- Considering buying a 2008 GX470, but possible trans issue
- GX470 Air Suspension
- GX470 intermittent noise- like starter ignition
- Shift problems
- Speedometer and gas gauge work randomly
- Some serious strangeness with my 07
- Naiv/Radio/Climate issue
- rear differential - replace bearings
- Need some advice, possibly buying a GX
- name of the rubber seal for cv axle....
- Ruger 2011’s GX 470 Build
- oem toyota lower ball joint part numbers?
- Model comparison ‘05 vs ‘06
- Add Navigation System to Base Model
- 08 GX470 223K miles should I fix the AC
- Where is native Bluetooth speaker for GX470
- 100k maintenance
- Rear door saggy net solutions?
- Backup Camera Connection
- GX470 Towing (2006) - pictures?
- Black rod coming out of inside RF seat track?
- GEN 4 to GEN 5/6 Upgrade
- Just bought my first GX. Have at it!
- Gx470 keep or sell
- Kdss as the source of a faint clunk/knock?
- Where to find ABS ECU 2004 GX
- recommendations for trans oil change/flush
- transmission fluid change?
- lower ball joint replacement
- Tune-up - What to replace?
- electrical issues - different inside cabin issues
- Seat pocket repair for my $5k GX470
- Installing an aftermarket amplifier
- Replacing '03 Nav Unit to CarPlay compatible?
- Yellow/hazy headlights - polished today
- Diagnosis Thread
- Hood Bug Deflector
- Updating Map DVD
- Rear Wheel Bearing '06 GX470
- Cluster Removal and instrument bulb replacement
- Inside back door handle pulls out
- Peeling off
- Dead Battery and Won't Charge
- 24 or 27 Battery?
- New to me '07 GX470
- Steering wobble
- Passenger side exhaust manifold leak
- 2007 GX470 Transfer Case Change
- 200k, Install a Secondary Air Injection Bypass Kit as a preventive measure?
- check engine VSC lights on
- Subwoofer Distorted Intermittently
- Another Master Cylinder Question?
- GX 470 or LX470 for Overlanding?
- Help me find these TRD rims.
- 05 Sport GX - KDSS sway bar bushings
- New to Lexus Family from BMW/Audi
- New Guy with 2004 GX470
- drivers door window wiper
- KYB shock part#
- Broken wire
- Possible New Purchase
- Extreme cold caused alarm to go off?
- Noise coming from the engine when driving
- Air suspension trouble
- Post-repair compressor start-up
- Lexus Performance SUV?
- FJ cruiser control arms on a GX?
- 04 gx470 approaching 200k-concerns?
- A few problems
- Installing 10.1 Android Radio on GX470
- Shifting at LOW rpm's
- Scratchy noise behind glove box
- Replace gx air filter
- thinking about swapping out my rear 5100s...
- Ticking noise in brakes - around absorber control actuator
- smoke from oil cap
- 05 KDSS coil conversion issues
- Wheel help
- Fog lights wont turn off... HELP!
- San Diego Indie Shop
- I have an Air Suspension Issue - Sucks
- New GX470 (to me). What should I do first?
- Can anyone Verify this leak
- ?s re locks and lights on 04 GX470
- Loud popping sounds when the front wheels are extremely turned
- Safe to drive without air suspension inflated?
- Door locks 2004 gx
- Wiring connections for driver side knock sensor
- Best way to replace T-nut for rear license plate screw?
- Advice please
- Lower Control Arm Cam bolt parts?
- 2006 with a transmission issue
- Opinion Needed: Icon Vs. Radflo
- South Florida Trail Riding
- Need Mechanic in DFW to Replace Timing Belt, etc...
- Cv boot rip
- Spare key
- Code P1442
- 10W-30 Oil for my 2004 GX470
- 05 Sport GX - Rear leaning to left
- Dashboard Compatibility
- Changed Battery Now brakes are gone...
- Tailgate won't open
- 285/70R17 KO2 on Stock GX470
- GX470 Change Units from Imperial to English
- no sound in rear dvd system (mylon/davis)
- Newb Just purchased a 2008 GX470.
- Cracked dash panel, DVD reader advice
- Bulb Size Chart
- GX470 Rear Suspension bottoms out sometimes over speed bumps. Techstream IMG attach
- Need a new dash.. but where?
- which CD / Navi to replace stock cd?
- Some sagging after sitting parked for few hours - time for new airbags??
- Service at 11yrs/24k miles?
- Did i install the wrong Bilstein 5100 shocks on my GX470?
- Clicking noise when braking
- Heated Seat Upgrade, Need Schematic
- Average cost for a brake job
- GX470 Air suspension works by itself, a problem or not?
- Blower motor change
- Rear coil spring height question
- Stuck sunroof
- traction control sound
- Clock Buttons Not Working
- GX470. Change miles to km in display ODO
- 03 gx470 rear suspension air compressor
- Exstending drivers seat in the 2007 GX470
- Engine Swap
- Dealer recommended services
- Have you seen this error message?
- 2007 GX470 rear suspension
- No audio sound
- Leaning. Suspension ecu?
- 05 Gx470 Starting issues and Dying when put in gear
- Drivetrain Whine @ Highway Speed
- Cold draft passenger wheel well 2005 GX470
- GX470 - whining noise.
- What’s this noise?
- 2004 GX470 - Navigation Disc HAWAII
- best all season tires for gx470
- Rear video screen will not turn on automatically
- Battery died, now car alarm goes off after charging battery
- Update maps on 2008 GX470
- Buying 08/09 GX...need help
- my blower quit working. fuse?
- Turn on Sub-woofer
- Radiator Leak
- Crazy Electrical Behavior
- New Guy to the Forum
- 2004 GX470 Transmission cooler line weeping
- Found 3rd row headrest. It’s hidden!
- Considering a purchase
- 6500 - 7500 mile oil change interval?
- Emergency Brake Won't Catch
- Lexus GX 470 - There is no Audio
- 05 suspension changeover
- SAIS Bypass Installed but I still throw codes
- How to replace my GPS DVD 2004 GXT 470 where is it located
- Front body dive - can it be fixed?
- ** Current part numbers for Bilsteins for the GX470 **
- New to GX - bought 2009
- 08 GX470 climate control acting up
- Running board bulbs?
- Brake, vsc, abs light and buzzing sound
- Deal on a 2006
- 0 mile range
- 2006 GX470 rear suspension questions
- Maintenance required light
- Burning smell after timing belt change
- navigation screen
- 04 GX470 Rear View Camera Broken - System check, camera = ok, audio h/u chek.
- Dobinsons lift kit success
- 2005 gx 470
- 2004 GX470 Steering U-joint
- 2008 GX470 brake pads
- low beam and drl are not working
- New GX owner, factory all season mats?
- 05 Lexus GX470 Stutter/Surge/Hesitation/Hiccup
- Tire pressure monitor alarm threshold
- Spare tire size
- part suppliers
- Beeping Noise
- Door Lock
- Trade 2008 RX350 for 2006 GX470
- Sun roof clog
- Bilstein 5100 front shocks with KYB SM5640 mounts
- Pump sound from right side of dash
- Found discussion on location of horn relay for 2003 GX470 location never defined
- Nav or no Nav
- Another 2004 GX with Shocks\Springs issues...but it's all been replaced
- Will the stock DVD integrate the Phoenix head unit
- Dunlop AT 20's
- plastic firewall nut
- Radio upgrade
- OEM wheels and tires for sale!
- For sale threads post in marketplace only
- Battery might have been issue
- Dank musty smell rear carpet
- Ol' Honey-dip!
- Lift time
- Trd pro wheels on gx470
- Reprogram locks
- 04gx470 nav update
- 07 Gx470 Lower Console Noise
- 2008 GX 470 belt idler/tensioner noise
- 4runner wheels with AT's
- Wet back carpet
- 07 Gx470 Running Board Light Help!
- For those that have installed GX460 calipers/rotors on GX470...
- 2004 lexus GX 470 door won't open
- 2003 GX470 AC system not working
- 2004 will not start
- One Master Key Suddenly Not Recognized By Immobilizer in 2008 GX
- Damper Step changing?
- Need help with GPS Antenna
- New Jersey to Grand Canyon/Vegas road trip
- 05-07 Tacoma WeatherTech front Liners
- Front License Plate Bracket
- GX470 rear tire mount
- Plethora of electric issues after sunroof leak
- 2018 4 runner wheels on 2004 GX470 will they fit
- AC on passenger side only.
- Would you buy a GX with 300,000 miles?
- Wood trim on dash & doors Swap
- Chrome wheel
- just bought 05 gx a few questions
- Rear air shock replacement instructional
- 12v and ground wires for radio
- crackling sound
- Side mirror question 1st gen 2004
- Power on Without Key Inserted - cranks but will Not Start
- How to replace headlight assembly on 2005 gx 470?
- DVD not working
- 2012 Switches next to shifter
- (25/9)
- Phoenix Android Radio users - NEED help!
- stereo wiring, with nav and rear dvd
- Help with the Tire Pressure Warning Light
- Tire Recommendations
- Hissing/buzzing sound from the rear?
- Parking brake issues/replacement
- 2007 gx470 hands free
- Proper Way to Drain Coolant
- Anyone have access to a few labor time or estimates?
- WTB: Mark Levinson Front Door Speakers for 03 GX470
- 2005 GX 470 Questions
- Peeling Paint and Cracking Speaker
- Mystery connector
- Curtain airbags & going off-road
