- How To Disconnect Wiring Harness Plugs
- Engine jacking
- RPMS Not Dropping, Completely Clueless
- 1JZ-GTE VVT-I Issues
- ??? oil pan gasket
- 1998 Lexus gs300 coolant sender gauge part number
- Borg Warner S366 opinions?
- Map ecu 3 on a NA-T build?
- Side mirrors
- Fuel Injector rail torque
- 1994 Lexus SC 400
- Just want to pull engine help
- Sc400 randomly dies
- Who has removed their charcoal canister?
- 92 SC400 HVAC either to hot or too cold, what's up?
- Plenum bolt torque
- 92 SC400cruise not working after alam install - help!
- apexi safc
- just bought sc300. few questions
- inside door handle - how does it break?
- Bypassing heater control valve (hcv) question
- EGR question
- Sc300 cluster problem
- Oil pan
- Fuel Injector Seals
- 97 SC400/1UZFE Idler Assembly Removal????
- SC400 mods on a college budget?
- radio
- acceleration
- Using 2jzgte vvti aristo ecu in 95 sc300 how do i make ac work?
- Intermittent starting problems. Replaced fuel pump ecu and can hear pump working
- Sway bar smashing against oil filter
- 300zx tt 5 speed swap?
- '92 SC400 revival
- Sc300 Cluster problem need help
- 92 SC400 turn signal not working
- Canadian 92 SC400 DRL info please
- SC400 Fuel Injector Electrical Connector
- t56 cad file
- Sc300 Speedo and RPM needles do not work
- 99 SC400 1/8 mile
- Idiot headlight bulb questions
- JZZ30 1JZGTE Help needed
- Lexus SC400 fuel leak under engine
- Door spkr box internal crossover?
- 92 sc400 cornering lamps, bulb choice, best practice etc.
- Cam seals
- 2JZGE help
- Question about my 1995 SC400
- Troubleshooting the climate control headunit?
- Driver footwell light LED conversion
- fuel line and return fuel line
- Leaking PS fluid after line change/iac delete
- 120 Amp Alt Fuse Blown
- Build suggestions.
- 5spd sc300 looking to replace water pump and timing belt, need suggestions
- Powerhouse Racing 1jz IACV
- SC400 W58 tranny swap build and price list
- 1995 SC400 Subwoofer Issue
- na-t questions
- Loss of Power, Bad Idle 92 SC400
- 120A Fuse
- Exhaust
- Replacement cam position sensors?
- Replacement Cam Position Sensors
- Top to bottem or side to side intercoolers discussion
- Cranks but won't start, no fuel. Ecu or pump?
- Temp Gauge wire
- 5 speed shifter bushings
- VVTI GE motors and blowby
- Cigarette lighter "ON" when ignition switched "OFF" . . . .
- Electrical Gremlins in SC400
- HELP..Ground strap Location
- Painting Polyurethan Parts
- 1995 SC400 with 67K miles. Time for Tune Up?
- 1995 SC400 Reading Codes
- Need help, codes can't be right
- Vibration SC400: Transmission Mounts?
- Aristo 2jz swap in a SC300 VVTI
- Sc300 am parts on sc400 fit?
- 1992 SC400 Reverse lights wire colors?
- IS300 E-Fans Conversion
- Center console lighting problem
- MPG Issue
- Steering Wheel Swap
- Valve or switch?
- Anyone want to walk me through a proper fuel pump ecu bypass?
- Sc400 Driveshaft on SC300
- Fujitsu of exhaust restrictive?
- Electrical HElp
- steering shaft question!?!?!
- '96 SC400 Aftermarket Tail Light Problem
- Troubleshooting Side Mirrors, Passenger Window not Working
- It wasn't my clutch ='(
- 1993 sc400 wont start
- An electrical gremlin has arrived...
- Suggested Adjustable Cam Settings?
- Who's running an AEM infinity 6/8/10 ?
- Weird issue with shifting
- VVTI engine with non VVTI auto trans
- Is this the right transmission output shaft seal?
- What cam/crank sub harness are direct swap with 92 SC400
- Fuse box contact ident help please
- Retrofit spoiler LEDs to non-LED 3rd brake wiring
- Timing/TPS question
- Will a supra harness work?
- What wire for reverse light?
- Surge idling and code 16
- Tires for 92 SC400
- 96 SC400 Tan Leather Stained, How Do I fix it?
- New SC300 owner
- Which Stock Stereo is Best/Easiest to Upgrade
- dual pumps stock rail and regulator question
- S2000 Seats install (On-Going)
- Where and how can I got proper hub centric rings?
- Different Foglight Problem
- MVP 2jzge headers, will they fit 99?
- how to remove drivers door arm rest
- 1jz
- Surge idling
- Orig plugs in my 94? BKR5EP-11
- Timing belt inspection/replacement - how do I?
- Retrofiting a newer Spoiler? Pics Included
- Interiors out, what parts are crack prone? Have epoxy will reinforce
- Looking for ideas on engine build: NA, stock
- Door hinges - is there a way to lube?
- Please help. Anything will do
- Bouncing Temp gauge needle
- Fuse box plug under hood
- Car accelerates hard after it hits ~2700 rpm - but not before - why?
- Window regulator 69802-24033 or 69802-24032?
- Car dies while driving, now won't start... thinking ECU?
- What sensor is this in the front of the SC?
- rack and pinion connector with aristo swap
- Heat Still Blowing Cold after Thermostat replacement
- AFC Neo question
- Aluminum parts seperation
- More control over your automatic transmission? (Theory behind AA80E madness)
- Fuel gauge issue? or sending unit?
- na-t map question
- 1.5jz build, what oil pump to use?
- How the f do you get the rear uca bushings off
- 2jzgte wiring what is on my harness???
- Vacuum hose
- 1995 lexus sc300 rougn idle / missing
- Crank but no start
- which pin/connector to run window up/down
- Header options for SC400
- 1993 sc400..lost of power
- Egr delete kit
- Check engine codes
- Which brand fuel pump? 94 SC300
- SC 400 Starter Motor Removal
- 96 SC300 Cluster lights issue, band-aid.
- Will knock sensor cel retard timing
- Battery Power drain on 95 SC 300
- SC 300 sitting since 2007
- How do you test antenna integrity?
- Need some help with my 1jzgte
- Help! Engine problems maybe can't figure it out
- Replacing SC300 OEM radios
- Please help me...
- Nakamichi stereo, no audio out for subwoofer
- Electric door locks malfunction on '95 SC300
- 94 Sc300 no power, white smoke.
- Windows do not work
- Engine swap from 94 to 99
- 92 SC400 aftermarket security system? Will I have problems?
- Fuel Pump and Headgastket Question
- 1UZ VVTi Upper Intake Removal
- SC300 idle issues and misfire throughout powerband
- Passenger window doesn't work..
- Idle issues (SC300) HELP.....
- 92 SC key and security system Q's
- Tuning up my '92 SC300
- Bulb failure light on with new LED's installed
- aem 30-6101 on na-t?
- The final fix--Power steering leak around pump
- climate control not working not fuses
- Automatic Transmission Throttle Cable swap.
- Stock HU/ 12 Disc CD changer repair
- Sc300 Check engine light came on after driving through some water on a rainy day
- Replacing Cluster
- stripping a parts car, what should I keep?
- basic engine mods for 4liter?
- 92 rear window cell phone antenna
- Engine bay lower splash guard Replacement?
- SC400 Paint oxidation - help
- Tips for turboing an existing engine?
- Blinker flashing very fast
- Diagnosis Fiends: Help me with this noise!
- Na-t W58 Clutches.... What do you run?
- Transmission question
- Code 12 and 14 No spark wont start
- 1993 SC 300 Cheapest Repairs help,
- Airbox Mod (good or bad?)
- Sc400 rough idle/stalling
- Trans swap
- battery size options
- auto transmission servicing
- Troubleshoot: Starter or Starter Contacts?
- Lexus SC400 Stuck Sunroof
- steering column
- 92 SC400 - Shocks & Amp help
- clock,radio and cigarette lighter don't turn off
- W58 Broken Shift Fork
- SC 300 Headache
- AC will not blow hot air.
- Treadstone cast manifold, anyone using one?
- New LED dash needles on '92 SC300
- Ideas and Thoughts on Sc400 not idling
- Transmission issue
- 1995 SC400 timing belt break due to water pump
- SC40 startup sound
- 1.5jz auto transmisson question
- Sc400 Issue
- Please help
- what do you think it could be!!?
- Sc400 squealing
- No Idle Issue
- Code 27, Sub O2 Sensor Signal
- Door Dome Light/Cluster Light on.. Doors are closed though?
- Help on speakers please!
- 2JZGTE Swap fan blade cheap solution
- Replacing Struts/Shocks
- Aftermarket stereo
- Another cluster repair question that may be different
- Crank pulley mounted supercharger
- MAJOR Starting issue! Please Help.
- sc300 1jz turbo lag issue
- Start and Stall
- Freaky Blinking Climate Control When Turn Signals On
- Quick easy question about SC400 Brakes...
- Manual to auto swap with aftermarket ecu
- 92 SC300 Stuck in park - Shift Lock Override NOT WORKING!
- Transmission problem: car won't get into gear
- Had Brake Failure in the SC3
- Climate Control/Heat always running?
- Possible A/T transmission emulator for 1998-2000 SC400 M/T swaps
- different mufflers
- 1jz/2jz non-vvti running MS3X? anyone have one?
- SC400 Auto Trans Question
- Manual 93 Sc clutch stuck engaged after drifitng a bit....
- Steering Banjo Bolt Torque
- SC 4th SOLENOID MOD IS STRAIGHT BS! (How I broke my tranny)
- Starting Issue
- oil catch can
- SC400 DIY Harmonic balancer spanner wrench
- Most cost effective way to manual swap SC400
- Swapped dash now a/c only works on full cold otherwise hot air
