- rear shocks
- hypothetical price 04 vs 05
- Going camping...
- 2004 gx470 mark levenson 12 ? 14 ? speakers ?
- Introduction - new to me 04' GX
- Removing subwoofer grill
- Gx470 vs mb gl550
- Audio/Video Interface to connect iphone 5
- 2006 GX470 Intermittent VSC Off, ABS Lights On
- '04 GX Tire Pressure Alarm
- 07 GX come with trailer wire?
- Rear Cargo mat
- 2008 GX470...CPO or Not....
- Replacing struts\shocks (OEM Parts) what should i get?
- Wood Grain chipped around shifter
- Aftermarket Navigation System?
- GX470 Sub Info
- Restored my wheels with plastidip
- GX470 Sub Replacement?
- Just the TRUTH about wheel alignment
- Spark Plug change Re-set ECU ?
- Can i change the accumulator on on a 07 GX470?
- 2003 gx470
- need some help on rock rails
- 2006 GX "I AGREE" on nav screen
- 2006 GX470 coin holder
- Need some advice on a problem.
- LC120 Wheel upgrade inputs
- How to remove driverside door panel on GX 470
- Buying a GX 470 - what to expect in a 100k+ truck?
- Power window problem GX 470 (2003)
- HID 5K or 6500K
- Small amount of smoke after new rotor and pad install
- Can you just install new front caliper dust boots?
- 2000 LC - $6,000 or 2005 GX470 $14,000
- 2007 gx 470, keep/buy/refund/advice
- 2004 GX - visible airbag casing on steering wheel
- Brakes lock up after washing
- 2009 GX470, Black, should I trade or sell privately?
- 07 GX470- Electrical smell from under hood
- 2003 lexus gx470 not running in drive but runs in 4 wheel drive
- 2008 - Dip in RPM after startup
- VSC OFF Light flash and Beep Alarm when shifting?
- Mark Levinson amp repair
- Rear Seat (Headrests) DVD Players
- Thanks GX forums
- 4runner tow hitch compatability
- GX 470 stuck in neutral between H and L
- Do you just deal with it or do you make....
- 2004 Finally the battery went out
- Can't get door panel back on....ugh!
- 2005 GX470 Grinding Noise from the Rear
- Lost almost ALL brakes (stopping)
- Buy this Used 2007 GX470?
- GX470 Passenger Running Board
- 2005 GX470 - Possible Purchase
- Fuel range indicator not working properly
- Need new tires
- Random cold start knock - in reverse!
- IOBD2 Wifi Wireless OBD2 Scanner for Iphone
- CDs won't eject
- Leather cleaning and crease marks
- help on aftermarket wheels
- brake noise--Maybe brake booster?
- Nav partially working
- My GX and Wifes RX
- Aftermarket Roof Mount DVD Hint
- Carpet Assembly - 6 gallon wine spill.
- 2003 Lexus GX470 - good time to trade it in?
- HELP!! 08 GX A/C Vents spitting out Charcoal Like Flakes / White Dust and Fibers
- Drivers side arm rest [ the one that moves ]
- Cabin filter
- GX Secrets
- Exhaust manifold ticking sound
- CEL - VSC and VSC TRAC Lights
- Impala Leaps into a prado (GX)
- gps dvd eject button
- Maybe I should get a cat
- Microphone for phone
- 2004 gx 470 dvd entertainment options
- 2006 GX470 SRS light on when engine hot-off when cold
- HELP!!! 2007 GX Drivers side floor soaking wet!!!!
- 2004 gx 470
- Map pocket repair
- height control
- A/C outlet specs?
- cost to refinish wheels
- Brake Squeal on new rotors/pads. Lets talk!
- A/C slow to cool down
- Driver Side Mirror Stays in Reverse Position
- manual gx470?
- Audio Adapter 2003 GX 470 W/Nav & ML
- no posting
- Bad A/C Clutch .. repair or unit replacement?
- Paint job?
- Fog light pin broken
- Towing light not working even after installing relays
- Soft Breaks
- Gx470 06 RSES DVD remote problems replacement
- 20" tire recommendation
- Exhaust Upgrade
- I found these online!
- Lexus using A-1 Cardone parts???
- Costco's Extended warranty on vehicles
- Slow start
- How to repair the pouchs on back of front seats?
- Tape deck upgrade/replacement NO kits
- o2 sensor location
- 2005 GX470 - A/C not working.
- rotors-oem or ebc ultrimax slotted (black)?
- Battery Voltage #'s
- Stuck in Neutral or limp mode
- Bilstein Shock by Arnott and Moog Ball joint repair, PICS!
- New to the Forum seeking advice on buying an 2003 GX470
- If navigation unit dies does it affect stereo cd player etc.
- Brake upgrade options?
- Tire Size on 20" wheels
- Easy exit
- Power Seat "Wah Wah" noise? And Lumbar Adjustment has a mind of its own.
- New owner of 06 GX470 - tips needed to make this baby last!
- Electrical?
- Battery light/electrical smell--Alternator
- back to let us soon
- Aftermarket Struts need to disable Adaptive Variable Suspension
- Hooking up a Galaxy s3
- Differences between Sport and Ultra Prem.
- Bluetooth system & Aux-in installation in GX470 COMPLETED
- keyless remote
- 2004 gx470 air ride issues
- Rear pad DIY? Caliper piston compression tips?
- Cigarette Lighter doesn't work when car is off
- Need Lower Control Arms: 05 GX470 w/KDSS
- ac vent tabs
- squeaking front seat
- Help w/ purchase - GX470, RX350, Sequoia, or Mercedes ML320??
- Name Your Best All Terrain Tires for the GX
- Feedback
- Rim Question
- GX 470 Mechanic
- sl2i iPhone cable
- 03 ride
- GX470 Transfer Case Actuator Seal Leak
- Henry Louis
- Procedure to remove map light housing
- Black Emblems
- Airbag Light Stays On
- Questions on Buetooth phone/audio install in non-navi 05' GX470
- Squeak
- Yakima Roof Rack - installed
- Slip tire lights blink on a hill...
- Help with 2003 GX trailer wiring...
- pics of custom sub gx 470
- Pics of Differential and Transfer Case Fluid after 63k miles
- HELP - GX470 gauges problem
- What is the average milage for transmission problems in a GX?
- Just saw an '03 GX with 266k miles. What is the highest milage GX that you have seen?
- Throttle Body and Power Steering
- How to deal with Hot leather seats in Texas
- Grinding noise coming from rear passager side while stopped
- Audio?
- Pics of GX460 F-Sport wheels on a GX470?
- Rear wiper arm removal
- Buying GX??
- GX470 Cargo Door
- New to forum
- KYB Shock Absorber GX470
- Timing Belt
- TPS harness clip fell off
- Rear subwoofer blown
- 07 GX with FJC Rims *Pic Heavy*
- Rear Wiper Blade
- Heated seats...is it just me or...
- LED Flasher GX470
- New Guy Here
- Speed Control T.S.B.
- Crickets
- Automatic Wipers folo
- HID Kit – Help on Decision Making
- Minor issues with my new (used) GX
- New to the club...
- Infiniti QX56 rims on GX470
- Sport mode?
- GX470 Drivers side window control panel loose
- Quick Newbie questions
- Can you replace just an AC Compressor Clutch
- ML350 ride comfort vs GX470 (experienced driver's only to comment)
- Squeaky A/C blower?
- Thanks for the advice for the leather seats.
- 07 GX 470 please advise on noise
- 05 GX470 Suspension question with error codes
- 2003 GX470 ABS lights needs Accumultor/Booster?
- Rear Air Conditioner Control
- For what it's worth if anyone is looking to buy an '07
- warped rotors and hwy steering wheel play
- Warped rotors
- Total Loss of Electrical
- 08 GX470 Vibration
- Running lights
- Aux audio input on 2003?
- New 2005 owner, manifold leak question
- 2005 GX 470 IPod Adapter
- Thinking of buying 05
- New Member - 2007 GX470
- Re-Locating oil filter
- PROBLEM: Rear Window Tint Film
- Thinking of upgrading w/questions
- Gas grade difference on GX? 87 v.s. 93
- 2005 GX470 Original Tires ?
- 2004 GX470 owners manual needed
- shock replacement
- Those who have converted the air suspension, please chime in
- Beautiful white lines on black paint
- Swaying Problem on 200,000 miles GX
- front axle boots
- dvd audio
- Gx470 2004
- rear mud flap
- Hitch-mounted cargo carrier?
- Adjusting headlight aim
- Inquiry on headlight
- 05 GX VSC OFF & Center Differential Lock lights on
- Transfer case leak
- Possible shock issue
- Outside rubber window seal replacement...
- Tip for fixing heat shield rattling on the muffler
- FS and WTB posts go in the classified forums only
- New member with a VX Prado not a GX
- Do I have KDSS?
- Towing hitch receiver
- 05 GX 470 95k- OBDii Fuel Economy Check
- 05 GX 470 - Android Bluetooth Playlist
- rear running board light loose?
- Is there a way to tell whether mt timing belt/water pump was changed?
- Value of 04 gx?
- Doors stuck in rear entertainment console GX470
- GX470: Tires, Wheels & Gas.
- Aftermarket rear camera issues/reverse light wiring
- Clunk when braking/accelerating
- Got Notice Mail /anyone class action suit ?
- Dac????
- Rear Door Door Stopper!!!!!! Haha!
- 18 F-sport wheels
- Passenger door lock not unlocking
- Loose brakes
- GX470 Power Stop Brake Rotors
- Suspension Problem
- Toyota Oil Filter Diameter for GX
- Found great deal on OEM rear shocks
- GX 470 Warning Lights VSC OFF, VSC TRAC, Anti Skid, Check Engine
- Overhead console sunroof homelink is not working anymore !!
