- Looking to swap out ugly old tan interior
- P/N for Trans Cooler Hoses to Radiator
- First I've heard of this happening
- Car Play/Android Auto for GX w/ Nav
- 2004 gx470 navigation drive
- Now getting upper ball joints/control arms done!
- rear door switch
- Rusty Frame
- My 2004 GX is gettin' squirrely when accelerating!
- Shifter Surround Lighting Inop
- Feedback on Aisin Ride Height Control
- Remote Door Lock Sound
- broken seal w/ oil leakage in flywheel?
- Max Tire Size for storage
- INFO- VSC TRAC OFF Codes P2445 C1201 HEWITT Bypass Kit Plates
- Potential 2006-2008 Purchase; Audio System Questions
- Upgrade 2003 GX Tow Hitch
- 470 vs 460 which is better overall?
- What is the market like for selling GX?
- Starter replacement...
- Needed: Split inner front CV axle boot 2009 -470
- Having same problems
- 2006 GX470 Navigation/Service updates
- Newbie. Any advice appreciated!
- TRQ Coils
- Skid plate over Cat
- Lexus mechanic in DFW area
- Transfer case grinds when shifting and center diff lock light blinks
- storing GX over winter/battery trips
- Attaching Body Mounts to Frame Due to Rust
- B1100 code
- Master Window control does not turn off and drains battery
- Engine taking forever to warm-up: Input
- HVAC issues
- Error Message: "Unable to reset this item. Setting possible up to the year 2022."
- Rust question
- Refreshing the suspension: part check
- Expert opinions needed - Considering 08 GX in near perfect condition
- Opinions on Tires
- Weird Buzzing sound
- 2008 GX470 Airbag Light Code B1153
- 2009 RX 350 Battery Constant Drain
- Body ECU connector identification
- How to check for leaking cam seal on Gx470s?
- All interior LEDs work, except Drivers side map light?
- Coolant re-fill after water pump replacment
- 04 Gx470 amp replaced still no sound
- Climate control codes 32/41/42/43/46
- Head Unit Upgrade
- 2004 GX470 - Multiple error codes!
- Remote Starter
- VSC off, VSC TRAC, and anti skid lights on
- Just brought home a 2006. First post.
- Help: Looking for the Wiring Harness Path
- GX470 back ac will not turm off
- 2004 GX470 Stereo Harness location help
- Sell or invest in my 2008 GX470?
- o2 Sensor Eliminator GX470 into the EGM harness
- high pitch sound cause
- Very Load ticking sound from behind dash
- Rear Brake trouble
- How to replace KDSS sway bar FRONT bushings
- bluetooth radio help
- Gx470 Fender flare clips
- Not all Climate Control Buttons Working
- Another Telsa screen thread
- Need Opinion!
- One headlight not working
- (09) Gx470
- KDSS front stabilizer leak 2005 GX
- GX470 OEM Spoiler Install
- Radiator replacement
- Discovered "Free Chrome" on GX 470 Grill
- Windshield replacement advice needed
- Coil Conversion Issues - Warning Lights on Dash
- Joining the GX470 Family
- Toyota Wheel Logo
- Electrical problem
- GX470 Transfer Case Actuator-Shaft removal
- Radio head unit upgrade
- Unstable Idle RPM When Cold, 2005 GX470
- Another Rear Coil Conversion Thread (specific to KDSS)
- Buying a 2007 GX470
- Stepping out on my GX
- 2003 Mark Levison IPOD (1st gen)? Connector
- New 6 CD Magazine, Player clicks and wont load the discs
- Brake Job
- AC Discharge Line Confusion
- Rims/tires help
- 2006 Lexus GX 470 rolling back in "D" on a hill
- Intermittent Start(s)
- 09 GX470 with Warning Lights on dash
- Terrible front end shake!
- 2007 GX470 HVAC vents TROUBLE SHOOTING SELF-DIAGNOSTICS
- Where do I find replacement window switches??
- Which Air Filter?
- A Bunch of Warning Lights???
- Maintenance Screen Past Year 2022?
- Where is the sunroof motor cable?
- Rear shocks
- O2 Sensor Removal, Help
- Factory headers and exhaust - are they stainless, aluminum or what?
- Timbren bump stops with Arnott coil springs - need advice
- Noob GX Owner and Forum Member, need a little help
- No start/ EFI relay battery drain
- Wipers (again)
- P0016 & P0018 CEL story
- Suspension Issue
- 2005 gx470 mark lev amplifier
- Gx470 Center Diff
- Window Master Switch LEDs stay on
- Anyone know what this is next to temp sensor?
- Gx470 EGR Valve
- 2006 GX470 Manifolds
- Lexus link system error
- Shampoo/Clean headliner and side pillars
- Blinking Maintenance Light
- New to me 2004 GX470 w/179k
- Catalytic Converter Cleaning P0430 P0420
- Need help with some decision-making...
- Steering column squeaking....how to grease?
- Getting ready for lift...what to prep?
- 2007 gx470 ac compressor new ticking sound.
- ATF Codes P2714 and P2757
- Driver’s Side Mirror Housing Loose
- Frame Damage and Busted Front Evaporator Core
- High fuel tank pressure
- Where's the Tube?
- Coil Conversion questions
- Ride control bulb replacement
- Electrical issue, battery dies, alternator replaced
- Just dove in...
- No FM or AM Signal or Sound
- Dimmed Dash Gauges
- Third Party Air Springs - Turning air inlet to RIGHT!
- Passenger window won’t come up(not initialize problem)
- Sunroof Automatic Control
- Rear Lower Bumper Trim
- Bumpy ride
- 2004 GX470 ABS Codes C1223 and C0215
- Replacing GX470 Mark Levinson Speakers Tips
- Prado OEM bullbar
- MY 2006 GX NAV/ML: Have BT? Radio Sound Settings forgotten, DVD Player maintenance?
- Replace the Central Differential actuator
- LEXUS GX470 (2003-2009) FOG LIGHT PACKAGE | Diode Dynamics | Vision Autoworks
- Wheel Refinishing?
- Hub Logo
- Brake fluid leak - stripped threads in caliper?
- Brake Controller
- Spending $24k restoring!
- Multi-Information Display - Adjusting Brightness
- Phoenix replacement radio
- After replacing solenoid, my gx can only go forward and not reverse
- GX 470 Sunroof Rattle
- GX Glove box dampener solution
- excessive heat
- Front wheel bearing question
- steering wheel tingling
- CV Axle Play
- My GX 470 Intro
- Shifting issues
- Help with knock sensors??
- GX470 A/C High Pressure Switch
- How quiet are GX470's compared to other Lexus models?
- Nearly perfect 200k mile 470
- Thinking of buying an 08' GX470 with 190k miles
- Low rumble sound
- Wheel bearing question
- GX470 - Pros/Cons of getting one
- Replacement Rack and Pinion due to leaking
- ‘07 Grinds gears between 3-4th gear
- New member here
- Misfire mystery
- LK01 Black Wood Interior Trim / Sport Package conversion
- OH NO! My Reliable Baby (2008 GX470) Just Left me Stranded!
- Hello all
- Replace Odometer Function/Reset Button
- Instrument Cluster Plexi Replacement
- Silly part number question
- Help! Christmas Tree lights on dashboard + key fob / central locking out
- Rate my Rust :) Is this worth buying?
- Help Diagnosing P0156 / P0158 Then Later P0051
- Dropped AC port cap...
- Air-Fuel Sensor
- 05 KDSS lean
- Rear Wiper stuck....
- 08 Problem with Gas Gauge
- 03 Lexus GX 470 Nav/Audio not working
- Non-Mark Levinson amplifer not working - Pioneer 86280-60291 Amplifier
- Strutmasters conversion and other adjustments
- 06 GX470 A/C codes
- warning lights VSC, ABS and Emergency Brake on
- 2007 GX470 randomly not starting.
- Shaking at idle (in gear) with foot off brake
- '04 GX470 Batt. replacement shenanigans
- Window Control Bezel
- Mechanic Sevierville, TN
- Radiator Pressure Test
- What does this part do?
- Gas Prices
- Car Covers
- Hewitt Tech Bypass Experience
- Please support 3DCarStickers
- Transfer Case Actuator
- GX470 Differential lift
- 2005 gx470 with ML Nav & RSE strange wire harness?
- Do I have a vvt-i engine?
- Rear brake caliper torque values
- Rear Door Won’t Open
- Rear Recovery Point Suggestions for a 2006 GX470
- 2008 GX470 towing assistance needed
- Change tires for a lift
- adjustable struts questions
- Volume Know not Working
- 2004 GX 470 Transfer case lights ( L N H ) indicator lights are all green
- Window Switch Lights
- Acceleration studder
- Transmission Lab results
- CD Changer Cubby
- GX 470 Facelift Idea Suggestion
- GX 470 Side Mirror Issue
- Chasing a heat problem - Passenger side cold
- Windshield washer not working properly
- 2003 Lexus GX470 - Power steering hoses
- All for sale threads belong in the marketplace classifieds only
- Satellite Radio Screen Issues
- Low AC Freon?
- Help Diagnose this Noise
- Wheel options
- Wheel options
- Weathertech Sunroof Visor
- Need your advice! First time buying a 2006 Lexus GX 470
- Oil Accumulator
- Mini Fuse seat fix
- Junction Connector Locations??
- How Many Miles Can A Gx470 Go?
- Interior Control/Button Removal
- 2008 gx470 just stopped running
- Replacing Drivers Seat Bottom - Instructions?
- 2005 GX470 buying tips.
- Rear door switch / alignment
- Audio Issues After Alternator Repair
- Matt rescues another GX
- 2003 GX470 Radio/Nav Unit Mess
- 2004 GX470 replacement GPS,Radio etc
- Buying
- Oil Filter base hoses
- Front suspension refresh
- Audio issues
- Climate Fan Speed Control Not Responsive
