- GX470 Instrument Cluster dead
- Seat belt compatibility
- Too rusty?
- Rear AC delete caps
- Redstoney
- Sunroof Glass Height Adjustment
- Window master control
- Drano in the sunroof drain, it works...
- 2003 gx 470
- Disable / Ignore Spare TPMS
- Weird Sounds from the dashboard 2004 GX470
- AC Leak Detected - how to fix
- 2004 GX470 Navigation wiring
- Braking issue
- Help with possible transmission problem
- Blower speed acting up
- Buying a 2008 GX470- Need suggestion
- Do I need a first Gen GX? Do You?
- Hydraulic Brake Hose Fitting Size and Advice
- How much shake is normal immediately after small bumps at high speed?
- 2004 GX470- Radio no Volume control
- Steering Rack Replacement
- new in town
- Want the stock suspension feel back
- Nav/Non-Nav Conversion
- Your One Stop Audi Parts Dealer!
- VSC TRAC/ VSC OFF/ CEL all lit
- Front end vibration when brakes applied
- 2004 GX 470 Frt Seats Yea Another?
- Vibration when driving
- Where to buy dashboard
- Steering Lock Disabled
- Problems with Lexus GX470 (oil leaking, screeching)
- Torque Spec for oil filter adapter
- Tension Pulley
- GEOLANDAR® A/T G015’s ride great!
- Possible Lexus Dealership Timing Belt Scam
- Problems with fuse controlling reversing light, turn signals, and airbags
- Lowering, Yes, Lowering
- Battery, again.
- Fog Light Assembly Replacement Options...
- Cheap Center Vent trim pieces
- Seat Covers for 2006 GX470
- Steering wheel shake and loud noise when accelerating
- GX 470 Factory Radio w/ Navigation
- 2005 GX470 Sport-Non Nav Price
- GX470 Rally Lights
- 2009 GX 470 Engine Noise
- 2004 GX 470 Creaky Steering Wheel / Noise Coming From Behind Dash
- GX Aftermarket Radio
- 2009 GX 470 Upper Radiator Hose keeps coming off
- FAQ/SEARCH-Maintenance/MODS/Repairs/Diagnostics/Info/Service Campaigns/Recalls/OBD
- Towed Home
- Loose Rear Fender Adjustment
- Suspension parts torque confusion
- New Key for 2004 GX470
- Rear Wheel Bearings Replacement Story
- My first experience with disconnecting the battery
- Ignition key will not turn on 2004, GX 470
- 03 gx heater control valve replace and part number?
- Washer fluid pump wiring - 04 GX470
- Rear gate and dome light
- Uneven Air Suspension - Driver’s Side Lower Than Passenger Side
- metal clips that hold the courtesy door light
- Blown Motor - 09 470
- 4.7 tundra vs GX470
- Starting issues
- Window switch related battery drain
- should i sell
- LED Headlight Upgrade
- gx 470 in a ditch and broken drive shaft and more
- 2005 Passenger window issue
- 2008 GX470 front suspension rebuild
- Part number for this breather hose and DIY option?
- Part number for vacuum hose coming off power steering pump
- Gas Tank Size
- Help identify 2 leaking hoses
- Plated rear bumper, looking for advice on reverse camera relocation
- New Member! Buyers Help
- Stock Rear camera replacement. EASY
- Issue w/ center vents not blowing air (cold or hot)
- Amazon Tesla Radio?
- autonomy
- Is an 03 GX470 worth purchasing?
- Remote Starter
- At the end of my rope.....
- Rear wiper not working
- Help: Rusty 2006 GX
- Is there a recent thread on using switchback LEDs
- Radiator hose leak
- wipers gx470
- LED turn signal bulbs front hyperflash
- Underbody Rust Management
- Replacing upstream O2 sensor - CEL code P0051
- Broken wire
- Black Snake Moan - HVAC issues
- Luftmeister
- Sunroof failed!
- Are the short drain covers on top important to have?
- GX470 Driver Side HVAC
- red 2008 gx407
- Under front end plastic shroud/skid plate
- LowervOil Pan Gasket Leaking
- Seat swap '03 bucket seats in an '08 GX
- 03 gx 470 power still at driver side window switches after key is removed
- Small interior parts still available?
- What is the string that comes out of the glove box fascia
- 2009 Lexus GX470 LED recommendation
- Buying A half a million mile GX - Question
- Find lost key using chip?
- Gx470 updated radio.
- Tire Fitment With Leveling Kit - Need Advice
- Grom Vline Carplay
- My console rubber mat - options?
- help diagnose shifting problems
- Trunk carpet pad getting wet after rain
- New GX 470 owner- what should be lit up at night?
- Is there a way to manually control the rear camera?
- 3rd brake light replacement on factory rear spoiler
- torque specifications 2006 gx470
- 2009 GX470 ML Audio Stumper!
- Partial wrap to solve hood and front bumper chipping?
- GX470 shoppers - 2023
- 2006 gx470 -- replacing entire headlight housing on saturday! any tips?
- Window HELP
- Quality aftermarket exhaust
- Temp gauge will sometimes stop working?
- Leveling Kit
- Shocks and ride height.
- 2004 GX470 Interior dash and switch light bulbs
- Cargo door wont open
- Help with Radiator Hose / Hissing
- Brakes "Pressurization" on Start up?
- Shock replaced and 4x4 alignment
- transmission drain, fumoto valve and oil change
- Towing ~3K lbs at 1/4 million miles
- 2006 GX470- manifolds
- Transmission fill thru WS plug
- Pink fluid leak driver's side GX470 2005
- 2009 Gx470.
- Trailer Hitch Recommendations
- Error codes P0420 and P0430 (09 Gx470)
- GX470 vs GX460 Seat height from ground
- lexus gx470, about to buy with a 130k motor swap 5500$
- Possible Water Pump Leak?
- Lubricating Driveshaft Interval for Normal Driving
- Rear Wiper Refill
- 2006 GX470 -- Need these small parts recommendations + weird issues!
- FN Wheels vs TRD Wheels on stock size Falken Wildpeaks.
- Brake Booster / Squeal Noise Inside Driver Cabin
- Best replacement for windshield washer nozzles
- 2008 gx470 kdss
- Steering & A-Arms
- Bluetooth connection issues and GROM install
- Cannot get my blower motor to work.
- My '08 with ML/Nav is giving me some trouble.
- WTS - GX bits
- are gx’s worth the prices they are at today?
- air shocks or converter unit GX470 2004
- Prospective buyer questions
- front passenger seat track rattle in 2008
- Will these Denali Tires work?
- A/c compressor won't power up
- motor brush
- Low mileage vs well maintained?
- Transmission leather boot - ‘08 GX
- GX470 with GX460 wheels RUBBING
- 08-09 rear windshield chrome strip restore, replace, remove?
- Reattach rear view mirror
- Intermittent Starting Issue Following A/C Compressor Replacement
- Power steering hose fastener/clip - ‘08 GX
- GX460 Trans level check (Radiator just replaced)
- Axle replacement recommendations- ‘08 GX
- New to me GX - underbody pics
- Please help identifying some leaks..
- 2005 GX470 Repair Advice
- Clunking noise…can’t quite pinpoint it
- 1st gen GX plastic shroud screws
- Ignition Coils
- oveheating question
- 3rd Gen GX forum has been set up
- Radiator fill tube cracked
- 07 GX470 intermittent front end issue at low speed.
- Good Purchase? 2004 GX470 Sport Utility
- 2003 GX470 Front Drive Axle
- '08 GX...not a submarine...
- Zero acceleration when pushing the pedal down
- After Market Seat Fan Installation
- Height Control Off Blinking when Raise
- Alternator cable? Charging issue
- Lexus GX 470 2007-2009 - how to install VLine for CarPlay and Android Auto
- TRQ Replacement Headlight Lenses - Anyone Tried Them?
- 2005 GX470 Driver Side A/C 10 ° warmer than Passenger Side
- broken radiator cap retrieved, check your cap
- Jerk/Shutter at stop 2007 GX
- Started a few hours ago and now it’s dead
- wireless door lock buzzer
- Cam shaft sensor codes
- 2004 GX470 - Delete keys from immobilizer
- Replace 2003 GX-470 rear air bags
- GX 470 Battery Drain
- 2006 Lexus GX470 Second Row Seat Stuck
- Noise when in drive and stopped
- Transmission and front/rear differential fluid
- newbie Wheel Question
- Stripped front diff drain plug
- LS or no LS for Gear Oil???
- Total capacity of gear oil?
- Buying a GX470 (Auction)
- Service in Oregon
- Lexus Repair near Corvallis Oregon
- Newbie - Lift / Tires
- 2007 GX470 Misfire Help
- Need a good place in New Jersey for Lexus service
- Location of VVT Solenoid Actuator Filters
- Leave or remove exhaust manifold/cat when pulling engine
- Remove dvd headrest 2007 GX470
- Auto tilt / telescope not working
- Will 17" Tacoma Wheels Fit?
- Overhead RSE Needed Parts
- 4Runner Wheels-Help!
- Newbie Question...
- Buying and pogramming new key...
- List of greaseable parts on the GX?
- 2008 suspension update time need input
- Is there a common cause to this group of codes?
- Suspension Conversion and Leveling
- Troubleshooting 05 GX470 Air Ride issue
- 2006 gx470 radio display not showing and radio buttons not working
- P0125 Code
- Maintenance calendar stops at 2022 WTF
- V8 4runner vs gx460
- Gx470 p0500 speed sensor
- Best Modern Stereo Upgrade for 04 470 w/OEM Nav?
- GX470 maximum wheel offset
- GX470 - Battery appears dead until you open and shut the drivers door.
- Gx470
- Brake Recommendations
- 2009 gx470
- Interior Colors
- Valve cover gasket replacement cost
- Shops in North Texas to lift my GX
- RIP, Soichiro Toyoda
- 07 GX470 w/Rear AC Pag Oil Capacity
- GX470 Interior Color
- 2009 GX470 - Bluetooth Inquiry
- Looking to swap out ugly old tan interior
- P/N for Trans Cooler Hoses to Radiator
- First I've heard of this happening
