- 2016 GS350 oem wheels, are they hub centric?
- Tire Pressure Monitor System (TPMS)
- Michelin Tires: Climate 2 vs Pilot Sport S
- Anyone running 35 series instead of 40 series on Oem 19” fsports (in front)
- What would you change about your GS?
- Help finding replacement parts of my GS 350
- Dealer holding my car for week+ for oil change and CSSP for the servo
- Have a problem: In Winter: feels like I have to press brake deep for clamping force
- To make GS350 go 300k mile, Expert has list of regular fluids: trans/steering/coolant
- What do you want or did you get after GS 4th gen?
- Any good autobody shops in Arizona?
- 255/40/19 All Season Pirelli Tires
- GS 350 vibration
- GS 350 AWD Inner Tie Rods
- Climate Control Error
- Spark plug change at 170k: How are my plugs?
- 2015 gs350 or 2019 es350 f sport?
- Squealing breaks!!
- Aftermarket headlights for 2013-2015 gs?
- Why does my 2018 350 fsport talk to me all the time?
- problem with GPS being far from location
- how to remove center console cover?
- can't pass smog, unable to connect to odb
- Pastic Steering Column Cover Removal?
- Do you need all suspention car parts to be torque wrenched?
- 235/50-18" Pirelli P7 all season plus 3
- All weather trunk tray
- New to custom wheels set up and ET
- What’s this front trim piece called and how do I remove it?
- Factory Navi in non-nav car? And other infotainment questions
- Longevity Q: Will a 2016/2019 Highlander last as long as a 2015 GS350? (salty roads)
- Passenger door needs 2 pulls to open
- Tear in front passenger side seat bottom
- Update on car, more suspension mods.
- Just found Club Lexus!
- 13 gs350 awd
- Can someone recommend a bolt-on rear caliper upgrade ?
- Weird experience - shifter? tranny? fluke?
- Headlight triple leds problem
- Modification: Adding Lumbar and Heat to Rear Luxury Package Seats
- How long my brake pipes will last, they doesnt look good please advice?
- How to test AVS suspention is there any way at all?
- Are PPE headers worth it?
- Rear Tailights - What does each wiring color mean? Confusion.
- How is the PPE Headers?
- 2015 gs350 tempature sending sensor location??
- Gremlins....?
- 2015 gs350 crankshaft position sensor location??
- Electronic parking brake help needed
- smallest wheel size for a 2013 base rwd lux
- Are RWD models more in demand than AWD ?
- 4th gen gs350 WONT START HAS P1604 DTC
- Smoke odour removal
- Compressor Control Valve
- 2013 gs350 tpms
- 2015 GS350 RWD Stablizer links from MOOG
- P0894 Code GS350 F Sport
- 2013 GS 350 F HVAC problems
- Performance upgrades?
- Where is our friend ItzFilyO?
- Replacing rear shocks
- Under-Torqued Spark Plugs
- GS F Sport Japanese Import 2013 rapid indicator adjustment not working.
- 4GS Rear bumper cross reference part numbers under JDM
- How to troubleshoot brake making noise?
- Lexus Suite Apps / 2016 GS 350 F Sport
- Where is the most ecomical place to buy GSF bumper?
- Cheapest place - 2015 GS350 Tail lights. Please help
- Is the GS a good family car?
- IDLE MAF G/S Readings
- O2 Sensor Bank Identification
- Radio diagnostic mode
- 2016 GS 350 / F SportEngine Cover
- Wiper Stalks Not Working
- Do you like my gs f floor mats, what gs f floor mats available in USA?
- HUD, Android Auto & Triple Beam Questions
- brake rotor
- Newb Question: At what intervals should we be really replacing engine air filter?
- Embarrassing brake squeal
- What Would You Buy???
- PCV value Replacement
- GS350 Still suffer from timing cover oil leak??
- Cigarette Lighter Not Working
- Transmission Issue after Transmission Fluid Change
- Remote Start & Car Shutting Off At Door Open
- Couldn’t quit the GS
- Conflicting info on Spark Plug change interval? Do I need to change at 60k miles?
- Is it generally safe to get spark plugs changed at a toyota dealer or generic shop?
- Plowed into & hit a wall on the freeway; God and my 2010 Lexus GS350 saved my life
- Gs450h 4th gen do i need car geometry alignment after shocks replacement?
- IS F Sport BBK on GS question
- Airlift Height Sensors Install Advice
- Does anybody know where this is from?
- Conflicting Oil filter info for 2015 AWD GS350 (heard YZZA5 vs YZZA3, and 6.8Qts?)
- New clock - is thi scounterfeit?
- Dome light not automatically on when door opened
- Thinking of adding a touchscreen in front of the current screen
- GS 2016 Rain Sensor
- 2013 Lexus GS 350 RWD Trans Filter and Gasket from Rock Auto
- Show your black GS?
- 2015 GS350 AWD wheel grinding/squeaking noise help
- Camber issues
- Aftermarket parking sensors?
- Coolant bleeding procedure for 2016 2GR-FKS
- How long do your tires last?
- RC300 seats 2017 F sport option
- Base model KYB vs. OE
- Grom Vline VL2 vs VLite
- '14 GS with 140K?
- Trying to install a F-Sport CAI top lid from an IS350
- New Wheels
- Replacing brake pads and rotors
- Turning drl on manually?
- Just purchased 2018 F Sport - 30 days to keep/return
- Curb rash touchup on 2016-20 factory 18” rims
- How to troubleshoot key-fob not unlocking driver door?
- 20x9 squared with RWD
- Gs350 headlights help
- Rear diffuser finally installed
- Should I buy it back?
- Door body weatherstrip
- Green GS350
- Sold My GS Today and Stayed w/ Lex
- Front and rear camber adjustment parts - Megan, Suspensia
- 2018 gs 350 f sport makes turbo spooling noise before car is warm. Whats the problem?
- Modifying Vehicle's Wheel Setup or Stance w/ Aftermarket Adapters/Spacers
- Rear spring rotation/orientation.
- DIY - How to repair a broken bumper
- Clock Running fast on my 2012 Lexus Gs
- How to open trunk with 12v Battery dead - gs$50H2017
- Is there a DIY to remove the rear bumper cover
- Using Roll Center Adjusters for Subtle Front Drop?
- Reliability
- Exhaust
- Front camera
- Fuse Box Troubles
- Mud Guards
- 2014 GS-350 AWD 3.5L idle
- Intrusion alarm in front dome light area?
- Alarm indication : check awd
- My other seat broke , please advice is it like that?
- Rear Shock replacement
- Weird steering behavior, sticking
- The need to speed…….
- Wheel gap solutions
- upgraded start button
- Creaking center console - fix attempt
- 2013 GS350 Suspension Torque Spec
- 4GS exhaust/intakes specifically for 2019 (AWD)
- Considering a 2019 G70 to Replace 2013 GS 350 AWD
- Front Left Window Motor
- 2015 GS350 ML Stereo ASL feature doesn't work at all
- Menu and Navigation buttons don't work and climate control error
- Fixing the B Pillar Journey
- Front bushing or suspension noise on gs 350 fsport
- Lexus Gs Seibon Hood?
- 2014 Lexus GS Roof Rattle
- Front Strut Mount
- Orange Brake Calipers
- 2016-2020 4th GS side F Sport emblem position
- RSR Springs & 20mm spacers
- 2018 F-Sport AWD Rotor Part Numbers
- Gas cap issues???
- Bosch AGM Battery review
- How to upgrade headlights to the 3-projector version
- Did you know the dimmer switch also controls the ambient lighting?
- Trunk Parts
- Bluetooth connectivity issue
- No air blowing coming from the center dash vents.
- 4GS parking sensor color
- Tire Help on GS350 F-Sport
- How do I fix this thing?
- Apple Car Play
- Avs Connector not plugged?
- Rear Diffuser for GS 200T (non-f sport model)
- Problem with Outside Air coming in even in Air Recirculation mode is set
- Wheel offsets need help
- Lexon front lip and sides for a 2019?
- Coin Holder PN55450-30060-C0
- Modern Lexus paint soft?
- Trying to remove ECU
- Extended cold start run time?
- Lower ball joint replacement
- What are some options to get an additional key fob?
- LED Lexus Door Lights
- Tires and pads for track
- Rear AC not blowing air
- On dash Apple Carplay Solution
- Which Spark Plugs?
- Transmission Shifter Sticky
- What is your average speed and lifetime MPG?
- AVS and techstream
- P0304 misfire
- GS450h aftermarket brakes
- Regarding the data I saw about EMPS using techstream, I don't know if this is correct
- Oil separator for oil burning ? YES-NO ?
- Remote start replacement
- Driving in manual mode all the time - good or bad for transmission?
- Larger wheel size - difference?? - GS 350
- Just got 2016+ front bumper and have fender liner ? (Also have gsf fenders)
- Good Video - What fuel do you put in?
- Performance difference 13-15 vs 16+
- What is the "Crafted Line"?
- Tire suggestions
- Power steering issue - need help!!
- Does anyone else's GS350 shift a little hard 1-2 in sport mode?
- The SOS light
- Headlight died
- 2015 Fsport Fog lights
- Rearview Mirror teardown
- Buying a 2016 300h f-sport?
- Exhaust flange broken - ideas?
- Check Park Sonar System Message
- Anyone we know? :P
- 120K mi service / Lexus dealership
- Replaced Right Outisde Mirror - BSD Errors
- 2015 GS350 Luxury package vs F-Sport - Which should I buy? (Specs in post)
- 2013 Lexus GS 350 RWD Trans fluid change filter
- XXR 527 Chromium Black Wheels
- Help with rim upgrade
- Splash shield part number
- YouTube video about GS350
- About to pull the trigger on a GS
- 2015 GS-350 F-Sport Scraping Sound
- BBQ Tick on GS 350?
- Remote Start Time-Out
- Passenger Window Replacement
- GS250 - Startup and oil consumption
- Hvac /aircon system, clogged doesnt with big particle...
- Deeper bass for basically free
- New Anti Sqeal shims & Lube question
- Steering rack / Bushings / coilovers question.
- Spark plugs - new or aftermarket?
- Happy 10th Birthday Lex 4rth Gen GS!
- 2014 GS 350 TV display split screen issue
- Best model years for under $25k or so? Any years to avoid?
- 2013 GS 350 F sport 2, 3 5 cyl misfire
- Gs450h mark levinson, Multimedia cant read my usb flash drive fat32?
- Multi-Dispay Half White, Audio Works
- Clock 3 hours ahead after replacing battery
- Candian vs US 4GS
- ISF 2007-2014 Rims on GS mkIV
- Oil for track use on a 2015 gs350
- BRAKE PEDAL STROKE Sensor
- Control arm bracket offset 0 or 20 ??
- Hello GS Fam !!
- F Sport exhaust
- Exhaust set up
- LED Puddle Lights Brand/Part#
- Stripped Torx on Sunroof
