- Please help no heat
- Faulty TPS or MAF Sensor???
- I have a maintenance issue? Any help?
- whats cuasing this?
- anyone two bovs?
- Smog fail
- Help!! Dying 97 sc3
- In need of a DIY for valve cover replacement for a 1JZ
- Plugged EVAP vent line
- How should I proceed?
- Can, it be done?
- Anybody here running a chasebays gte harness?
- 1jz big twin turbo
- Please help car wont start
- Just bought a Jdm 2jzge. Few qestions.
- 95 SC300 issue
- IS300 to sc400 coilovers question
- jdm 2jz boost
- New ignition key needed?
- VSV for Evap?
- Whistle/ screeching sound from throttle body
- CEL and TRAC Light On Codes (13,17,54)
- sc300 vs sc400: in terms of engine swap
- Need Help,1JZ Engine Half Built,How to Complete her?
- 94+ supra auto trans in Sc
- Issue: Buzzing Drone Sound at Low RPM
- Engine mounts $1200?
- ? about modded knuckles and daily driving?
- R154 swap clutch help
- Middle vents wont blow
- Installed turbo intake now compressor surge?
- sc400 how do you get to the rack to install dm ps hose?
- Tt ecu help
- 1997 SC300 auto trans issues??
- 94 SC300 Speedometer Harness Burned Up
- Winter is coming...FCD or SAFC?
- Where to buy Fuel pump and sending unit
- Loud Taps At Cold Start Ups - 95 SC300
- You really need a inline fuel filter for the feed?
- Let me see your electric fan setups....
- SC400 92-97 engine swap to 98-00
- Starts with starting fluid..wont stay running
- Differences between 1jz soarer and sc400 a340E transmission
- Im thinking about straight piping my car but need opinions
- Ecu/Tuning Question!?
- Help me Fix my SC300 - black smoke
- Rear diff identification.. "F2OSZ 3-1"
- Which mkiv supra fan and shroud do I need for swap?
- How do I route these heater hoses (1jzgte) ?
- transmission code
- Please help!!!! Car starts backfires when starting to boost.
- 1jgte guys on singles what did you do for iacv?
- choices, choices, choices...which transmission should i go with?
- Does the 1st gen 1uzfe have 2 cam sensors?
- Power Steering
- NEED HELP!!!car keeps DYING!!!
- Cant seem to figure out whats wrong with the car
- dyno reading automatics
- SC400 W58 Swap Parts List (Clarification Needed)
- 1JZ SC400 Cannot Get CEL to flash (Followed wiring procedure)
- Need Help, Don't know what to do!!!
- sc300/400 pictures!! add on!!
- 97 sc300 iacv connector wires
- Question: 2jzge vvti vs. 2jzgte vvti
- Need Help - How to Put sc300 Distributor back in
- 1jzgte !!!!!!
- aem wideband install help
- 97+ sc300 auto to manual help
- Turbo Question
- turbo question!
- Transmission swap maybe
- TT usdm ecu in na-t wont start.. Need Help!!
- So the "Alternator FIRE O-Ring Leak" happen to me a few hrs ago :(
- 2jzge vs 2jzgte oil dipstick
- Putting a distributor back in
- 1uz in a sc300 5 speed?
- question about downstream O2 sensor wiring
- SC300 problem..Need help!
- Best Headers for VVT-i SC400?
- Ecu pin out on aristo blitz ecu?
- Start up/shut-off issue.
- first na-t build
- lexus sc300 r154 help
- Help ASAP cold weather poblems
- Engine Control 1UZFE
- Results of Timing Belt Service
- Used intake and wire harness...anyone?
- having a problem oil smells like gas
- Long Time Member/Rare Time Poster - Car Isn't Starting :)
- 97 sc300 1jzgte swap info requested
- sc300 running rich help
- Prognosis is... blown headgasket
- SC400 coolant reservoir replacement
- sc 300 wont start after swap
- BOV Vacuum
- Whats A good turbo For sc 300 2000
- SC300 Problems.
- SC300 Starter Contact Part #
- Fuel injector o-ring part number
- need help on some info on the swap
- Awesome! My 1JZGTE VVTI will be here next week!
- Grumbling Sound From Engine On Start Up
- Pics of Your fuel system in your sc
- AC vents
- Need help with ECU and AFM obd1--->2 conversion
- Cam Timing
- SC400 being converted to 2JZ-GE w/ Auto - Need info plz
- na-t vs jdm 2jz
- exhaust manifold and o2 sensor question
- common oil leaks?
- CA : Failed Smog
- From NON VVTI to VVTI..??
- Left outer brake light not working!
- Just installed turbo....a few concerns...
- Rough shifting...?
- Sloppy W58 shifter. What about new bushings for TRIPOD Shifter setups?
- 1998 sc300 2jzgte swap
- Shifter Question ?
- After 1JZ ECU Repair Please Help
- Won't idle, but............
- need a little electrical help on 5speed swap
- Help 97 sc300 with r154
- Rear end question on LS1 swap
- Help guys: Need info on 1JZ VVTI
- 1jz won't start after swap need help!!!
- weird engine noise sc400
- Help!! Sc400 is dieing!!!! +++ +++
- My compression test numbers, good or bad?
- Removing 1JZ Turbo Manifold
- 55K miles 97sc300. need FNG help (maint./engine light)
- Sc300 with 3.76 gearing possible?
- Ebay w58 1uz adapter kit $175 WHAT?!?!
- resurface pads?
- Moar SC400 probs
- oil level light comes 2jzgte swap
- how to remove cats on sc4
- Question about AC problem!!
- Mass Air Flow sensor cleaning gone wrong.
- MR2 Electronic Power Steering Pump?
- Megasquirt 2 in parallel with factory ECU
- Axle Upgrade Options?
- A/C plug
- Not sure where leak is coming from.
- Ge iacv
- engine tried to die out at complete stop. help
- Need help fast!! Car is having trouble building boost?
- Anyone Adjusted The Valves Before?
- Intermittent Issue/Best Order to Perform Maintenance
- 97 sc300 minor repairs exhaust,steerwheel shakes, speedometer etc..
- harness splice is this normal
- sc300 OBD1 ECU question
- FI CNC Files
- 97 sc300 iacv wire colors
- Another cleaning maf thread
- Very long story short
- 1jz swap ecu options
- Greddy 3bar map sensor without EMU?
- W58 Driveshaft Question (R154 shaft possible? )
- Winter Transformation
- Oh Crap - Won't start after oil change
- Power Steering Line Question
- Car issue 1jz?
- Different OEM Throttle Bodies
- 97 Cluster disassembly/assemby help
- another weird issue please Help my daily
- Dual intank pump setup in SC300 tank
- To ARP rod studs or not to ARP?
- sc300 engine wiring diagram
- 1994 SC300 rough idle while cold
- AEM v2...question about IAt and Map sensor...
- relocating fuse box to the trunk
- MEGAN RACING axle-back exhaust for SC400?
- Loose cruise control or what?
- another 1.5jz question
- W58 Transmission rebuild Kits from ebay.com
- Dirty intake manifold?
- 97-SC300: My V160 6spd swap thread (TONS of pics)
- Fried sc300 ECU X3, Cause?
- 2jz-ge na-t 101
- Heater Problems AGAIN!!!
- SC400 Headers Group Buy - Last Day
- sc300 fuel injector replacement
- New Ecu But totally Different Problems than old one.
- CATS delete
- nitrous fuel tap question.
- Exhaust Sound
- which fuel management karman MAF na-t
- New exhaust setup question
- Another SC400 with A340e shift issues
- SC400 EGR Delete from Lextreme???
- Best HP add for 1998 SC400
- denso 1020 fuel pump ?????????????
- Need help - Engine change
- DIY with Pics: Cleaning the IACV-SC400
- Oil light.
- TT ecu on Na-t wont start!
- 1jz auto swap questions
- 1jz-gte vvti from MAF to MAP (mass air flow to manifold pressure) ??? conversion?
- coolant over flow bottle types and location recommendations for FMIC
- Mass airflow delete? Possible?
- Hard Start, Speedometer & Tachometer Doesn't work
- Sc400 auto swap
- intercooler pipeing.... need opinions
- sc300 exhaust question
- Gas Gauge
- Nitrous and Fuel Line
- SC430 3.26 Diff??
- Anyplace sell 1jz gasket sets anymore?
- sc400 95year diagnostic
- Alternator question
- 2jz-ge q45 toyota tps adapter?
- Rear Bulb Out Indicator ON...
- HELP, I have high NOX and cant pass CA smog
- Sound Proofing?
- Bad Cats overheat 96 sc400 (168000 mi)?
- buckwheats sc 300
- 93 SC 400 running bad
- Hose off heater control valve
- 99 sc won't start.
- Engine Bay Harness
- Wastegate options on 2jzge turbo manifold?!
- JDM ECU Piggyback Setups - post them up
- car suddenly running bad
- has anyone used seafoam to lower NOX levels
- Powder coated the rear diff today!
- SC 400 '95 Transmission Front flange
- 92 sc300 hard start help
- Clutch, ebay vs. jcwhitney any good?? help
- O2 sensor question
- SC400 probs
- 1JZGTE IACV Bypass?
- A/c delete serpentine belt part number?
- Unusually High Idle After Driving
- Precision 6365H or Precision 7068
- Automatic Transmission Fluid
- 1993 Sc300 Build
- '00' SC400 code P0121 $1750 for repair?
- OBX Headers for SC400. Who's going to be the Guinea Pig?
- maintance: breaks and rotors... gas tank pressure?
- Can I use evo 8 560cc injectors?
- ENGINE BLOCK Bolt Ears (holes) for Trans broken off
- help me identify injectors
- PCV Valve Replacement
- Fuel pump problem
- 1995 sc400 crossed battery terminals no power
- O/D Flashing DTC89: Need help removing code
- help! rpm goes really high when i start my SC400
- 1jz aeromotive fpr install help!!!
- Na-T Crank Seal Issues
