PDA
View Full Version : NX - 1st Gen (2015-2021)
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
  1. Car throws an OBD code that doesn't exist! No power under acceleration
  2. DTC P125D Fuel Presure Relief Valve
  3. Troubleshooting Trunk Door Actuator
  4. Lexus Nx200t 2015 infotainment problem
  5. TPMS After Rotation
  6. Rough ride
  7. Is that much of a rust a problem?
  8. 10.25inch Carplay Screen for Lexus NX models with Android 13.0 system
  9. Brake master cylinder part number
  10. Tire sizes
  11. Coolant change
  12. 2015 NX300H tailgate won’t close, button pressing only creates a beep
  13. tire
  14. 2016 Lexus NX200 2.0L cranks but doesn’t start? Fuel pump?
  15. Unknown broken part from driver side power seat
  16. Replaced water pump on 2016 Lexus NX200 2.0L, how do I fill the radiator?
  17. Lexus 300h Towing Questions
  18. What is the Best NX Seat Color for Families with Kids?
  19. Shifter moves freely
  20. 2018 NX 300 Sport
  21. The trouble with Mark Levinson
  22. Fuel door not closing properly
  23. Nx 300h 2018 passenger light question
  24. A/c and heat problems
  25. Lexus OEM Extended Warranty Question
  26. Multimedia upgrade NX 2018 for android auto
  27. NX300 2018 high pressure full pump recall
  28. 2019 NX300h mileage 75K gas mileage, what is your full tank mileage (summer/winter)
  29. Led front emblem nx300 fsport
  30. Keyless fob / keyless entry system
  31. How can I tell if my airbags have ever deployed
  32. AM Radio Stations Not Working
  33. oil change frequency now 6 months?
  34. Backup camera cleaner for Lexus NX
  35. 2019 Lexus NX 300 Navigation
  36. Stupid question-Battery replacement
  37. Trouble with alignment
  38. Maps download
  39. NX300h Thump Sound with Gas Tank is Full
  40. Wheel locks? Were they factory included?
  41. Need to change differential fluids around every 30,000mi
  42. 9th year in and just found out
  43. Nx300 Tonneau Cover Parts
  44. Auto headlights quit working
  45. Refitting the A pillar cover
  46. NX 300 (2015) and replacement hybrid battery
  47. Rear Tailgate Power Liftgate Support Strut Shocks for Lexus NX200t
  48. NX 200t missing buttons
  49. OEM Tire Replacement
  50. 2015 nx200t horn fuse
  51. Chrome delete St. Louis
  52. Connecting to high-beam signal
  53. BSM Reset
  54. Hard wired dashcam installation
  55. WTD: Replacement NX Center Console Arm Rest Black/Red
  56. Hps turbo resonator + hps charge pipe
  57. Gasket leak?
  58. Tightening bolts at drive shafts
  59. Any one use a Carlinkit 5.0 with their NX?
  60. new NX
  61. Automatic Headlight
  62. Backup camera
  63. Tires
  64. DCM Issue - Replacement necessary?
  65. Blind Spot Malfunction
  66. Paint damage on tailgate
  67. TPMS will no longer recalibrate
  68. NX200T track driving
  69. P0136 code - O2 sensor- bank 1 sensor 2 location
  70. SVC light on with (Hold On) Button flashing
  71. Parking Sensors retrofit in NX
  72. Navigation app lost connection
  73. NX200T Mountain road driving
  74. Replacement tire advice
  75. Vibration between 25 and 35 MPH
  76. NX 2020 F Sport High Pitch Pop (noise) upon start up
  77. CarPlay Recommendations for 2017 NX200T?
  78. Adaptive radar cruise control question
  79. NX300 widshield washer
  80. Reduce Engine Power 42k after changing spark plugs
  81. nx300 F Sport grill on nx300h
  82. 1st Gen Lexus NX 300 dash cam
  83. Black trim on NX300 melting
  84. NX200T locking on its own with fob in car
  85. installing padle shifter on NX300h 2015
  86. Are Toyota OEM wiper inserts the same as the Lexus version?
  87. NX2015 - Luxury Varient
  88. 12v Power When NX is Parked
  89. turbo boost pressure valve solenoid
  90. Lexus NX200t F Sport Front Bumper Conversion, is it Possible?
  91. Tire Size Advice
  92. Centre arm rest
  93. Dented my 2019 Lexus NX 350h
  94. Will insurance total my NX?
  95. Totaled NX?
  96. Lexus GS wheels on NX?
  97. Battery drain - ECU-B No.2
  98. Lexus NX300H Brake & ABS Module Bleeding Procedure
  99. Vibration when braking
  100. close (back door) and lock - what I do wrong
  101. Radio Infotainment in Reboot mode.
  102. Lock doors with trunk open
  103. 2015 1st gen Lexus NX 200t engine or transmission issue
  104. Key hole missing
  105. Coolant shelf life
  106. 2019 NX300h bjs tire center service - scratch rim
  107. Lexus NX300H 2017 Workshop Manual & Electrical Wiring Diagram
  108. Heads Up Display Adjustment
  109. 2020 NX300 10 Speaker System Upgrade
  110. Lexus NX300h 2017 - 4 or 5 core cable
  111. 2015 Nx200T Backdoor Stops at 1ft Open
  112. Creaking sound when applying the hand electric brake
  113. Driver side door mirror Broke off HELP
  114. intercoolant coolant change
  115. 2019 NX300h brakes and rotors replacement
  116. Shaking Engine and noise
  117. Price Check on used NX300h
  118. Turbo intercooler coolant change instructions
  119. Gas grade for 2019 NX
  120. Noob nag screen question - is there easy way to turn off nav screen display?
  121. 2017 Nx200t transmission Solenoid replacement
  122. Tpms
  123. Location of AC evaporator coil
  124. Replacing Right Tail Light Assembly, 2019 NX 300h
  125. More towing threads
  126. BSM Light in Mirror Stays On (Passenger Side)
  127. Road noise
  128. Suing a Lexus Dealer?
  129. Aftermarket or DYI adaptive cruise control challenge
  130. 2018 NX300 OEM roof crossbars distance
  131. Does it have AVS?
  132. 2015-2021 NX reliability
  133. What is this thing in my dash????
  134. Anyone installed an auto windows raising module in their first gen 2015 Lexus NX200t?
  135. 2017 NX 200t Replacing lift gate chrome strip
  136. Dealerships says engine needs to be removed for Fuel injectors
  137. Stateside NX suggestions
  138. Front brakes clicking in reverse
  139. 2019 NX Lexus Dynamic Map Navigation
  140. '16 200t needed Water Pump, only 54k Miles
  141. NX200T Oil Leak (not front or rear cam seal?)
  142. Continuous 12v in the front doors?
  143. Frustration with proving ownership
  144. OEM Brake Rotors or Aftermarket?
  145. Power fold DYI mod for 2015 Lexus nx 200t
  146. Doors auto locking randomly after oil change?
  147. Moonroof adjustment? Not sealing right
  148. Estimated repair for the rear plastic bumper?
  149. Towing Hook
  150. Lexus nx300h (F SPORT 3 beam) headlight upgrade
  151. Looking for more horsepower
  152. Question about Weather + Traffic
  153. RIM Touch-up Paint for F Sport
  154. How to Change the back Door Tweeter Speaker?
  155. Cross traffic Alert
  156. Possible NX300h prepurchase Questions
  157. Liftgate motor kit for NX300 that never had one?
  158. Which wheelchair fits in trunk of NX?
  159. Swapped the plastic oil filter housing to metal (pics)
  160. Drivers door panel removal - 2018 NX300
  161. How long does your NX OEM battery last
  162. Marks on interior doors
  163. Help identifying a Lexus model
  164. My 2021 Lexus NX Started itself
  165. Remove front license plate bracket?
  166. Android Auto for cars with Carplay only
  167. Base DRL to Enhanced DRL -- DIY?
  168. Stereo area smelled like smoke, lost power
  169. Gen 10 Multimedia to Gen 11 possible?
  170. USB ports not working- power outlet works
  171. 2017 NX - Brake Fluid Replacement Interval?
  172. NX Parking brake Malfunctions
  173. 2017 NX - P0303 cylinder 3 misfire, fault ignition coil?
  174. Slight ticking noise before engine is warmed up
  175. 2020 NX carplay
  176. Wheel color
  177. Torque Specs: WP, Idler, and Tensioner
  178. SD Card Navigation doesn't work
  179. Error P0456 - Only when it's cold
  180. Question about CPO and independent shops.
  181. Independent Lexus shop in SoCal- Valencia, Santa Clarita, SFV area
  182. Anyone Replaced the Alternator? NX200t 2015
  183. NX upgrad apple Carplay&andriod auto
  184. Voice to text on 2020 NX stopped working
  185. Voice to text on 2020 stopped working
  186. 2020 NX Voice to Text stopped working
  187. Potential new owner
  188. Air ride question/request
  189. Radio and Infotainment Not Working After Battery Replacement
  190. Cover under car
  191. Transmission shift quality question
  192. 2018 NX brakes failed
  193. Will the NX do 200k?
  194. Bumper ends
  195. JDM 2018 Lexus NX300 DRL
  196. OEM part price differences from dealer-to-dealer
  197. NX300 Headliner
  198. Gas/oil smell from vents
  199. Brake upgrade NX300 2021
  200. 2019 nx300h premium
  201. Lexus NX 2021 Model
  202. Locking the car doesnt beep or flash
  203. Tire recommendation for 2020 NX300?
  204. Radio turns on but no sound
  205. Is there a preferred model year
  206. Low Key Battery Warning in Dash
  207. Low highway mileage
  208. Can I change my front bumper to the newest model,
  209. 2018 NX Canadian Version
  210. Leak from Pillar trim while in car wash
  211. Shopping for new tires - Looking for recommendations!
  212. Low Frequency Sound 1000-1250RPMs Underneath the car
  213. New Wheels , Lip Skirt installed
  214. Help - What’s wrong with my side mirror
  215. Front camera black "V"
  216. Another Oil Change Question - Lexus NX300 2020
  217. Dash Camera
  218. 2020 NX TPSM Issue
  219. Car unlocking itself by bringing key near
  220. Leaking oil
  221. Android Auto audio cuts out constantly
  222. Cigar lighter fuse location
  223. Noise from luggage cover and back door 2015
  224. 2016 NX300h Pre Purchase Questions
  225. 2020 Malfunction in the Electronic control Engine, Throttle or Automatic Transimssion
  226. Oil Change Interval/ Spark Plugs on used 200t
  227. MPC remote start 2016 200NXt
  228. NX300 Interior Leaking
  229. 2015 lexus nx - water pump replacement instructions or videos?
  230. Lights on dash
  231. Fumoto Oil Drain Valve
  232. Right marker light not working, DRLs work
  233. No Washer Fluid front windshield only
  234. Anyone have factory service or repair manual for 2020 lexus nx300
  235. Lexus NX300 2021r. Canada - error U0182 Help!!
  236. Extended warranty
  237. Shaky Drivers Side View Mirror
  238. How to read Parts Manual?
  239. 2021 NX 300 - Replace Antenna Assembly and Fin
  240. pk389-78j00-tr rear mud flap instructions
  241. NX300h USB stopped working (2018)
  242. Usb port not working
  243. Trunk light voltage ( to install more powerful led light)
  244. Why there is a need for a "breathing hole"?
  245. NX 350H Color Concerns
  246. Two simple questions
  247. Trickle charge 12v battery
  248. "NuLuxe" seats cracking - under warranty?
  249. Struts and Shocks.
  250. Need Some Input from NX owners
