View Full Version : Suspension
- 4 allignments in 2 years?
- Best springs for MINIMAL drop
- Factory alignment specs for GS450h 2020
- Steering wheel popping noise/clicking noise
- Side to side bounce - 2018 GS 350 F Sport
- Help with purchasing rear shocks replacement
- Rear Toe and Rear Upper Control Arm Bolts
- 2014 GS350 F sport AWD rear camber arms
- Is350 rsr sports i coils on 13 gs350
- 2015 GS 350 F-Sport Lowered on Coils
- Gs coilover suggestions ?
- Strut mount replacement
- Clunking noise
- Awd lowering springs on rwd
- Can't locate clunking noise
- Best coilovers that are close to stock feel
- 2013 GS350 AWD rear wheel bearing replacement
- CV axle - 2014 GS350
- Coilovers
- Need help with hub to fender heights
- RSR Basic-i Coilover Shock Longevity
- Slight Vibration in steering wheel
- 120K Service
- Strut bar fore base gs
- 2013 AWD GS LUX - Need TEIN street coil part #
- Did Coilovers Fix/Reduce this problem for you?
- Suspension advice needed
- Rear Shock - AVS or Regular
- VGRS System error
- Megan Racing Front Strut Bar
- Stabilizer bar end links
- AWD front springs. Easy way- how I installed springs.
- Swift Springs Rake, lower in back Problem??
- Strut bar story. Ultra racing
- What performance mods are available for base suspension without lowering car?
- Requesting Help Identifying a Clinking Sound
- Front & Rear Strut bar: Ultra Racing & Tom's Install
- Rear Sway Bar Install - 9hrs?
- gs450h dead shot avs shocks what are my options?
- Swift Springs fully settled & 20mm spacing all around
- Swift Springs installed, need camber kit?
- Coilover options for 2014 gs350 non Fsport
- The turn signal of Lexus gs250 can't turn off automatically after turning.
- 2015 GS350 AWD Swift Springs
- Can coilovers or air suspension kit improve the stock ride comfort?
- Shinigami Air Rear Bags Rubbing
- KYB rear strut for 2013 AWD
- anyone have any input on airtekk struts??
- which air shock/strut will be best overall ride comfort
- Yet Another Lowering Thread - ‘13 AWD F-Sport
- Sway bar
- aftermarket struts and shocks for 4th Gen gs RWD
- Airlift Suspension Questions…
- Rear sway bar end links too long
- 2018 GS350 F Sport Coilovers
- ES rims fix on GS 300h?
- GS350 Springs back to stock height
- Swift vs Tanabe
- Intermittent clunking in the front suspension.
- Swift, RSR, Tanabe, Other?
- Control arm bushing
- Suspension torque specs
- 19" Wheels with a 40 Offset?
- Lowering 2013 GS350 F-Sport AWD
- GS350 AWD F 2014 - Rear shock bottom bolts
- Has anyone tried BC Racing coilovers with Swift spring upgrade?
- Purchasing a 2013 GS350 RWD FSport. Some help and advice please!
- AWD vs. RWD Front Suspension Differences
- Coil to Bag Conversion for BC Racing
- BC Racing Extreme Low Vs Regular for Air Suspension
- Gs needs to be lowered
- HELP!!! CX RACING Coilovers
- CKS vs SWIFT coils
- Suspension crossmember
- installed: UR/Toms front/rear upper/lower chassis bracing - pics and review
- Oscillating Vibration at 75+
- Q50 lowering springs on my 4gs
- RSR Superdown and shock life?
- Bad alignment. Pulls to the right
- GS450h & GS350 RWD OEM Ride Height Meaurements
- Spacers question for GS 350 F-Sport RWD owners
- 2015 GS 350 F, vibration
- Ultra racing front strut brace
- 2014 gs350 RWD F sport Rear struts
- Suspension Help!
- Front Bumper Parking Sensors
- RSR Besti coilovers paired with Swift springs
- Anyone with non-F-Sport AWD?
- When to replace suspension?
- Swift Springs (4T911) on 2020 GS
- Coilover Spring Rates
- Question about Stock Struts with Lowering Springs
- yaw calibration after alignment and swift springs
- Strut Replacement
- Replacement OEM Shocks
- RSR Superdown Springs install
- What option should I go with? Shocks/Struts or Coilovers?
- Strut tower brace with AVS modules?
- Front upper control arms
- Godspeed rear camber arms
- Toe ?
- Opinions on the impact of Tanabes on stock shocks
- Shocks?
- Tires
- What is the most comfortable lowering option?
- 2016 GS350 Swift Springs need camber kit for even tire wear?
- Initial RS-R coilover settings for AWD?
- RS-R I-Basic Active Coilovers
- What is the best suspension upgrade available for 2015 GS F Sport AWD
- Camber kits.
- 350 coilovers fit the 450h, correct?
- 2016+ GS help!!
- Weird Noise after RSR DOWN springs
- Gs350 way too high please help
- Shop Recommendation
- DIY Airlift Suspension Install
- Air Suspension Install Questions
- Suspension pop
- Air suspension tanks!!!
- Best Coilover setups for the AWD F-sport?
- Spring Rates and Approximate Drop
- Coils for daily driven fsport
- Lowering Springs for 2019 GS350 FSport
- Fender liner clearance after lowering
- 2013 GS350 Suspension issues
- Suspension
- Aftermarket shocks for 13 GS350 Fsport
- Coil Overs but...
- Question about suspension
- Have you lowered a GS450h?
- Help installing SPC rear Camber arms
- Drop an AWD is bad?
- Swift vs RSR Down
- Air Suspension Trunk set up
- Swift 4T911 for GS450h
- Questions on upgrading rear calipers on 16 4gs awd
- AirLift Questions
- No FS in discussion thread
- Shock Advice '13 F-Sport AWD
- Lowering and Adaptive Variable Suspension
- Wheel spacers for 17' GS 350 F Sport RWD
- 15 fsport GS 350 rattling noise from back rear & weird groaning noise when I turn
- Popping sound in suspension
- Tire wear on Tanabe Springs QUESTION?
- 2015 GS 350 F Sport Alignment
- Airlift 3P and cup kit
- Megan vs BC coilovers
- Caster bushing anyone?
- AWD 2015 F-Sport --Tanabe or RS-R?
- Rear camber arm questions
- Great Coil-Over Explanation Video with Eibach GM
- 4gs Tanabe springs question
- CKS coils or RSR coilovers?
- accuair elevel management with height sensors
- Any AWD camber kit?
- AWS & 19” vs Standard & 18”
- Where to buy J5 suspension kit or similar to GS450H
- Springs from RWD F-Sport on AWD F-Sport?
- 2018 Lexus GS 350 F Sport
- Vossen 20" wheels maximum for 4GS when lowered
- GS450H lowered on RSR down
- Modding a 2019 GS350 F-Sport
- Tanabe springs AWD?
- Front LCA Bushing Question
- D2 racing rs series coilovers
- KYB Extage Kit Reviews?
- Soon to be owner with air ride questions
- LSD differential for 4GS?
- Those who are bagged...
- 2013 GS350 AWD (4GS) front upper ball joints
- Will strut bars (front and undercarriage) void my warranty from Lexus?
- ‘18 F Sport...Just lowered on RS-R Down
- Tein flex avs
- Defective struts
- Are You Sure About Wanting Stiffer Springs?
- RSR I coilover install instructions
- Tanabe NF210 on stock shocks
- lowered springs on hybrid ??
- 4GS grill/bumper to 5GS grill/bumper
- Installed some.goodies
- Installed Megan Racing Coilovers, Need Help
- Platinum VIP
- Can anyone help?
- Tower Strut Nut Torque
- Super downs or Tanabe?
- Dealership Obligated to Return Old Part?
- Struts - Tanabe vs Ultra Racing
- bags and stock wheels
- Tireds and RR LCA bushing
- Sway Bars, Bushings & End Links
- RSR AVS controlled Coilovers
- Coil overs and deleting the strut adjustment motors?
- Weird Noise from suspension? 2015 GS350 F Sport
- Cup Kits Anyone? (4GS)
- Firmer than stock
- Tire Wear issues even after adj camber arms
- MXM4 vs Pilot Sport 4S for a 2105 GS 350 F Sport?
- Height issues on GS450h
- Gs350 AWD F SPORT springs and wheel set up
- Stabilizer bushings on Lexus Gs350
- Excessive Tire Wear
- Maximum pressure for air bags?
- Issues when wheel's turned completely on 13 GS350 F Sport
- Avs noise after coil over install
- Raising height of rears coilovers
- oem suspension parts
- Rear Sway Bar
- Any scoop on the running change for F-Sport Rotors?
- My thoughts on Tanabe NF210's
- Question: 2014 gs f-sport shocks option
- On coilovers? how do you guys disable the AVS light?
- Tanabe Lowering Springs
- For those on bags
- RS*R Superdowns uneven...
- Lowering suspension
- HELPP! Rear Air suspension bags hitting control arms..
- Wheel spacers on '15 F Sport
- Camber kit - do I need front and rear?
- RSR coilover rebuild
- Rear chrome muffler cover
- Regarding suspension upgrade...
- Thoughts on RR Racing LCA Bushing
- Ballpark range of spring install?
- Torque specs for front Upper Control Arm (UCA)
- Lowered on RSR super downs and scraping
- FS threads go only in the classifieds, not here
- Is rubbing normal on NF210s?
- Anyone done air on a 450h?
- Suggestions of Springs for a 2017 GS350 F-Sport
- Rear Shock-absorbers IDs
- 2015 GS350 F-Sport AWD Lowering Springs & Tower Strut Bar Compatibility
- 2014 gs 350 f sport newbie with lowering
- Newbie question about springs
- Aftermarket shocks/struts possibly?
- Front right tire molding loose
- Rsr Super Down springs
- ULTIMATE Tanabe Vs RS-R
- BC Coilovers with Swift Springs
- Swift lowering springs question
- Any good Alignment places in So Cal?
- Tanabe Springs & New tires (pics)
- Is lowering the car with coilovers worth losing AVS?
- Rear sway bar links
- 2013 GS350 - BC coilovers, UAS bags, Airlift 3P
- Work Wheels - VSXX Fitment / Air Suspension
- Front shocks blown @ 49,952
- Clunking coming from the rear of my GS350
- GSF rear sway bar swap?
- 4GS - Bagged or Static and What Happens to the Sport Modes
