- why does this happen?
- drift SC
- Ball Joints?
- Variable Steering?
- I'm confused about upgraded caliper clearance - how can I fit them?
- Replaced LCA's and rerouted the wire harness
- very weird
- Lifespan of Bushings, mounts, etc
- ABS... is it supposed to be that overeactive?
- will supra coilover fit the sc400?
- new shocks = alignment?
- TEIN basics installed
- Why No Factory 4 Piston Caliper???
- Holy hell... who needs BBK?!
- poor man suspension part 2
- Do I need new rear shocks?
- help clunking sound
- Need Help ASAP!
- OEM bushings
- How to stop/remove this?
- Cusco front STB installed
- Just got a new toy, but I'm a Lexus newbie
- Poor man suspension
- bushings
- First suspension install! Went great
- Rack and pinion?
- you guys think i should buy these tt brakes?
- Alignment; Still Pulls to the Right After
- Rubber piece in upper strut
- Help Probleme w/ brembo rotors
- Another Pup is born....twins lol
- alignment specs?
- In for alignment today, now I need parts and advice. Help please!
- stiffness on tein ss?
- whats the lowest i can go on ss?
- whats the best way to take off the shock bolt?
- If you are planning on adding Eibach springs...
- sc shaking
- Longer wheel studs/difference in spacers?
- Rattling noise.
- Anyone have a pic of Espelir springs installed?
- jic sc4/3 tie rods
- Does this pricing seem fair?
- Bushing change?
- Tramlining problem
- custer brake light????
- any one try the titan motorsports sway bar???
- Look What Fedex Brought Me Today
- Looking to buy Tein basics
- Need Suspension Advice...
- Will the suspension off a NA 89 Supra fit Sc's?
- Brake maybe Bushing Problem
- Wheel Shimmy Problem!
- Help... what suspension bushing is this? (pics)
- Alignment Issues
- Need help...which suspension to get?
- HELP!! Front suspension making grinding noises :sad:
- Living in San Francisco
- My LS400 Brake install
- $200 a fair price for installing springs/struts??
- never dropped
- wierd brake sound, please help
- where is the clicking sound coming from?
- Brake LS 400 Upgrade questions
- I Finally....Dropped my SC300
- Q about Daizen camber kit
- Brakes smoking?????
- lower springs worth it-do you guys have alota problems?
- car sits low in front driver side-lowering springs eatin tires!
- Cutting Springs
- daizen
- Alignment issues
- bleeding brakes?
- Tein Basics Installed w/Pics
- Supra Brake Question
- 2.5" drop w' TT rims and ties..OK?
- Harness Bar
- MKIV Suspension - Need help quick!!!!
- I must love my coupe... shheeeeesh!
- Need to make decision quick.. please help!!
- after LS brakes...
- Can you explain this statement to me?
- Big Brake Upgrade with 16" wheels - German SC400 engineering!
- Any SC Owners running a lot of negative camber?
- Need help w/ rear suspension part ID
- Can someone with stock ride height help me?
- so is it bad if...(there's "goop" comin out of the ball joint )
- Will GS Wheels clear Supra Brake Upgrade?
- 20" WHEELS
- Difficulty of removing LCA? Please help...
- metal hitting sound in brakes
- suggestions on shocks and springs choice
- trac acumulator bleeding (problem)
- Aggravating vibration, need help!!!!
- canovers????
- what a great day!
- New Eibachs vs 4 year old stock springs height?
- New ride
- SC400 Rotor Size Difference??
- help on rear trd sways...
- Rack & Pinion Asy / Steering Bracket
- Vlamos Bushings install in NYC
- ls braker conversion
- brake pads
- Wheel Fell off - Lug Bolts Snapped off
- Coilover reccomendations?
- tuner lugs?
- Rear Tires wear problem
- vllamos steering rack bushings
- clumping feeling when backing up
- question about strut replacement
- which calipers fit the sc300?!?
- Brake parts for 92 before I sell?
- Questions about Eibachs
- sc 400 steering problem
- planning to install trd sways this wknd.
- Spacers - Hub-centric worth it?
- Finally got some coilovers!
- Arg!!!! Is a suspension settling like this normal?
- Subframe mount install
- GS Strut Tower Bar on an SC
- BEST way to lower the car for 2"......
- Getting 19's but no $$ for drop
- Shaving TT brake calipers
- TT Springs on NA shocks??
- Anyone measure before & after big brake upgrade
- Results of spacers for big brake clearance?
- big brake done
- Calipers
- Tein Flex
- TT suspension upgrading... endlinks? bushings?
- UPS brought my SC some goodies today. (Supra brakes)
- Rear Brake Options
- do-luck sway bars
- Clicking in Front End when going Strait??
- TT Front Sway Bar
- Strut Tower spacer/washer
- The Ball Joint Dilemma
- KYB AGX and H&R's from MKIV TT
- installing front sway bars
- UPS truck came by today and...
- coilover perch ring and strut body ?'s (for anyone with coilovers)
- Eibach: Which spring for front/rear?
- Supra TT Caliper pins
- what is your coilover suspension setup?
- Any other parts of suspension that can be done?
- ANyone try EBC Red or Yellow Stuff pads on their SC?
- Brake Problem on the 300
- Brake pad options for LS400 calipers
- ls brake conversion
- Got TRD??
- where to get oem shocks & struts
- ls brakes
- TT Strut Mounts Compatibility
- Min Thickness Max Runout SC300 Rotors
- teins?
- help! cruise control and brake light malfunction
- Tein's or HKS?
- Brakes
- Does anyone know how much the stock SC rims of any year weigh?
- 97' SC400- Want Stock ride and stock springs-which Tokiko, HP or ?
- Loosing Control
- Ok, so I gave in.....
- edfc mounting
- Pics of my car after Espelir drop
- ABS Kicks in when wheel is turned all the way to righ/left???
- tien basics?
- 97-00 rear control arm bushings
- Another cross-drilled rotor question...
- I need your advice on my project car
- Daizen Sways Thickness?
- Springs?
- Moving SC 300 Fronts to Rear
- Sc Brakes
- jza70 sus.
- tein basic part no. for SC?
- Lowering Springs for SC400
- Daizen rear bushings
- Are supra TT rear sways suppose to be thinner than the stock SC sways?
- sc300 handling capabiltys?
- mikeloc24's suspension install meet *pics*
- autocross/track in tokicoHP/Espelir setup
- are these the endlinks needed?
- Need a nuckle for suspension
- how did you guys fit a supra sway bar on your car?
- supra brake conversion
- Tein coilovers
- Steering rack problem?
- knocking after tein install
- Important notice for those who want to use swaybars from the TT
- Would you guys get mad if I airbagged my sc3 5sp?
- Anybody using the Tien Super Street setup
- Tanabe Sustec Sways
- What is This??? Take this Steering Test and please reply here
- Can you show me?
- Daizen Front Camber Kit installed
- coilover or sways
- which supra wheels?
- Tanabe NF210 Springs???
- steering rack bushings...
- Tein Flex Coilover Question
- Installed Daizen Front LCA Bushing & Tokico Blues
- Suspension on Passenger Front higher than Driver's front
- want to see pics of tokico illumina setup
- Diazen Sway Settings?
- steering problems
- Trd Sways Or Tt Sways...
- pillow ball mounts
- lowest settings on coilovers
- Rubbing noise?
- How good is the Tokico illuminas struts/springs
- Tanabe Front Strut Bar
- Daizen bushing install
- Lowered with factory feel?
- Quick question about eibach prokit
- 93 vs. 97 Supra arms
- New toys for my SC4 for Christmas- pics
- Point of Supra LCA's
- do Supra REAR lower control arms fit?
- Could we get a Group Buy on Supra Lower Control Arms?
- Damper Setting for Tein Flex system?
- Bushings & Bushes. Whatever, mine are Bad!
- Looking for front struts for an SC300
- Need new Front Control Arm sleeves..
- Supra springs Tein S Tech
- need pics and advice on strut bar
- supra tt sway bar conversion (parts needed?)
- rear stru tower bar?
- Tired of squeaky brakes
- which suspension set up?
- manual rack
- Quick question about TT brakes
- Steering rack prices?
- my rear end sounds likes its loose...
- Could this be suspension problem?
- Front Shocks.
- My supension came today ..... YEAH!!!!
- confusion about wheel offset and camber
- Spring rates?
- JIC FLT-A2 Question
- knocking noise
- rebuilding shocks.
- Blitz suspension?
- Daizen Bushing Kit. Where can i get cheap?
- greddy strut tower bar
- Question on Suspension Setup..
- Supra Coilovers on SC?
- tokico kit question - please read
- Reverse Supra brake conversion? Loosing the TT 4pots?
- Conversion to Twin Turbo Spring Shock?
