- Check Engine Light
- 2017 IS300 F Sport Auto Dimming Mirrors?
- Wierd sound when starting the engine
- 2018 IS300 F Sport
- 2017 IS300 - YZZA1 or YZZA5 ?
- Car prep for Coast to Coast trip - painter's tape
- To which fuse should you wire a dash cam?
- Random Warning Lights
- Looking for carbon fiber lip non F sport
- Nav screen dots
- Where to buy TRD Lexus parts in USA
- Brakes making clinching sound when letting off brakes - 2014 is 350
- Headlight flares
- New Rim/Tires... Already damaged. FML.
- Proud Owner
- CF Spoiler Fitment Issues
- Anyone using a trickle charger? more battery drain woes on my 14
- 2018 IS350 AWD Wheel Options?
- Finally!!!
- Winter Wheel Setup
- Moonroof leaking
- Manual anyone?
- Resonator or Second Cats Delete?
- Exhaust Help
- Tire and wheel question.
- Headlight question
- Swapping out rear view mirror with RC350 rear view mirror
- first time i had this pop up on my dash, do anyone know what this means?
- Piece of my Headlight Fell Off
- Tire Oppinions - All Season
- Front Badge 5D LED
- Taking Lexus wheels off
- Seat position after/before switching on
- DIY oil change surprise
- Tip: Disable 'animation' through your dash settings to greatly speed up the UI
- Stock 2014 - IS 350 (Baseline Dyno Run)
- iPhone Bluetooth Connectivity
- Time to Change FRONT Pads/Rotors?
- Bottle holes cover
- Turning off seat belt chime on 2017 IS300
- Music / Phone Call issue
- 2015 IS 250 Oil Change cost at dealer?
- Replacing 2015 nav system with nextgen
- Maintenance required soon
- Change language for the main cluster interface
- Should I buy a 2014 is250?
- Gear vs Speed
- Body Flex?
- Work Kiwami Setup??
- Lexus 3IS stock brake pad sources, part numbers, and tips!
- All doors not unlocking?
- Mudflaps
- Vinyl Repair for doors? Need some advice
- Tuning Options for the IS250?
- Has anyone put these side splitters on their IS 2017?
- Lowering questions
- Looking for a used 2014 IS350: what are must have options?
- Inner tire wear (picture)
- Purchase a CPO 2015 CT200h or lease a 2018 IS 300 F sport
- Potential damage from poor roads
- Daesboard Cover User !!!
- Ideal fitment with RSR Downs ?
- Dash speaker replacement on my 18 IS300F
- Tires
- 14 IS250 F-Sport seems sluggish?
- Lexus IS350 Supercharged +500 HP
- Key hole mod
- UK is300h front number plate bracket removal.
- Went up against a Dodge Challenger v6?
- What brand lightning cable do you use for iPhone? Keep getting disconnected driving
- 2018 IS F-Sport puddle light problems
- Interior Dust
- 2014 is 350 f sport- static sounds from radio
- Question: 2017 is300 Fsport Series 2
- 2014 is350 F sport awd - bad mileage
- Lexus floor mat
- Potential Buyer
- Mod chip
- A pothole ripped my sidewall...help
- Rotors and Brakes Question
- Is this a good deal on a 2018 IS300 F sport lease?
- New is300 owner with questions.
- Lexus IS color matched lip splitter.
- My salary literally just tripled...how much Lexus should I buy?
- front wheel arch height
- Apple/Android CarPlay
- Slight trunk rust on edge of trunk IS 250 3rd gen
- Cabin air filter replacement 2014 is
- Anyone running this tire size?
- Rear-ended on highway; chances of frame damage?
- My car got dinged by someone while parked
- Mark Levinson Sound Quality
- Panel removal
- Under body scratched with parking entrance hump! need the cover part number
- Black on Black or Black on Carbon Fiber
- Got into a fender bender
- RPM Meter and Folding Mirrors
- just got my new Lexus IS300H
- Condensation
- Rear speaker deck vibration with subwoofer
- Exhaust fumes smell / Soot on Steering column on '14 IS350
- Transmission
- Roav C1 Dash Cam Install - Suggestions/help!
- Lexus Branded Dash Camera Available in Canada
- 2018 is 300
- Battery and Settings
- 6K LED Headlights for 2016 IS300 FSport
- OBD Fusion and PDI ... tips and tricks?
- Regrets but it's too late.
- No Volume From Speakers
- 3IS IS250 Muffler Delete
- Adding FSport and IS350 Emblems After Shave?
- rim damage from wheel cleaner
- Panel removal
- 2014 IS250 F Sport - Tires
- Hybrid or petrol Usage
- aftermarket wheels on stock suspension
- Suspension IS350 Executive vs IS350 Sport
- Lexus RCF bumper on IS
- Sunglasses holder
- When do you get oil change / transmission fluid change?
- Another battery DEAD!
- Touch Up Paint for 18 inch Non-F Sport Rims
- Curb rash fixup
- Ftp charge pipe
- Driver's Actuator
- Part numbers for all the little bumper clips, tabs, etc
- Door handle key hole remove
- Making additional 2 holes for license plate frame?
- Whats up new fam!
- Real(?) RC F V8 Engine Swap in IS 250 (Instagram Page)
- Sound System
- Would like some help deciding if I should or not?
- Why can't I keep my map visible while on a phone call?
- 200t Piggy back tune recommendations
- is300h 12V Battery tray
- Cleaning trim around front grill
- Who has used their extended warranty and for what?
- Looking for a used F-Sport wheel in Dallas, TX
- Glass/Window cleaning?
- New front tires for IS 350 FSPORT 2016.
- Creaking popping
- tire pressure
- I miss seeing this IS!
- Coming over from the other side
- 2is fsport on exhaust on the 3is
- Drive Mode - Temporary Shift Range
- Does any know any good front end lip for the IS
- Stealth Hitches. Atlanta car owners look here
- RWD question
- RSR lowering springs
- Mini Shoot at Lakeridge Lexus
- Tire Flaps?
- Coolant Leak
- Air Oil Seperator
- 19x9.5+35 F and 19x10.5+45 R
- Snapped some quick pics with this morning
- Is 400
- IS350 vs Dodge Charger Race video
- F Sport Instrument Cluster Poll
- Intake
- Acceleration problems
- new 2018 is350f sport nebula gray/new member
- 2017 IS 300/350 F-sport packages
- HomeLink Garage Programming
- 2018 Lexus 300is F TMPS ID Code Registration
- 3IS Simple/"Dumb" Questions Thread - Ask away and get answers!
- Tires and rims for winter? Possible square setup?
- Is it worth it?
- Traction control off
- What brand of fuel are you using?
- Trunk spring
- HD Radio - GPS traffic in Canada
- BIg Brake Kit. Is it worth the money?
- shifter lens
- Reliability of IS350 engine and transmission
- New Car
- Window Visor
- Carbon Fiber Dip?
- New rims for 2014 lexus is350 awd
- Switch for engine Sound Generator?
- Lexus TRD body damper quick review (rear)
- Converting 7” to 10” Display + Radio/Center Console Upgrade
- Navigation Loop, Help Please!!!
- Does 2010 IS250 AWD Rotors fit 3rd Gen IS350 AWD F-sport ?
- A/C Leak From Under Dash
- Spoiler install template
- LEXUS, year 2013. without navigation
- Multimedia system reboot
- Bumper clip
- 2014 Lexus side mirror inner housing cracked
- In the market for a 3rd Gen IS: what did you pay?
- OEM Bridgestone to Michelin Pilot Sport Tire Pull
- IS250 Sqeaking Steering Whee (Hood Latch ?)
- Maintenance Required Light
- MV Tuning Spoiler
- How to check for mold and mildew
- Nuluxe crease on driver side seat
- 2018 5 HP Increase
- Dealer loaner felt faster, more responsive 2016 vs 2017
- Trunk hinges
- What is the small Square ?
- Exhaust tips too hidden
- Tires for 2015 Lexus IS250
- Girlfriend wants an IS 3rd Gen
- Smart Key Replacement
- Issues with Lexus Dealership not solving my issues
- Anyone ever go up a tire size on their rear F Sport 18" wheels? 265 35 18?
- Forum Member arentz07 Reviews His IS300 F Sport
- Stereo ID#
- Upgraded my Lexus IS with LX570 parts!
- Bigger wheels on Lexus IS 250 base model
- Dash Panel Removal Question
- Subwoofer Amp combo that is not too obnoxious?
- Any input on these?
- instrument cluster
- tire sizes on 19x9 w/ no drop
- gauge read out
- F-sport badging option in the interior
- Air Suspension (3P) Mounts with Nav
- Coilover Spring Rate Help
- Possible to add blind spot oe mirror with sensors?
- Touch-up paint on rock chips?
- 3GIS question, regarding low beam, led or hid?
- Lexus IS front splitter
- 2014 is250 grill swap
- Stereo Replacement
- Installed RSR Down Sus - Help with spacers please
- Radio speakers suck
- Beatsonic + Apple Carplay / GROM VLine 2
- Car possessed?
- Bagged IS Vs Static IS
- Is200t
- What is this?
- check out this Lexus IS with Eyelids!!
- Digital Clock Mod?
- Electrical HELP! Installing GS-100A Strobe Brakelight
- 2018 IS 300 F-Sport Seat Defect (Red)
- Wrap vs paint
- Looking into 2014 IS350 AWD - Question on F-Sport Package
- Can I replace my IS200T non Navigation sceeen for the bigger 2017 one
- Why do our OEM tires perform bad but are so expensive?? Help finding a replacement!
- 2014 IS350 Bumper Swap
- How to enable av input in motion lexus nx 300h
- tail light tinted
- Lexus F keychain
- Led reflector help
- 2017 IS350 F Sport Price Question
- 2016 is300 fsport looking for info
- Not the classifieds
