PDA
View Full Version : Performance & Maintenance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86
  1. Are these bad caps???
  2. Garrett t04e BB 60-1
  3. Can anyone help explain this: low AFR under boost and no Fuel Cut??
  4. Need help, maybe ecu related
  5. SC 300 Failed Emmisions Test, Replaced 02 Sensor...Still Not Passing
  6. lost.... im new to the lexus scene and need a lil help please :)
  7. lost on what axles to run help needed.
  8. 1UZ-FE Or VVTI 1UZ????? S13 swap
  9. sc400 cranks but wont fire up.
  10. My new custom exhaust SC300
  11. 1jz vvti intake cam seal?
  12. Trac light on...
  13. R154 manual swap needs clutch ??
  14. '93 fuel filter and rear seat back
  15. Please help! SC400 won't start!
  16. Installing new -6 AN braided fuel line/Aeromotive filter. Will these parts work?
  17. Club NA-T KIT
  18. 1uz Injector Rail Torque Specs??
  19. 1JZGTE Single Turbo Boosting SLOOWWWW HELP
  20. MAS performance sc300 runs a 9.8!!
  21. OBDI vs OBDII engine harness
  22. 2jzge obd1 code 14 please help
  23. is clutch pedal spring supposed to be super stiff?
  24. Walk through for installing BOV
  25. low idle and no ac, 1jz vvti
  26. Who Can HELP Me
  27. Need to verify exact length difference for factory R154 Soarer shift extension vs MK3
  28. 93, poor low end power. solutions?
  29. KA24DE Trans on SC400?
  30. startup hiccups sometimes
  31. Why want SC300 turnover?????
  32. Driveshaft deminsions
  33. Pulling out all my hair!!
  34. K&N Intake from a GS400 on my SC400, finally its been done with a pic!
  35. Help a noob out.. A341E trans swap A LOT of Questions!
  36. Na-t vvti do I use a tt head gasket?
  37. O2 Oxygen Sensor LIES for the 1JZ... 4 wire to 3 wire conversion?
  38. NA auto shift kit?
  39. Titan Motorsports: Aeromotion Wing
  40. 1JZ VVTI FPR vacuum switch / solenoid?
  41. 1993 lexus sc300 mpg ?! Awful help !
  42. Gs300 pumpkin swap into my sc300?
  43. R154 - Ridiculously high clutch engagement
  44. 97 1uzfe sc400 ground start run
  45. 1jz vvti second fuel pressure regulator under intake manifold?
  46. Seeking advice from NA-T expert ha!
  47. 1jz/2jz vvti aluminum accessory pulleys
  48. which driveshafts for your sc300
  49. Alarm problems please help!!
  50. DIY: 99 SC400 Valve Cover Gasket, T-Belt, Water Pump etc..
  51. 92 sc400 w58 no crank/no start. NSS wiring?
  52. Battery Draining?
  53. hard oil feed line
  54. Strange Occurrence!!!
  55. need to find injector orings
  56. Safc2 in 97 na-t, help
  57. SC400: Hesitation above 1500rpms
  58. temperature gauge issue on swap
  59. What is wrong with my SC!?
  60. Help...CEL 15 Ignition Signal...starts then dies...
  61. AC Codes 23 42 and 43
  62. MKIII R154 shift housing extension?
  63. anyone try this mod yet?
  64. 2JZ-GE ACIS Intake Vacuum Control Valve install questions
  65. 1JZ W/ Sc300 shroud and fan??????
  66. 1993 lexus sc300 2jzge questions about boost ? Please help
  67. ?? for na-t guys, What is this for?
  68. Question on MAF's
  69. 1jz crazy high fuel pressure, bad FPR?
  70. 6766/1jz what size oil feed?
  71. no overdrive/4th gear in 1jz auto transmission
  72. 93 sc300 2jzge w/ auto tranny turbo help/opitions ?!
  73. Blower Control Harness
  74. Upgraded throttle body on 2jzgte, what tps/tps issues
  75. How to delete power steering?
  76. 92 SC400 Cranks But Will Not Start - Smoking Cable
  77. Nothing but hot air...
  78. coil pack
  79. Green liquid leaking from EGR valve
  80. ABS Sensor/Speedometer not working 95+
  81. Fuel system cleaner question
  82. Intermittent overheating 'I think'?
  83. neeed more speed haha
  84. My 1JZ is killing itself
  85. AEM EMS v2?
  86. Question about rear differential
  87. no power to fuel pump, car won't start
  88. Sc400 Fuel line replacement north of filter. Where does it start?
  89. Cant connect to stupid AEM V2
  90. big hp r154 must go??
  91. 1993 sc400 problems
  92. Shakey Idle ??? Car Performs Fine
  93. NA-T suggestions.
  94. SC300 doesn't start sometimes! (Video)
  95. Ordering Rack & Pinion...with or without EVO Component
  96. greddy trust piggy back
  97. w58 to auto swap
  98. Bfi?
  99. AC Clutch? help
  100. NA-T build Part list so far
  101. ...............................................
  102. 1jz crank no start help please!!!!
  103. BorgWarner oil feed line questions
  104. I tried the how-too and she still hesitates
  105. Can my oxygen sensors be going without throwing codes?
  106. Engine oil/ tranny oil
  107. My 92 sc400 starts and shuts rite off
  108. LS6 swap. sc400
  109. Loud grinding/screech when ac turns on
  110. Turbo
  111. jerking when boosting
  112. SC400 won't crank when warm
  113. door handel/lock actuator
  114. 93 sc300 2jzge chokes!! help
  115. Please Help Me Understand Data From My Voltmeter.
  116. Shifting Issue
  117. Another alternative for the R154?
  118. 1JZ Single SC400 bucking and irregular idle
  119. cam cap location/direction help on 2jzgte aristo
  120. CEL code 71
  121. Input on Xspower turbo kits needed
  122. Jerky shifting...Interesting...
  123. sc400 Hurricane Headers?
  124. Stock 7M-GTE clutch & PP vs ACT HDSS for R154 swap to NA 2JZ-GE
  125. Trans issue 93 SC400
  126. Quick silly question about my turbo's orientation...?
  127. Turbo kits for the sc300
  128. Sc400 code 21 and 28
  129. Things to replace during tranny swap
  130. loss of power..but stops if I turn over drive off
  131. Is running "Cat-less" bad for my 400?
  132. sc400 auto shifter stiff/stuck
  133. Can I use a 95 auto transmission with my 92 sc400
  134. Catalytic Converters ?
  135. How to remove stuck exhaust manifold nut
  136. Marlin Crawler VSS
  137. Info Please
  138. 92 sc400 code 13
  139. Mizu Electric Fans for MKIV
  140. o2 sensor does not fit onto obx midpipe
  141. Is it just me? Or, are turbo "kits" getting cheap
  142. Power Steering Question & FCD Question
  143. 2000 sc400 low idle in drive - OK in neutral
  144. clutch cylinder help
  145. SC400 no start, no CEL
  146. OBDI 2JZGE & 1UZFE Injectors Interchangeable?
  147. 90K Maintenence
  148. Need help figuring out problem with rough engine
  149. Ground Wire Replacement
  150. What is this rusty part with the chewed up bushing under my car?
  151. soarer help pleeeease
  152. EGR tube issue Not the "two lower bolts"
  153. Fuel Pump ECU overheating ... Need some advice ...
  154. beluga racing exhaust sound
  155. 2000 SC400 grinding noise first gear/low speeds - FIXED
  156. 95 sc300 o2 sensors
  157. 2000 SC400 scratching noise first gear
  158. What transmission fluid could I use? 92 sc400 auto
  159. Preference for cabin air filter? (Denso (OE) vs Beck/Arnley)
  160. 1jz fuel ratios
  161. Maf Sensor Wiring Help
  162. question concerning the 1uz power
  163. Swap woes
  164. Who offers the best tune up kit for the 1uz???
  165. Air Intake issues
  166. Curious about Nitrous.....
  167. 1UZ block with 2UZ crank??
  168. New sc300... and a leak
  169. Intermittent Power Loss.
  170. just got tuned after new part install and car goes crazy, need help
  171. HAYDEN idler pulley for an SC400?
  172. low oil level light help
  173. Differential output flanges wet with fluid... from where? (Pics)
  174. transmission problems for 92 sc400
  175. Fuel line broken, Filter temporarily bypassed with HP hose, best options?
  176. Poor Performance
  177. 1JZ-GTE Bad turbos?? Please help
  178. strong fumes inside of car
  179. Dyno s366, aristo stock ecu,sc300, 12 psi
  180. Battery Light Is still On... WTF
  181. Need help, electrical nightmares, headlights cutting off tranny acting up
  182. 92 SC400 MAF Issues
  183. Oil leak near, driver sid enear cyl 1 and 2
  184. SC4 plugs and gasket questions
  185. Should i upgrade my alternator?
  186. 1997 automatic ? swap or turbo kit?
  187. new 1uzfe engine soon
  188. 94 SC400 trans replacement
  189. Help with idle!
  190. Which 2jz-gte engine is it?
  191. 1UZ gurus please help.
  192. temp gauge issue
  193. my sc 300 turns off while driving...
  194. 1jzgte, Single turbo, vaccum issue
  195. No heat...help
  196. Replaced Cam+ Crank seals and still leaking
  197. 93 lexus sc400 Rumbling sound from the transmission or engine
  198. Anybody know how to setup FIC1100 injectors for the AEM V1?!?!
  199. Help needed
  200. Completely stock 1JZ twin turbo OR stock 1JZ VVT against 200k W58?
  201. Radiator Question
  202. Tensioner possibly dying?
  203. Building FFIM. Need measurements
  204. Rear Cam seal replacement
  205. Compatible Differentials
  206. 1jz cam sensors
  207. Hollowing out cats
  208. HELP: 1JZ VVTI Swap A/C & P/S Issues
  209. Need help with gated shifter conversion
  210. Manually raise and hold idle rpm (for diagnostic purposes)?
  211. jzz30 wiring diagrams
  212. Powerwashed my sc300 and it isn't running right !
  213. Oil Pan gasket replacement.
  214. 400 running cool
  215. First tuneup for Me and My Sc400. Spinning Tires Now! ;-)
  216. Warm weather= low rough idle??
  217. performance
  218. please help have a problem sc400 starts and shut off
  219. A "how my clutch feels" question
  220. Gauge cluster bulbs?
  221. Progressive power steering delete....is it possible?
  222. M2 performance muffler test dummy
  223. External Shifting R154 is apart - in search of some guidance
  224. 92 SC 400 rough idle, need help
  225. Need help.. harmonic balancer
  226. Aristo 2JZGTE running lean
  227. vvt-i ecu chaser - soarer
  228. intake and exhaust
  229. running very very poorly
  230. Will I have a problem clearing my 6766 on this manifold?
  231. Differential bushing removal?
  232. Power steering leak, potential source?
  233. 1996 sc300 p0401 code help please!
  234. low idle problem
  235. Help!!! No spark 92 sc400
  236. O2 sensor wires cut
  237. Q:50mm wastegate on 44mm flange/tube
  238. Aftermarket power steering reservoirs?
  239. making steel braided fuel lines for sc400
  240. How hard is it to install Rack/Pinion and Tie End Rods?
  241. Checking Engine Codes - CEL Burnt Out
  242. 1jz-gte into my sc300 fuse box?
  243. R12 a/c pressures
  244. 98 sc400 2jzgte swap? manual transmission
  245. A/C Compressor seized up / smoking. I want to delete it.
  246. SC300 Aristo Swap Rear Thoughts
  247. 1JZ GTE VVTI Swap Code 78 Question
  248. 2jzgte breaking up above 14psi
  249. SC300 stalls/hesitates.
  250. Replacing PS fluid and fan fluid with synthetic?
