- 4WD newbie question
- Intermittment humming noise
- Transmission problem(?)
- BFG tire options for stock GX
- Where do you guys go to buy OEM parts?
- Will these 18" 4Runner Limited wheels fit my GX?
- 3" front lift and 2" rear lift like the 4Runner?
- New owner
- Navigation screen issues
- Timing Belt Kit
- I need your help with arm brake
- I need a painted 3rd brake light cover...
- How do I know which bearing is bad
- What did you do to your GX TODAY?
- Grind when putting in 4wd mode
- Instructions for Map Update (2006 GX470)
- Battery problems
- Dome light / Garage Door Opener Short
- 03-04 vs. 05-07 Model Years
- Old/New GX470
- hit from behind, can someone help me find a part?
- Height control - what's the point?
- Transmission 2004
- Catalyst DTCs P420/P430 w/ VSC issues too
- Auto Door Unlock
- loose fog lights
- GX Left side passenger door issue
- Voice Command for Heat on GX-08
- 05 Alternator Diagnosis
- 2009 GX Buyout
- Snow tires and wheels, should I bother with TPMS sensors?
- Please help! New clunk, new place.
- leak coming from under car, HELP!
- Convert 2005 GX 470 to Push-button Start?
- GX jack tools part# needed
- New 2006 GX470 owner- only 12v up front?
- blinkers
- Super Low Miles
- Full Stereo Upgrade-OEM Parts available
- Tweeter Rattle Problem/Door Panel Removal How to with pics
- Maintenance light problem
- Parking Brake wire on 2005 GX470
- new shoes - t4r 18's Nitto Crossteks
- KDSS vehicle on Ebay 10/23
- New guy.
- Just wanted to say Hello and Thanks
- GX470 speaker replacement/sizes
- TPMS Sensor what to do?
- tires
- Water Stains Rremoval on Windshield
- Gas cap tether
- GX 470 Stereo Upgrade Options, Non-NAV
- Aux Input
- Buying a GX470
- Xenon Home Depot HID failure <24 hrs!?!
- Yet other reason to change your own oil
- Tire sensor
- Advice for Possible buyer/BT Pairing?
- Is Excessive Rust on the GX 470 Undercarriage/Suspen./Brakes a sign of problems?
- low tire pressure sensor
- Early Season :(
- double wide armrests modification from jjproducts
- VAIS SLI2up install?
- H3 HID foglight help
- diff/transfer/tranny fluids, propeller shaft, etc, etc
- New TSB?
- Help Please!!! VSC, VSC Trac, Check Engine Lights On
- Air suspension replacement question
- 2011 4runner SR5 wheels?
- Pirelli Scorpion ATR tires any good?
- Service manual
- Please helpp!!
- Please help
- Uh ohh
- New member, new GX
- 17" Tacoma Wheels on GX470??
- GX Rear Cup Holder
- 2007 GX470 70K, Price Question
- Dealer oil changes - going to do it myself now
- Wierd 110 volt outlet question
- Help with RSES / rear seat entertainment system
- Passenger Seat Vibration
- advice on buying a 2004 Gx470
- 2005 gx470
- KDSS worth it?
- When did KDSS start?
- Fair price for a 2007?
- When did bluetooth start?
- Xenon bulb 6,000K or 4,300K
- I need Help! Anbody near QUEEN CREEK/GILBERT (Phoenix) AZ?
- OK what gives? (Fuel economy)
- VSC/Trac off lights came on???
- POLL: Ride Quality of GX
- Steering noise??
- 04 GX Engine Filter replacement
- Turn rotors on 2005 GX
- Service Indicator Light - which service is due?
- anyone good at photoshop?
- CV Boot Replacement or Repair
- Cold air intake for 2009 gx470? will 2006-2009 4runner intake fit?
- Sat Radio Activation Question
- Disable Bluetooth?
- Years to stay away from/cost of repairs?
- New GX Owner
- OEM "Pintle" Hitch Questions
- Please help, weird clicking noise near the key / AC area, video inside
- ? about extended warranty and Battery
- Buzzing noise behind glovebox at start up
- cd won't load
- iCarKit for iPod using the tape deck input
- Removing Instrument Cluster
- Prado Tail Light Swap question
- Brakes Squeaking
- Squeaky suspension 2005
- ? where to purchase some skid plate bolts
- cold air intake
- Tires Sensor battery life
- Warning Lights On
- surging transmission
- Warranty is ending soon
- Front Doors will not Lock
- Deterrent Theft System
- front cup holder, does it adjust?
- Replacement Headphones - Which will work?
- Wind noise
- Need Help ASAP lights and check engine on???
- Window is not working----HHHHHelp !
- DIY, Bank 2 Sen 1 O2 sensor replaced
- New 03 GX470 - Headunit Question
- tinted windshield
- Best place to buy OEM shocks
- Maint Req. light-can it be changed for Synthetic?
- 1st Towing Experience
- suspension issue
- 2004 GX470 Bluetooth/Iphone Aftermarket Products - Is there one that works?
- Replace key w/ flip key ( from ebay ), can't start the engine :(
- GX470 door lock actuator motor repair
- where is the connection to the power amplifier?
- Largest tire size on stock GX suspension
- Rear suspension not airing up
- Considering used GX purchase; help
- How to install factory roof racks 04 GX470
- Any Lexus-specific salvage yards?
- New 05 GX470 owner - mild off road pics
- 03 GX470 new owner with questions on common problems
- GX 470 Trasnsfer case issues
- Tires Cuping After 5000 Miles
- Good Deal on a 2006 GX470?
- DVD Override/ Nav 08
- Fairwell Lexus Forums
- Front shocks???
- 1st day with 08, suspension question
- Substitute for Trailer Wiring Harness 82169-60050?
- coolant leaked all over engine...
- NEW clunk please help
- 2005 Gx470 Buying Advice
- How much should I offer for 2008 GX
- TRD Performance Brake Components
- 2004 GX470 Questions-Voice Command and Brakes
- Reputable HID bulb failing after three hours of burn time?
- went offroading today...just hope my GX is fine!
- 2004 Lexus GX470 No sound from radio, help
- OK KIDS..........interesting new problem :-/
- Need help asap.......air suspension related
- Radio Turning Off
- 07 Wheel Corrosion question
- mirrors stick
- no sound coming from radio/tape /disc
- 07 GX sport package?
- Which Trailer Wiring Kit?
- front engine cover
- Which HID kit to get for the GX?
- Michelin Latitude Tour
- Replacement tires?
- Fuel filter replacement DIY?
- Toyota Dealer Service
- Weird electrical problem...
- Power Steering Fluid Flush
- Advice on GX purchase (from RX 300 owner)
- "Floaty" ride in the front suspension
- 2005 GX Sport : just bought
- New GX Owner
- 20" Ballistics with Nitto Geograppler 265/50-20s
- Update on after market/Iphone interface
- Plastic Tab Above Gear Shift
- 2005 GX470 shaking while driving
- Can you put 2 boosters 1 car seat on the 2nd row seat?
- timing belt.. backwards?!?
- 06 Does the DVD player in center console play mp3?
- Used '06 Navigation
- Dealer Problem!
- 06' Rear screen question
- After market Stereo
- CD Changer: Help: Newbie
- Outside Temperature Sensor
- Act of generosity from a fellow GX owner...
- 35% tint over factory tint
- DVD won't play through car speakers only wirelss headphone
- Threads moved to Classifieds
- Stuck DVD
- Nut/bolt size for fan pulley assembly, etc.?
- New '08 GX Owner with questions
- Do you use the running board?
- Sunroof Rattle/Tranny Slip
- Questions on Brakes and other
- help! locked out and i have the key :P
- Timing belt
- hid kit color????
- Hubby's replacing brakes do any of you use brake quite
- Lexus Corporate Agrees GX Windshield Is Defective
- New 2007 GX470 Owner
- Brake replacement suggestions
- aftermarket brake shims
- Rear Air Suspension Issue
- Rearview Mirror unglued???
- Axle boots leaking?
- Where this HID kit (fog light) cable supposed to go ?? i searched
- Engine cover and cago net clip
- Should I buy 2008
- 2004 gx 470 no sound
- Entertainment System GX-470
- CPO - what condition are the tires in?
- Navigation Unit Upgrade
- A/C issue - can't see dye from leak
- Question about brake pads?
- Steering wheel vibration/shaking on 2004 GX 470 at speeds over 50mph
- Help replacing nut and ? on gear oil
- leather color code on '04 GX470
- Locking lug nut key?
- clicking noise when accelerating
- Just got a 2006 GX470
- Instrument Cluster - Led burned out?
- What is the Rear Tow Hook Cover part number?
- Passenger window won't roll down from driver side controls
- GX470 Fuel Economy
- Is it really synthetic?
- Input or change destination while suv is in motion
- How to disable navigation system caution message
- HID Kit Conversion
- Lets Talk Tires
- Parking Lights
- door courtesy light problem
- Roof rattle?
- LED installation
- Anyone tried DC Gold 8 ohm 6x9s?
- Is 6 months too long on lot?
- Black out tail lights and reflectors in bumper!
- Need help for a intake system!
- red out taillights
- Navigation Interface/Appearence Update?
