PDA
View Full Version : Performance & Maintenance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86
  1. AC compressor Pulley eating serpentine belt
  2. apexi avcr help?
  3. what turbo parts needed: 94 sc300 with 8.5:1 comp block
  4. 1JZ-GTE Toyota Soarer No Start
  5. Side mount IC with Front mount IC
  6. AEM EMS 30-1101 Confusion
  7. 1JZ Throttle Issue.
  8. A/c issue
  9. SC300 Timing - Misfire vs. Engine Stall!!
  10. SC400 has no power. Need help!
  11. Hydraulic Throwout Bearing on R154
  12. Engine swap
  13. R154 Swap JZX90 92-96 Chaser
  14. soarer r154
  15. Help Identifying AC Part!
  16. Drive Shaft Diameter
  17. AC Hardline replacement
  18. aluminum radiator ac not as cool
  19. Time to overcome this: PS leaks only after being driven
  20. Help! Rear axles no good
  21. Sc300 vs Sc400 swap efficiency
  22. 99 uz into a 97 sc400
  23. Tuning question anyone?
  24. 97+ supra engine mounts.
  25. Opinion from those with V160 and TRD mount
  26. Tru Boost Pinout
  27. I'm hitting boostcut @3500 rpm with my boost completely turn off
  28. Staggered Cams On a 2JZGE??
  29. Foam in coolant resivor
  30. Put new platinum NGK spark plugs in runs worst now
  31. turbo build throttle body
  32. Timing Belt Slipped?
  33. 93' Sc400 Transmission Problems HELP
  34. JZA70 1jzgte in 1992 sc300.. please help
  35. 400 is misfiring
  36. Oil leak from distributor, HELP PLEASE!
  37. Take a look at my spark plug and let me know what you think.
  38. 92 SC4 problems please help
  39. 93 sc300 speedo problems
  40. Wtf!
  41. sc 300 clunky transmission
  42. Weird noise from middle console when going high speeds like a grinding noise NEED HEL
  43. Idleing problem saga continues!
  44. sc300 1jz Project Car
  45. sc300 1jz Project Car
  46. Upgrading from Dual Walbro 255's
  47. TPS Throttle Stop Screw Location w picture
  48. e85?
  49. Bleeding the Traction Control
  50. NA-T 389rwhp 445ft-lbs need help with ignition
  51. cold air intake & exhaust?
  52. parts
  53. should I rebuild or repair my 96 sc300 engine
  54. ebay timing belt kit
  55. Aftermarket Parts and HP
  56. O2 Sensor
  57. No power to Ecu or fuel pump.
  58. Hayden 677 Transmission Cooler Installed
  59. what turbo is this?
  60. power steering question w/pic
  61. Na-t tt ecu single turbo a/f's
  62. Anyone running ACL bearings?
  63. SC300 - Will not run - Please Help
  64. 1993 SC400 Turns over a few times and fails... then starts 4th or 5th try
  65. Should I be able to pass emissions?
  66. New to forum! My SC...need some help!
  67. Grinding sound from shifter, also transmission flush?
  68. Mysterious green light on dash board?
  69. Distributor plug locations numbers
  70. Clutch disc melted to flywheel??? Southbend/R154
  71. 95 alternator issue
  72. washed my engine, now guess what........
  73. mk3 supra w58 swap clutch help
  74. SC300 differential backlash
  75. Need some recommendations for turbo
  76. ignition problems
  77. R154 Trans / 1UZ V8 ? compatible flywheel?
  78. At a complete loss
  79. opinions on 1jz or 1.5jz
  80. alternator wiring help
  81. Soarer R154 question
  82. Quick crank pulley question
  83. Automatic SC400 dying
  84. GE-GTE compatible parts?
  85. 99' SC300 5-Speed Swap Question
  86. weird no idleing run like poop question
  87. Lextreme stage one cylinder head
  88. 93 sc300 AC problems
  89. Does a sc400 iacv fit on the sc300???
  90. sc400 stops accelerating & accelerates again
  91. headers/aftermarket exhaust for SC400
  92. r154 vibration / shaking issue.....
  93. 1992 sc 400 won't stay running
  94. Injector not getting a ground
  95. Something weird happened..
  96. swapping my 1uz
  97. IACV Question
  98. strange tachometer
  99. How easily should a driveshaft insert into the rear of the transmission?
  100. Air Conditioning Issue
  101. Should I get a 1JZ or should I just mate a manual gearbox into my SC400?
  102. rebuilding auto tranny for 600 hp?
  103. bc 264 install in 1jz
  104. Electric fan conversion
  105. Is my gearing messed up? (1JZ W58 Low Speeds, High RPMS! - 5speed SC owners plz come)
  106. Power steering noise
  107. quick question; bad waterpump? AND or BHG?
  108. Just installed my R154 and having problems
  109. spark plugs
  110. WOAH! (Three questions in one thread. Clutch Jerk/Drivetrain/AC Leak ECU)
  111. 1uz egr tube remove ?
  112. Sc300 fuel system
  113. Help in Denver
  114. Time to start over, or can I fix it?
  115. Anyone running any sort of upgraded cams on their GE?
  116. High idle & transmission mis shifting?
  117. CEL and Trac Off lights on.
  118. 92 sc400 temp gauge pegged at hot
  119. Smaller turbo installed now boosting higher
  120. 1JZ twin turbo replacement w/ twins.
  121. Heads up tip : air conditioning leak
  122. please help with electrical issue on my sc
  123. new mufflers
  124. undercoating
  125. 1.5jz build parts needed
  126. engine build opinions
  127. replace front turn signal bulb on 1995 SC300
  128. 1jz problems help !!!!
  129. SC400 A/C Compressor Revolution Sensor
  130. 1jz vvti water pump, where to buy?
  131. brake lights not working
  132. Working on my 95 sc400 ignition
  133. transmission mounts help!
  134. driveshaft length?
  135. Help!!! faulty MAF sensor not sure
  136. Bought the wrong water pump have a question
  137. vvti vs non vvti parts.
  138. No overdrive / cruise control
  139. Quick favor from the 98-00 SC400 guys
  140. Can anyone recommend a good aftermarket 1JZ-R154 flywheel?
  141. GTE knock sensors while rebuilding the block
  142. 1999 sc300 comes with LSD stock?
  143. Head Replacement
  144. Auto TT trans
  145. vortech help
  146. Need some help figuring out what could be the issue with my SC
  147. Grinding fenders for larger tires
  148. SC300 Not Getting Spark; Aristo 2JZ-GTE
  149. Charging Voltage Mod for $.50
  150. clutch problem?
  151. 99 sc300 body plug diagram
  152. High RPM lockout, southbend/soarer r154
  153. Blowing smoke under boost
  154. Is this the ABS sensor on my MKIII R154?
  155. u-joint
  156. SC400 won't start?
  157. Is this good enough for fuel management?
  158. Exhaust Manifold flange warped??
  159. Power steering OVER assisted, Too light, twitchy after overfill/drain extra
  160. Low Fuel Pressure??
  161. Stripped nut on fan clutch need some ideas.
  162. ems choices and help
  163. 1JZ Sticky Idle symptoms?
  164. Need Help with my Loss of Power
  165. Window regulator killing me. See pic need HELP
  166. What was the story behind the Dave H orphan turbo kit?
  167. What mount and crossmember for R154 into SC300? (have searched)
  168. Need help w window regulator!!!
  169. W58 Clutch and Flywheel
  170. So my SC is overheating and I'm still deployed..Awesome.
  171. just bought my first lexus
  172. Window motor really starting to aggravate me.
  173. 1jzgte swap into 93 sc300
  174. Neutral Safety Switch
  175. Are these bad caps???
  176. Garrett t04e BB 60-1
  177. Can anyone help explain this: low AFR under boost and no Fuel Cut??
  178. Need help, maybe ecu related
  179. SC 300 Failed Emmisions Test, Replaced 02 Sensor...Still Not Passing
  180. lost.... im new to the lexus scene and need a lil help please :)
  181. lost on what axles to run help needed.
  182. 1UZ-FE Or VVTI 1UZ????? S13 swap
  183. sc400 cranks but wont fire up.
  184. My new custom exhaust SC300
  185. 1jz vvti intake cam seal?
  186. Trac light on...
  187. R154 manual swap needs clutch ??
  188. '93 fuel filter and rear seat back
  189. Please help! SC400 won't start!
  190. Installing new -6 AN braided fuel line/Aeromotive filter. Will these parts work?
  191. Club NA-T KIT
  192. 1uz Injector Rail Torque Specs??
  193. 1JZGTE Single Turbo Boosting SLOOWWWW HELP
  194. MAS performance sc300 runs a 9.8!!
  195. OBDI vs OBDII engine harness
  196. 2jzge obd1 code 14 please help
  197. is clutch pedal spring supposed to be super stiff?
  198. Walk through for installing BOV
  199. low idle and no ac, 1jz vvti
  200. Who Can HELP Me
  201. Need to verify exact length difference for factory R154 Soarer shift extension vs MK3
  202. 93, poor low end power. solutions?
  203. KA24DE Trans on SC400?
  204. startup hiccups sometimes
  205. Why want SC300 turnover?????
  206. Driveshaft deminsions
  207. Pulling out all my hair!!
  208. K&N Intake from a GS400 on my SC400, finally its been done with a pic!
  209. Help a noob out.. A341E trans swap A LOT of Questions!
  210. Na-t vvti do I use a tt head gasket?
  211. O2 Oxygen Sensor LIES for the 1JZ... 4 wire to 3 wire conversion?
  212. NA auto shift kit?
  213. Titan Motorsports: Aeromotion Wing
  214. 1JZ VVTI FPR vacuum switch / solenoid?
  215. 1993 lexus sc300 mpg ?! Awful help !
  216. Gs300 pumpkin swap into my sc300?
  217. R154 - Ridiculously high clutch engagement
  218. 97 1uzfe sc400 ground start run
  219. 1jz vvti second fuel pressure regulator under intake manifold?
  220. Seeking advice from NA-T expert ha!
  221. 1jz/2jz vvti aluminum accessory pulleys
  222. which driveshafts for your sc300
  223. Alarm problems please help!!
  224. DIY: 99 SC400 Valve Cover Gasket, T-Belt, Water Pump etc..
  225. 92 sc400 w58 no crank/no start. NSS wiring?
  226. Battery Draining?
  227. hard oil feed line
  228. Strange Occurrence!!!
  229. need to find injector orings
  230. Safc2 in 97 na-t, help
  231. SC400: Hesitation above 1500rpms
  232. temperature gauge issue on swap
  233. What is wrong with my SC!?
  234. Help...CEL 15 Ignition Signal...starts then dies...
  235. AC Codes 23 42 and 43
  236. MKIII R154 shift housing extension?
  237. anyone try this mod yet?
  238. 2JZ-GE ACIS Intake Vacuum Control Valve install questions
  239. 1JZ W/ Sc300 shroud and fan??????
  240. 1993 lexus sc300 2jzge questions about boost ? Please help
  241. ?? for na-t guys, What is this for?
  242. Question on MAF's
  243. 1jz crazy high fuel pressure, bad FPR?
  244. 6766/1jz what size oil feed?
  245. no overdrive/4th gear in 1jz auto transmission
  246. 93 sc300 2jzge w/ auto tranny turbo help/opitions ?!
  247. Blower Control Harness
  248. Upgraded throttle body on 2jzgte, what tps/tps issues
  249. How to delete power steering?
  250. 92 SC400 Cranks But Will Not Start - Smoking Cable
