- LS1 Swap?
- SC400 Transaxle Rebuild
- Errrrrrrr noise(help all gurus)
- shift solenoid connector
- sc400 shifter stuck in park!!!
- 1jz vvti ct15b failing? hearing turbo even in vacuum
- Spark plug gap
- Need some AC help
- 93 sc400 Knock sensors
- Experiences with performance shops
- Oil pump question 98 sc400
- pricing for a standard tranny
- Transmission issue.
- Transmission randomly drops into 1st gear.
- huge problem :(
- SC CAD Model
- Grinding and screeching sound from front driver side wheel.
- 92 sc400 safc II bogging after weak battery
- 98 na Fuel pump ecu, ac compressor and BCC
- 230k mile 2jz overhaul
- 98 5 speed auto trans swap
- Bad accerlation.. exhaust sputters.. 95 SC400
- 97 SC4, Posted for sale on Craigslist, Please Help, dont want to have to sell
- w58 into sc400 shifter question
- GE Head on GTE Block
- Power steering fluid changed, now the steering feels heavier . . .
- Which car would win in a race?
- fuel pump relay
- Timing Belt Job
- 1j sc300 trans issue need help fast
- 95 sc400 maf(afm) issues. Rpm limited to 2000
- 1jz engine rattle
- Jdm auto Trans for 95 sc400
- Oil on Spark Plugs
- sc400 won't idle, timing...or something...
- fuel injection wiring
- Aristo 2jzgte into SC?
- Car won't start again
- Stand Alone for 2jzge non vvti
- Guys running e85 please chime in
- Cat for turbo
- How much trans fluid to add?
- Need Help, Cant figure out starting issue on SC300 1J
- Correct Part? 97SC4, O2 Sensors
- Starting issues again..
- AEM V1 Sensors Needed running MAF
- Differential Options
- Heater Valve
- Finished up my SC300 transmission service today
- My BFI mod
- BW S366 on a 1jz?
- lexus is300 irs 8.8 swap
- WTF is this in my tranny???
- sc400 wont shift from park
- 93 sc400 wont shift from park
- Limp home mode troubleshooting?
- 1999 Gs300 Diff in a 93 sc300
- Cleaning OBD2 Maf
- Body Control Module?
- P0401 EGR and effect on A/F ratios
- GS300 trans into SC300 question
- valve cover gaskets, rockers and torque specs
- SC400 Gas Mileage Issue
- third time replacing fuel pump this year
- Motor and Trans mounts sc300
- Electrical shortage on acceleration above 2000rpm
- SC400 Idle Issues w/pics, Please Advise!
- Clogged cat
- Alternator, Sepentine belt or Fuse?
- 1jz vvti diverter valve
- designing a hood vent
- How to by pass the safety switch
- No Start issue
- Need Some Help With RPMs
- Check engine light
- Oil in spark plug area
- SC400 no crank, no click, nothing.
- Putting R154 in 93 Sc300
- Help all gurus
- 1jz vvti throttle tip in hesitation
- gs300 transmission in a sc400
- RX7 FD 550cc Injectors in a 1JZ
- 2jzgte vvti vs non vvti and front and rear sump
- GM 5L40-E Transmission Paired with 2JZ
- SC400 Mods and Maintenance
- 5 speed or 6 speed
- Help!! Smoke coming out exhaust
- to go jz or just stick with uz-fe
- Soarer R154 or MK3 Supra r154
- Attention IAC (idle air control) experts.
- Noise? Power steering?
- Car wont Start. Fuel Related Issue
- What part is this
- No Heat in SC400
- engine problem... help plz
- Rear End/Axle Torque Specs
- Any progress made with 1uz TURBO or SUPERCHARGER kits?
- 1jz swap oil warning light
- OE Toyota part number for compatible Supra LSD?
- Body kit plus car cover help.
- Head gasket recommendation
- Going to Lexus today, Some advice please :)
- rusEfi: open source DIY ECU
- Spark plugs information needed
- Sc300 electrical gremlims! All help appreciated
- TT 1UZ power level issues.
- A/T shifter vibration rattle, possible improved "fix"
- 97 SC4, 5 years, first time Ive been stranded on side of road, please offer ideas
- Aftermarket cams for a non-vvti 2JZ-GE
- Please help me?!? sc400 WONT START?
- SC 400 engine issue
- weird transmission/fuel pump problem
- exhaust help.
- Supra lsd swap question
- 92 SC400 starting issues, so stumped
- Sc400 needs more power
- Replaced distributer O Ring and lost timing
- All Boostlogic Manifold NA-T Users
- 1993 Lexus sc400 upgrades?
- No spark from D/S disto
- crank pulley will not come off
- Tachometer error after spark plug & wire change.
- 1jz vvti safc settings
- Need Some ATF Speed Auto Transmission Info.
- Broken TT auto differential
- Checking ECU Capacitors
- Random Limp Mode?
- Proefi48 vs mapecu2 vs aem v2
- Tranny problem...
- 95 sc4 cranks but wont start
- 1jzgte auto transmission having problems shifting
- AC ground cable location?
- Electric Superchargers (real ones)
- PNP manifold?
- *Please help* Traction control issue 93 sc400
- 92 sc300 na-t question
- More air induction good or bad?
- 92 sc400 wont start
- Supra TRD install questions
- sc 400 wont shift out of park
- Climate Sensor
- power steering pump and belt squeal. please help
- 92 SC400 transmission running GREAT! Brown color, though.
- 4th Solinod cut on my 96 OBD2 CEL Help please!
- '92 SC400 Bad TPS?
- Wrong Ecu in car. Side effects ?
- Left and Right Rear Axle Seals Leak
- Power steering leaking abhorrently
- need help find where hose goes
- 92 SC 400 rough idle
- Turbo Hitting Shock Tower!
- 1jz valve guides?? Need help!
- Not Sure What To Do
- Heater blowing cold air and the air smell bad.
- turbo with Trac control?
- No Start SC300
- Extremely high idle ~3k
- throttle body click away when ignition on, engine and traction light on
- so let's talk exhausts...
- fuel pump not starting
- Leaky tb/ Manifold gaskets....RTV???
- Trac Control Stuck On
- TPS Confusion
- SC400 takes longer to start up after fuel pump replacement
- 92 SC400 Transmission problems (no codes)
- SC300 Possible Head Gasket
- ??? about 1jz swap
- Tearing sc300 dif apart. Question
- Engine idling high/low/high/low aka rpm hunting. Please advise.
- tps 1995 sc400
- VVTI Feedback Needed: NA-T or GTE
- TT head Gasket on non turbo?
- Won't start, help!
- iacv sc400 liquid
- what am I missing? (w58 Swap)
- 1992 Sc400 wont start
- Sc400 1jzgte cranks no start help!!
- Hello everyone! A few maintenance questions.
- Need quick help
- Cold air intake on a stock SC300/5 speed.
- What does it sound like?
- iac valve 1995 sc400
- Fuel pump Issues 92 Sc300
- 1992 SC300 hood seals - anyone have part numbers?
- W58 Gasket replacement
- Sc300 with sc400 radiator problems
- What do you guys think about this turbo?
- Need Help ! No Power !
- 1 JZ starter question
- Accl controller question.
- how do i get a soarer harness/ecu to work with chaser engine
- JZX100 auto ecu gear inputs
- 1992 Sc300 Alternator.
- r154 Extreme play in shifter
- 1JZ-GTE Ticking, Revs and Dies
- Aftermarket header problems
- Dyno results are in 662hp on 2jzge
- Crossmember issues?
- Fuel Lines
- Exhaust question...
- SC400 Plugs Recomendations
- 92-97 vs 98+ sc400 differences?
- 95 Hydraulic Clutch
- Spark Plug stuck
- suprasick on my stock 300 bai/exhaust
- Why isn't there an NA section?
- 1jz starter questions
- Need pic to fix code 71 (resistor mod)
- 95 Sc400 idle and acceleration problem
- replacing fuel injectors, anything else I should do at same time?
- Just replaced my knock sensor...
- Cxracing turbo manifold
- Just order my knock sensor
- "Chugging" at 40mph
- na-t or 1jzgte automatic
- Gated shifter help! Car will not move when in gear
- Check Engine Light, Running Great
- Aem 1100 box on NA-t stat sync'd OFF help
- slippy release bearing SC400 + W58 + T56 bearing
- 1JZ - Why does my 1J like plugs gapped less than .020??
- Power steering vacuum air control valve issue
- Power Steering noise HELP!!!
- trd s/c for sale
- Master cylinder install question on 5sp swap
- Starter help please
- Weird EFI Problem
- Anyone w/ 98-00 GS300(auto) ring/pinion gear?
- New to lexus need help what's te best fitment for A 92 sc300 the supra motor are the
- Inner distributor leak?
- 95' sc400 serpentine idler pulley question.
- tell me why this will not work on a sc400
- BMW gearbox + 2jz ; anyone stateside done this yet?
- easy fix for squeaky door panels
- Does our orig. key affect a new ECU?
- 1jz oil pan dented
- Loss of power
- cel code 52 on a lexus sc 300
- Upgrade S366 to 11 blade billet wheel
- Weird Issues With SC400
- Advice on buying a flodded SC300
- 93
- Clutch pedal assembly...where do last 2 bushings go?
- 98 sc400 cel codes
- need some help out here guys.
- Replacing SC A/C evaporator, expansion valve and heater core - Am I missing anything?
- Key & Tumble / Ignition Switch Same as Supra?
- Random AC Light flashing sometimes....?
