PDA
View Full Version : Performance & Maintenance
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87
  1. big turbo sc300 start up/tuning issues(was running until firmware flash) (im doing so
  2. Check your Walbro 450s for leaks
  3. Has anyone try to modify the 2JZGE fan for a GTE swap?
  4. Need part number help
  5. what wheels are these
  6. Can't Pass Emissions in IN - NOx
  7. '97 SC300 - Idle Surges After Warm Up
  8. Need Part number for lower door trim
  9. [Guide] Sc300 Auto to Manual conversion
  10. How capable is a GTE ecu w/ piggyback?
  11. 1UZFE Swap throwing a couple codes... need help
  12. 1UZ-vvti ECU swap questions
  13. RTH: Need bolt size/thread pitch for JZ Power Steering Pumps
  14. 92 SC400 hesitating when stopped, gas smell
  15. Can't do burnout
  16. sc400 code 13
  17. Question about keys for sc400
  18. What Rear Diff Should I Go With?
  19. 2JZ-GE Y-Plenum EGR passage cleaning
  20. How much $$$ to fix a leaky valve cover gasket on a 2JZ-GE???
  21. Anyone recognize this part?
  22. Cam sensor replaced, code 13 removed, still problem
  23. MOPAR Trans. Swap
  24. Sc300 treadstone nat manifold fitment?
  25. Dome light gremlin?
  26. My favorite game
  27. changing instrument cluster-no start
  28. Code 42 and 47
  29. Clicking/ Snap Noise under Shifter
  30. any guesses how old this timing belt is?
  31. sc400 Instrument cluster installation
  32. SC300 power window switch?
  33. Need help with reshimming valve bucket procedure
  34. SC Front Lighting - "A Correct Way to Do Them"!
  35. upper power steering hose part #?
  36. Injector Latency Question
  37. Toyota TRD Oil Filter 90915-YZZG2 (for all JZ engines)
  38. Need help on sc300
  39. 5Zigen Fireball Mega axleback exhaust (CA smog check)
  40. electrical troubleshooting
  41. "Intermittent electrical issue causing misfire"
  42. Picture request: 96+ CA or 97 5-Speed throttle body
  43. Sc300 starter replacement
  44. i think i destroyed my motor please help
  45. Remote Start Not Working SC400, Owners Manual for Omega Security System Needed
  46. Sc300 clutch pedal strut blown?
  47. Approaching 200k Miles, Rebuild or Engine Replacement?
  48. Mysterious sound coming from engine.
  49. SC300 with 1JZ swap - Extending ECU Wires
  50. SC300 with 1JZ swap - Tach Fix
  51. Went through big puddle ROUGH idle HELP
  52. Input needed: Bmw zf trans
  53. Catless midpipe CEL Question
  54. Smog craziness with test results - please help - time is limited
  55. 98 SC400 Window Regulator-where do I get one??
  56. Check Engine Light On When Brakes Applied
  57. What I need for installing this engine in my 93 sc300
  58. Alternator plug will not come out!
  59. ECU Rebuild Vendor Recommendation
  60. Tuning AEM EMS V2
  61. Cylinder head different - oil tubes?
  62. Replaced my cluster, now speedo doesn't work? (sc400 manual swap)
  63. Going to be installing a transmission
  64. Transmission options
  65. 1998 SC400 1UZFE VVTI Questions
  66. Rotton Eggs & Exhaust Options
  67. Gasoline odor in exhaust/oil... direction?
  68. WTF is going on here???!!!
  69. How to make SC300 louder?
  70. 1JZ Oil Relocation + Cooler Kits
  71. 98+ SC400 throttle response question
  72. 1JZGTE SC300 swap - intake side hose locations
  73. Spark spark spark
  74. Methanol with MAP ECU
  75. 1UzFe Non vvti Engine
  76. CV axles left and right
  77. Hesitation/Surging upon acceleration from stop.
  78. Accelerator Pedal Position Sensor
  79. Help!! High pitch noise from glovebox area!
  80. Bought my 1st Lexus.. Drives Terrible. Help!
  81. Horn help
  82. Is the 1jzgte worth it?
  83. 98-00 SC300 Timing belt/tune up part numbers
  84. Transmission temp
  85. Lifter or rod, you decide!
  86. 99' SC300 5 speed swap vss conversion question
  87. How to remove the dashboard of an SC300 with pics
  88. 95 sc400 fuel pump issue
  89. Throttle Cable Slack?
  90. Lifting the Sc400?
  91. transmission fluid level check
  92. Installing an aluminum splash shield
  93. I need help
  94. SC400 - AC Suddenly shuts down.
  95. Clunk in rear after hks coil over install
  96. JZZ30 will not start after being stored
  97. Sc300 Radiator Options
  98. Noob Engine Swap Question...
  99. Rear main seal right?
  100. Is my starter on it way out?
  101. Auto Shift Knob
  102. W58 transmission differences/sc400 5spd swap
  103. Jzs147 lsd in a soarer
  104. Help - Hydraulic clutch / Input Shaft quesiton
  105. 95-97 Non-Stop-Tuning Short Shifter First Impression
  106. 97 Sc300 NA-T Build
  107. What's this hose for?
  108. Coolant Leak!
  109. Blowing 10am heater fuse
  110. Sc300 Vs Soarer: Question regarding parts and maintenance.
  111. Opinions: New Gaskets or New Engine
  112. Halp. Car wont start up and no cel
  113. A340E auto for 2JZ-GTE only?
  114. Running extremely rich, help
  115. Post Timing belt Service no Start
  116. Codes 25 & 26???
  117. HELP PLEASE!How to remove stripped head bolt??!!
  118. A340 mods...Shift kit, or DIY mods?
  119. Oil pan gasket replacement
  120. What piston rings to go with?
  121. R154 Trans Question!
  122. Which Clutch for stock sc300 - LUK, AISIN, M - Pact?
  123. Battery Relocation for the SC400
  124. Fuel pump stays running!
  125. My homemade 1uz vvti intake
  126. rear subframe mounts won't budge
  127. 1995 sc300 won't crank
  128. No Spark or Fuel, what else am I missing?
  129. Sc4 auto to manual Bellhousing suggestions
  130. High Pressure Power Steering Hose Bleeding
  131. 93 SC 400 A/C problem
  132. 1jzgte obd cel codes 13 & 47
  133. What diff can I use as an upgrade on my 94sc4?
  134. timing belt question SC400
  135. No cranking or solenoid noise
  136. Driveshaft/coupler problem or something else?
  137. Cluster bulbs are burned out, need replacements
  138. 93 Lexus sc400
  139. Need Master Cylinder Replacement Advice--Traction or Not?
  140. Can you tell me what this ruined plug was?
  141. Undertray ALuminum for SC300 ?
  142. Who makes MAF flange for 1uz vvti?
  143. Spark control?
  144. '98+ key and/or remote programming
  145. Limp mode and blowing 150A fuses with very odd variables
  146. do all SC fuel gauges read 3-4 ga low?
  147. Alternator went wooosj
  148. No power to fuel pump HELP NEEDED!!
  149. sc300 headgasket replacement
  150. $1400 later and still no cool air in the cabin
  151. 95 Sc400 No Spark Mystery Extraordinaire
  152. gated shifter install? yes I searched....
  153. Hydrogen On Demand for better fuel economy and increased power?
  154. AT to MT!!! On my sc4
  155. 1993 sc300 5 speed and ge swap -> NA-T
  156. 1993 SC300 Brake light
  157. Do I have to remove the driveshaft to install rear upper control arms?
  158. Help! Abnormally loud wind noise from engine bay
  159. Powersteering hoses
  160. 2003 trd parts list
  161. 92 SC3 Driveline Vibration Issue
  162. Engine Rebuild?
  163. 92 Sc300 M/T Idling Issue
  164. Do you have take dash out for heater core removal
  165. Alternator replacement brand suggestions
  166. new car coolant is black?
  167. battery size
  168. Found this piece broken underneath
  169. 1998 SC400 5-speed won't select 2nd or low
  170. Check engine light goes off at 1800 RPM
  171. SC400 door hinge repair kit??
  172. sc300 stuck in park
  173. replacing ignition starter switch
  174. Gated Shifter Mod
  175. no start, again
  176. Sc400 park and drive indicator lights both on at same time
  177. Sc300/Sc400 Moonroof/Sunroof Delete!
  178. High performance A340E transmission
  179. Access to OBDi port under dash
  180. Recently bought 1997 SC400 overheating
  181. Flashing OD Off Light
  182. SC400 - Wild Tranny Issue
  183. muffler hangers
  184. sc300 fuel damper ?
  185. steering wheel tilt/tele troubleshooting
  186. Check engine light came after air cond repair
  187. Odd problem
  188. Blown Spark plug on 1uz
  189. W58 Rebuild Kits?
  190. How to check for bad hazard or combination switch?
  191. Operating temps SC300 higher?
  192. Aristo TT throttle body & manifold, or not?
  193. Manual Conversion Pedals
  194. MAF(afn?) code thrown
  195. GM overdrive transmission choices?
  196. Clicking noise at very bottom of clutch
  197. 1jz auto swap in sc300
  198. sc400 misfire help!!!
  199. Injector size vs. fuel pressure?
  200. Horsepower help
  201. 1993 sc 400 ecu rebuild
  202. Who's rebuilt an SC300 P/S pump?
  203. Exhaust manifold questions NA 2JZ
  204. sc300 2jzgte vvti single turbo won't idle
  205. Help! First issue with one owner Lexus SC 300 , Need assistance Please!!
  206. HELP! Spark plug broke
  207. Bad Fuel Pump/Very Hot EFI Relay?
  208. Today exchange my water pump in my Lexus sc300
  209. Stalls @ startup when hot
  210. 350z Z33 Tranny Swap
  211. Coolant bubbling in reservoir, not overheating
  212. Soarer manual and single turbo conversion - car won't start. Need help
  213. 93 SC300 2JZ heater hose leak at back of engine
  214. Another rough idle/stall fix 300
  215. EGR delete on 2jzge question/help
  216. Turbo Kit 97 Sc300
  217. Single turbo for SC300 with Aristo 2JZGTE?
  218. were to get mod parts ?
  219. Click here to play, "Name That Popping Sound"
  220. Swinging Side Mirror Help
  221. ticking noise around intake plenum
  222. Single 76mm turbo 2JZGTE
  223. Heater control valve unplugged
  224. help choosing wideband setup
  225. LSD recomendation
  226. vss 1jzvvti swap w58 no speed
  227. 13 or 16 PSI
  228. SC300 factory exhaust gasket reference part numbers
  229. Two vs One
  230. Tps screw
  231. Exhaust Leak, or Ignition related issue?
  232. A340E automatic transmission .xls
  233. NA-T Questions?? Ask the Guru
  234. Lexus SC auto trans. support group, lets help each other
  235. HKS cam install on TT 2JZ?
  236. Sc400 shorted out, won't start
  237. Acceleration issue?
  238. 1uz starter wiring help
  239. 93 SC400: No Crank, No Start
  240. SC300 power steering not working... even after changing PS pump
  241. Sc300 wiring help
  242. '92 SC300 Electronics Woes. At my wits end
  243. Auto trans mod
  244. Tail brake light won't go off
  245. Location of coolant temperature sensor? 1999 SC300
  246. Safe boost on stock Jdm twins 2jzgte
  247. STRANGE or normal Throw out bearing noise...
  248. door lock sensors interchangeable?
  249. car shuts off in reverse!?!?
  250. Buzzing from fuel pump and whinning from fuel rail
