PDA
View Full Version : Performance & Maintenance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86
  1. Even MORE transmission issue
  2. Unichip GS400
  3. Help 3 battery cables????
  4. Engine bay line sizes? Ps, ac, brakes..
  5. 1992 Lexus Sc400 Mechanical issues *Help*
  6. DIY Replace Fuel Filter and New Flange Nuts
  7. Looking for 98_00 sc400 drive line
  8. What fuel management??
  9. question about sc 400s
  10. Cheap fuel pump?
  11. 94 SC400 has no electrical power
  12. alternator help
  13. Boost gauge fluctuating on vacuum side
  14. Gearbox issue
  15. is this okay? AND what do else should i do while adjusting valve clearance?
  16. 98 sc400 headers are they worth it and which mods are ?
  17. Hypereutectic pistons?
  18. intermittently dies, aem?
  19. 99sc300 intake manifold vacuum??
  20. Gas Leak
  21. No clue - Help with diagnosis?
  22. power steering hose question (not high pressure)
  23. good deal on a 1jzgte and extras?
  24. yellow oil light help
  25. '93 SC Climate Control LED
  26. Thoughts on E-cut?
  27. Lca
  28. 2jzge 5spd ecu run a gs300 harness??
  29. hydraulic cooling fan pump vibrating
  30. Gaskets and RTV and FIPG
  31. Getting ready for the swap
  32. Cali Spec SC 300/400
  33. Clutch recommendations
  34. got 27mpg straight highway driving
  35. Question on CEL code P1700
  36. Help oil pan plug?
  37. Speedometer not working properly - all other gauges working
  38. Need assistance - MPG dropping quickly, need mechanical expertise
  39. downpipe question
  40. Homemade SC300 exhaust VIDEO/SOUND clip inside
  41. cracked radiator
  42. 92 sc300 1jzgte Swap Is Not Accelerating As Fast As it Should
  43. IACV problem?? (pics)
  44. How hard is an Injector Job?
  45. fail smog again? -_________-
  46. OEM radiator replacements?
  47. SC400: intermittent fuel smell in cabin
  48. sc3 na-t *help* before tune on Sat
  49. intake mainfolds????
  50. 1.5jz help max boost?
  51. I'm confused...modding 1jz couple ?'s
  52. 97 sc300 cranks but won't start
  53. Ignition issue??
  54. Fail SMOG!?? WTH...
  55. driveshaft guru's inside!!
  56. 1jz idle speed screw - pic help
  57. 6 Cylinder CNG Natural Gas Conversion Kit?
  58. 2jzge obd1 auto ecu work with w58??
  59. floor jack and jack stand
  60. eBay Turbo kit
  61. Messed up with trans fluid. Full flush?
  62. How do I clean valves? Doing valve stem seals
  63. Of course, trans pan gasket leak..:(
  64. help!!! snap on/snap off!!!!
  65. Where do I begin?
  66. OK, how do I put the valve body back in to the tranny properly?
  67. 2JZGE non vvti Cam question (distributorless)
  68. 1JZ wiring guru's, AEM V2...
  69. BIZARRE tranny issue, please help!
  70. GS400 manifolds
  71. 1997 sc400 cel code p0340?? Cam sensor
  72. SC300 Power Steering Hoses (not the high pressure one)
  73. Injector Dynamics
  74. 1997 Sc400 Differential fluid?
  75. Oh god did I just blow my engine?
  76. Sc400 Auto trans filter? Autozone vs dealer?
  77. Main relay (efi relay) getting hot - car wont run properly
  78. Getting My 1UZ Into The 300+hp Club
  79. 1jzgte single turbo o2 sensor help
  80. Transmission jerking on sc400
  81. would this work?
  82. Fuel system part identification help
  83. 5 or 6 speed automatic from newer SC400/430's?
  84. W58 or R154 transmission?
  85. ngk in my sc400
  86. Thinking of getting a Torsen LSD 3.69 ratio from a Supra for the Soarer
  87. Torn between setups
  88. Fuel return issues
  89. radiator light
  90. overheating problem
  91. 1jzgte SC400 which motor mounts?
  92. 5 speed help!!
  93. my 92 sc400 engine fluid fan keeps running out, input needed
  94. I need advice please!!
  95. 2jz-ge Help!!
  96. Mass airflow sensor mods?? 1jzgte vvti
  97. How Much Power
  98. 2jzge vvt-I na-t tuning
  99. Looking for tips on LSD swap
  100. I did the impossible...now need advice
  101. Can anyone confirm 2jzgte intake valve seals work on 1j intake side?
  102. Thoughts on this gasket kit?
  103. HELP! 92 Lexus SC400 won't start.
  104. 98 sc300 2jzgte swap(aristo) NEED HELP
  105. 1jz gte Black smoke?!
  106. does taking cats off give you less power??
  107. high performance crate motor
  108. 2000 sc400 radiator in 92sc400???
  109. Transmission options
  110. SC3xx starts then dies, please help!
  111. The Ultimate Daily Driver, Build Thread.
  112. Wobbly Harmonic Balancer
  113. 98 SC300 vvt-i to 1jzgte question
  114. battery drain
  115. does the apexi safc 2 make i big difference after dynoed?
  116. Watermeth + stock compression? see what happens inside
  117. Fuel pump noise FTL! Any ideas to shut it up?
  118. Basic Engine Upgrades
  119. Special tools needed to rebuild a W58?
  120. So finally got my car on a lift...
  121. NA-T s366 or 6265 ??
  122. A/C Issues - Expansion Valve Replacement
  123. Engine swap question
  124. EGR removal problem
  125. TRD Japan 5sp Quick Shifter
  126. [Q]TRD Shifter Spacer Needed?
  127. valve specs on na mk4 same as 97 sc300? or any one have that section?
  128. I really need some help with this guys.
  129. Cooling Fan Relay
  130. vinyl sc300 question
  131. Motor mount trouble
  132. Should i keep single or dual exhaust on my sc300
  133. 93 sc400 running rough on idle
  134. Sc400 manual VS. 2002 M3 ??
  135. SC3 custom exhaust setup help!
  136. Greddy oil relocation kit 2jzgte...installed pics?
  137. I can't fill my gas tank on the SC300
  138. 92 sc300 manual ecu on 97 sc300 manual convertion.
  139. Anybody foolishly remove the throttle body...then the Y-pipe?
  140. Updated video of my ls1 swapped sc
  141. leaking R154
  142. absurdly high idle!
  143. Best place to buy Center driveshaft bearing ?
  144. Car wouldn't start ... now it does ... fuel pump issue?
  145. 97 Sc400 Fuel Pump 12v mod.
  146. OEM stero with one speaker issue
  147. is there a difference between 95 and 97 sc300 a/c compressor?
  148. Diy
  149. ACIS Vacuum Line
  150. auto ecu or 6 speed ecu
  151. SC300 parts numbers diagrams, crazy electrical questions
  152. 1UZ-FE swap complete. S366, Haltech, E85
  153. valvoline atf typt t-vi???
  154. 92 sc400 engine tune up help
  155. electrical thingamabopper
  156. Can you really boost a sc400 and not upgrade fuel?
  157. The Check Engine Light thought...
  158. How Do you feel about a Fan Clutch delete
  159. slow on take off
  160. on the line?
  161. New to the SC world. Bought a 400, having a few issues and need help.
  162. Help!!!
  163. Electrical help please!
  164. aem ems V2 for soarer, driftmotion !
  165. HELP:CAR MISFIRES AFTER 194 DEGs
  166. I need some help I searched
  167. Responsiveness
  168. High Output Alternator (200amps) for 1JZ -> Help Newb
  169. 2jz swap problem
  170. aristo trany in sc300
  171. 1jz a340 auto or r154 5-speed?
  172. 93 sc400 - runs good, rough right off idle
  173. 2jzgte swap exhaust question
  174. The Famous pouring white smoke/gas
  175. 1JZ auto ecu to manual ecu, auto harness
  176. 240sx with 2jz not starting.
  177. Interior fuse box location?
  178. adjusting distributor?help!!
  179. Issues with SC300
  180. my tach stopped work on my sc300 to day but mph works
  181. sc400 power loss???
  182. Questions for changing the spark plugs...
  183. why my clutch slipped so bad
  184. Need help with my sc400
  185. 94 SC400 Check Engine Light & TRAC Light Issue
  186. 1JZGTE VVT-i and lower HC & NOx?
  187. sc300 turbo back exhaust?!
  188. a few engine management questions
  189. Engine cuts out when pushed/Electrical power loss
  190. Trans Flush? used seach multiple answers...
  191. Quick...What is the tranmission solenoid operation for each gear?
  192. w58 clutch install diy
  193. Cold start idle and smoke?Valves?HG?please chime in.
  194. 2jzgte swap problem???????
  195. Code 47 and constant flashing od light!
  196. How do I get 1jz to run low imp top feed 440 injectors?
  197. Wiring issues...
  198. I've searched and come up with different answers!
  199. EGR code 71 stalling
  200. Heater Control Valve Repair w/MKIII Supra Valve
  201. sc300 help plz
  202. An update with good news....FINALLY!!! lol
  203. Heater Control Valve
  204. W58 questions!
  205. Down pipe suggestions
  206. Battery keeps dying
  207. alternater prob i think 1995 sc300
  208. turbo timer install diy
  209. r154 swap help
  210. question transmission for sc400
  211. 1995 SC 400 Coolant Overflow Reservoir Replacement
  212. lost....
  213. 1jz guys what clutch fan and shroud are you using?
  214. electrical? gas?
  215. Engine Miss
  216. Wont start help needed
  217. overheating:(
  218. car alarm system
  219. R154 and W58 same shifter bushing & socket?
  220. Injector upgrade CLIP Q:
  221. Differential Bushings - new product
  222. Transmission gurus / rebuilt fluid question
  223. fuel injector compatability??
  224. Advice needed on crank shaft pulley
  225. Advice on High Output Alternator
  226. na-t steal?
  227. It begins...
  228. Broken alt. bracket
  229. Ran outta gas, now low idling
  230. Oil Pressure Light
  231. Supra swap questions
  232. sc300 clutch/brake assembly
  233. Anyone tried to install engine harness with motor in the bay?
  234. ebay universal throttle bodies (I have searched everywhere......)
  235. are they tunable?
  236. name that sensor..
  237. 1uz
  238. jdm 2jzge swap
  239. changing all hoses
  240. Torque convertor lock up?
  241. what happens if i disconnected iacv on 92 sc300?
  242. MVP AEM Email Tune????
  243. First Tune-up doing it myself =]
  244. transmission problem
  245. is this the harmonic balancer problem?
  246. Can i please get some help with timing? I cant find out how to do this.
  247. Pics of your oil feed/return setup thread!!
  248. help: serpentine belt tensioner location
  249. Dyno results from my 93 NA-T
  250. troube setting the timing????
