc400 engine fluid fan keeps running out, input needed
- I need advice please!!
- 2jz-ge Help!!
- Mass airflow sensor mods?? 1jzgte vvti
- How Much Power
- 2jzge vvt-I na-t tuning
- Looking for tips on LSD swap
- I did the impossible...now need advice
- Can anyone confirm 2jzgte intake valve seals work on 1j intake side?
- Thoughts on this gasket kit?
- HELP! 92 Lexus SC400 won't start.
- 98 sc300 2jzgte swap(aristo) NEED HELP
- 1jz gte Black smoke?!
- does taking cats off give you less power??
- high performance crate motor
- 2000 sc400 radiator in 92sc400???
- Transmission options
- SC3xx starts then dies, please help!
- The Ultimate Daily Driver, Build Thread.
- Wobbly Harmonic Balancer
- 98 SC300 vvt-i to 1jzgte question
- battery drain
- does the apexi safc 2 make i big difference after dynoed?
- Watermeth + stock compression? see what happens inside
- Fuel pump noise FTL! Any ideas to shut it up?
- Basic Engine Upgrades
- Special tools needed to rebuild a W58?
- So finally got my car on a lift...
- NA-T s366 or 6265 ??
- A/C Issues - Expansion Valve Replacement
- Engine swap question
- EGR removal problem
- TRD Japan 5sp Quick Shifter
- [Q]TRD Shifter Spacer Needed?
- valve specs on na mk4 same as 97 sc300? or any one have that section?
- I really need some help with this guys.
- Cooling Fan Relay
- vinyl sc300 question
- Motor mount trouble
- Should i keep single or dual exhaust on my sc300
- 93 sc400 running rough on idle
- Sc400 manual VS. 2002 M3 ??
- SC3 custom exhaust setup help!
- Greddy oil relocation kit 2jzgte...installed pics?
- I can't fill my gas tank on the SC300
- 92 sc300 manual ecu on 97 sc300 manual convertion.
- Anybody foolishly remove the throttle body...then the Y-pipe?
- Updated video of my ls1 swapped sc
- leaking R154
- absurdly high idle!
- Best place to buy Center driveshaft bearing ?
- Car wouldn't start ... now it does ... fuel pump issue?
- 97 Sc400 Fuel Pump 12v mod.
- OEM stero with one speaker issue
- is there a difference between 95 and 97 sc300 a/c compressor?
- Diy
- ACIS Vacuum Line
- auto ecu or 6 speed ecu
- SC300 parts numbers diagrams, crazy electrical questions
- 1UZ-FE swap complete. S366, Haltech, E85
- valvoline atf typt t-vi???
- 92 sc400 engine tune up help
- electrical thingamabopper
- Can you really boost a sc400 and not upgrade fuel?
- The Check Engine Light thought...
- How Do you feel about a Fan Clutch delete
- slow on take off
- on the line?
- New to the SC world. Bought a 400, having a few issues and need help.
- Help!!!
- Electrical help please!
- aem ems V2 for soarer, driftmotion !
- HELP:CAR MISFIRES AFTER 194 DEGs
- I need some help I searched
- Responsiveness
- High Output Alternator (200amps) for 1JZ -> Help Newb
- 2jz swap problem
- aristo trany in sc300
- 1jz a340 auto or r154 5-speed?
- 93 sc400 - runs good, rough right off idle
- 2jzgte swap exhaust question
- The Famous pouring white smoke/gas
- 1JZ auto ecu to manual ecu, auto harness
- 240sx with 2jz not starting.
- Interior fuse box location?
- adjusting distributor?help!!
- Issues with SC300
- my tach stopped work on my sc300 to day but mph works
- sc400 power loss???
- Questions for changing the spark plugs...
- why my clutch slipped so bad
- Need help with my sc400
- 94 SC400 Check Engine Light & TRAC Light Issue
- 1JZGTE VVT-i and lower HC & NOx?
- sc300 turbo back exhaust?!
- a few engine management questions
- Engine cuts out when pushed/Electrical power loss
- Trans Flush? used seach multiple answers...
- Quick...What is the tranmission solenoid operation for each gear?
- w58 clutch install diy
- Cold start idle and smoke?Valves?HG?please chime in.
- 2jzgte swap problem???????
- Code 47 and constant flashing od light!
- How do I get 1jz to run low imp top feed 440 injectors?
- Wiring issues...
- I've searched and come up with different answers!
- EGR code 71 stalling
- Heater Control Valve Repair w/MKIII Supra Valve
- sc300 help plz
- An update with good news....FINALLY!!! lol
- W58 questions!
- Down pipe suggestions
- Battery keeps dying
- alternater prob i think 1995 sc300
- turbo timer install diy (for SC300's)
- r154 swap help
- question transmission for sc400
- 1995 SC 400 Coolant Overflow Reservoir Replacement
- lost....
- 1jz guys what clutch fan and shroud are you using?
- electrical? gas?
- Engine Miss
- Wont start help needed
- overheating:(
- car alarm system
- R154 and W58 same shifter bushing & socket?
- Injector upgrade CLIP Q:
- Differential Bushings - new product
- Transmission gurus / rebuilt fluid question
- fuel injector compatability??
- Advice needed on crank shaft pulley
- Advice on High Output Alternator
- na-t steal?
- It begins...
- Broken alt. bracket
- Ran outta gas, now low idling
- Oil Pressure Light
- Supra swap questions
- sc300 clutch/brake assembly
- Anyone tried to install engine harness with motor in the bay?
- ebay universal throttle bodies (I have searched everywhere......)
- are they tunable?
- name that sensor..
- 1uz
- jdm 2jzge swap
- changing all hoses
- Torque convertor lock up?
- what happens if i disconnected iacv on 92 sc300?
- MVP AEM Email Tune????
- First Tune-up doing it myself =]
- transmission problem
- is this the harmonic balancer problem?
- Can i please get some help with timing? I cant find out how to do this.
- Pics of your oil feed/return setup thread!!
- help: serpentine belt tensioner location
- Dyno results from my 93 NA-T
- troube setting the timing????
- Differential question for anyone running 750(ish)whp through R154
- no fuel or spark
- 2jzgte bpu+
- why dose the car idol so high??
- w58
- Help!!! Soarer not starting..
- this engine cluster light
- Air intake on SC300
- timing off or bad ect??
- Need Advice SC400 stumbling
- 700hp 97 SC300 build.
- sc300 1jzgte jzx90 swap tach fix and speedo fix ?
- 1JZ / 2JZ Complete Wiring
- 1jzgte swap come here!!
- wheres the temp sender located??
- no heat
- 95 sc300 5spd swap
- i believe my high idle is because.....
- Best deal on Specialty Service Tools?
- 1997 SC300 ECU Compatible with 1993 SC300?
- Automatic Transmission
- where does everyone mount their HID ballasts?
- Ceramic Turbos + Meth / Water Injection
- Squeal On Startup - SC300 - Crank Pulley, Video Inside!
- 1jz exhaust bolt pattern
- Fuse Box Trunk Relocation
- Fuel pump ecu bad???
- New swap questions - 1jz with pictures!
- 93 sc400 eaton m90 upgrade
- 1uz ECU Rebuild
- Power Steering tilt
- 93 SC400 + Intake, exhaust, safc2, Wideband O2
- Innovate wideband error code "E8"
- mounts
- Fake hks?
- Vlad's AEM Series 2 idle tutorial
- Anyone here put one of these exhausts on their SC?
- stall converters...
- Looking to buy a 1992 sc400 but it has problems
- NATEASER project thread
- Strange oil Leak
- Engine Compatibility for 92 SC300
- Steering Wheel and under the seat shake!!
- Oil Pump Bolts 2JZGE
- Battery Relocation. Clarification Needed
- Installing TT pump; What hardware and isolator?
- Never ending 1JZGTE Issues
- Need oversized pistons
- Turbo
- 180000 miles is turbo bad idea
- Help! Smoking like crazy.
- wheel bearing replacement
