- 300zx trans apadter
- Proefi Install on SC300/GTE
- 1997 sc300 AutoTT Swap USDM 2j TEMP GAUGE HELP!!
- o2 sensor plug help?
- 93sc400 Code 25
- Help! Seperate Problems or are they connected some how?
- Alarm, No start
- Will it run with this disconnected
- Few engine swap question need answer fast
- 2JZGTE VVTI questions
- BC Small Core 272 JZ Cams. Need Help.
- CEL code 71 help
- Boostlogic manifold
- Sc400 Limp plenty of spark
- Building a 1jz, need all the help i can get
- Please Help me with Wiring on my 1jz Soarer Harness!!
- Gasoline leakage Don't know what to do.
- 1992 sc400 curb hit axel broken
- Small Leak
- Just need some real answers.
- coolant tank
- Could be power steering pump or pulley bearing?
- sc400 light weight exhaust question
- SC400 turbo
- 2JZ-GTE Intake Manifold Q (VVti vs Non-VVTi)
- problems with 1jz....help
- Ever wanted to build your own harness?
- SC300 Power Steering Pump Screen
- Lexus Sc300 Power Steering & Heater Failure! Please Help..
- Help with 1JZ Sc300 fuse box connectors
- Need speedo and tach help
- 1jzgte rebuild question.
- No Spark at Ignition Coil
- coil options
- 1UZ problems.
- My SC400 -HEATER AND AC QUIT
- Could it be my Southbend clutch setup?
- Standalone with auto transmission
- 1uz expansion tank
- 2j-ge rebuild suggestions
- 1UZ to VVTI?
- Is the Sc4 cluster harness or body plugs identical to the Sc3/Soarer?
- Changed Fuel Pump Car started but now Dead again
- sc400 95 diagnosis port
- 1UZ header bolts.
- Help with some dash wiring please?
- 1992-1997 sc400 Basic performance parts list
- 1jzgte issues
- NA-T gurus in here please
- tensioner mark
- Need some helps, thought it was EGR
- JZS161 Aristo Vacuum Diagram
- merry xmas !!!!new member gt500tony
- Building a fuel system for 800-900hp
- sc400 replaced engine, ecu, cranks but wont start
- Charcoal canister mounted in the trunk?!?
- Issue Starting Car
- Pcv valve hose
- Quick Question about the Parking Brake
- speaker issue help
- Belt tensioner help
- ac compressor bypass
- Bolts for automatic 1jz gte Flexplate?
- SC400 rear twitch?
- Oil leak help
- 95 sc300 ABS unit pinout
- A Very Odd Alternator Problem
- Low RPM issue ?
- how many quarts of oil for automatic 1jz transmission?
- 2jzge Na-t No Start Problem
- Sc400 hesitates
- 2-wire and 3-speed sensor/sender
- seized 2jzge... What to do?
- 96 Lexus sc300 fog light issue
- Been researching swap wiring, thought you all might find this useful.
- sc exhaust question???
- sequence for 1jz coil packs?
- Sc300 stumbling issues
- stripped some bolts on my 1jz, what can i use?
- Auto Trans Shift Kit...
- r154 swap rhd pedals in lhd sc
- W58; can hear the synchros, huh?
- Rear coolant leak. Heater valve?
- Rear Differential mounting bolts
- SC300 will not start, no CEL!
- Wiring cam & crank sensor
- Thinking of twin turbo!
- some 1jz swap questions...
- car window wont close!
- Greddy MX Axle Back not fitting on sc400
- Maybe have a failed water pump
- 92 sc400 engine replacement questions & advice, not found through searching!
- help! shifter button broke
- Gas Cap Question...
- Help!!! 1jz backfire issues!
- R154 Rebuild (Opinions Valued)
- Will a mk4 Midpipe bolt into stock sc300 exhaust system?
- Which trans to choose?
- gas smell in oil cap? 1jz
- does a soarer 1jz downpipe match with a stock sc300 midpipe?
- sc400 sputters, please help
- VVTI turbo swap...dumb wiring question, I'm gonna ask it anyway
- max to mill vvti head
- sc400 power steering resivor in sc with 1jz?
- 97 manual ecu problem
- Is a 2JZ VVTI considerably stronger than a 1JZ VVTI on the butt dyno?
- Why does factory ECU lean in high gears/speeds?
- W58 acting odd
- Reading knock PCM?
- PCV Valve between valve cover and intake manifold
- Power steering valve(?) questions
- Crank, no start, code 12
- Good God... I need emissions help please!!!
- Rough idle - code 27
- Starter click
- 98 SC300-Dayco Part 89055 Belt Tensioner
- wanting alittle more pep
- aftermarket fuel set up 700+whp
- new own. Help?
- SC400 Rear Differential Issue?
- Soarer harness 1jz auto chaser sc300
- Another MAF issue, I've searched, I'm stumped
- auto/manual drive shaft difference?
- a340e aem ems problems
- air intake size
- How did you select your turbo
- Budget Trans Upgrades
- sc400 - ignition coil problems + Coolant Leak
- Sc400 starter disengage whirring, grinding noise
- Overheating - after replaced 2jzge waterpump - bad clutch fan?
- Sc400 engine bay fuel line thread pitch
- Harbor Freight tools
- Got my engine, oil in turbo, what do?
- Reusing zero mile valve cover gaskets
- water pump question
- Won't start, died randomly
- Hard cold start + Code 25
- Timing cover gasket
- Having issues please help
- Can I use a W58 Aristo Trans in my sc4?
- 92' SC400 Misfiring
- too much air equils failed emission
- PS Resevoir Bubbling and Rack & Pinion leaking
- Sc300 Won't start
- OEM brand Knock Sensors??
- New Timing belt, water pump, radiator. OVERHEATING?
- 2JZGTE VVTI down pipe?
- To fix or sell, that is the question?
- Weird acceleration issue
- Put 93 SC4 in the shop for oil leak
- ECU compatibility
- Dead 93 Lexus SC400
- SC300 Oil Leak
- tt ecu mod with stock coil interest?
- 1JZ Single Conversion Coolant & Vacuum Questions (With Pics)
- guess what guys. CT20As on 2jz
- Lexus SC400 won't shift out of first gear?
- Small Leak
- Anyway to disable key in ignition sound?
- Question to the 2JZGTE swapped SC400 guys and gurus
- Regarding getting a "factory" intake air box for a 2JZ-GTE swap
- Will a Supra intake fit a GTE swapped SC?
- oil level sensor??
- Having trouble swapping exterior door handle
- 1994 SC400 won't start
- Fuel Injector wiring; Need immediate answer
- fuel tank, pump, lines
- 12-disc cd changer
- pcv valve
- Car dies when I use the turn signal. Help
- 1JZ/2JZ crank pulley
- Where Can I get A Power Steering Pump From 98 Sc400
- Very low compression?
- Clutch Install Help
- diameter of 1jz stock twins turbo inlet pipe? for intercooler
- Need help installing Manual Boost Controller
- Car no power!!!! Helpp!!!!!!!!!!!
- AEM V1 Base Map for NA-T
- SC400 manual transmission swap
- 2jz Soarer - New Timing belt kit and VVTI
- sc300 white smoke
- Just Finished My Exhaust!
- Help !!! sputtering, no power, red cats,shaking.!!
- sc300 ac compressor compatibility?
- 1jz LC1 narrowband signal to ecu
- Knock Sensor - HELP PLZ
- Turbo math
- 92 sc300 with 2jzgte swap.. Gauge cluster prob
- I'm looking for Dimensions to 7MGTE or 2JZGTE IACV Flange for FFIM
- ObdII 2jzge turbo insights/questions
- intermittent sluggish shifting
- evap purge valve
- 5spd swap...low idle and stalling when driving
- What am I missing/forgetting for BPU Aristo swap SC300?
- NIGHTMARE problem with Car Running Terrible (Stutters, Bucks, Dies out, etc)
- Car won't stay running
- FFIM IAVC options?
- Adjusted timing now car feels slower?
- exhaust piping size
- turbo direction
- 1jz single on stock fuel? Target boost?
- How much was your build?
- Power steering leak!! Please help!!
- Buzzing Noise Air Conditioning
- Extending 1JZ Soarer Harness for Sc300 *If you have done it come here*
- Injector wiring
- Fan Clutch
- alternator
- weird check engine light and trac light problem.
- 2JZ Dying
- ARP flywheel bolts torque specs question
- The timing belt saga continues
- Coolant Leak on top of engine
- Auto to manual swap...
- Sc300 Overheating prob need help!
- SC300 heating problem ?
- PSA: Putting AN hoses together
- Fuel Pressure Check
- SS Tool for Valve Clearance Adjustment
- exhaust and cam video search
- Can you use an OBD2 maf sensor on an OBD1 car?
- 1UZ-fe wont pass 4k rpm
- Constant Misfire troubleshooting
- SC300 swap question
- Power steering pump question
- Map-ECU
- 92 sc300 starts but shuts off when cold
- Ar and twin scroll? 1jz 83-75 help!
- Boost Creep problem
- 1jz manifold for rhd?
- egr delete can't get the resistor right cel is still on
- Do not buy Bosh wires (sc400)
- HKS SLD Type-2
- Second power sterring hose failure
- Door Bind
- Alternator plug/wiring help
- fuel tank, pump, system pics?
- Trouble finding a braided fuel line for my 1JZ into my SC300
- driftmotion ps hose help
- Water Bridge Gasket
- Overheating problems
- Failry New to the 1UZ, Had a 2JZ
- 4runner Distributor cap issue
- ECU questions
- 5.3L V8 swap question
- 92-95 ecu pinout needed!
- NaT questions
- Exhaust theory 101
- Limited Heat
- FML SC300 has gremlins.... rough start, won't shift, NEED HELP!
