PDA
View Full Version : Performance & Maintenance
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87
  1. 2JZ-GTE Intake Manifold Q (VVti vs Non-VVTi)
  2. problems with 1jz....help
  3. Ever wanted to build your own harness?
  4. SC300 Power Steering Pump Screen
  5. Lexus Sc300 Power Steering & Heater Failure! Please Help..
  6. Help with 1JZ Sc300 fuse box connectors
  7. Need speedo and tach help
  8. 1jzgte rebuild question.
  9. No Spark at Ignition Coil
  10. coil options
  11. 1UZ problems.
  12. My SC400 -HEATER AND AC QUIT
  13. Could it be my Southbend clutch setup?
  14. Standalone with auto transmission
  15. 1uz expansion tank
  16. 2j-ge rebuild suggestions
  17. 1UZ to VVTI?
  18. Is the Sc4 cluster harness or body plugs identical to the Sc3/Soarer?
  19. Changed Fuel Pump Car started but now Dead again
  20. sc400 95 diagnosis port
  21. 1UZ header bolts.
  22. Help with some dash wiring please?
  23. 1992-1997 sc400 Basic performance parts list
  24. 1jzgte issues
  25. NA-T gurus in here please
  26. tensioner mark
  27. Need some helps, thought it was EGR
  28. JZS161 Aristo Vacuum Diagram
  29. merry xmas !!!!new member gt500tony
  30. Building a fuel system for 800-900hp
  31. sc400 replaced engine, ecu, cranks but wont start
  32. Charcoal canister mounted in the trunk?!?
  33. Issue Starting Car
  34. Pcv valve hose
  35. Quick Question about the Parking Brake
  36. speaker issue help
  37. Belt tensioner help
  38. ac compressor bypass
  39. Bolts for automatic 1jz gte Flexplate?
  40. SC400 rear twitch?
  41. Oil leak help
  42. 95 sc300 ABS unit pinout
  43. A Very Odd Alternator Problem
  44. Low RPM issue ?
  45. how many quarts of oil for automatic 1jz transmission?
  46. 2jzge Na-t No Start Problem
  47. Sc400 hesitates
  48. 2-wire and 3-speed sensor/sender
  49. seized 2jzge... What to do?
  50. 96 Lexus sc300 fog light issue
  51. Been researching swap wiring, thought you all might find this useful.
  52. sc exhaust question???
  53. sequence for 1jz coil packs?
  54. Sc300 stumbling issues
  55. stripped some bolts on my 1jz, what can i use?
  56. Auto Trans Shift Kit...
  57. r154 swap rhd pedals in lhd sc
  58. W58; can hear the synchros, huh?
  59. Rear coolant leak. Heater valve?
  60. Rear Differential mounting bolts
  61. SC300 will not start, no CEL!
  62. Wiring cam & crank sensor
  63. Thinking of twin turbo!
  64. some 1jz swap questions...
  65. car window wont close!
  66. Greddy MX Axle Back not fitting on sc400
  67. Maybe have a failed water pump
  68. 92 sc400 engine replacement questions & advice, not found through searching!
  69. help! shifter button broke
  70. Gas Cap Question...
  71. Help!!! 1jz backfire issues!
  72. R154 Rebuild (Opinions Valued)
  73. Will a mk4 Midpipe bolt into stock sc300 exhaust system?
  74. Which trans to choose?
  75. gas smell in oil cap? 1jz
  76. does a soarer 1jz downpipe match with a stock sc300 midpipe?
  77. sc400 sputters, please help
  78. VVTI turbo swap...dumb wiring question, I'm gonna ask it anyway
  79. sc400 power steering resivor in sc with 1jz?
  80. 97 manual ecu problem
  81. Is a 2JZ VVTI considerably stronger than a 1JZ VVTI on the butt dyno?
  82. Why does factory ECU lean in high gears/speeds?
  83. W58 acting odd
  84. Reading knock PCM?
  85. PCV Valve between valve cover and intake manifold
  86. Power steering valve(?) questions
  87. Crank, no start, code 12
  88. Good God... I need emissions help please!!!
  89. Rough idle - code 27
  90. Starter click
  91. 98 SC300-Dayco Part 89055 Belt Tensioner
  92. wanting alittle more pep
  93. aftermarket fuel set up 700+whp
  94. new own. Help?
  95. SC400 Rear Differential Issue?
  96. Soarer harness 1jz auto chaser sc300
  97. Another MAF issue, I've searched, I'm stumped
  98. auto/manual drive shaft difference?
  99. a340e aem ems problems
  100. air intake size
  101. How did you select your turbo
  102. Budget Trans Upgrades
  103. sc400 - ignition coil problems + Coolant Leak
  104. Sc400 starter disengage whirring, grinding noise
  105. Overheating - after replaced 2jzge waterpump - bad clutch fan?
  106. Sc400 engine bay fuel line thread pitch
  107. Harbor Freight tools
  108. Got my engine, oil in turbo, what do?
  109. Reusing zero mile valve cover gaskets
  110. water pump question
  111. Won't start, died randomly
  112. Hard cold start + Code 25
  113. Timing cover gasket
  114. Having issues please help
  115. Can I use a W58 Aristo Trans in my sc4?
  116. 92' SC400 Misfiring
  117. too much air equils failed emission
  118. PS Resevoir Bubbling and Rack & Pinion leaking
  119. Sc300 Won't start
  120. OEM brand Knock Sensors??
  121. New Timing belt, water pump, radiator. OVERHEATING?
  122. 2JZGTE VVTI down pipe?
  123. To fix or sell, that is the question?
  124. Weird acceleration issue
  125. Put 93 SC4 in the shop for oil leak
  126. ECU compatibility
  127. Dead 93 Lexus SC400
  128. SC300 Oil Leak
  129. tt ecu mod with stock coil interest?
  130. 1JZ Single Conversion Coolant & Vacuum Questions (With Pics)
  131. guess what guys. CT20As on 2jz
  132. Lexus SC400 won't shift out of first gear?
  133. Small Leak
  134. Anyway to disable key in ignition sound?
  135. Question to the 2JZGTE swapped SC400 guys and gurus
  136. Regarding getting a "factory" intake air box for a 2JZ-GTE swap
  137. Will a Supra intake fit a GTE swapped SC?
  138. oil level sensor??
  139. Having trouble swapping exterior door handle
  140. 1994 SC400 won't start
  141. Fuel Injector wiring; Need immediate answer
  142. fuel tank, pump, lines
  143. 12-disc cd changer
  144. pcv valve
  145. Car dies when I use the turn signal. Help
  146. 1JZ/2JZ crank pulley
  147. Where Can I get A Power Steering Pump From 98 Sc400
  148. Very low compression?
  149. Clutch Install Help
  150. diameter of 1jz stock twins turbo inlet pipe? for intercooler
  151. Need help installing Manual Boost Controller
  152. Car no power!!!! Helpp!!!!!!!!!!!
  153. AEM V1 Base Map for NA-T
  154. SC400 manual transmission swap
  155. 2jz Soarer - New Timing belt kit and VVTI
  156. sc300 white smoke
  157. Just Finished My Exhaust!
  158. Help !!! sputtering, no power, red cats,shaking.!!
  159. sc300 ac compressor compatibility?
  160. 1jz LC1 narrowband signal to ecu
  161. Knock Sensor - HELP PLZ
  162. Turbo math
  163. 92 sc300 with 2jzgte swap.. Gauge cluster prob
  164. I'm looking for Dimensions to 7MGTE or 2JZGTE IACV Flange for FFIM
  165. ObdII 2jzge turbo insights/questions
  166. intermittent sluggish shifting
  167. evap purge valve
  168. 5spd swap...low idle and stalling when driving
  169. What am I missing/forgetting for BPU Aristo swap SC300?
  170. NIGHTMARE problem with Car Running Terrible (Stutters, Bucks, Dies out, etc)
  171. Car won't stay running
  172. FFIM IAVC options?
  173. Adjusted timing now car feels slower?
  174. exhaust piping size
  175. turbo direction
  176. 1jz single on stock fuel? Target boost?
  177. How much was your build?
  178. Power steering leak!! Please help!!
  179. Buzzing Noise Air Conditioning
  180. Extending 1JZ Soarer Harness for Sc300 *If you have done it come here*
  181. Injector wiring
  182. Fan Clutch
  183. alternator
  184. weird check engine light and trac light problem.
  185. 2JZ Dying
  186. ARP flywheel bolts torque specs question
  187. The timing belt saga continues
  188. Coolant Leak on top of engine
  189. Auto to manual swap...
  190. Sc300 Overheating prob need help!
  191. SC300 heating problem ?
  192. PSA: Putting AN hoses together
  193. Fuel Pressure Check
  194. SS Tool for Valve Clearance Adjustment
  195. exhaust and cam video search
  196. Can you use an OBD2 maf sensor on an OBD1 car?
  197. 1UZ-fe wont pass 4k rpm
  198. Constant Misfire troubleshooting
  199. SC300 swap question
  200. Power steering pump question
  201. Map-ECU
  202. 92 sc300 starts but shuts off when cold
  203. Ar and twin scroll? 1jz 83-75 help!
  204. Boost Creep problem
  205. 1jz manifold for rhd?
  206. egr delete can't get the resistor right cel is still on
  207. Do not buy Bosh wires (sc400)
  208. HKS SLD Type-2
  209. Second power sterring hose failure
  210. Door Bind
  211. Alternator plug/wiring help
  212. fuel tank, pump, system pics?
  213. Trouble finding a braided fuel line for my 1JZ into my SC300
  214. driftmotion ps hose help
  215. Water Bridge Gasket
  216. Overheating problems
  217. Failry New to the 1UZ, Had a 2JZ
  218. 4runner Distributor cap issue
  219. ECU questions
  220. 5.3L V8 swap question
  221. 92-95 ecu pinout needed!
  222. NaT questions
  223. Exhaust theory 101
  224. Limited Heat
  225. FML SC300 has gremlins.... rough start, won't shift, NEED HELP!
  226. need an actuator for 1jz vvti
  227. How to check Auto Transmission outside of car
  228. bosch 760cc injectors
  229. Alternator Issues
  230. Intercooler tuck..thoughts
  231. 92 sc400 reverse wires? w58
  232. Sc400 1uz-fe dtc 29, 31, 41
  233. Help finding Soarer 1JZ!?
  234. Clunking noise in the differential
  235. Car trouble
  236. 2jzge auto-manual differences?
  237. 1JZ GTE VVTI Spark Plugs & Gaps
  238. 240sx trans
  239. HELP!!! 1jz turbo downpipe???
  240. I need input
  241. Heater Problem SC400 1995
  242. Transmission Jerk, Surge, Clunk shifting to Reverse and Drive
  243. auto to manual conversion...mechanics
  244. temp gauge sender.. does it have a washer?
  245. Need help from someone with a soarer 1jz swap
  246. Pontiac Transmission = R154?
  247. Car stalled today, Fuel pump ECU?
  248. 1jz-gte swap questions
  249. 94 SC300 tail light fuse keeps blowing
  250. Soarer downpipe/y-pipe/dump pipe same as Supra?
