PDA
View Full Version : Performance & Maintenance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86
  1. Are these the supra tt motor mounts needed for sc300 stock replacements?00
  2. Need help auto to w58 not starting
  3. Intercooler and blowoff valve!!!
  4. transmission mount replacement
  5. Sc400 1jz swap help
  6. Soarer clutch master/slave cylinder same as?
  7. Who has a Spec Stage 5 clutch?
  8. catalytic converter issue
  9. Do you have a noisy fuel pump??
  10. Pricing for V160 6-Speed V160 Getrag Transmission? Rebuilt or New?
  11. I came across this turbo
  12. legit lsd??
  13. starting problems. will crank but no start
  14. Where to buy oem spark plug tube seals
  15. **Coolant Issue** Need help diagnosing an issue
  16. GS400 Mid pipe on SC?
  17. Bought a Turbo 5 speed SC400, and its already under the knife...
  18. SC400 heater: out of commision! Assist.
  19. Getting tired of this
  20. Blown headgasket or something else..?!!?
  21. Window motor repair
  22. aftermarket foglight issue smoking issue
  23. Foaming water!!!
  24. sc300 keeps turning over not starting
  25. 1jzgte in the works maybe??
  26. 1jzgte backfiring, wont start
  27. Anyone replace valve steam seals with oem?
  28. Man! Now Check Engine and Track Off!!!
  29. replaced iacv and now the car won't turn over
  30. turbo quesiton
  31. 92 SC400 Wont pass Emissions - Possible ECM Failure???
  32. Rebuilding Engine. Part/Brands?
  33. Engine dies at 3000 rpm and then kicks back in after head gasket repair
  34. sc400 with 1jzgte kickdown cable not connected
  35. Seafoam smoking under the hood?
  36. na/t fuel management
  37. Battery keep draining
  38. Please help, rack & pinion, PS pump
  39. What intake are you using 4 stock twins?
  40. Can this issue be cause of a weak motor mount?
  41. Stage 3 Clutch recommendations?!
  42. will GS300 diff in sc400
  43. Please confirm my basic aristo swap checklist
  44. What are your ideas on this? 400 issue
  45. Big single SC400 GTE in progress
  46. questions about my sc400-T build
  47. Tundra TRD Supercharger In An SC400
  48. Which fan and shroud for 1jz?
  49. ls1 engine to sc400 swap?
  50. Dildomatic Shifter, But with Crown Royal Boot
  51. Engine issues after accident
  52. HELP...Car making funny noise / shaking and won't shut off, finally did!!!
  53. Problem solved! sourse of power loss, new crank seals and ps hose,espiler springs
  54. Weird noise coming from Timing belt area/Power Steering pump area (video)
  55. Parasitic Drain Help Please
  56. Calling all JZ Pros!!
  57. Motor swap "Sorda"
  58. my 95 sc400 just died pulling up to the light wtf?
  59. TRAC Light and clicking sound!!!!
  60. Starting Help Needed
  61. Magnaflow Cats and new exhaust?
  62. Everything in my SC4 has power but no start
  63. Help...
  64. W58 rebuild
  65. JZA70 1JZ swap into a SC300
  66. Quick Spool Valve on my 1JZ, initial impression...
  67. I blocked the EGR with a soda can!
  68. Deleteing the AC System
  69. boosting a 2jzge motor with 185k on it
  70. Just a little more help on my 1jz auto.... Please!
  71. new member question about intake and head
  72. Rear main seal
  73. Boost cut
  74. What am I missing HELP!
  75. Mods for 1JZ that can be used on 2JZ
  76. W58 shifter bushings 92-94 sc300
  77. a340e questions (tundra)
  78. (sc400 - 92) Misfire issue @ idle & 40mph cruising.
  79. Does the sc300 have the same transmission as the sc400?
  80. another "car wont start" thread.
  81. koyo radiator question
  82. 1JZ starting issue after finishing swap
  83. Attn. Guys with LS Swap: Need a favor
  84. Head gasket failure poll
  85. Blue Smoke On Cold Start
  86. SC400 misfire on one cylinder.
  87. DIY: Ford 8.8" Differential Swap
  88. Help with 1jz sc swap please!
  89. How many miles on your 2JZ-GE
  90. Help SC400 Problems
  91. curiosity...
  92. Gates serpentine on SC3?
  93. Need help: What size belt to use to eliminate AC pump?
  94. Picture request 1996+ SC300 EGR area hoses
  95. SEMICIRCULAR plug
  96. need some ideas
  97. WTB: catalytic converter for 1996 SC400
  98. Timing Belt is RUBBING
  99. 5spd help plz
  100. sc 300 rpm problem?
  101. 1JZ/2JZ Oil Catch Can Questions
  102. Radio Issues and More...Tech gurus needed
  103. thermo fan issue
  104. Help with DIY! Returnless fuel system
  105. A swarm of potential technical questions
  106. ideas on traction for crank pulley?
  107. thinking 1jzgte swap
  108. 1jzgte+2jzge= two 1.5j's!
  109. MKIV TT Auto+LSD, or MKIII R154 w or w/o ABS???
  110. Car will not crank... please help
  111. I need Help on parts for my 1JZ VVTI
  112. another tt ecu on na :)
  113. Engine problems again, need advice please!!!!!
  114. Aristo swap problem revving up
  115. Cylinders full of fuel...HELP!!!
  116. Need Sc300 wiper motor diagram
  117. HOT center console/cup holder ... is this normal?
  118. Injectors Stuck Open?
  119. 1JZ owners: Have some questions
  120. HELP! white smoke
  121. can u remove a motor by dropping the subframe?
  122. Fuel issue
  123. Started head gasket job..
  124. 1JZ squeaked and died and now wont start!! Video inside!!
  125. Anyone converted to TT ecu before going turbo?
  126. Fuel System Picture Thread
  127. Cheapest NA-T Setup for ~400HP Daily Driver
  128. Pulling out the wiring harness through the firewall
  129. Calling all 1uzfe enthusiasts
  130. what clutch w58 na-t
  131. valve cover gaskets fail
  132. valve cover gaskets fail
  133. Subframe swap???
  134. Aftermarket header CEL problem 2jz-ge
  135. Transmission question
  136. Ikeya formula front upper control arms
  137. Dead Sc300...stuck at work
  138. vvt-i or no?
  139. SC400 Transmission Question
  140. is this causing my car to overheat?
  141. can you use an sc400 fuel pump ecu on a sc300?
  142. 1JZGTE IACV assembly
  143. 1jz MAP Sensor Pic PLEASE?
  144. help with fuel pump mod
  145. Just ordered some cams :D
  146. help! what fuel pump or set up should i get for the amount of hp i want my sc to run?
  147. SC400 1UZFE VVTi differences
  148. For the guys looking to put a 2J cam into a 1J
  149. Sc300 NA-T build
  150. Ebay Intake Manifold
  151. 1JZ and 2JZ turbo owners: open wastegate downpipe or NOT?
  152. clutch fan or electric fan???
  153. Airbag removal...
  154. 1jzgte uses a stock sc300 driveshaft correct?
  155. A Question About Vibration...
  156. Mass Air Flow Sensor Code
  157. Trans Code 42- Speed Sensor #1
  158. 1jzgte problems need help!
  159. 1JZGTE delete IACV
  160. weird idle fix...but why???
  161. 2jz GTE VVTi stock twin numbers
  162. sc300 swap 2jzgte
  163. Help! Gas/Fuel in Throttle Body
  164. Has anyone retrofit an ISC to an aftermarket intake manifold?
  165. TRAC code 26-- Anyone else had it?
  166. Auto trans slipping/shuddering?
  167. 1JZGTE swap into SC400
  168. Battery Keeps Dying
  169. SC400 - For those who have replaced your o2 sensors....come on in!
  170. HELP!! New engine swap ideas!
  171. Kickdown
  172. Wont Start...after replacing components that have nothing to do with it.
  173. Neutral Safety bypass problem
  174. sc300 na-t VPC question
  175. HID Garbage
  176. Please Help Engine sounding very choppy and heavy smoke
  177. 1998-2000 SC400 LSDs?
  178. sc300 na-t tt hg arp torque specs
  179. Diagram needed
  180. Best investments for NA-T 2JZ?
  181. First sc300!!! overheating
  182. Weird Oil Leak...Help me diagnose please
  183. Idle Issue
  184. Top hose prob
  185. Costs of a swap?
  186. Serp belts differences?
  187. Warning: May be a stupid question. Mkiv exhaust on sc300
  188. Car Won't start or idle unless Brake Applied
  189. Name That FPR!
  190. Noise that sounds like knock, but speed dependent not RPM dependent
  191. what do you think about that ?
  192. Torque Specs for valve cover bolts, 2JZ-GE?
  193. Strong smell of fuel
  194. rpm question
  195. Which ARP studs/bolts?
  196. 1jz or na-t 2j build
  197. 1JZ problems surprise surprise
  198. My 95 SC300 NA-T Build (Holset HX40)
  199. Turbo 4.8 LSx SC300 - 509wrhp @ 12psi
  200. Brittle Fuel Injector Connectors
  201. What's the skinny on NA-T with totally stock fuel/control?
  202. Heat Shield Rattle
  203. Any top mount turbo manifolds not made in China for this car?
  204. heater work without an a/c condenser?
  205. ppe engineering headers???
  206. Side by side pics of LS400 and TT calipers?
  207. Reliability and costs for 2JZGTE
  208. Built Auto Trans
  209. 92 SC 400 sputters
  210. New to the site
  211. about to buy my first sc300. just a few questions
  212. SC 400 Valve cover gasket?
  213. Codes 24 and 55... Stuck at work right now..
  214. PS, Speedo, Radio all went out. ABS light on. What just happened?
  215. Huge power loss Please help. PLEASE...
  216. guess who's car is still down...dies when in gear
  217. Vibration after 5spd swap
  218. Vacuum Hose sizes
  219. wierd vibration when driving. tranny or something else??
  220. AEM Map Sensor
  221. 98-2000 SC400 1UZ NA potential powers?
  222. Tuning and Injector Help 1JZ
  223. Where should I begin diagnosing loss of power?
  224. 1JZ wiring diagrams, schematics and info thread
  225. Trac and ABS relay delete
  226. 1992-1997 SC400 Primary Catalytic Converters
  227. 1jz VVTI swap info, a few questions.
  228. sc300 triple pump in-tank installation
  229. sc400 turning off when braking hard help.
  230. SC300 overheating again!
  231. 95 Sc400 tranny problems help please!!
  232. Hesitating sc400
  233. To helicoil or not to helicoil, that is the question.
  234. to Silicone valve cover gaskets, or not to silicone valve cover gaskets?
  235. sc300 exhaust
  236. Dashboard Problems
  237. Input needed; pics inside of my distributor cap
  238. Anybody with a 4.7 swap?
  239. 1JZ patch harness to 2JZ Aristo problem-CEL
  240. 5 Speed SC300 Won't Crank...Doesn't seem like clutch switch...HELP!
  241. my car finally starts and stays running...with a new problem
  242. T-IV or Dexron III for SC300
  243. Remove Cat or Resonator?
  244. **SC400 Crackling Under Acceleration & Stalling Issues**
  245. Bee-r Rev Limiter wiring help! (2jz-gte)
  246. Auto transmission?
  247. Cost to swap to a 2jz?
  248. IS300 LSD in a SC300?
  249. car shuts off by itself?
  250. Help with Clutch Fan install
