View Full Version : Suspension and Brakes
- WTB Coilovers for SC300!
- Need your Suspension Expertise....GS300 - SC300
- put on some new wheels. hitting my fender
- Help with supra control arm install...
- front shocks/ struts install
- Brake issue
- eibach pro kit springs
- Master cylinder (abs deleted)
- I need help!!!!
- ***WANTED***Upper Pillow Tops / Camber Plates
- Can't do the LS400 or Supra brakes upgrade, what are my options?
- IS F front rotors
- LS400 brake upgrade for sc300
- swapping suspension?
- is this a suspension problem? noise while turning
- lower strut bushing?
- control arm bushings
- simple question for brake pad
- Got the KYBs Installed - HATE THE RIDE!
- SC400 Factory Alarm disable
- New tire + alignment, car shakes at high speed!!
- SC400 custom PS line specifications? (size, length etc)
- Slotted Rotors = short brake pad life?
- rear suspension banging
- alignment? help
- steering problem=( help anyone?
- Supra Control Arms?
- 2 questions...
- D2 coilovers
- TEIN CST adjustment
- Power Steering Flush
- Got New KYBs Coming...Anything Else I Might need??
- strange sound...=(
- Tire pressure loss
- Steering problem
- LS400 Brake pedal travel
- Uneven Suspension Settling
- Car Shakes when wheel turned to full lock
- Best shocks for the money, is this the best bet??
- Bbk Question
- Help with chossing the right lowering springs or coilovers for my sc300
- need advice - right rear wheel a bit loose
- spacer suggestion
- Monoblock Brakes
- LS400 Brake calipers
- 1997 sc300 front right lower control arm
- What are my brake options with the stock rims??
- replacing brake master cylinder after LS400 swap
- Espelir Active Super Down??
- na vs tt suspension
- Different kind of CA bushing
- brake pads
- coil overs?
- Stance coilovers!
- weird ride height problem???
- LS400 Brakes
- need brakes
- question on rubber bushing suspenion.....
- Riding Low on Driver's Side
- Need camber kit
- Need camber kit
- Spare Tire for BBK
- Tein SS coilovers???
- 1 piece front strut bar???
- help upper lca bolt froze
- TRD front tower bar
- Adjustable Struts???
- tokico blues and stock springs
- caliper cost
- edfc & TRD strut bar?
- tanabe springs, tokico struts on my Soarer
- Is there a diffence in size on the rear sway bar...
- NEED HELP GUYS, Supra Eibach and GAB struts installed..
- delete
- Erratic steering question, im stumped
- Finding Brakes for a 99 SC300
- biggest tire width on stock rim
- Just bought an sc300, Springs question
- got my HA'S
- Megan's SS and LP!
- new brake pads are humming loud
- IS to SC?
- Camber adjustment help
- Need Brake Rotor Input
- flush
- So, I took off the wheel to repalce a fuel filter, and find this on my shock
- Front end shake...maybe the rotors?
- Will Stock calipers (sc300) fit on TT Rotors?
- Front Brake Pads
- Rack and pinnion
- Difference between Supra NA & Supra TT Shocks/Springs?
- Opinions on R1 Rotors??
- tein ss drop
- Does anyone have these brakes?
- SC300 Rotors-Pads-Sources & DIY
- Rear suspension problem????
- Help need rear LOWER & UPPER cta bushing part #
- Snapped Rear Axle/right Upper Control Arm
- 1992 sc400 suspension torque specs
- 92 sc400 standard suspension height???
- how much drop w/o rub??
- Reason to get brake upgrade beside looks
- is this legit?
- Question on JDM Soarer Brakes
- sway bars
- Noob's Coilover DIY Sc300 Install
- stainless steel power steering line modification for SC's
- rotors and calipers
- Will OEM GS350 wheels fit over LS400 Brakes?
- big ? on is and sc???????
- ***Will an Tein CS for GS fit an SC?***
- Some suspension questions... ('97 sc400)
- Supra TRD Strut Tower Bar.....on SC400??
- Brembo Calipers from 350Z and G35
- minimum offset for supra brakes
- I need a rear wheel hub..
- Speed Bleeders
- spring & strut inquiry
- 97+ SC LCAs Swapable with Earlier LCAs?
- How much abuse can suspension parts/coilovers take?
- suspension question
- Espiler/KYB and excessive front camber
- need some advice on struts
- Stock Geometry settings for rear suspension
- Supra brakes
- need a lift (rear)
- Tein - Circuit Master Ra
- TT Rotor Caliper Clearance
- Which should I get first LCA's or Struts?
- Need HELP with my SC300 Brakes
- brake lock up
- HELP rack and pinion bushings
- shearched didnt find MKIV eibach pro kit with stock shocks
- Crack Head Deal... Brembo Brake Question ??
- Just installed Teins. Questions.
- Master Cylinder for my sc
- Rear LCA's life span?
- Trac Off Light Blinking
- Rear strut bar
- megan supra coilovers
- Changing rear wheel bearing soon....
- Stock springs with after market struts
- Just lowered 93 sc4!!
- 93 SC300 w/ Supra Shocks and Supra Sprint Springs
- spacer question
- Megan LP series Coilovers?
- Anyone know the STOCK spring rates?
- clunking after coilover install?
- BEST rotors / pads???
- loweering issue plz help
- want to lower, but not lose the comfort. any ideas??
- ball joint sc300
- Vlamos steering rack bushings
- 4 pot ls upgrade
- Finally lowered, Espelir and Tokico blues
- Springs and Strut suggestion?
- sc300 suspensions replace?
- Alignment?
- Offset and rubbing! Help before buying please
- clicking noise when taking off...
- What make and model struts came on the 97 SC300?
- Replacing Air Ride.. Help Needed
- want SC400 caliper options
- Rear Upper Control Arms
- Help: Mechanic suggesting Napa Sensa-Trac
- front control arm bushings problem
- stock shocks with lowering springs?
- Soarer Calipers?
- cross drilled/slotted rotors question?
- Lower drop...Megan Street LP or Tein SS??
- Whats that noise?
- something weird happened last night...
- i've searched. I read it before but I can't find it back.
- Tein stiffness knobs...
- Model year?? Re: SC400 Brake Booster and Master Cylinder
- Squeak when I start going forward or reverse
- Help me with Rotor Problems?
- I searched. Tell me about H&R Springs
- Supra or LS400 Brakes
- LS400 caliper bolt Part Number
- Search for suspenssion CANT FIND ANYTHING!!!!
- I need help removing tie rod end
- help needed: supsension, steering and brake problem
- Koni users please check in...
- Tein before/after pic
- Just had bearings replaced
- I need help installing ss brake lines
- Rubbers
- Quick Question about Supra suspension
- SC300 and Supra Front Shocks
- Another LS400 Brake thread
- HELP - broke something
- Alignment specs
- Anybody using Megan Racing Coilover for more than a year?
- Tokico Illumina Adjustable: What setting are you using?
- How do you know if you have supra or sc suspension?
- Your opinion on new company
- sc300 spring and shock combo advice
- brake problem?(long read)
- please post a pic of your eibach springs
- Blown Suspension?
- After brake fluid change my dash brake light goes on/off
- Looking for Stock Ride Characteristics...
- Anyone have a pic of an SC w/ Eibach's and AGX's?
- I need to vent: blown Megan coilover... under warranty, but still no replacement!!!
- Spring choice....
- Did the TT suspension swap today
- New rotors =) New problems =(
- Braking system Supra Turbo 93-98 at Lexus SС 300
- Best price on TT Eibachs...
- Quick question on wheel spacers..
- Sway bar bolt broke.... what now?
- Just installed new shocks and springs, have specific questions.
- Noob Question about Shocks and Struts
- Tein CST damper settings
- tt springs
- Supra MKIV sway bars in a SC
- Weird noise coming from rear when gas pedal is pushed....
- Will Supra BBK clear these rims?
- Another Brake Noise Thread...
- Susp. Gurus, an alignment mystery
- Another Gixxer-Drew Bilstein Hypercoil Review
- Older - Newer SC400 Suspension and Brakes?
- Rear Camper adjustment
- alignment/wheel balance question...
- suspension noise
- curbed rim, need alignment???
- Daizen Bushings
- Anyone with that Air Force coilover kit?
- rear strut bar?
- Lower control arm?
- hks hypermax
- who fits 18x12 in back on stock fender
- sc300 steering boot
- Does my car look lowered?
- Using the 2007 14 inch tundra brakes on a sc
- brake lines
- SC400 Sway Bars.
- Control Arm Supension
- Quick MKIV Suspension Question
- LS brakes 20+ offset?
- Hypermax II Coilovers (Best Pricing?)
- Installed my coilovers and...
- Stock Supra TT Shocks & Springs... how much lower?
- Pedal to the floor to stop
- Oem Lsd
- Supra chrome brake decal
- what's the worse than could happen
- Suspension question
- Brake question?
